MCSDK Video中的TFTP出问题
软件平台:CCS5.2
硬件:6678EVM
按照这个流程走(processors.wiki.ti.com/.../MCSDK_VIDEO_2.1_CODEC_TEST_FW_User_Guide),报错如下:
附件详细说明错误:
[C66xx_0] Read tftp config file
[C66xx_0] Read testVecs file
[C66xx_0] Read codec config file name ..\..\..\siu\vct\testVecs\h264hpdec\config\codecParams.cfg
[C66xx_0] Read test file name ..\..\..\siu\vct\testVecs\h264hpdec\config\multiClip.cfg
[C66xx_0]
[C66xx_0] Creating Algorithm Instance...FYI: Attrs     | Val
[C66xx_0]      SCRATCH   |  0
[C66xx_0]      PERSIST   |  1
[C66xx_0]      WRITEONCE |  2
[C66xx_0] Num. buffs requested = 23
[C66xx_0] algAlloc req. Buffer 0: space = 17, attr = 1, size = 4840
[C66xx_0] algAlloc req. Buffer 1: space = 0, attr = 0, size = 8840
[C66xx_0] algAlloc req. Buffer 2: space = 0, attr = 0, size = 78184
[C66xx_0] algAlloc req. Buffer 3: space = 0, attr = 0, size = 8992
[C66xx_0] algAlloc req. Buffer 4: space = 17, attr = 1, size = 8664
[C66xx_0] algAlloc req. Buffer 5: space = 17, attr = 1, size = 176
[C66xx_0] algAlloc req. Buffer 6: space = 17, attr = 1, size = 144
[C66xx_0] algAlloc req. Buffer 7: space = 17, attr = 1, size = 4420
[C66xx_0] algAlloc req. Buffer 8: space = 17, attr = 1, size = 24
[C66xx_0] algAlloc req. Buffer 9: space = 17, attr = 1, size = 1860480
[C66xx_0] algAlloc req. Buffer 10: space = 17, attr = 1, size = 15079680
[C66xx_0] algAlloc req. Buffer 11: space = 17, attr = 1, size = 1966080
[C66xx_0] algAlloc req. Buffer 12: space = 17, attr = 1, size = 136
[C66xx_0] algAlloc req. Buffer 13: space = 17, attr = 1, size = 144
[C66xx_0] algAlloc req. Buffer 14: space = 17, attr = 1, size = 8840
[C66xx_0] algAlloc req. Buffer 15: space = 17, attr = 1, size = 544
[C66xx_0] algAlloc req. Buffer 16: space = 17, attr = 1, size = 540
[C66xx_0] algAlloc req. Buffer 17: space = 17, attr = 1, size = 264
[C66xx_0] algAlloc req. Buffer 18: space = 17, attr = 1, size = 12672
[C66xx_0] algAlloc req. Buffer 19: space = 17, attr = 1, size = 74880
[C66xx_0] algAlloc req. Buffer 20: space = 17, attr = 1, size = 110592
[C66xx_0] algAlloc req. Buffer 21: space = 17, attr = 1, size = 8160
[C66xx_0] algAlloc req. Buffer 22: space = 17, attr = 1, size = 116
[C66xx_0] algAlloc supplied: Buffer 0: space = 17, attr = 1, size = 4840
[C66xx_0] algAlloc supplied: Buffer 1: space = 0, attr = 0, size = 8840
[C66xx_0] algAlloc supplied: Buffer 2: space = 0, attr = 0, size = 78184
[C66xx_0] algAlloc supplied: Buffer 3: space = 0, attr = 0, size = 8992
[C66xx_0] algAlloc supplied: Buffer 4: space = 17, attr = 1, size = 8664
