如题.
目前enable了RTOS的UIA,也能在debug时打开这个工具,但是一直没有任何数据出来,一片空白,如下图:
请问怎么设置让其开始有图像或者数据输出/显示出来呢?
如题.
.cfg文件全部代码如下:
var Defaults = xdc.useModule('xdc.runtime.Defaults');
var Diags = xdc.useModule('xdc.runtime.Diags');
var Error = xdc.useModule('xdc.runtime.Error');
var Log = xdc.useModule('xdc.runtime.Log');
var LoggerBuf = xdc.useModule('xdc.runtime.LoggerBuf');
var LoggerCallback = xdc.useModule('xdc.runtime.LoggerCallback');
var Main = xdc.useModule('xdc.runtime.Main');
var Memory = xdc.useModule('xdc.runtime.Memory')
var SysMin = xdc.useModule('xdc.runtime.SysMin');
var System = xdc.useModule('xdc.runtime.System');
var Text = xdc.useModule('xdc.runtime.Text');
var BIOS = xdc.useModule('ti.sysbios.BIOS');
var Clock = xdc.useModule('ti.sysbios.knl.Clock');
var Swi = xdc.useModule('ti.sysbios.knl.Swi');
var Task = xdc.useModule('ti.sysbios.knl.Task');
var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore');
var Hwi = xdc.useModule('ti.sysbios.hal.Hwi');
var Mailbox = xdc.useModule('ti.sysbios.knl.Mailbox');
var Queue = xdc.useModule('ti.sysbios.knl.Queue');
var ECM = xdc.useModule('ti.sysbios.family.c64p.EventCombiner');
var core = xdc.useModule('ti.sysbios.hal.Core');
var Cache = xdc.useModule('ti.sysbios.hal.Cache');
var Startup = xdc.useModule ("xdc.runtime.Startup");
var ti_sysbios_family_c64p_Cache = xdc.useModule('ti.sysbios.family.c64p.Cache');
var Timestamp = xdc.useModule('xdc.runtime.Timestamp');
var GateMutex = xdc.useModule('ti.sysbios.gates.GateMutex');
ECM.eventGroupHwiNum[0] = 7;
ECM.eventGroupHwiNum[1] = 8;
xdc.loadPackage('ti.sdo.edma3.drv.sample');
var devType = "omapl138"
/* Load the OSAL package */
var osType = "tirtos"
var Osal = xdc.useModule('ti.osal.Settings');
Osal.osType = osType;
Osal.socType = devType;
/*use CSL package*/
var Csl = xdc.loadPackage('ti.csl');
Csl.Settings.deviceType = devType;
/* Load the Board package and set the board name */
var Board = xdc.loadPackage('ti.board');
Board.Settings.boardName = "lcdkOMAPL138";
/* Load the gpio package */
var Gpio = xdc.loadPackage('ti.drv.gpio');
Gpio.Settings.enableProfiling = false;
Gpio.Settings.socType = devType;
/* Load the spi package */
var Spi = xdc.loadPackage('ti.drv.spi');
Spi.Settings.enableProfiling = false;
Spi.Settings.socType = devType;
Spi.Settings.useDma = "true";
/* Load the uart package */
var Uart = xdc.loadPackage('ti.drv.uart');
Uart.Settings.enableProfiling = false;
Uart.Settings.socType = devType;
Uart.Settings.useDma = "true";
/* Load the I2C package - required by board */
var I2c = xdc.loadPackage('ti.drv.i2c');
I2c.Settings.socType = devType;
var Edma = xdc.loadPackage ("ti.sdo.edma3.drv.sample");
var drv = xdc.loadPackage ("ti.sdo.edma3.drv");
var rm = xdc.loadPackage ("ti.sdo.edma3.rm");
//var System = xdc.useModule('xdc.runtime.System');
SysStd = xdc.useModule('xdc.runtime.SysStd');
System.SupportProxy = SysStd;
/* Load and use the CSL packages */
var Csl = xdc.useModule('ti.csl.Settings');
Csl.deviceType = devType;
* Uncomment this line to globally disable Asserts.
* All modules inherit the default from the 'Defaults' module. You
* can override these defaults on a per-module basis using Module.common$.
* Disabling Asserts will save code space and improve runtime performance.
Defaults.common$.diags_ASSERT = Diags.ALWAYS_OFF;
* Uncomment this line to keep module names from being loaded on the target.
* The module name strings are placed in the .const section. Setting this
* parameter to false will save space in the .const section. Error and
* Assert messages will contain an "unknown module" prefix instead
* of the actual module name.
Defaults.common$.namedModule = false;
* Minimize exit handler array in System. The System module includes
* an array of functions that are registered with System_atexit() to be
* called by System_exit().
System.maxAtexitHandlers = 4;
* Uncomment this line to disable the Error print function.
* We lose error information when this is disabled since the errors are
* not printed. Disabling the raiseHook will save some code space if
* your app is not using System_printf() since the Error_print() function
* calls System_printf().
Error.raiseHook = null;
* Uncomment this line to keep Error, Assert, and Log strings from being
* loaded on the target. These strings are placed in the .const section.
* Setting this parameter to false will save space in the .const section.
* Error, Assert and Log message will print raw ids and args instead of
* a formatted message.
Text.isLoaded = false;
* Uncomment this line to disable the output of characters by SysMin
* when the program exits. SysMin writes characters to a circular buffer.
* This buffer can be viewed using the SysMin Output view in ROV.
SysMin.flushAtExit = false;
* The BIOS module will create the default heap for the system.
* Specify the size of this default heap.
BIOS.heapSize = 0x4000;
* Build a custom SYS/BIOS library from sources.
BIOS.libType = BIOS.LibType_Custom;
/* System stack size (used by ISRs and Swis) */
Program.stack = 0x2000;
/* Circular buffer size for System_printf() */
SysMin.bufSize = 0x200;
* Create and install logger for the whole system
// Override error output color with ANSI codes, and use shorter (file.c:line) format.
Log.L_error = {
mask: Diags.STATUS,
level: Diags.ERROR,
msg: "\x1b[31;1mERROR:\x1b[0m (%s:%d) %$S"
Log.L_info = {
mask: Diags.INFO,
msg: "\x1b[32;1mINFO:\x1b[0m (%s:%d) %$S"
Log.L_warning = {
mask: Diags.STATUS,
level: Diags.WARNING,
msg: "\x1b[33;1mWARNING:\x1b[0m (%s:%d) %$S"
LoggerCallback.outputFxn = "&loggerOutput"
var loggerParams = new LoggerCallback.Params();
loggerParams.arg = 1;
Main.common$.diags_INFO = Diags.ALWAYS_ON;
Defaults.common$.logger = LoggerCallback.create(loggerParams);
System.SupportProxy = SysMin;
var clock0Params = new Clock.Params();
clock0Params.instance.name = "CLK_PRD10ms";
clock0Params.period = 10;
clock0Params.arg = 10;
clock0Params.startFlag = true;
Program.global.CLK_PRD10ms = Clock.create("&SemPost", 5, clock0Params);
var clock1Params = new Clock.Params();
clock1Params.instance.name = "CLK_PRD1Hz";
clock1Params.startFlag = true;
clock1Params.period = 1000;
clock1Params.arg = 1000;
Program.global.CLK_PRD1Hz = Clock.create("&SemPost", 5, clock1Params);
var swi0Params = new Swi.Params();
swi0Params.instance.name = "SWI1KHz";
swi0Params.priority = 10;
Program.global.SWI1KHz = Swi.create("&Swi1KHzExecute", swi0Params);
var task0Params = new Task.Params();
task0Params.instance.name = "TSK_PRD1Hz";
task0Params.priority = 3;
Program.global.TSK_PRD1Hz = Task.create("&Prd1HzTask", task0Params);
var task1Params = new Task.Params();
task1Params.instance.name = "TSK_PRD10ms";
task1Params.stackSize = 2048;
Program.global.TSK_PRD10ms = Task.create("&Prd10msTask", task1Params);
var task2Params = new Task.Params();
task2Params.instance.name = "TSK_1KHz";
task2Params.priority = 6;
Program.global.TSK_1KHz = Task.create("&Tsk1KHzExecute", task2Params);
var semaphore2Params = new Semaphore.Params();
semaphore2Params.instance.name = "TSK1KHzSEM";
semaphore2Params.mode = Semaphore.Mode_BINARY;
Program.global.TSK1KHzSEM = Semaphore.create(null, semaphore2Params);
var semaphore0Params = new Semaphore.Params();
semaphore0Params.instance.name = "PRD10msSEM";
Program.global.PRD10msSEM = Semaphore.create(null, semaphore0Params);
var semaphore1Params = new Semaphore.Params();
semaphore1Params.instance.name = "PRD1KHzSEM";
Program.global.PRD1KHzSEM = Semaphore.create(null, semaphore1Params);
Clock.timerId = 0;
var swi1Params = new Swi.Params();
swi1Params.instance.name = "hSysInfoSetSwi";
Program.global.hSysInfoSetSwi = Swi.create("&WrapSysinfo_swiNotifySubscriber", swi1Params);
var queue0Params = new Queue.Params();
queue0Params.instance.name = "sysinfoNotifMem";
Program.global.sysinfoNotifMem = Queue.create(queue0Params);
var queue1Params = new Queue.Params();
queue1Params.instance.name = "sysinfoNotifQue";
Program.global.sysinfoNotifQue = Queue.create(queue1Params);
var task3Params = new Task.Params();
task3Params.instance.name = "uartTxTask";
task3Params.priority = 3;
Program.global.uartTxTask = Task.create("&uartTxTaskFunc", task3Params);
var semaphore3Params = new Semaphore.Params();
semaphore3Params.instance.name = "uartTxSem";
semaphore3Params.mode = Semaphore.Mode_BINARY;
Program.global.uartTxSem = Semaphore.create(null, semaphore3Params);
var task4Params = new Task.Params();
task4Params.instance.name = "debugScreenTask";
Program.global.debugScreenTask = Task.create("&debugScreenTaskFunc", task4Params);
var swi2Params = new Swi.Params();
swi2Params.instance.name = "hCanTxSwi";
Program.global.hCanTxSwi = Swi.create("&CANDATAtxHandler", swi2Params);
var mailbox0Params = new Mailbox.Params();
mailbox0Params.instance.name = "hML2RxMbx";
Program.global.hML2RxMbx = Mailbox.create(17, 100, mailbox0Params);
ti_sysbios_family_c64p_Cache.initSize.l2Size = ti_sysbios_family_c64p_Cache.L2Size_128K;
ti_sysbios_family_c64p_Cache.initSize.l1pSize = ti_sysbios_family_c64p_Cache.L1Size_32K;
ti_sysbios_family_c64p_Cache.initSize.l1dSize = ti_sysbios_family_c64p_Cache.L1Size_32K;
ti_sysbios_family_c64p_Cache.MAR192_223 = 128;
ti_sysbios_family_c64p_Cache.MAR0_31 = 0;
var hwi0Params = new Hwi.Params();
hwi0Params.instance.name = "canDataHwi";
hwi0Params.eventId = 62;
Program.global.canDataHwi = Hwi.create(9, "&CANDATAintHandler", hwi0Params);
var mailbox1Params = new Mailbox.Params();
mailbox1Params.instance.name = "ML2ECPEMBX0";
Program.global.ML2ECPEMBX0 = Mailbox.create(14, 100, mailbox1Params);
var mailbox2Params = new Mailbox.Params();
mailbox2Params.instance.name = "ML2ECPEMBX1";
Program.global.ML2ECPEMBX1 = Mailbox.create(14, 100, mailbox2Params);
var mailbox3Params = new Mailbox.Params();
mailbox3Params.instance.name = "ML2ECPEMBX2";
Program.global.ML2ECPEMBX2 = Mailbox.create(14, 100, mailbox3Params);
var mailbox4Params = new Mailbox.Params();
mailbox4Params.instance.name = "ML2ECPEMBX3";
Program.global.ML2ECPEMBX3 = Mailbox.create(14, 100, mailbox4Params);
var mailbox5Params = new Mailbox.Params();
mailbox5Params.instance.name = "ML2ECPEMBX4";
Program.global.ML2ECPEMBX4 = Mailbox.create(14, 100, mailbox5Params);
var mailbox6Params = new Mailbox.Params();
mailbox6Params.instance.name = "ML2ECPEMBX5";
Program.global.ML2ECPEMBX5 = Mailbox.create(14, 100, mailbox6Params);
var mailbox7Params = new Mailbox.Params();
mailbox7Params.instance.name = "ML2ECPEMBX6";
Program.global.ML2ECPEMBX6 = Mailbox.create(14, 100, mailbox7Params);
var mailbox8Params = new Mailbox.Params();
mailbox8Params.instance.name = "ML2ECPEMBX7";
Program.global.ML2ECPEMBX7 = Mailbox.create(14, 100, mailbox8Params);
var gateMutextParams = new GateMutex.Params;
Program.global.hML2StreamWatchdogMutex = GateMutex.create(gateMutextParams);
Program.global.hFtpSessionMutex = GateMutex.create(gateMutextParams);
var mailbox9Params = new Mailbox.Params();
mailbox9Params.instance.name = "FTPProcessMBX";
Program.global.FTPProcessMBX = Mailbox.create(40, 200, mailbox9Params);
var queue2Params = new Queue.Params();
queue2Params.instance.name = "ftpReqQueMem";
Program.global.ftpReqQueMem = Queue.create(queue2Params);
var queue3Params = new Queue.Params();
queue3Params.instance.name = "ftpReqQue";
Program.global.ftpReqQue = Queue.create(queue3Params);
var semaphore4Params = new Semaphore.Params();
semaphore4Params.instance.name = "SEMML2data";
semaphore4Params.mode = Semaphore.Mode_BINARY;
Program.global.SEMML2data = Semaphore.create(1, semaphore4Params);
var task9Params = new Task.Params();
task9Params.instance.name = "TSK_2KHz";
task9Params.priority = 7;
Program.global.TSK_2KHz = Task.create("&Tsk1KHzExecute", task9Params);
semaphore4Params.instance.name = "TSK2KHzSEM";
Program.global.TSK2KHzSEM = Semaphore.create(null, semaphore4Params);
谢谢啦!
