拷贝Demo mc_proc_srio,在 System_Init中增加了 C6678_Set_Psc_All_On, Srio_Interrupts_Init,giga_ethernet_init,tcpip_stack_init。然后在 master_main中增加了 upd相关的变量初始化等。编译后报错:
#10099-D program will not fit into available memory. placement with alignment fails for section ".cinit" size 0xcb0.Available memory ranges:
#10099-D program will not fit into available memory. run placement with alignment fails for section "systemHeap" size 0x8000.Available memory ranges:
