用6678自带的gel文件初始化如何用C语言函数达到同样的效果
// * TMS6678L GEL File
// * This is the GEL file for use in Code Composer Studio for the 6678L platform.
// * Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/
// * Redistribution and use in source and binary forms, with or without
// * modification, are permitted provided that the following conditions
// * are met:
// * Redistributions of source code must retain the above copyright
// * notice, this list of conditions and the following disclaimer.
// * Redistributions in binary form must reproduce the above copyright
// * notice, this list of conditions and the following disclaimer in the
// * documentation and/or other materials provided with the
// * distribution.
// * Neither the name of Texas Instruments Incorporated nor the names of
// * its contributors may be used to endorse or promote products derived
// * from this software without specific prior written permission.
// * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// * KeyStone1 Emupack version "1.0.4.0"
#define GEL_VERSION 2.004
// The System PLL governs the device (CorePac) operating speed.
// Each board designer defines the CLKIN frequency. On the
// TMDXEVM6678L,LE,LXE EVMs, the CLKIN frequency defined to 100MHz. The
// values for PLL1_M(39) and PLL1_D(1) defined below are pre-set
// to provide a 1000MHz operating frequency on the EVMs.
// Other board designs using different CLKIN frequencies and/or
// applications that requiring other operating frequecies, the PLL can
// be configured by adjusting PLL1_M and PLL1_D per the
// following formula:
// Target Frequency (MHz) =
// input_clock (MHz) * [(PLL1_M + 1)]/ (2 * (PLL1_D + 1) )
// Table 2-13, "C66x DSP System PLL Configuration" in the device data sheet,
// focus.ti.com/.../tms320c6678.pdf provides the suggested
// values for PLL1_M and PLL1_D for various input clocks and desired
// operating frequencies.
// Please note that there might be multiple PLL1_M and PLL1_D
// values for the same Input clock and Desired Device Speed as long as the
// multipliers and dividers are in the acceptable range.
// More details on the PLL including the limitations on acceptable ranges
// for multipliers and dividers are in the PLL's user guide at
// The table provides some sample values of PLL1_M and PLL1_D:
// Please select PLL1_M values such that 0 < PLL1_M <= 64
// | (CLK)Desired | (CLKIN) Input | | |
// | Device Speed (MHz) | Clock (MHz) | PLL1_M | PLL1_D |
// | 1000 | 100 | 19 | 0 |
// | 1000 | 100 (EVM) | 39 | 1 |
// | 1250 | 100 | 24 | 0 |
// | 1000 | 50 | 39 | 1 |
// | 1000 | 156.25 | 63 | 4 |
// | PA PLL VCO | (CLKIN) Input | | |
// | Rate (MHz) | Clock (MHz) | PLL1_M | PLL1_D |
// | 1050 | 100.00 (EVM) | 20 | 0 |
// | 1044 | 122.88 | 31 | 1 |
// | 1050 | 122.88 | 204 | 11 |
// | 1050 | 156.25 | 335 | 24 |
// | DDR3 PLL VCO | (CLKIN) Input | | |
// | 1333 | 66.667 (EVM) | 19 | 0 |
