cpsw 网卡驱动故障导致内核panic
Hi :
   我这里有一个故障,此故障在某些机器上可以复现,具体内核日志如下:
<5>[ 0.000000] Linux version 2.6.37_[et800_dm8148_V1.0.0_20180720] (root@user-R5300-G3) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #21 Sat Sep 7 20:54:56 CST 2019
<4>[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
<4>[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
<4>[ 0.000000] Machine: ti8148evm
<6>[ 0.000000] bootconsole [earlycon0] enabled
<4>[ 0.000000] [tanx] no reserved
<4>[ 0.000000] <buzh> arm_memblock_init _ 301 : Reserved mem (start= 0xB0000000,size=0x1400000) for boot_logo
<6>[ 0.000000] TI81xx: reserved VRAM size = 0x3200000 at 0xfcd00000
<4>[ 0.000000] Memory policy: ECC disabled, Data cache writeback
<6>[ 0.000000] OMAP chip is TI8148 3.0
<6>[ 0.000000] SRAM: Mapped pa 0x402f1000 to va 0xfe400000 size: 0xf000
<7>[ 0.000000] On node 0 totalpages: 363776
<7>[ 0.000000] free_area_init_node: node 0, pgdat c065f540, node_mem_map c06b5000
<7>[ 0.000000] Normal zone: 384 pages used for memmap
<7>[ 0.000000] Normal zone: 0 pages reserved
<7>[ 0.000000] Normal zone: 48768 pages, LIFO batch:15
<7>[ 0.000000] HighMem zone: 3710 pages used for memmap
<7>[ 0.000000] HighMem zone: 310914 pages, LIFO batch:31
<7>[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
<7>[ 0.000000] pcpu-alloc: [0] 0
<4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 359682
<5>[ 0.000000] Kernel command line: rootwait init=/init rw mem=192M@0x80000000 mem=1279M@0xb0000000 earlyprintk notifyk.vpssm3_sva=0xAFD00000 vmalloc=500M vram=50M initrd=0x81f06938,0x53255f nwhwconf=device:eth0,hwaddr:00:E6:D6:86:85:D7 ip=$(ipaddr):$(serverip):$(gatewayip):$(netmask):vct:eth0:off t8mnb_version=0x20003 t8vin_version=0x12001 t8hdeb_version=0x0 t8mode_version=0x0 bigphysarea=2000 debuglevel=3 enableconsole=1 log_buf_len=0x10000 watchdog=open dispmode=0 BOOT_VERSION=U-Boot 2011.06-dirty
<4>[ 0.000000] Get_Mac_Addr_From_Cmdline:: mac_addr=0:e6:d6:86:85:d7
<6>[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
<6>[ 0.000000] Memory: 192MB 1229MB = 1421MB total
<5>[ 0.000000] Memory: 1410396k/1410396k available, 95908k reserved, 1238016K highmem
<5>[ 0.000000] Virtual kernel memory layout:
<5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
<5>[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
<5>[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
<5>[ 0.000000] vmalloc : 0xcc800000 - 0xf8000000 ( 696 MB)
<5>[ 0.000000] lowmem : 0xc0000000 - 0xcc000000 ( 192 MB)
<5>[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
<5>[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
<5>[ 0.000000] .init : 0xc0008000 - 0xc003b000 ( 204 kB)
<5>[ 0.000000] .text : 0xc003b000 - 0xc060f000 (5968 kB)
<5>[ 0.000000] .data : 0xc0610000 - 0xc065ff20 ( 320 kB)
<6>[ 0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
<6>[ 0.000000] NR_IRQS:407
<4>[ 0.000000] gpmc_fck: 220000000arm_dpll_ck: 1000000000mpu_ck: 1000000000set_audio_pll_clock,4133,1
<4>[ 0.000000] set_audio_pll_clock,4137,4
<4>[ 0.000000] set_audio_pll_clock,4139,fa1c52e4=0
<4>[ 0.000000] sys_clkout1 clk_get successed.
<4>[ 0.000000] osc1_clkin_ck clk_get successed.
<4>[ 0.000000] set_audio_pll_clock,4156,fa1c52e4=7
<4>[ 0.000000] set_mcasp2_clock,4166,1
<4>[ 0.000000] set_mcasp2_clock,4170,4
<4>[ 0.000000] set_mcasp2_clock,4173,fa181548=30000
<4>[ 0.000000] set_mcasp2_clock,4177,fa181548=30002
<4>[ 0.000000] set_mcasp2_clock,4180,fa180384=2
<4>[ 0.000000] set_mcasp2_clock,4185,fa180384=2
<6>[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
<6>[ 0.000000] Total of 128 interrupts on 1 active controller
<6>[ 0.000000] GPMC revision 6.0
<4>[ 0.000000] Trying to install interrupt handler for IRQ400
<4>[ 0.000000] Trying to install interrupt handler for IRQ401
<4>[ 0.000000] Trying to install interrupt handler for IRQ402
<4>[ 0.000000] Trying to install interrupt handler for IRQ403
<4>[ 0.000000] Trying to install interrupt handler for IRQ404
<4>[ 0.000000] Trying to install interrupt handler for IRQ405
<4>[ 0.000000] Trying to install interrupt handler for IRQ406
<3>[ 0.000000] Trying to install type control for IRQ407
<3>[ 0.000000] Trying to set irq flags for IRQ407
<4>[ 0.000000] GPMC_CONFIG1_0(cc804060) = 800
<4>[ 0.000000] GPMC_CONFIG2_0(cc804064) = 40400
<4>[ 0.000000] GPMC_CONFIG3_0(cc804068) = 40400
<4>[ 0.000000] GPMC_CONFIG4_0(cc80406c) = 2000300
<4>[ 0.000000] GPMC_CONFIG5_0(cc804070) = 50406
<4>[ 0.000000] GPMC_CONFIG6_0(cc804074) = 0
<4>[ 0.000000] GPMC_CONFIG7_0(cc804078) = f41
<6>[ 0.000000] OMAP clockevent source: GPTIMER1 at 20000000 Hz
<4>[ 0.000000] Console: colour dummy device 80x30
<6>[ 0.000000] console [tty0] enabled, bootconsole disabled
<6>[ 0.003000] Calibrating delay loop... 995.32 BogoMIPS (lpj=497664)
<6>[ 0.022000] pid_max: default: 32768 minimum: 301
<6>[ 0.022000] Security Framework initialized
<4>[ 0.022000] Mount-cache hash table entries: 512
<6>[ 0.022000] CPU: Testing write buffer coherency: ok
<6>[ 0.022000] devtmpfs: initialized
<4>[ 0.023000] omap_voltage_early_init: voltage driver support not added
<6>[ 0.023000] regulator: core version 0.5
<6>[ 0.023000] regulator: dummy:
<4>[ 0.024000] fb0_info->fb_base = 0xccc00000
<4>[ 0.024000] enter logo_probe
<4>[ 0.024000] end load_data_driver
<4>[ 0.024000] end driver_init
<6>[ 0.024000] Can not found LOGO patition!
<6>[ 0.024000] Failed in logo_probe (ret=-1)
<6>[ 0.024000] logo_disp: V1.0_2011.07.11, Compiled at: Sep 7 2019 20:52:29
<6>[ 0.024000] NET: Registered protocol family 16
<6>[ 0.024000] OMAP GPIO hardware version 0.1
<6>[ 0.025000] OMAP GPIO hardware version 0.1
<6>[ 0.026000] omap_mux_init: Add partition: #1: core, flags: 4
<4>[ 0.029000] nand bw = 0
<6>[ 0.029000] registered ti814x_vpss device
<6>[ 0.029000] registered TI814x on-chip HDMI device
<4>[ 0.029000] ============= wifi_powerpin_init in ===============
<4>[ 0.031000] DEBUG: 00000630 0000727c 00000634 184b0ffc
<2>[ 0.031000]
<2>[ 0.031000] <tanx> : call ti81xx_init_pcie
<2>[ 0.031000] <tanx> Set PLLCFG for PCIE
<2>[ 0.031000] <tanx> config pcie type : RC
<2>[ 0.031000] <tanx> force_x1 :1
<2>[ 0.031000] <tanx> start register platform device: ti81xx_pcie
<2>[ 0.031000]
<2>[ 0.031000] <tanx> : end of ti81xx_init_pcie
<2>[ 0.032000]
<2>[ 0.032000] <tanx> : disable video_mux for muxmod
<6>[ 0.032000] registered ti81xx_vidout device
<6>[ 0.036000] Debugfs: Only enabling/disabling deep sleep and wakeup timer is supported now
<2>[ 0.039000]
<2>[ 0.039000] <tanx> Register platform driver: ti81xx_pcie_driver
<2>[ 0.039000] <tanx> Enter ti81xx_pcie_probe...
