[ 2.189063] sgtl5000 0-000a: Failed to get mclock: -2
[ 2.194895] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:16:19 UTC (946685779)
[ 2.203706] i2c 0-000a: Driver sgtl5000 requests probe deferral
[ 2.212779] ALSA device list:
[ 2.215779] No soundcards found.
[ 2.319931] kjournald starting. Commit interval 5 seconds
[ 2.326907] EXT3-fs (mmcblk0p2): using internal journal
[ 2.333460] EXT3-fs (mmcblk0p2): recovery complete
[ 2.338274] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
[ 2.345540] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 2.353543] devtmpfs: mounted
[ 2.357083] Freeing unused kernel memory: 256K (c0836000 - c0876000)
Mount failed for selinuxfs on /sys/fs/selinux: No such file or directory
[ 2.535119] random: init urandom read with 53 bits of entropy available
[ 2.772883] init: plymouth-upstart-bridge main process (813) terminated with status 1
[ 2.780861] init: plymouth-upstart-bridge main process ended, respawning
[ 2.917525] init: plymouth-upstart-bridge main process (824) terminated with status 1
[ 2.925597] init: plymouth-upstart-bridge main process ended, respawning
[ 2.941008] init: ureadahead main process (816) terminated with status 5
[ 3.003366] init: plymouth-upstart-bridge main process (829) terminated with status 1
[ 3.011322] init: plymouth-upstart-bridge main process ended, respawning
Ubuntu 14.04.5 LTS localhost.localdomain ttyS0
localhost login: [ 4.571450] Adding 524284k swap on /SWAP.swap. Priority:-1 extents:136 across:678348k SS
[ 6.423016] sgtl5000 0-000a: Failed to get mclock: -2
[ 6.445136] sgtl5000 0-000a: Failed to get mclock: -2
[ 6.481362] sgtl5000 0-000a: Failed to get mclock: -2
[ 7.242547] sgtl5000 0-000a: Failed to get mclock: -2
[ 7.459166] sgtl5000 0-000a: Failed to get mclock: -2
[ 7.524406] sgtl5000 0-000a: Failed to get mclock: -2
[ 8.143949] sgtl5000 0-000a: Failed to get mclock: -2
[ 8.408538] sgtl5000 0-000a: Failed to get mclock: -2