// | 1066 | 66.667 | 31 | 1 |
// | 800 | 66.667 | 11 | 0 |
#define PLL1_M 39
#define PLL1_D 1
#define DDR3_BASE_ADDRESS 0x80000000
// Global Register and constant definitions
#define REF_CLOCK_KHZ 100000
// Global timeout value
#define GTIMEOUT 1000
// Power definitions
#define PSC_BASE 0x02350000
#define PSC_PTCMD *( unsigned int* )( PSC_BASE+0x120 )
#define PSC_PTSTAT *( unsigned int* )( PSC_BASE+0x128 )
#define PSC_PDCTL_BASE ( PSC_BASE+0x300 )
#define PSC_MDSTAT_BASE ( PSC_BASE+0x800 )
#define PSC_MDCTL_BASE ( PSC_BASE+0xA00 )
#define LPSC_EMIF25_SPI 3 // EMIF16
#define LPSC_TSIP 4
#define LPSC_DEBUGSS_TRC 5
// PD 1
#define LPSC_TETB_TRC 6
// PD 2
#define LPSC_PKTPROC 7 // PA
#define LPSC_CPGMAC 8 // SGMII
#define LPSC_Crypto 9 // SA
// PD 3
#define LPSC_PCIEX 10
// PD 4
#define LPSC_SRIO 11
// PD 5
#define LPSC_Hyperbridge 12
// PD 7
#define LPSC_MSMCSRAM 14
// Power domains definitions
#define PD0 (0) // Power Domain-0
#define PD1 (1) // Power Domain-1
#define PD2 (2) // Power Domain-2
#define PD3 (3) // Power Domain-3
#define PD4 (4) // Power Domain-4
#define PD5 (5) // Power Domain-5
#define PD6 (6) // Power Domain-6
#define PD7 (7) // Power Domain-7
#define PD8 (8) // Power Domain-8
#define PD9 (9) // Power Domain-9
#define PD10 (10) // Power Domain-10
#define PD11 (11) // Power Domain-11
#define PD12 (12) // Power Domain-12
#define PD13 (13) // Power Domain-13
#define PD14 (14) // Power Domain-14
#define PD15 (15) // Power Domain-15
#define PD16 (16) // Power Domain-16
#define PD17 (17) // Power Domain-17
#define PSC_SYNCRESET (0x1)
#define PSC_DISABLE (0x2)
#define PSC_ENABLE (0x3)
// BOOT and CONFIG dsp system modules Definitions
#define CHIP_LEVEL_REG 0x02620000
#define DEVSTAT (*(unsigned int*)(CHIP_LEVEL_REG + 0x0020))
#define KICK0 (*(unsigned int*)(CHIP_LEVEL_REG + 0x0038))
#define KICK1 (*(unsigned int*)(CHIP_LEVEL_REG + 0x003C))
#define TINPSEL (*(unsigned int*)(CHIP_LEVEL_REG + 0x0300))
#define TOUTPSEL (*(unsigned int*)(CHIP_LEVEL_REG + 0x0304))
#define MAINPLLCTL0 (*(unsigned int*)(CHIP_LEVEL_REG + 0x0328))
#define MAINPLLCTL1 (*(unsigned int*)(CHIP_LEVEL_REG + 0x032C))
#define DDR3PLLCTL0 (*(unsigned int*)(CHIP_LEVEL_REG + 0x0330))
#define DDR3PLLCTL1 (*(unsigned int*)(CHIP_LEVEL_REG + 0x0334))
#define PAPLLCTL0 (*(unsigned int*)(CHIP_LEVEL_REG + 0x0338))
#define PAPLLCTL1 (*(unsigned int*)(CHIP_LEVEL_REG + 0x033C))
#define OBSCLKCTL (*(unsigned int*)(CHIP_LEVEL_REG + 0x03AC))
// DDR3 tuning registers
#define DATA0_GTLVL_INIT_RATIO (*(unsigned int*)(CHIP_LEVEL_REG + 0x043C))
#define DATA1_GTLVL_INIT_RATIO (*(unsigned int*)(CHIP_LEVEL_REG + 0x0440))
#define DATA2_GTLVL_INIT_RATIO (*(unsigned int*)(CHIP_LEVEL_REG + 0x0444))
#define DATA3_GTLVL_INIT_RATIO (*(unsigned int*)(CHIP_LEVEL_REG + 0x0448))
#define DATA4_GTLVL_INIT_RATIO (*(unsigned int*)(CHIP_LEVEL_REG + 0x044C))