<6>[ 0.039000] ti81xx_pcie: Invoking PCI BIOS...
<2>[ 1.037000] <tanx> finish reset pex8112
<2>[ 1.037000] <tanx> : hw->setup
<6>[ 1.037000] ti81xx_pcie: Setting up Host Controller...
<6>[ 1.037000] ti81xx_pcie<tanx> Get reg_phy =0x51000000 for pcie registers
<6>[ 1.037000] ti81xx_pcie<tanx> Get pcie res0 : PCI Memory [0x20000000 ~ 0x2fffffff] IORESOURCE_MEM
<6>[ 1.037000] ti81xx_pcie<tanx> Get pcie res1 : PCI I/O [0x40000000 ~ 0x402fffff] IORESOURCE_IO
<6>[ 1.037000] ti81xx_pcie<tanx> Get ( ram_base =0x80000000 ,ram_end=0xffffffff ) for pcie inbound0
<6>[ 1.038000] ti81xx_pcie: Register base (reg_phys@0x51000000) mapped @0xcc818000
<6>[ 1.038000] ti81xx_pcie: <tanx> Enable pcie_ck.
<6>[ 1.038000] ti81xx_pcie: <tanx> set the link to x1 lane.
<6>[ 1.038000] ti81xx_pcie: <tanx> initiate Link Training
<6>[ 1.139000] ti81xx_pcie: <tanx> set outbound trans [0x20000000, 0x2fffffff] for pcie
<6>[ 1.139000] ti81xx_pcie: <tanx> Get pcie-irq: legacy_irq=48, msi_irq=49
<2>[ 1.139000] <tanx> : hw->scan
<6>[ 1.139000] ti81xx_pcie: Starting assign resource for PCI...
<4>[ 1.139000] Autoconfig PCI channel 0xcb897540
<4>[ 1.139000] Scanning bus 00, I/O 0x40000000:0x40300000, Mem 0x20000000:0x28000000, Pre_Mem 0x28000000:0x30000000
<4>[ 1.139000] 00:00.0 Class 0604: 104c:8888 (rev 01)
<4>[ 1.139000] Bridge: primary=00, secondary=01
<4>[ 1.139000] Scanning sub bus 01, I/O 0x40000000, Mem 0x20000000, PreMem0x28000000
<4>[ 1.139000] 01:00.0 Class 0604: 10b5:8112 (rev aa)
<4>[ 1.139000] Bridge: primary=01, secondary=02
<4>[ 1.139000] Scanning sub bus 02, I/O 0x40000000, Mem 0x20000000, PreMem0x28000000
<4>[ 1.139000] 02:04.0 Class 0604: 104c:ac28 (rev 02)
<4>[ 1.139000] Bridge: primary=02, secondary=03
<4>[ 1.139000] Scanning sub bus 03, I/O 0x40000000, Mem 0x20000000, PreMem0x28000000
<4>[ 1.139000] 03:01.0 Class 1180: 104c:b002 (rev 01)
<4>[ 1.139000] Mem at 0x20000000 [size=0x8000]
<4>[ 1.139000] Mem at 0x20008000 [size=0x8000]
<4>[ 1.139000] Mem at 0x20400000 [size=0x400000]
<4>[ 1.139000] Prefetch_Mem at 0x28000000 [size=0x20000]
<4>[ 1.139000] Prefetch_Mem at 0x28800000 [size=0x800000]
<4>[ 1.139000] Prefetch_Mem at 0x29000000 [size=0x800000]
<4>[ 1.139000] 03:02.0 Class 1180: 104c:b002 (rev 01)
<4>[ 1.139000] Mem at 0x20800000 [size=0x8000]
<4>[ 1.139000] Mem at 0x20808000 [size=0x8000]
<4>[ 1.139000] Mem at 0x20c00000 [size=0x400000]
<4>[ 1.139000] Prefetch_Mem at 0x29800000 [size=0x20000]
<4>[ 1.139000] Prefetch_Mem at 0x2a000000 [size=0x800000]
<4>[ 1.139000] Prefetch_Mem at 0x2a800000 [size=0x800000]
<4>[ 1.139000] 03:05.0 Class 1180: 104c:b002 (rev 01)
<4>[ 1.139000] Mem at 0x21000000 [size=0x8000]
<4>[ 1.139000] Mem at 0x21008000 [size=0x8000]
<4>[ 1.139000] Mem at 0x21400000 [size=0x400000]
<4>[ 1.139000] Prefetch_Mem at 0x2b000000 [size=0x20000]
<4>[ 1.139000] Prefetch_Mem at 0x2b800000 [size=0x800000]
<4>[ 1.139000] Prefetch_Mem at 0x2c000000 [size=0x800000]
<4>[ 1.140000] 03:06.0 Class 1180: 104c:b002 (rev 01)
<4>[ 1.140000] Mem at 0x21800000 [size=0x8000]
<4>[ 1.140000] Mem at 0x21808000 [size=0x8000]
<4>[ 1.140000] Mem at 0x21c00000 [size=0x400000]
<4>[ 1.140000] Prefetch_Mem at 0x2c800000 [size=0x20000]
<4>[ 1.140000] Prefetch_Mem at 0x2d000000 [size=0x800000]
<4>[ 1.140000] Prefetch_Mem at 0x2d800000 [size=0x800000]
<4>[ 1.140000] 03:09.0 Class 0000: 104c:9065 (rev 01)
<4>[ 1.140000] Prefetch_Mem at 0x2e000000 [size=0x400000]
<4>[ 1.140000] Mem at 0x22000000 [size=0x800000]
<4>[ 1.140000] I/O at 0x40000000 [size=0x10]
<4>[ 1.140000] Reserved PCI space for FPGA on BUS_3
<4>[ 1.140000] MEM [0x22800000, 0x257FFFFF) are reserved for FPGA GUI
<4>[ 1.140000] End of Scanning bus :ret =0
<6>[ 1.140000] ti81xx_pcie: busno=0
<6>[ 1.140000] ti81xx_pcie: Starting PCI scan...
<2>[ 1.140000] <tanx> alloc pci_dev for 0000:00:00.0
<7>[ 1.140000] pci 0000:00:00.0: [104c:8888] type 1 class 0x000604
<2>[ 1.140000] <tanx> PCI_DEV 0000:00:00.0: [104c:8888] type 1 class 0x000604
<2>[ 1.140000] <tanx> Setup bridge
<2>[ 1.140000] <tanx> pci_read_bases howmany=2, rom=56
<2>[ 1.140000] <tanx> fixups for bus0
<4>[ 1.140000] pbus_assign_bus_resources_361 <tanx> bus_0 res_0: 0x20000000 ~ 0x2fffffff , flags=0x200
<4>[ 1.140000] pbus_assign_bus_resources_361 <tanx> bus_0 res_1: 0x40000000 ~ 0x402fffff , flags=0x100
<6>[ 1.140000] PCI: bus0: Fast back to back transfers disabled
<2>[ 1.140000] <tanx> alloc pci_dev for 0000:01:00.0
<7>[ 1.141000] pci 0000:01:00.0: [10b5:8112] type 1 class 0x000604
<2>[ 1.141000] <tanx> PCI_DEV 0000:01:00.0: [10b5:8112] type 1 class 0x000604
<2>[ 1.141000] <tanx> Setup bridge
<2>[ 1.141000] <tanx> pci_read_bases howmany=2, rom=56
<7>[ 1.141000] pci 0000:01:00.0: reg 10: [mem 0x00000000-0x0000ffff 64bit pref]
<2>[ 1.141000] <tanx> 01:00.0 Bar_0: res 0000:01:00.0, [0x0~0xffff], flags=0x10220c
<7>[ 1.141000] pci 0000:01:00.0: supports D1
<7>[ 1.141000] pci 0000:01:00.0: PME# supported from D0 D1 D3hot
<7>[ 1.141000] pci 0000:01:00.0: PME# disabled
<2>[ 1.141000] <tanx> fixups for bus1
<6>[ 1.141000] PCI: bus1: Fast back to back transfers disabled
<2>[ 1.141000] <tanx> alloc pci_dev for 0000:02:04.0
<7>[ 1.141000] pci 0000:02:04.0: [104c:ac28] type 1 class 0x000604
<2>[ 1.141000] <tanx> PCI_DEV 0000:02:04.0: [104c:ac28] type 1 class 0x000604
<2>[ 1.141000] <tanx> fixups for bus2
<6>[ 1.141000] PCI: bus2: Fast back to back transfers enabled
<2>[ 1.141000] <tanx> alloc pci_dev for 0000:03:01.0
<7>[ 1.141000] pci 0000:03:01.0: [104c:b002] type 0 class 0x001180
<2>[ 1.141000] <tanx> PCI_DEV 0000:03:01.0: [104c:b002] type 0 class 0x001180
<2>[ 1.141000] <tanx> pci_read_bases howmany=6, rom=48
<7>[ 1.141000] pci 0000:03:01.0: reg 10: [mem 0x20000000-0x20007fff]
<2>[ 1.141000] <tanx> 03:01.0 Bar_0: res 0000:03:01.0, [0x20000000~0x20007fff], flags=0x200
<7>[ 1.141000] pci 0000:03:01.0: reg 14: [mem 0x20008000-0x2000ffff]
<2>[ 1.141000] <tanx> 03:01.0 Bar_1: res 0000:03:01.0, [0x20008000~0x2000ffff], flags=0x200
<7>[ 1.141000] pci 0000:03:01.0: reg 18: [mem 0x20400000-0x207fffff]
<2>[ 1.141000] <tanx> 03:01.0 Bar_2: res 0000:03:01.0, [0x20400000~0x207fffff], flags=0x200
<7>[ 1.142000] pci 0000:03:01.0: reg 1c: [mem 0x28000000-0x2801ffff pref]
<2>[ 1.142000] <tanx> 03:01.0 Bar_3: res 0000:03:01.0, [0x28000000~0x2801ffff], flags=0x2208
<7>[ 1.142000] pci 0000:03:01.0: reg 20: [mem 0x28800000-0x28ffffff pref]
<2>[ 1.142000] <tanx> 03:01.0 Bar_4: res 0000:03:01.0, [0x28800000~0x28ffffff], flags=0x2208
<7>[ 1.142000] pci 0000:03:01.0: reg 24: [mem 0x29000000-0x297fffff pref]
<2>[ 1.142000] <tanx> 03:01.0 Bar_5: res 0000:03:01.0, [0x29000000~0x297fffff], flags=0x2208
<2>[ 1.142000] <tanx> alloc pci_dev for 0000:03:02.0
<7>[ 1.142000] pci 0000:03:02.0: [104c:b002] type 0 class 0x001180
<2>[ 1.142000] <tanx> PCI_DEV 0000:03:02.0: [104c:b002] type 0 class 0x001180
<2>[ 1.142000] <tanx> pci_read_bases howmany=6, rom=48
<7>[ 1.142000] pci 0000:03:02.0: reg 10: [mem 0x20800000-0x20807fff]
<2>[ 1.142000] <tanx> 03:02.0 Bar_0: res 0000:03:02.0, [0x20800000~0x20807fff], flags=0x200
<7>[ 1.142000] pci 0000:03:02.0: reg 14: [mem 0x20808000-0x2080ffff]
<2>[ 1.142000] <tanx> 03:02.0 Bar_1: res 0000:03:02.0, [0x20808000~0x2080ffff], flags=0x200
<7>[ 1.142000] pci 0000:03:02.0: reg 18: [mem 0x20c00000-0x20ffffff]
<2>[ 1.142000] <tanx> 03:02.0 Bar_2: res 0000:03:02.0, [0x20c00000~0x20ffffff], flags=0x200
<7>[ 1.142000] pci 0000:03:02.0: reg 1c: [mem 0x29800000-0x2981ffff pref]
<2>[ 1.142000] <tanx> 03:02.0 Bar_3: res 0000:03:02.0, [0x29800000~0x2981ffff], flags=0x2208
<7>[ 1.142000] pci 0000:03:02.0: reg 20: [mem 0x2a000000-0x2a7fffff pref]
<2>[ 1.142000] <tanx> 03:02.0 Bar_4: res 0000:03:02.0, [0x2a000000~0x2a7fffff], flags=0x2208
<7>[ 1.142000] pci 0000:03:02.0: reg 24: [mem 0x2a800000-0x2affffff pref]
<2>[ 1.142000] <tanx> 03:02.0 Bar_5: res 0000:03:02.0, [0x2a800000~0x2affffff], flags=0x2208
<2>[ 1.142000] <tanx> alloc pci_dev for 0000:03:05.0
<7>[ 1.142000] pci 0000:03:05.0: [104c:b002] type 0 class 0x001180
<2>[ 1.142000] <tanx> PCI_DEV 0000:03:05.0: [104c:b002] type 0 class 0x001180
<7>[ 1.142000] pci 0000:03:05.0: reg 10: [mem 0x21000000-0x21007fff]
<2>[ 1.142000] <tanx> 03:05.0 Bar_0: res 0000:03:05.0, [0x21000000~0x21007fff], flags=0x200
<7>[ 1.142000] pci 0000:03:05.0: reg 14: [mem 0x21008000-0x2100ffff]
<2>[ 1.142000] <tanx> 03:05.0 Bar_1: res<5>[ 0.000000] Linux version 2.6.37_[et800_dm8148_V1.0.0_20180720] (root@user-R5300-G3) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #21 Sat Sep 7 20:54:56 CST 2019
<2>[ 0.031000]
<2>[ 0.031000]
<2>[ 0.032000]
<2>[ 0.039000]
<2>[ 1.142000] <tanx> 03:] sd 1:0:0:0: [sda] Attached SCSI removable disk
<3>[ 2.837000] EXT3-fs (sda): error: unable to read superblock
<3>[ 2.837000] EXT2-fs (sda): error: unable to read superblock
<3>[ 2.838000] FAT: unable to read boot sector
<4>[ 2.838000] isofs_fill_super: bread failed, dev=sda, iso_blknum=16, block=32
<5>[ 3.057000] UBI: max. sequence number: 123436
<4>[ 3.057000]
<4>[ 3.057000] rena_he: <attach_by_scanning> ubi->flash_size = 0x000006900000, mtd->size = 0x000006900000, image_seq = 195907362, good_peb_count = 840,
<5>[ 3.066000] UBI: attached mtd7 to ubi0
<5>[ 3.066000] UBI: MTD device name: "data"
<5>[ 3.066000] UBI: MTD device size: 105 MiB
<5>[ 3.066000] UBI: number of good PEBs: 840
<5>[ 3.066000] UBI: number of bad PEBs: 0
<5>[ 3.066000] UBI: number of corrupted PEBs: 0
<5>[ 3.066000] UBI: max. allowed volumes: 128
<5>[ 3.066000] UBI: wear-leveling threshold: 4096
<5>[ 3.066000] UBI: number of internal volumes: 1
<5>[ 3.066000] UBI: number of user volumes: 1
<5>[ 3.066000] UBI: available PEBs: 2
<5>[ 3.066000] UBI: total number of reserved PEBs: 838
<5>[ 3.066000] UBI: number of PEBs reserved for bad PEB handling: 8
<5>[ 3.066000] UBI: max/mean erase counter: 198/146
<5>[ 3.066000] UBI: image sequence number: 195907362
<5>[ 3.068000] UBI: background thread "ubi_bgt0d" started, PID 613
<5>[ 3.103000] UBIFS: recovery needed
<5>[ 3.252000] UBIFS: recovery completed
<5>[ 3.252000] UBIFS: mounted UBI device 0, volume 0, name "data"
<5>[ 3.252000] UBIFS: file system size: 103485440 bytes (101060 KiB, 98 MiB, 815 LEBs)
<5>[ 3.252000] UBIFS: journal size: 5206016 bytes (5084 KiB, 4 MiB, 41 LEBs)
<5>[ 3.252000] UBIFS: media format: w4/r0 (latest is w4/r0)
<5>[ 3.252000] UBIFS: default compressor: lzo
<5>[ 3.252000] UBIFS: reserved for root: 4887873 bytes (4773 KiB)
<4>[ 3.261000] cpsw_mac_config mac_control = 0xa1
<6>[ 3.548000] [rtl8368b_phy.c][rtl8367_config_init][L1035]<INFO>mbrmsk: 0xff, untagmsk:0xff, fid: 0
<6>[ 3.552000] [rtl8368b_phy.c][rtl8367_config_init][L1045]<INFO>evid: 1, fid_msti:0x0, mbr: ff, meteridx: 0, vbpen:0, vbpri:0
<6>[ 3.554000] [rtl8368b_phy.c][rtl8367_config_init][L1053]<INFO>mbrmsk: 0x00, untagmsk:0x00, fid: 5
<6>[ 3.558000] [rtl8368b_phy.c][rtl8367_config_init][L1063]<INFO>mbrmsk: 0x44, untagmsk:0xbf, fid: 3
