前情提要:核间通讯真是多灾多难,到现在这都要一个星期过去了,目前还没打通core0和core1 ,Notify方法已经翻车:e2echina.ti.com/.../944077
正准备使用MessageQ做核间通信,到第一步又被卡主了,创建HeapBufMP_create就是不成功,这个创建的方法和例子里是一模一样的,就是不成功,代码如下:
#define HEAP_NAME "myHeapBuf"//这个在任务之外定义的 //下面代码在任务里 HeapBufMP_Handle heapHandle; HeapBufMP_Params heapBufParams; HeapBufMP_Params_init(&heapBufParams); heapBufParams.regionId = 0; heapBufParams.name = HEAP_NAME; heapBufParams.numBlocks = 1; heapBufParams.blockSize = 1 * sizeof(MessageQ_MsgHeader); heapHandle = HeapBufMP_create(&heapBufParams);
提示:"../main.c", line 40: error #167: too few arguments in function call
这怎么可能少参数嘛,我都把函数定义翻出来了:C:\ti\ipc_3_50_04_08\packages\ti\sdo\ipc\heaps->HeapBufMP.c文件中明明写了:
HeapBufMP_Handle HeapBufMP_create(const HeapBufMP_Params *sparams)
ti_sdo_ipc_heaps_HeapBufMP_Params params;
ti_sdo_ipc_heaps_HeapBufMP_Object *obj;
Error_Block eb;
Error_init(&eb);
if (sparams != NULL) {
HeapBufMP_getRTSCParams(¶ms, (Ptr)sparams);
/* call the module create */
obj = ti_sdo_ipc_heaps_HeapBufMP_create(¶ms, &eb);
else {
obj = ti_sdo_ipc_heaps_HeapBufMP_create(NULL, &eb);
return ((HeapBufMP_Handle)obj);
就一个输入参数啊!
就算你说少参数,那我加参数,参考CCS10.1 HELP文档中搜索到的定义:HeapBufMP_Handle HeapBufMP_create(const HeapBufMP_Params *params, Error_Block *eb);
params — per-instance config params, or NULL to select default values (target-domain only)
eb — active error-handling block, or NULL to select default policy (target-domain only)
(明明是同一个函数,在.C文件和HELP文件里定义不一样 感觉就离谱 )
按照这个定义加一个NULL,其他代码同上就 heapHandle = HeapBufMP_create(&heapBufParams,NULL); 这个改变,再编译,编译是成功了,但是运行到这句话就卡住!为啥啊,这是按照标准例子创建啊,到我这里就不好用么?
附件是程序完整版:
#include "EVM_init.h"
#include <ti/sysbios/syncs/SyncSem.h>
MessageQ_Handle messageQ;
MessageQ_Params messageQParams;
SyncSem_Handle syncSemHandle;
MessageQ_QueueId remoteQueueId;
#define HEAPID 0
#define Qname_Core0_to_Core1 "Core0_to_Core1"
typedef struct {
MessageQ_MsgHeader reserved; // Required
UInt32 cmd;
} MyMsg;
MyMsg *msg;
Void ledPlayTask(UArg a0, UArg a1)
//Int status;
uint32_t coreId;
//UInt16 msgId ;
coreId = CSL_chipReadReg (CSL_CHIP_DNUM);
switch(coreId)
case 0:
platform_write("Core %d is working!\n",coreId);
//Create the heap that will be used to allocate messages.
//heapHandle = HeapBufMP_create(&heapBufParams);
platform_write("Core %d mission complete!\n",coreId);
if (heapHandle == NULL) {
platform_write("HeapBufMP_create failed\n" );
case 1:
break;
Int main()
platform_write("Start BIOS\n");
BIOS_start();
return(0);
和.cfg文件:6685.app.cfg