#define DATA5_GTLVL_INIT_RATIO (*(unsigned int*)(CHIP_LEVEL_REG + 0x0450))
#define DATA6_GTLVL_INIT_RATIO (*(unsigned int*)(CHIP_LEVEL_REG + 0x0454))
#define DATA7_GTLVL_INIT_RATIO (*(unsigned int*)(CHIP_LEVEL_REG + 0x0458))
#define DATA8_GTLVL_INIT_RATIO (*(unsigned int*)(CHIP_LEVEL_REG + 0x045C))
#define DATA0_WRLVL_INIT_RATIO (*(unsigned int*)(CHIP_LEVEL_REG + 0x040C))
#define DATA1_WRLVL_INIT_RATIO (*(unsigned int*)(CHIP_LEVEL_REG + 0x0410))
#define DATA2_WRLVL_INIT_RATIO (*(unsigned int*)(CHIP_LEVEL_REG + 0x0414))
#define DATA3_WRLVL_INIT_RATIO (*(unsigned int*)(CHIP_LEVEL_REG + 0x0418))
#define DATA4_WRLVL_INIT_RATIO (*(unsigned int*)(CHIP_LEVEL_REG + 0x041C))
#define DATA5_WRLVL_INIT_RATIO (*(unsigned int*)(CHIP_LEVEL_REG + 0x0420))
#define DATA6_WRLVL_INIT_RATIO (*(unsigned int*)(CHIP_LEVEL_REG + 0x0424))
#define DATA7_WRLVL_INIT_RATIO (*(unsigned int*)(CHIP_LEVEL_REG + 0x0428))
#define DATA8_WRLVL_INIT_RATIO (*(unsigned int*)(CHIP_LEVEL_REG + 0x042C))
#define DDR3_CONFIG_REG_0 (*(unsigned int*)(CHIP_LEVEL_REG + 0x0404))
#define DDR3_CONFIG_REG_12 (*(unsigned int*)(CHIP_LEVEL_REG + 0x0434))
#define DDR3_CONFIG_REG_23 (*(unsigned int*)(CHIP_LEVEL_REG + 0x0460))
#define DDR3_CONFIG_REG_24 (*(unsigned int*)(CHIP_LEVEL_REG + 0x0464))
#define SGMII_SERDES_CFGPLL (*(unsigned int*)(CHIP_LEVEL_REG + 0x340))
#define SGMII_SERDES_CFGRX0 (*(unsigned int*)(CHIP_LEVEL_REG + 0x344))
#define SGMII_SERDES_CFGTX0 (*(unsigned int*)(CHIP_LEVEL_REG + 0x348))
#define SGMII_SERDES_CFGRX1 (*(unsigned int*)(CHIP_LEVEL_REG + 0x34C))
#define SGMII_SERDES_CFGTX1 (*(unsigned int*)(CHIP_LEVEL_REG + 0x350))
#define KICK0_UNLOCK (0x83E70B13)
#define KICK1_UNLOCK (0x95A4F1E0)
#define KICK_LOCK 0
/* PA PLL Observation Clock Control Register */
#define OBSCLKCTL (*((unsigned int *) 0x026203AC))
#define PA_PLL_OBS_CLK_SEL_MASK (1 << 4) /* OBSCLKCTL Register Bit 4 - set to 0 to see PA PLL reference (input) clock, set to 1 to see PA PLL output*/
#define PA_PLL_OBS_CLK_EN_MASK (1 << 5) /* OBSCLKCTL Register Bit 5 - set to 1 to enable power to PA PLL observation clock*/
/* PA PLL Registers */
#define BYPASS_BIT_SHIFT 23
#define CLKF_BIT_SHIFT 6
#define CLKR_BIT_SHIFT 0
//#define DEVSTAT (*((unsigned int *) 0x02620020))
//#define PAPLLCTL0 (*((unsigned int *) 0x02620338))
//#define PAPLLCTL1 (*((unsigned int *) 0x0262033C))
#define PASSCLKSEL_MASK (1 << 17) /* Tells the configuration of the PASSCLKSEL pin */
#define PA_PLL_BYPASS_MASK (1 << BYPASS_BIT_SHIFT) /* Tells whether the PA PLL is in BYPASS mode or not */
#define PA_PLL_CLKOD_MASK (0x00780000) /* Tells the output divider value for the PA PLL */
#define PA_PLL_CLKF_MASK (0x0007FFC0) /* Tells the multiplier value for the PA PLL */
#define PA_PLL_CLKR_MASK (0x0000003F) /* Tells the divider value for the PA PLL */
// Timeout definitions
int _GEL_Global_Timeout1 = 0;
#define TIMEOUT_ID 10
int iRESULT = 0;
// Extended Memory Controller (XMC) Configuration