<6>[ 3.560000] [rtl8368b_phy.c][rtl8367_config_init][L1069]<INFO>mbrmsk: 0x42, untagmsk:0xbf, fid: 2
<6>[ 3.562000] [rtl8368b_phy.c][rtl8367_config_init][L1075]<INFO>mbrmsk: 0x41, untagmsk:0xbf, fid: 1
<6>[ 3.792000] [rtl8368b_phy.c][rtl8367_config_init][L1089]<INFO>idx: 0, evid: 30, fid_msti:0x0, mbr: 44, meteridx: 0, vbpen:0, vbpri:0
<6>[ 3.792000] [rtl8368b_phy.c][rtl8367_config_init][L1092]<INFO>idx: 0x00, evid:30, mbr: 44, Mbrcfg:44, untag: bf
<6>[ 3.794000] [rtl8368b_phy.c][rtl8367_config_init][L1089]<INFO>idx: 1, evid: 20, fid_msti:0x2, mbr: 42, meteridx: 0, vbpen:0, vbpri:0
<6>[ 3.794000] [rtl8368b_phy.c][rtl8367_config_init][L1092]<INFO>idx: 0x01, evid:20, mbr: 42, Mbrcfg:42, untag: bf
<6>[ 3.796000] [rtl8368b_phy.c][rtl8367_config_init][L1089]<INFO>idx: 2, evid: 10, fid_msti:0x1, mbr: 41, meteridx: 0, vbpen:0, vbpri:0
<6>[ 3.796000] [rtl8368b_phy.c][rtl8367_config_init][L1092]<INFO>idx: 0x02, evid:10, mbr: 41, Mbrcfg:41, untag: bf
<6>[ 3.845000] [rtl8368b_phy.c][rtl8367_config_init][L1109]<INFO>disable vlan mirror
<6>[ 3.846000] [rtl8368b_phy.c][phy_config_init][L572]<INFO>phydev->addr = 2, phydev->supported = 0x00000fff, phydev->advertising = 0x00000fff
<3>[ 3.850000]
<3>[ 3.850000] CPSW phy found : id is : 0x8367
<6>[ 3.859000] ADDRCONF(NETDEV_UP): eth0: link is not ready
<6>[ 3.859000] 8021q: adding VLAN 0 to HW filter on device eth0
<3>[ 3.859000] Adding vlanid 0 to vlan filter
<3>[ 3.865000] Adding vlanid 30 to vlan filter
<3>[ 3.869000] Adding vlanid 20 to vlan filter
<3>[ 3.876000] Adding vlanid 10 to vlan filter
<6>[ 3.885000] ADDRCONF(NETDEV_UP): eth0.30: link is not ready
<6>[ 3.890000] ADDRCONF(NETDEV_UP): eth0.20: link is not ready
<6>[ 3.895000] ADDRCONF(NETDEV_UP): eth0.10: link is not ready
<4>[ 3.918000] fpga_r_w driver, to read/write all registers, V1.00
<4>[ 3.918000] Complite time: Apr 26 2018 15:20:43
<4>[ 6.169000] [Mpq_dev.c][parse_master_param][#380]s_ptMpqMasterRes->dwMpqStart = 0x8c000000
<4>[ 6.169000] [Mpq_dev.c][parse_master_param][#381]s_ptMpqMasterRes->dwMpqSize = 0x400000
<4>[ 6.169000] [Mpq_dev.c][parse_local_param][#553]s_dwMpqLocalNum = 0x1
<4>[ 6.169000] [Mpq_dev.c][parse_local_param][#560]s_ptMpqLocalRes[0].dwMpqStart = 0x8c400000
<4>[ 6.169000] [Mpq_dev.c][parse_local_param][#561]s_ptMpqLocalRes[0].dwMpqSize = 0x400000
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2347]
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2348]=============Setup for LOCAL(sum=1)=============
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2360]Success in allocation of mpq_data(0xcbbf7d00) for dm8148_local0
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2363]Setup alloc_res and release_res for local dev
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2388]Success in allocation of mpq_res(c202bcc0) for dm8148_local0
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2435]Success in allocation of mpq_dev(cbbf7c80) for dm8148_local0
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2440]Succss in creating mpq local0(name =dm8148_local0, start = 0x8c400000, size = 0x00400000)
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2451]
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2452]=============Setup for MASTER.=============
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2455]Setup mpq master:dm8148_master
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2470]Success in allocation of mpq_data(0xcbbf7700) for dm8148_master
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2498]Success in allocation of mpq_res(c202bd00) for dm8148_master
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2505]Setup DMA for mpq master
<6>[ 6.169000] [dma_dev.c][malloc_dma_channel][L497]<INFO>Alloc a dma channel : lch=2, tcc=2, Slot=2, SyncMode=1
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2517]malloc read dma channel "mpq_read_dma" success.
<6>[ 6.169000] [dma_dev.c][malloc_dma_channel][L497]<INFO>Alloc a dma channel : lch=3, tcc=3, Slot=3, SyncMode=1
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2528]malloc write dma channel "mpq_read_dma" success.
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2593]Success in allocation of mpq_dev(cbbf7f80) for dm8148_master
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2598]Create mpq master (start = 0x8C000000, size=0x00400000).
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2610]
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2611]=============Setup for SLAVE.=============
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2650]Success in allocation of mpq_dev(cbbf7b80) for dm8148_slave0
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2655]Create dm8148_slave0(start = 0x8c400000, size = 0x00400000).
<4>[ 6.169000] [Mpq_dev.c][mpq_init][#2672]iLocalNum = 1, iMasterNum = 1, iSlaveNum = 1 iDevNum = 3
<4>[ 6.169000] .[Mpq_dev.c][mpq_init][#2694]Sucess alloc 3 device number begin with [241, 0]
<4>[ 6.170000] [Mpq_dev.c][mpq_init][#2704]Sucess create class: " mpq_dev ".
<4>[ 6.170000] [Mpq_dev.c][mpq_init][#2721]cdev_add for dm8148_local0: dev_t=0xf100000, major=241, minor=0
<4>[ 6.174000] [Mpq_dev.c][mpq_init][#2744]Sucess add cdev and create device for " dm8148_local0 " : dev_t = 0xf1,0x0
<4>[ 6.174000] [Mpq_dev.c][mpq_init][#2721]cdev_add for dm8148_master: dev_t=0xf100001, major=241, minor=1
<4>[ 6.175000] [Mpq_dev.c][mpq_init][#2744]Sucess add cdev and create device for " dm8148_master " : dev_t = 0xf1,0x1
<4>[ 6.175000] [Mpq_dev.c][mpq_init][#2721]cdev_add for dm8148_slave0: dev_t=0xf100002, major=241, minor=2
<4>[ 6.176000] [Mpq_dev.c][mpq_init][#2744]Sucess add cdev and create device for " dm8148_slave0 " : dev_t = 0xf1,0x2
<4>[ 6.176000] [Mpq_dev.c][mpq_init][#2753]MPQ driver Version 1.2 Apr 26 2018
<4>[ 6.202000] [tidm.c][#1070]TIDM driver Version: tidm-v4
<4>[ 6.202000] [tidm.c][#1071]TIDM driver, Compile date and time: May 14 2019 10:20:29
<4>[ 6.202000] [tidm.c][#944]********************************************************
<4>[ 6.202000] [tidm.c][#945]Probe PCI DM642 0
<4>[ 6.202000] [tidm.c][#946]********************************************************
<4>[ 6.202000] [tidm.c][#733]Config dm642_0, devfn:48
<4>[ 6.202000] [tidm.c][#787]mmio_start 0:2e000000
<4>[ 6.202000] [tidm.c][#788]mmio_len 0:400000
<4>[ 6.202000] [tidm.c][#789]mmio_end 0:2e3fffff
<4>[ 6.202000] [tidm.c][#790]mmio_flags 0:2208
<4>[ 6.202000] [tidm.c][#800]mmio_start 1:22000000
<4>[ 6.202000] [tidm.c][#801]mmio_len 1:800000
<4>[ 6.202000] [tidm.c][#802]mmio_end 1:227fffff
<4>[ 6.202000] [tidm.c][#803]mmio_flags 1:200
<4>[ 6.202000] [tidm.c][#813]pio_start:40000000
<4>[ 6.202000] [tidm.c][#814]pio_len:10
<4>[ 6.202000] [tidm.c][#815]pio_end:4000000f
<4>[ 6.202000] [tidm.c][#816]mmio_flags 2:101
<4>[ 6.202000] [tidm.c][#828]Request regions for pci dev name:dm642_0
<4>[ 6.202000] [tidm.c][#898]Base0 map addr:d0800000
<4>[ 6.202000] [tidm.c][#899]Base1 map addr:d1000000
<4>[ 6.202000] [tidm.c][#900]Base2 map addr:cca2a000
<4>[ 6.202000] [tidm.c][#973]Setup mpq_data for pci_dev :dm642_0
<4>[ 6.203000] [tidm.c][#1086]Requst dm6467 chrdev.
