如何理解C6678中对预取数据的描述?
在C6678中有这样的描述:
"The L2 cache indicates to the XMC if a given line-fill was triggered by a L1P memory controller or L1D memory controller request. This enables the prefetch buffer to apply
different filtering to each request."
即然L1D或L1P申请了数据,为什么还要根据MAR的配置进行预取的操作。
  • Hi Chenpjh,
                    preftech buffer是独立于L1D 和 L1P之外的硬件,用于预取数据。  两者的主要区别为:
    Prefetch controllers read data from memory before the DSP needs them - Cache controllers read data from memory when the DSP needs them
                    prefetch buffer 分为data prefetch 和program preftch, 所以需要 L2 cache indicates to the XMC if a given line-fill was triggered by a L1P memory controller or L1D memory controller request.
                    关于prefetch buffer的详细内容可参考user guider sprugw0b.
    http://www.ti.com/general/docs/lit/getliterature.tsp?literatureNumber=sprugy8&fileType=pdf
                   Jane