#define XMC_BASE_ADDR (0x08000000)
#define XMPAX2_L (*(unsigned int*)(XMC_BASE_ADDR + 0x00000010))
#define XMPAX2_H (*(unsigned int*)(XMC_BASE_ADDR + 0x00000014))
// DDR3 definitions
#define DDR_BASE_ADDR 0x21000000
#define DDR_MIDR (*(unsigned int*)(DDR_BASE_ADDR + 0x00000000))
#define DDR_SDCFG (*(unsigned int*)(DDR_BASE_ADDR + 0x00000008))
#define DDR_SDRFC (*(unsigned int*)(DDR_BASE_ADDR + 0x00000010))
#define DDR_SDTIM1 (*(unsigned int*)(DDR_BASE_ADDR + 0x00000018))
#define DDR_SDTIM2 (*(unsigned int*)(DDR_BASE_ADDR + 0x00000020))
#define DDR_SDTIM3 (*(unsigned int*)(DDR_BASE_ADDR + 0x00000028))
#define DDR_PMCTL (*(unsigned int*)(DDR_BASE_ADDR + 0x00000038))
#define DDR_ZQCFG (*(unsigned int*)(DDR_BASE_ADDR + 0x000000C8))
#define DDR_RDWR_LVL_RMP_CTRL (*(unsigned int*)(DDR_BASE_ADDR + 0x000000D8))
#define DDR_TMPALRT (*(unsigned int*)(DDR_BASE_ADDR + 0x000000CC))
#define DDR_RDWR_LVL_CTRL (*(unsigned int*)(DDR_BASE_ADDR + 0x000000DC))
#define DDR_DDRPHYC (*(unsigned int*)(DDR_BASE_ADDR + 0x000000E4))
#define RD_DQS_SLAVE_RATIO_1333 0x34
#define WR_DQS_SLAVE_RATIO_1333 0x45
#define WR_DATA_SLAVE_RATIO_1333 0x85
#define FIFO_WE_SLAVE_RATIO_1333 0xBC
#define RD_DQS_SLAVE_RATIO_1066 0x34
#define WR_DQS_SLAVE_RATIO_1066 0x37
#define WR_DATA_SLAVE_RATIO_1066 0x77
#define FIFO_WE_SLAVE_RATIO_1066 0xA0
// PLL 1 definitions (DSP clk and subsystems)
#define PLL1_BASE 0x02310000
#define PLL1_PLLCTL (*(unsigned int*)(PLL1_BASE + 0x100)) // PLL1 Control
#define PLL1_SECCTL (*(unsigned int*)(PLL1_BASE + 0x108)) // PLL1 Sec Control
#define PLL1_PLLM (*(unsigned int*)(PLL1_BASE + 0x110)) // PLL1 Multiplier
#define PLL1_DIV1 (*(unsigned int*)(PLL1_BASE + 0x118)) // DIV1 divider
#define PLL1_DIV2 (*(unsigned int*)(PLL1_BASE + 0x11C)) // DIV2 divider
#define PLL1_DIV3 (*(unsigned int*)(PLL1_BASE + 0x120)) // DIV3 divider
#define PLL1_CMD (*(unsigned int*)(PLL1_BASE + 0x138)) // CMD control
#define PLL1_STAT (*(unsigned int*)(PLL1_BASE + 0x13C)) // STAT control
#define PLL1_ALNCTL (*(unsigned int*)(PLL1_BASE + 0x140)) // ALNCTL control
#define PLL1_DCHANGE (*(unsigned int*)(PLL1_BASE + 0x144)) // DCHANGE status
#define PLL1_CKEN (*(unsigned int*)(PLL1_BASE + 0x148)) // CKEN control
#define PLL1_CKSTAT (*(unsigned int*)(PLL1_BASE + 0x14C)) // CKSTAT status
#define PLL1_SYSTAT (*(unsigned int*)(PLL1_BASE + 0x150)) // SYSTAT status
#define PLL1_DIV4 (*(unsigned int*)(PLL1_BASE + 0x160)) // DIV4 divider
#define PLL1_DIV5 (*(unsigned int*)(PLL1_BASE + 0x164)) // DIV5 divider
#define PLL1_DIV6 (*(unsigned int*)(PLL1_BASE + 0x168)) // DIV6 divider
#define PLL1_DIV7 (*(unsigned int*)(PLL1_BASE + 0x16C)) // DIV7 divider
#define PLL1_DIV8 (*(unsigned int*)(PLL1_BASE + 0x170)) // DIV8 divider
#define PLL1_DIV9 (*(unsigned int*)(PLL1_BASE + 0x174)) // DIV9 divider
#define PLL1_DIV10 (*(unsigned int*)(PLL1_BASE + 0x178)) // DIV10 divider