<4>[ 6.203000] [tidm.c][#1092]Major number 250 assigned for dm642
<4>[ 6.227000] [dm6467.c][#1698]"dm6467" are compiled : Apr 26 2018 15:20:47
<4>[ 6.227000] [dm6467.c][#1704]Register dm6467 chrdev.
<4>[ 6.227000] [dm6467.c][#1712]dm6467: Major number 210 assigned
<4>[ 6.227000] [dm6467.c][#447]0: Found DM646x PCI device at 0xcb827800 with resource: 0x28800000~0x28ffffff, flags=0x2208, size=0x800000
<4>[ 6.227000] [dm6467.c][#447]1: Found DM646x PCI device at 0xcb827c00 with resource: 0x2a000000~0x2a7fffff, flags=0x2208, size=0x800000
<4>[ 6.227000] [dm6467.c][#447]2: Found DM646x PCI device at 0xcb8a8000 with resource: 0x2b800000~0x2bffffff, flags=0x2208, size=0x800000
<4>[ 6.227000] [dm6467.c][#447]3: Found DM646x PCI device at 0xcb8a8400 with resource: 0x2d000000~0x2d7fffff, flags=0x2208, size=0x800000
<4>[ 6.227000] [dm6467.c][#460]PCI: 4 DM6467 was found.
<4>[ 6.237000] [dm6467.c][#1725]PCIDRV - Found PCI Devices
<4>[ 6.237000] [dm6467.c][#590]PCIDRV - BAR Configuration -
<4>[ 6.237000] [dm6467.c][#594] Start | Length | Flags
<4>[ 6.237000] [dm6467.c][#595] ---------------DEV0---------------------
<4>[ 6.237000] [dm6467.c][#608] 0x20000000 | 0x00008000 | 0x00000200
<4>[ 6.237000] [dm6467.c][#608] 0x20008000 | 0x00008000 | 0x00000200
<4>[ 6.237000] [dm6467.c][#608] 0x20400000 | 0x00400000 | 0x00000200
<4>[ 6.237000] [dm6467.c][#608] 0x28000000 | 0x00020000 | 0x00002208
<4>[ 6.238000] [dm6467.c][#646]tcm_virt = ioremap_nocache (0x20000000, 0x8000)
<4>[ 6.238000] [dm6467.c][#656]ARM TCM RAM memory mapped to 0xcca30000
<4>[ 6.239000] [dm6467.c][#680]emif_virt = ioremap_nocache (0x20008000, 0x8000)
<4>[ 6.239000] [dm6467.c][#690]DDR2 Memory Controller registers mapped to 0xccad0000
<4>[ 6.239000] [dm6467.c][#714]reg_virt = ioremap_nocache (0x20400000, 0x400000)
<4>[ 6.239000] [dm6467.c][#724]MMR registers mapped to 0xd2000000.
<4>[ 6.239000] [dm6467.c][#732]Remapping of BAR4 for DDR2-A
<4>[ 6.239000] [dm6467.c][#491] dm646x_pci_remap_BAR(0x00000004, 0x80800000) : pci_regs = 0xD201A000
<4>[ 6.239000] [dm6467.c][#547]Original BAR-4 value = 0x80000000
<4>[ 6.239000] 0xd201a1d0
<4>[ 6.239000] [dm6467.c][#552]New BAR-4 value = 0x80800000
<4>[ 6.239000] [dm6467.c][#739]Remapping of BAR4 for DDR2-B
<4>[ 6.239000] [dm6467.c][#491] dm646x_pci_remap_BAR(0x00000005, 0x81600000) : pci_regs = 0xD201A000
<4>[ 6.239000] [dm6467.c][#558]Original BAR-5 value = 0x80800000
<4>[ 6.239000] [dm6467.c][#561]New BAR-5 value = 0x81600000
<4>[ 6.239000] [dm6467.c][#747]
<4>[ 6.239000] [dm6467.c][#755] 0x28800000 | 8388608 | 0x00002208
<4>[ 6.239000] [dm6467.c][#755] 0x29000000 | 8388608 | 0x00002208
<4>[ 6.239000] [dm6467.c][#807]DDR2-A: DDR2 memory phy=0x28800000 mapped to virt=0xccb00000
<4>[ 6.239000] [dm6467.c][#809]DDR2-A: Communication/Script area phy=0x28880000 mapped to virt=0xccf00000
<4>[ 6.239000] [dm6467.c][#812]DDR2-A: Linux area phy=0x28900000 mapped to virt=0xd2800000
<4>[ 6.239000] [dm6467.c][#844]DDR2-B memory phy=0x29000000 mapped to virt=0xd3000000
<4>[ 6.239000] [dm6467.c][#847]
<4>[ 6.239000] [dm6467.c][#594] Start | Length | Flags
<4>[ 6.239000] [dm6467.c][#595] ---------------DEV1---------------------
<4>[ 6.239000] [dm6467.c][#608] 0x20800000 | 0x00008000 | 0x00000200
<4>[ 6.240000] [dm6467.c][#608] 0x20808000 | 0x00008000 | 0x00000200
<4>[ 6.240000] [dm6467.c][#608] 0x20c00000 | 0x00400000 | 0x00000200
<4>[ 6.240000] [dm6467.c][#608] 0x29800000 | 0x00020000 | 0x00002208
<4>[ 6.240000] [dm6467.c][#646]tcm_virt = ioremap_nocache (0x20800000, 0x8000)
<4>[ 6.240000] [dm6467.c][#656]ARM TCM RAM memory mapped to 0xccae0000
<4>[ 6.240000] [dm6467.c][#680]emif_virt = ioremap_nocache (0x20808000, 0x8000)
<4>[ 6.240000] [dm6467.c][#690]DDR2 Memory Controller registers mapped to 0xccaf0000
<4>[ 6.240000] [dm6467.c][#714]reg_virt = ioremap_nocache (0x20C00000, 0x400000)
<4>[ 6.240000] [dm6467.c][#724]MMR registers mapped to 0xd3800000.
