由于中秋、国庆节假期,帖子审批以及工程师回复将会有所延迟,敬请谅解.
利用PRU-ICSS-EtherCAT_Slave_01.00.08.01生成TMDXICE110开发板的工程文件报错
求解决啊
报错信息如下:
C:\ti\PRU-ICSS-EtherCAT_Slave_01.00.08.01\protocols\ethercat_slave\projects>projectCreate.bat AMIC11x arm ethercat_slave_full
Environment Configuration Summary:
CCS Install Directory : c:\ti\ccs1011
CCS Workspace Directory : C:\Users\DELL\workspace_v10
SDK Install Directory : C:\ti\PRU-ICSS-EtherCAT_Slave_01.00.08.01\protocols\ethercat_slave\projects\..\..\..
PDK Install Directory : C:\ti\pdk_am335x_1_0_17\packages
Projects create Directory : C:\ti\PRU-ICSS-EtherCAT_Slave_01.00.08.01\protocols\ethercat_slave\projects\..\..\..\protocols\ethercat_slave\projects
Project create args directory : C:\ti\PRU-ICSS-EtherCAT_Slave_01.00.08.01\protocols\ethercat_slave\projects\..\..\..\protocols\ethercat_slave\projects\ccsproject_args
Creating project 'ethercat_slave_full_AMIC11x_arm' for 'AMIC11x' platform in directory 'C:\ti\PRU-ICSS-EtherCAT_Slave_01.00.08.01\protocols\ethercat_slave\projects\..\..\..\protocols\ethercat_slave\projects\ethercat_slave_full_AMIC11x_arm' by overwriting the project if it exists already...
系统找不到指定的路径。