[C66xx_0] algAlloc supplied: Buffer 5: space = 17, attr = 1, size = 176
[C66xx_0] algAlloc supplied: Buffer 6: space = 17, attr = 1, size = 144
[C66xx_0] algAlloc supplied: Buffer 7: space = 17, attr = 1, size = 4420
[C66xx_0] algAlloc supplied: Buffer 8: space = 17, attr = 1, size = 24
[C66xx_0] algAlloc supplied: Buffer 9: space = 17, attr = 1, size = 1860480
[C66xx_0] algAlloc supplied: Buffer 10: space = 17, attr = 1, size = 15079680
[C66xx_0] algAlloc supplied: Buffer 11: space = 17, attr = 1, size = 1966080
[C66xx_0] algAlloc supplied: Buffer 12: space = 17, attr = 1, size = 136
[C66xx_0] algAlloc supplied: Buffer 13: space = 17, attr = 1, size = 144
[C66xx_0] algAlloc supplied: Buffer 14: space = 17, attr = 1, size = 8840
[C66xx_0] algAlloc supplied: Buffer 15: space = 17, attr = 1, size = 544
[C66xx_0] algAlloc supplied: Buffer 16: space = 17, attr = 1, size = 540
[C66xx_0] algAlloc supplied: Buffer 17: space = 17, attr = 1, size = 264
[C66xx_0] algAlloc supplied: Buffer 18: space = 17, attr = 1, size = 12672
[C66xx_0] algAlloc supplied: Buffer 19: space = 17, attr = 1, size = 74880
[C66xx_0] algAlloc supplied: Buffer 20: space = 17, attr = 1, size = 110592
[C66xx_0] algAlloc supplied: Buffer 21: space = 17, attr = 1, size = 8160
[C66xx_0] algAlloc supplied: Buffer 22: space = 17, attr = 1, size = 116
[C66xx_0]
[C66xx_0] Algorithm Instance Creation Done...
[C66xx_0]
[C66xx_0] Starting TFTP Get for airshow_p352x288.264... Error receive from server!      //显示应该是TFTP设置有问题吧!求解答怎么设这TFTP
[C66xx_0]
[C66xx_0] TFTP Get stopped.
[C66xx_0] TFTP Statistics-------------------+
[C66xx_0] |  RX Bytes          :          0 |
[C66xx_0] |  TX Bytes          :          0 |
[C66xx_0] |  Valid Packets     :          0 |
[C66xx_0] |  Duplicate Packets :          0 |
[C66xx_0] |  Error Packets     :          0 |
[C66xx_0] +---------------------------------+
[C66xx_0]
[C66xx_0] TFTP Put stopped.
[C66xx_0]
[C66xx_0]  --------------  SUMMARY --------------------
[C66xx_0]  Total number of Frames              = 1
[C66xx_0]  Width and Height                    = 0, 0
[C66xx_0]  --------------    END   --------------------
[C66xx_0]
[C66xx_0]  End of execution
  • 你可以先在uboot命令行或者linux命令行使用tftp命令,验证是否能够和tftp服务器通讯上。
  • 1. 我用的是win7系统,在DOS里面测试TFTP通讯吧?是测DSP是否能够和服务器连接还是PC与服务器连接?
    2. 在PC上安装tftpd32软件之后,是把PC作为服务器吧?如果PC作为服务器,还需要在DOS中输入tftp命令吗?
    由于对tftp不是太懂,谢谢您的回答。
  • UBOOT命令行怎么调出来?是设置hyper terminal吗?波特率115200那个吗
  • 在mcsdk_video目录中,dsp文件夹是在DSP上运行的程序,host目录是在PC上运行的吗?如果是这样,同时运行两个程序,CCS不是不能同时打开两个工程吗?求解,谢谢!