<4>[ 6.240000] [dm6467.c][#732]Remapping of BAR4 for DDR2-A
<4>[ 6.240000] [dm6467.c][#491] dm646x_pci_remap_BAR(0x00000004, 0x80800000) : pci_regs = 0xD381A000
<4>[ 6.240000] [dm6467.c][#547]Original BAR-4 value = 0x80000000
<4>[ 6.240000] 0xd381a1d0
<4>[ 6.240000] [dm6467.c][#552]New BAR-4 value = 0x80800000
<4>[ 6.240000] [dm6467.c][#739]Remapping of BAR4 for DDR2-B
<4>[ 6.240000] [dm6467.c][#491] dm646x_pci_remap_BAR(0x00000005, 0x81600000) : pci_regs = 0xD381A000
<4>[ 6.240000] [dm6467.c][#558]Original BAR-5 value = 0x80800000
<4>[ 6.240000] [dm6467.c][#561]New BAR-5 value = 0x81600000
<4>[ 6.240000] [dm6467.c][#747]
<4>[ 6.240000] [dm6467.c][#755] 0x2a000000 | 8388608 | 0x00002208
<4>[ 6.240000] [dm6467.c][#755] 0x2a800000 | 8388608 | 0x00002208
<4>[ 6.240000] [dm6467.c][#807]DDR2-A: DDR2 memory phy=0x2a000000 mapped to virt=0xd0300000
<4>[ 6.240000] [dm6467.c][#809]DDR2-A: Communication/Script area phy=0x2a080000 mapped to virt=0xd0400000
<4>[ 6.240000] [dm6467.c][#812]DDR2-A: Linux area phy=0x2a100000 mapped to virt=0xd4000000
<4>[ 6.241000] [dm6467.c][#844]DDR2-B memory phy=0x2a800000 mapped to virt=0xd4800000
<4>[ 6.241000] [dm6467.c][#847]
<4>[ 6.241000] [dm6467.c][#594] Start | Length | Flags
<4>[ 6.241000] [dm6467.c][#595] ---------------DEV2---------------------
<4>[ 6.241000] [dm6467.c][#608] 0x21000000 | 0x00008000 | 0x00000200
<4>[ 6.241000] [dm6467.c][#608] 0x21008000 | 0x00008000 | 0x00000200
<4>[ 6.241000] [dm6467.c][#608] 0x21400000 | 0x00400000 | 0x00000200
<4>[ 6.241000] [dm6467.c][#608] 0x2b000000 | 0x00020000 | 0x00002208
<4>[ 6.241000] [dm6467.c][#646]tcm_virt = ioremap_nocache (0x21000000, 0x8000)
<4>[ 6.241000] [dm6467.c][#656]ARM TCM RAM memory mapped to 0xccb90000
<4>[ 6.241000] [dm6467.c][#680]emif_virt = ioremap_nocache (0x21008000, 0x8000)
<4>[ 6.241000] [dm6467.c][#690]DDR2 Memory Controller registers mapped to 0xccba0000
<4>[ 6.241000] [dm6467.c][#714]reg_virt = ioremap_nocache (0x21400000, 0x400000)
<4>[ 6.241000] [dm6467.c][#724]MMR registers mapped to 0xd5000000.
<4>[ 6.241000] [dm6467.c][#732]Remapping of BAR4 for DDR2-A
<4>[ 6.241000] [dm6467.c][#491] dm646x_pci_remap_BAR(0x00000004, 0x80800000) : pci_regs = 0xD501A000
<4>[ 6.241000] [dm6467.c][#547]Original BAR-4 value = 0x80000000
<4>[ 6.241000] 0xd501a1d0
<4>[ 6.241000] [dm6467.c][#552]New BAR-4 value = 0x80800000
<4>[ 6.241000] [dm6467.c][#739]Remapping of BAR4 for DDR2-B
<4>[ 6.241000] [dm6467.c][#491] dm646x_pci_remap_BAR(0x00000005, 0x81600000) : pci_regs = 0xD501A000
<4>[ 6.241000] [dm6467.c][#558]Original BAR-5 value = 0x80800000
<4>[ 6.241000] [dm6467.c][#561]New BAR] sd 1:0:0:0: [sda] Attached SCSI removable disk
<4>[ 3.057000]
<3>[ 3.850000]
<4>[ 6.241000] [dm64678]dm6467_0 is open @03:01.0
<4>[ 44.983000] [dm6467.c][#1190]MPQ_IOCS_SLAVE_MEM:mpq_dm6467_ioctl,1190
<4>[ 44.983000] [dm6467.c][#491] dm646x_pci_remap_BAR(0x00000004, 0x88800000) : pci_regs = 0xD201A000
<4>[ 44.983000] [dm6467.c][#547]Original BAR-4 value = 0x80800000
<4>[ 44.983000] 0xd201a1d0
<4>[ 44.983000] [dm6467.c][#552]New BAR-4 value = 0x88800000
<4>[ 44.983000] [dm6467.c][#1147]dm646x_pci_release
<4>[ 44.983000] [dm6467.c][#1160]dm6467_0 is released @03:01.0
<4>[ 44.983000] [dm6467.c][#1116]Open dm6467: devt=0xd200001, (210,1)
<4>[ 44.983000] [dm6467.c][#1138]dm6467_1 is open @03:02.0
<4>[ 44.983000] [dm6467.c][#491] dm646x_pci_remap_BAR(0x00000004, 0x88800000) : pci_regs = 0xD381A000
<4>[ 44.983000] 0xd381a1d0
<4>[ 44.983000] [dm6467.c][#1160]dm6467_1 is released @03:02.0
<4>[ 44.983000] [dm6467.c][#1116]Open dm6467: devt=0xd200002, (210,2)
<4>[ 44.983000] [dm6467.c][#1138]dm6467_2 is open @03:05.0
<4>[ 44.983000] [dm6467.c][#491] dm646x_pci_remap_BAR(0x00000004, 0x88800000) : pci_regs = 0xD501A000
<4>[ 44.983000] 0xd501a1d0
<4>[ 44.983000] [dm6467.c][#1160]dm6467_2 is released @03:05.0
<4>[ 44.983000] [dm6467.c][#1116]Open dm6467: devt=0xd200003, (210,3)
<4>[ 44.983000] [dm6467.c][#1138]dm6467_3 is open @03:06.0
<4>[ 44.983000] [dm6467.c][#491] dm646x_pci_remap_BAR(0x00000004, 0x88800000) : pci_regs = 0xD681A000
<4>[ 44.983000] 0xd681a1d0
<4>[ 44.983000] [dm6467.c][#1160]dm6467_3 is released @03:06.0
<4>[ 44.983000] [Mpq_dev.c][mpq_open][#1132]Opening device dm8148_master: DEV ID = 1, i_rdev=0xf100001.Major=241, Minor=1
<4>[ 44.984000] [Mpq_dev.c][mpq_open][#1132]Opening device dm8148_slave0: DEV ID = 2, i_rdev=0xf100002.Major=241, Minor=2
<4>[ 44.984000] [dm6467.c][#1116]Open dm6467: devt=0xd200000, (210,0)
<4>[ 44.984000] [dm6467.c][#1138]dm6467_0 is open @03:01.0
<4>[ 44.984000] [dm6467.c][#1116]Open dm6467: devt=0xd200001, (210,1)
<4>[ 44.984000] [dm6467.c][#1138]dm6467_1 is open @03:02.0
<4>[ 44.984000] [dm6467.c][#1116]Open dm6467: devt=0xd200002, (210,2)
<4>[ 44.984000] [dm6467.c][#1138]dm6467_2 is open @03:05.0
<4>[ 44.985000] [dm6467.c][#1116]Open dm6467: devt=0xd200003, (210,3)
<4>[ 44.985000] [dm6467.c][#1138]dm6467_3 is open @03:06.0
<4>[ 44.985000] [tidm.c][#303]Open DM642(0).
<4>[ 44.985000] [tidm.c][#269]remap_pfn_range (0x4F500000, 0x2E000000, 0x00400000, 0x00000183)
<6>[ 45.431000] DMA: Module install successful, device major num = 248
<6>[ 45.431000] DRV: Module install successful
<6>[ 45.431000] DRV: Module built on Jan 19 2017 18:20:24
<4>[ 46.304000] [tidm.c][#269]remap_pfn_range (0x42327000, 0x2E000000, 0x00400000, 0x00000183)
<3>[ 49.308000] VPSS_FVID2: M3 firmware version 0x1000137 is newer,driver may not work properly.
<4>[ 50.801000] [Mpq_dev.c][mpq_open][#1132]Opening device dm8148_local0: DEV ID = 0, i_rdev=0xf100000.Major=241, Minor=0
<6>[ 54.540000] device eth0.30 entered promiscuous mode
<6>[ 54.540000] device eth0 entered promiscuous mode
<3>[ 54.540000] net eth0: promiscuity ignored!
<4>[ 54.739000] unregister_asc_console
<4>[ 220.136000] [dm6467.c][#1116]Open dm6467: devt=0xd200003, (210,3)
<4>[ 220.136000] [dm6467.c][#1138]dm6467_3 is open @03:06.0
<4>[ 220.136000] [dm6467.c][#1116]Open dm6467: devt=0xd200002, (210,2)
<4>[ 220.136000] [dm6467.c][#1138]dm6467_2 is open @03:05.0
<4>[ 421.715000] hrtimer: interrupt took 18600 ns
<4>[32374.168000] ip collision happened!
<4>[32374.168000] 0==(======> Notice: IP conflict !
<4>[32375.161000] ip collision happened!
<4>[32375.161000] 0==(======> Notice: IP conflict !
<4>[32376.161000] ip collision happened!
<4>[32376.161000] 0==(======> Notice: IP conflict !
<4>[32377.016000] IPCOLLI:sha=3c:da:2a:d2:1e:27, sip=169.254.11.23
<4>[32377.016000] ip collision happened!
<4>[84637.358000] 0==(======> Notice: IP conflict !
<4>[84638.540000] IPCOLLI:sha=0:c:98:d:21:ce, sip=169.254.11.23
<4>[84638.540000]
<1>[99678.296000] Unable to handle kernel paging request at virtual address 00100104
<1>[99678.296000] pgd = c0004000
<1>[99678.296000] [00100104] *pgd=00000000
<0>[99678.296000] Internal error: Oops: 817 [#1]
<0>[99678.296000] last sysfs file: /sys/devices/virtual/ubi/ubi0/dev
<4>[99678.296000] Modules linked in: ti81xxfb vpss osa_kermod syslink osd_drv 8821au rtl8367_rw isdn irda dm6467 dm642 mpq_dev fpga_rw nandbm
<4>[99678.296000] CPU: 0 Not tainted (2.6.37_[et800_dm8148_V1.0.0_20180720] #21)
<4>[99678.296000] PC is at __slab_alloc+0xdc/0x228
<4>[99678.296000] LR is at __slab_alloc+0x84/0x228
<4>[99678.296000] pc : [<c00c56b8>] lr : [<c00c5660>] psr: 80000193
<4>[99678.296000] sp : c0611d68 ip : c082c618 fp : c0611d8c
<4>[99678.296000] r10: c038e264 r9 : 0000000a r8 : ffffffff
<4>[99678.296000] r7 : 00000020 r6 : cb802400 r5 : c16bb060 r4 : cb801100
<4>[99678.296000] r3 : 00200200 r2 : 00200200 r1 : c082c600 r0 : 00100100
<4>[99678.296000] Flags: Nzcv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
<4>[99678.296000] Control: 10c5387d Table: 8a25c019 DAC: 00000017
<0>[99678.296000] Process swapper (pid: 0, stack limit = 0xc06102e8)
<0>[99678.296000] Stack: (0xc0611d68 to 0xc0612000)
<0>[99678.296000] 1d60: 00000000 60000113 cb802400 00000020 c038e264 00000000
<0>[99678.296000] 1d80: c0611dbc c0611d90 c00c58b0 c00c55e8 c16bb060 c0611da0 c0393e10 cb802100
<0>[99678.296000] 1da0: c200a480 00000020 00000640 c038e264 c0611de4 c0611dc0 c038d1d4 c00c5810
<0>[99678.296000] 1dc0: cb814000 ca2e0e40 cb814000 cb814360 00000000 00000044 c0611dfc c0611de8
<0>[99678.296000] 1de0: c038e264 c038d188 00000000 ca2e0e40 c0611e2c c0611e00 c02c054c c038e24c
<0>[99678.296000] 1e00: c0053530 c00673e4 60000113 cbb5c5c0 cbb4d780 00000044 ca2e0e40 00000000
<0>[99678.296000] 1e20: c0611e54 c0611e30 c02bad08 c02c0498 00000000 cc9145c0 80000113 4a102000
<0>[99678.296000] 1e40: c4010044 05f0f85a c0611e7c c0611e58 c02bae08 c02bac84 00000000 cbb4d780
<0>[99678.296000] 1e60: 00000040 00000001 cb814370 0000000a c0611e9c c0611e80 c02bae4c c02bad18
<0>[99678.296000] 1e80: 00000000 cb814360 00000040 00000001 c0611ec4 c0611ea0 c02bf140 c02bae28
<0>[99678.296000] 1ea0: cb814370 00000040 0000000c 00000001 0000012c 0000000a c0611eec c0611ec8
<0>[99678.296000] 1ec0: c0394230 c02bf118 c0610000 00000100 0000000c 00000001 00000003 c0681700
<0>[99678.296000] 1ee0: c0611f24 c0611ef0 c0073a34 c03941e4 c0611f1c c0611f00 c062bdd0 00000029
<0>[99678.296000] 1f00: 00000000 c002f81c c061412c 8002de5c 413fc082 0000001f c0611f34 c0611f28
<0>[99678.296000] 1f20: c0073b04 c00739c0 c0611f4c c0611f38 c003b080 c0073ac8 ffffffff fa200000
<0>[99678.296000] 1f40: c0611fa4 c0611f50 c048b074 c003b00c 81400381 40000013 c0611f98 81400081
<0>[99678.296000] 1f60: c0610000 c065ffc0 c002f81c c061412c 8002de5c 413fc082 0000001f c0611fa4
<0>[99678.296000] 1f80: c0611f98 c0611f98 c0046ee4 c0046ee8 20000013 ffffffff c0611fbc c0611fa8
<0>[99678.296000] 1fa0: c004771c c0046ea8 c0684968 c065ffc0 c0611fcc c0611fc0 c047ff9c c00476d8
<0>[99678.296000] 1fc0: c0611ff4 c0611fd0 c0008c6c c047ff48 c00087c4 00000000 00000000 c002f820
<0>[99678.296000] 1fe0: 10c53c7d c06600dc 00000000 c0611ff8 80008034 c0008a20 00000000 00000000
<4>[99678.296000] Backtrace:
<4>[99678.296000] [<c00c55dc>] (__slab_alloc+0x0/0x228) from [<c00c58b0>] (__kmalloc_track_caller+0xac/0xe8)
<4>[99678.296000] [<c00c5804>] (__kmalloc_track_caller+0x0/0xe8) from [<c038d1d4>] (__alloc_skb+0x58/0xe8)
<4>[99678.296000] r8:c038e264 r7:00000640 r6:00000020 r5:c200a480 r4:cb802100
<4>[99678.296000] [<c038d17c>] (__alloc_skb+0x0/0xe8) from [<c038e264>] (__netdev_alloc_skb+0x24/0x4c)
<4>[99678.296000] [<c038e240>] (__netdev_alloc_skb+0x0/0x4c) from [<c02c054c>] (cpsw_rx_handler+0xc0/0x13c)
<4>[99678.296000] r5:ca2e0e40 r4:00000000
<4>[99678.296000] [<c02c048c>] (cpsw_rx_handler+0x0/0x13c) from [<c02bad08>] (__cpdma_chan_free+0x90/0x94)
<4>[99678.296000] [<c02bac78>] (__cpdma_chan_free+0x0/0x94) from [<c02bae08>] (__cpdma_chan_process+0xfc/0x110)
<4>[99678.296000] [<c02bad0c>] (__cpdma_chan_process+0x0/0x110) from [<c02bae4c>] (cpdma_chan_process+0x30/0x50)
<4>[99678.296000] r9:0000000a r8:cb814370 r7:00000001 r6:00000040 r5:cbb4d780
<4>[99678.296000] r4:00000000
<4>[99678.296000] [<c02bae1c>] (cpdma_chan_process+0x0/0x50) from [<c02bf140>] (cpsw_poll+0x34/0xa0)
<4>[99678.296000] r7:00000001 r6:00000040 r5:cb814360 r4:00000000
<4>[99678.296000] [<c02bf10c>] (cpsw_poll+0x0/0xa0) from [<c0394230>] (net_rx_action+0x58/0x154)
<4>[99678.296000] r9:0000000a r8:0000012c r7:00000001 r6:0000000c r5:00000040
