AM572x GP EVM 开发板如何从emmc格式化分区以及启动
Other Parts Discussed in Thread: BEAGLEBOARD-X15, AM5728
我们从ti 获取到一块 AM572x Evaluation 开发板进行评估,板子可以从SD卡启动和运行。可是我们从emmc中启动时却出现了问题。
我们按照 <<AM572x Evaluation Module Quick Start Guide>>连接 J3,J4,J6确定启动模式,并插入SD卡,从SD卡启动uboot
在主机上运行
longdunmei@GZ-20180119 ~
$ uuidgen
811f1381-7e9c-4928-9b62-20897f4a4261
$ uuidgen
3a68a76c-e2ee-4ba3-90bd-6c025df6e785
Uboot中
U-Boot SPL 2019.01-g333c3e72d3 (Apr 20 2020 - 05:48:48 +0000)
DRA752-GP ES2.0
no pinctrl state for default mode
** Unable to read file dra7-ipu1-fw.xem4 **
Firmware loading failed
Trying to boot from MMC1
Loading Environment from FAT... OK
U-Boot 2019.01-g333c3e72d3 (Apr 20 2020 - 05:48:48 +0000)
CPU  : DRA752-GP ES2.0
Model: TI AM5728 BeagleBoard-X15
Board: AM572x EVM REV A.3A
DRAM:  2 GiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Net:   eth0: ethernet@48484000
Hit any key to stop autoboot:  0
=> printenv partitions
partitions=uuid_disk=${uuid_gpt_disk};name=bootloader,start=384K,size=1792K,uuid=${uuid_gpt_bootloader};name=rootfs,start=2688K,size=-,uuid=${uuid_gpt_rootfs}
=> setenv uuid_gpt_disk  811f1381-7e9c-4928-9b62-20897f4a4261
=> setenv uuid_gpt_rootfs  3a68a76c-e2ee-4ba3-90bd-6c025df6e785
=> gpt write mmc 1 ${partitions}
Writing GPT: success!
=> env save
Saving Environment to FAT... OK
=> mmc part
Partition Map for MMC device 0  --   Partition Type: DOS
Part    Start Sector    Num Sectors     UUID            Type
  1     2048            143360          cf75671d-01     0c Boot
  2     145408          31244288        cf75671d-02     83
=> mmc dev 1
switch to partitions #0, OK
mmc1(part 0) is current device
=> mmc part
Partition Map for MMC device 1  --   Partition Type: DOS
  1     1               7471103         00000000-01     ee
=> mmc dev 0
mmc0 is current device
=> mmc rescan
=> mmc dev 1
=> fatload mmc 0 ${loadaddr} MLO
157799 bytes read in 9 ms (16.7 MiB/s)
=> mmc write ${loadaddr} 0x100 0x100
MMC write: dev # 1, block # 256, count 256 ... 256 blocks written: OK
=> mmc write ${loadaddr} 0x200 0x100
MMC write: dev # 1, block # 512, count 256 ... 256 blocks written: OK
=> fatload mmc 0 ${loadaddr} u-boot.img
1445892 bytes read in 66 ms (20.9 MiB/s)
=> mmc write ${loadaddr} 0x300 0x400
MMC write: dev # 1, block # 768, count 1024 ... 1024 blocks written: OK
=>  mmc bootbus 1 2 0 2
=> mmc partconf 1 1 1 0
=> mmc rst-function 1 1
断电,拔掉SD卡,重新启动,没有任何反应。
  • 参考以下帖子看一下,是否有可能是没有将完整的img文件写进去。
    e2e.ti.com/.../788928
  • 我想知道这个过程是正确的吗?
    一般的步骤是怎么样的?
    1. 使用 gpt write mmc 1 ${partitions} 对emmc进行分区。
    2. 写入 MLO 和 uboot
    3.
    1. 是否少了 分区格式化的步骤?
    执行 mmc part mmc0 和emmc完全不同
    => mmc dev 1
    => mmc part
    Partition Map for MMC device 1 -- Partition Type: EFI
    Part Start LBA End LBA Name
    Attributes
    Type GUID
    Partition GUID
    1 0x00000300 0x000010ff "bootloader"
    attrs: 0x0000000000000000
    type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
    guid: 21200400-0804-0146-9dcc-a8c51255994f
    2 0x00001500 0x0071ffde "rootfs"
    guid: 3a68a76c-e2ee-4ba3-90bd-6c025df6e785
    => mmc dev 0
    => mmc part
    2.
    为什么 MLO 在emmc中的起始地址是 0x100 这是由什么确定的?
    3. 一般的步骤是怎么样的?
  • 1、参考以下链接进行分区,分区之后有没有重启一下设备。
    software-dl.ti.com/.../Foundational_Components_U-Boot.html
    A reset is required for the partition table to be visible.
    参考如下步骤。
    地址的问题我再研究看一下。
  • 地址的问题我认为可参考手册33.3.7.6.4 Read Sector Procedure
    Raw mode is detected by reading sectors 0, 256, 512, and 768.
    www.ti.com/.../spruhz6l.pdf
  • 确实是 MLO没有写完整,被SDK误导了。
    0x100  * 512 = 131072 < 157799
    我改了一下到 mmc write ${loadaddr} 0x100 0x200 就好了。
    但是遇见新的问题,
    DRA752-GP ES2.0
    Card did not respond to voltage select!
    Trying to boot from MMC2_2
    Loading Environment from FAT... Card did not respond to voltage select!
    Loading Environment from MMC... *** Warning - bad CRC, using default environment
    DRAM:  2 GiB
    Loading Environment from FAT... MMC: no card present
    Net:
    Warning: ethernet@48484000 using MAC address from ROM
    => env save
    Saving Environment to FAT... MMC: no card present
    Failed (1)
    环境变量好像是保存在FAT和MMC0里面,怎么改到emmc?
  • 在uboot config文件中禁用CONFIG_ENV_IS_IN_FAT 选项,仅使能CONFIG_ENV_IS_IN_MMC试一下,参考以下帖子。
    e2e.ti.com/.../937592