  • 你对照网页上的步骤再对一下。PC是作为TFTP服务器的。你需要保证DSP的地址设置正确,PC的IP地址配置正确。另外你也可以检查一下tftp服务器的log,看是否有错误信息。
    你做的这个例子是不需要DSP跑linux的,所以我的建议说在linux下测试tftp不适用了。
  • 1.  谢谢您的耐心回答,在tftp的log中显示如下:
    Connection received from 192.168.1.100 on port 51651 [11/03 13:03:40.965]
    Write request for file <input>. Mode netascii [11/03 13:03:40.966]
    Using local port 51652 [11/03 13:03:40.969]
    Peer sent unexpected message 5 [11/03 13:03:41.098]
    2. PC的ip地址我是通过DHCP方式和路由连接,然后用一根网线把DSP和路由连接,路由和外网没有没有连接,PC和外网也没有连接,同ipconfig /all命令看到IP如下:设这为192.168.1.101;DSP的IP地址设置为192.168.1.100,这应该有没有错吧
  • wei,您好!我做了一个这个实验(http://processors.wiki.ti.com/index.php/MCSDK_VIDEO_2.1_PKT_Demo_Guide),但是到后期运行startMplayer.dat,就会出先这个问题,如下图:
    我的系统是WIN7,然后系统盘是D盘。在运行sendpkts.dat时,也出现路径的问题,但是通过看sendpkts.dat文件,发现指定的perl软件是C盘,通过修改,可以运行sendpkts.dat。但是运行startMplayer.dat时候,出现如上如问题。这次找不解决办法。
    还有就是WIN7的Mplayer必须是特定版本吗?
    望您能给与帮助,谢谢!
  • wei,您好!
    通过查看代码,siuVctTftp.c中看到,如下:
    但是TFTP_FILE_XFER_COMPLETE这个定义我在本文件包含的头文件没有找到,我想看看这个代表什么意思,查找错误出现在哪个地方?
    我怎样可以测试DSP是否与TFTP server连接呢?上面您提到UBOOT命令,这个不知道怎么使用,可否指教!谢谢
  • 这个问题你查得怎么样了?
    从log上看,两边的IP设置都应该是正常的,服务器和client能够互相交换报文。可能还是文件路径配置,或者是访问权限的问题。你可以用Wireshark抓一下握手报文,看看tftp交换的具体过程,具体的参数。
  • 你好,h264hpdec这个实验做成功了,但是在做h264hpenc这个实验一直不成功,我load完sv04.out,运行的时候,卡到了这里,截图如下:
    就不往下执行了,也没有报错。
    查看代码如下:
    这也没有输出报错信息。我想问问,这是编码需要时间长,还是怎么回事?
    好长时间都没有反应。
  • 麻烦你把前面tftp遇到的问题的结论分享一下吧。
    你现在用的EVM自带的USB仿真模块,速率不是很快,如果读一个大文件会花些时间。
  • 最开始的问题,就是我把板子和PC都连接在路由上面,结果不行。
    最后把板子和PC相连接,就好了。
    还有就是要注意ARP的设置,有时候设置完,但是运行程序的时候就没了,一定要查看。
    有没有一个比较好的方法,是读取文件速度快些呢?
  • 您好,文件airshow_p1920*1080.yuv总共15M。您可以做次实验,谢谢。
    如果正确运行的程序,会输出如下结果:
    ///现在是到这个地方就不再往下走了,不知道怎么回事
    [C66xx_0]
    [C66xx_0]
    [C66xx_0]
    [C66xx_0] Starting TFTP Get for airshow_p352x288.264... Server ACK received.
    ////显示是通过TFTP接受数据和从板子上传回的,速度应该是比较快的。
    [C66xx_0] Decoding...
    [C66xx_0]
    [C66xx_0] Decoded Frame # 0 , frame size 152064 bytes
    [C66xx_0]
    [C66xx_0]
    [C66xx_0] Starting TFTP Put for airshow_p352x288_264hpdec.yuv... Server ACK received.
    [C66xx_0]
  • yuv视频数据是从网口下载的,配置文件是通过fopen,JTAG口来访问PC的文件系统,这个过程受限于100V1的速度,访问时间会比较长。如果可能你可以尝试使用560V2仿真器速度回快很多,或者直接把配置信息在代码里面直接配置,规避这个问题。
  • 前辈您好,我也遇到了同样的问题:
    6678的264enc例程到这个地方就不再往下走了,不知道怎么回事,请问您是怎么解决的啊