<4>[99678.296000] r4:cb814370
<4>[99678.296000] [<c03941d8>] (net_rx_action+0x0/0x154) from [<c0073a34>] (__do_softirq+0x80/0x108)
<4>[99678.296000] [<c00739b4>] (__do_softirq+0x0/0x108) from [<c0073b04>] (irq_exit+0x48/0x94)
<4>[99678.296000] [<c0073abc>] (irq_exit+0x0/0x94) from [<c003b080>] (asm_do_IRQ+0x80/0xa0)
<4>[99678.296000] [<c003b000>] (asm_do_IRQ+0x0/0xa0) from [<c048b074>] (__irq_svc+0x34/0xa0)
<4>[99678.296000] Exception stack(0xc0611f50 to 0xc0611f98)
<4>[99678.296000] 1f40: 81400381 40000013 c0611f98 81400081
<4>[99678.296000] 1f60: c0610000 c065ffc0 c002f81c c061412c 8002de5c 413fc082 0000001f c0611fa4
<4>[99678.296000] 1f80: c0611f98 c0611f98 c0046ee4 c0046ee8 20000013 ffffffff
<4>[99678.296000] r5:fa200000 r4:ffffffff
<4>[99678.296000] [<c0046e9c>] (default_idle+0x0/0x54) from [<c004771c>] (cpu_idle+0x50/0x90)
<4>[99678.296000] [<c00476cc>] (cpu_idle+0x0/0x90) from [<c047ff9c>] (rest_init+0x60/0x78)
<4>[99678.296000] r5:c065ffc0 r4:c0684968
<4>[99678.296000] [<c047ff3c>] (rest_init+0x0/0x78) from [<c0008c6c>] (start_kernel+0x258/0x2ac)
<4>[99678.296000] [<c0008a14>] (start_kernel+0x0/0x2ac) from [<80008034>] (0x80008034)
<4>[99678.296000] r5:c06600dc r4:10c53c7d
<0>[99678.296000] Code: e59f3144 e5820000 e5813018 e59f313c (e5802004)
<4>[99678.297000] ---[ end trace 922822f52bc30c69 ]---
<0>[99678.297000] Kernel panic - not syncing: Fatal exception in interrupt
<4>[99678.297000] Backtrace:
<4>[99678.297000] [<c0049db8>] (dump_backtrace+0x0/0x110) from [<c0488fa4>] (dump_stack+0x18/0x1c)
<4>[99678.297000] r7:c00c56bc r6:c0611bcf r5:c00c56ba r4:c0660dd0
<4>[99678.297000] [<c0488f8c>] (dump_stack+0x0/0x1c) from [<c0489008>] (panic+0x60/0x19c)
<4>[99678.297000] [<c0488fa8>] (panic+0x0/0x19c) from [<c004a14c>] (die+0x284/0x2d8)
<4>[99678.297000] r3:00000100 r2:c05e084d r1:00000000 r0:c0571599
<4>[99678.297000] [<c0049ec8>] (die+0x0/0x2d8) from [<c004cde8>] (__do_kernel_fault+0x6c/0x8c)
<4>[99678.297000] [<c004cd7c>] (__do_kernel_fault+0x0/0x8c) from [<c048d05c>] (do_page_fault+0x1f8/0x214)
<4>[99678.298000] r9:00000817 r8:00100104 r7:00000000 r6:c0613100 r5:c0611d20
<4>[99678.298000] r4:c0614778
<4>[99678.298000] [<c048ce64>] (do_page_fault+0x0/0x214) from [<c003b2a4>] (do_DataAbort+0x3c/0x9c)
<4>[99678.298000] [<c003b268>] (do_DataAbort+0x0/0x9c) from [<c048b02c>] (__dabt_svc+0x4c/0x60)
<4>[99678.298000] Exception stack(0xc0611d20 to 0xc0611d68)
<4>[99678.298000] 1d20: 00100100 c082c600 00200200 00200200 cb801100 c16bb060 cb802400 00000020
<4>[99678.298000] 1d40: ffffffff 0000000a c038e264 c0611d8c c082c618 c0611d68 c00c5660 c00c56b8
<4>[99678.298000] 1d60: 80000193 ffffffff
<4>[99678.298000] r8:ffffffff r7:00000020 r6:cb802400 r5:c0611d54 r4:ffffffff
<4>[99678.298000] [<c00c55dc>] (__slab_alloc+0x0/0x228) from [<c00c58b0>] (__kmalloc_track_caller+0xac/0xe8)
<4>[99678.298000] [<c00c5804>] (__kmalloc_track_caller+0x0/0xe8) from [<c038d1d4>] (__alloc_skb+0x58/0xe8)
<4>[99678.298000] r8:c038e264 r7:00000640 r6:00000020 r5:c200a480 r4:cb802100
<4>[99678.298000] [<c038d17c>] (__alloc_skb+0x0/0xe8) from [<c038e264>] (__netdev_alloc_skb+0x24/0x4c)
<4>[99678.298000] [<c038e240>] (__netdev_alloc_skb+0x0/0x4c) from [<c02c054c>] (cpsw_rx_handler+0xc0/0x13c)
<4>[99678.298000] r5:ca2e0e40 r4:00000000
<4>[99678.298000] [<c02c048c>] (cpsw_rx_handler+0x0/0x13c) from [<c02bad08>] (__cpdma_chan_free+0x90/0x94)
<4>[99678.298000] [<c02bac78>] (__cpdma_chan_free+0x0/0x94) from [<c02bae08>] (__cpdma_chan_process+0xfc/0x110)
<4>[99678.298000] [<c02bad0c>] (__cpdma_chan_process+0x0/0x110) from [<c02bae4c>] (cpdma_chan_process+0x30/0x50)
<4>[99678.298000] r9:0000000a r8:cb814370 r7:00000001 r6:00000040 r5:cbb4d780
<4>[99678.298000] r4:00000000
<4>[99678.298000] [<c02bae1c>] (cpdma_chan_process+0x0/0x50) from [<c02bf140>] (cpsw_poll+0x34/0xa0)
<4>[99678.298000] r7:00000001 r6:00000040 r5:cb814360 r4:00000000
<4>[99678.298000] [<c02bf10c>] (cpsw_poll+0x0/0xa0) from [<c0394230>] (net_rx_action+0x58/0x154)
<4>[99678.298000] r9:0000000a r8:0000012c r7:00000001 r6:0000000c r5:00000040
<4>[99678.298000] r4:cb814370
<4>[99678.298000] [<c03941d8>] (net_rx_action+0x0/0x154) from [<c0073a34>] (__do_softirq+0x80/0x108)
<4>[99678.298000] [<c00739b4>] (__do_softirq+0x0/0x108) from [<c0073b04>] (irq_exit+0x48/0x94)
<4>[99678.298000] [<c0073abc>] (irq_exit+0x0/0x94) from [<c003b080>] (asm_do_IRQ+0x80/0xa0)
<4>[99678.298000] [<c003b000>] (asm_do_IRQ+0x0/0xa0) from [<c048b074>] (__irq_svc+0x34/0xa0)
<4>[99678.298000] Exception stack(0xc0611f50 to 0xc0611f98)
<4>[99678.298000] 1f40: 81400381 40000013 c0611f98 81400081
<4>[99678.298000] 1f60: c0610000 c065ffc0 c002f81c c061412c 8002de5c 413fc082 0000001f c0611fa4
<4>[99678.298000] 1f80: c0611f98 c0611f98 c0046ee4 c0046ee8 20000013 ffffffff
<4>[99678.298000] r5:fa200000 r4:ffffffff
<4>[99678.298000] [<c0046e9c>] (default_idle+0x0/0x54) from [<c004771c>] (cpu_idle+0x50/0x90)
<4>[99678.298000] [<c00476cc>] (cpu_idle+0x0/0x90) from [<c047ff9c>] (rest_init+0x60/0x78)
<4>[99678.298000] r5:c065ffc0 r4:c0684968
<4>[99678.298000] [<c047ff3c>] (rest_init+0x0/0x78) from [<c0008c6c>] (start_kernel+0x258/0x2ac)
<4>[99678.298000] [<c0008a14>] (start_kernel+0x0/0x2ac) from [<80008034>] (0x80008034)
<4>[99678.298000] r5:c06600dc r4:10c53c7d
<0>[99678.298000] panic_timeout = 0 PANIC_TIMER_STEP = 100
<4>[84638.540000]
     从最后的back trace可以看出,是因为cpsw网卡驱动里调到kmalloc再到slab_alloc然后就报错了。
     我理解内核里的内存管理模块不会有什么问题,所以问题还是出在了cpsw驱动上。
     请问Ti的专家们,有什么解决思路或补丁吗?  多谢。
