我使用的是ti-processor-sdk-linux-am335x-evm-06.01.00.08,可以从SD卡启动uboot,但无法对emmc进行烧写,这是哪里出了问题,请大神帮帮忙
U-Boot 2019.01-g1ebdbc7-dirty (May 21 2020 - 22:18:26 +0800)
CPU : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM: 512 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Loading Environment from FAT... MMC: no card present
Loading Environment from MMC... Card did not respond to voltage select!
*** Warning - No block device, using default environment
<ethaddr> not set. Validating first E-fuse MAC
Net: Could not get PHY for ethernet@4a100000: addr 0
eth0: ethernet@4a100000
Warning: usb_ether MAC addresses don't match:
Address in ROM is de:ad:be:ef:00:01
Address in environment is 4c:3f:d3:cb:f2:55
, eth1: usb_ether
Press SPACE to abort autoboot in 2 seconds
## Error: "bootcmd_nand0" not defined
starting USB...
USB0: Port not available.
using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in
MAC de:ad:be:ef:00:01
HOST MAC de:ad:be:ef:00:00
RNDIS ready
The remote end did not respond in time.missing environment variable: pxeuuid
Retrieving file: pxelinux.cfg/01-4c-3f-d3-cb-f2-53
RNDIS ready
The remote end did not respond in time.Retrieving file: pxelinux.cfg/00000000
RNDIS ready
RNDIS ready