#define PLL1_DIV11 (*(unsigned int*)(PLL1_BASE + 0x17C)) // DIV11 divider
#define PLL1_DIV12 (*(unsigned int*)(PLL1_BASE + 0x180)) // DIV12 divider
#define PLL1_DIV13 (*(unsigned int*)(PLL1_BASE + 0x184)) // DIV13 divider
#define PLL1_DIV14 (*(unsigned int*)(PLL1_BASE + 0x188)) // DIV14 divider
#define PLL1_DIV15 (*(unsigned int*)(PLL1_BASE + 0x18C)) // DIV15 divider
#define PLL1_DIV16 (*(unsigned int*)(PLL1_BASE + 0x190)) // DIV16 divider
#define PLL_REG_RSCTL_VALUE_KEY (0x5A69)
#define PLL_REG_RSCFG_FIELD_POWER_ON_RESET (1<<29)
// CACHE definitions
#define CACHE_BASE 0x01840000
#define CACHE_L2CFG (*( unsigned int* )( CACHE_BASE ))
#define CACHE_L1PCFG (*( unsigned int* )( CACHE_BASE + 0x0020 ))
#define CACHE_L1DCFG (*( unsigned int* )( CACHE_BASE + 0x0040 ))
#define L2WBINV (CACHE_BASE + 0x5004) // L2WBINV Control
#define L2INV (CACHE_BASE + 0x5008) // L2INV Control
#define L1PINV (CACHE_BASE + 0x5028) // L1PINV Control
#define L1DWBINV (CACHE_BASE + 0x5044) // L1DWBINV Control
#define L1DINV (CACHE_BASE + 0x5048) // L1DINV Control
// EDMA3 definitions
#define EDMA3_TPCC0_BASE 0x02700000
#define IERH_0 (EDMA3_TPCC0_BASE + 0x1054) // IERH Control
#define EERH_0 (EDMA3_TPCC0_BASE + 0x1024) // EERH Control
#define ICRH_0 (EDMA3_TPCC0_BASE + 0x1074) // ICRH Control
#define ECRH_0 (EDMA3_TPCC0_BASE + 0x100C) // ECRH Control
#define IER_0 (EDMA3_TPCC0_BASE + 0x1050) // IER Control
#define EER_0 (EDMA3_TPCC0_BASE + 0x1020) // EER Control
#define ICR_0 (EDMA3_TPCC0_BASE + 0x1070) // ICR Control
#define ECR_0 (EDMA3_TPCC0_BASE + 0x1008) // ECR Control
#define IECRH_0 (EDMA3_TPCC0_BASE + 0x105C) // IECRH Control
#define IECR_0 (EDMA3_TPCC0_BASE + 0x1058) // IECR Control
#define EECRH_0 (EDMA3_TPCC0_BASE + 0x102C) // EECRH Control
#define EECR_0 (EDMA3_TPCC0_BASE + 0x1028) // EECR Control
#define EDMA3_TPCC1_BASE 0x02720000
#define IERH_1 (EDMA3_TPCC1_BASE + 0x1054) // IERH Control
#define EERH_1 (EDMA3_TPCC1_BASE + 0x1024) // EERH Control
#define ICRH_1 (EDMA3_TPCC1_BASE + 0x1074) // ICRH Control
#define ECRH_1 (EDMA3_TPCC1_BASE + 0x100C) // ECRH Control
#define IER_1 (EDMA3_TPCC1_BASE + 0x1050) // IER Control
#define EER_1 (EDMA3_TPCC1_BASE + 0x1020) // EER Control
#define ICR_1 (EDMA3_TPCC1_BASE + 0x1070) // ICR Control
#define ECR_1 (EDMA3_TPCC1_BASE + 0x1008) // ECR Control
#define IECRH_1 (EDMA3_TPCC1_BASE + 0x105C) // IECRH Control
#define IECR_1 (EDMA3_TPCC1_BASE + 0x1058) // IECR Control
#define EECRH_1 (EDMA3_TPCC1_BASE + 0x102C) // EECRH Control
#define EECR_1 (EDMA3_TPCC1_BASE + 0x1028) // EECR Control
#define EDMA3_TPCC2_BASE 0x02740000
#define IERH_2 (EDMA3_TPCC2_BASE + 0x1054) // IERH Control
#define EERH_2 (EDMA3_TPCC2_BASE + 0x1024) // EERH Control
#define ICRH_2 (EDMA3_TPCC2_BASE + 0x1074) // ICRH Control
#define ECRH_2 (EDMA3_TPCC2_BASE + 0x100C) // ECRH Control
#define IER_2 (EDMA3_TPCC2_BASE + 0x1050) // IER Control
#define EER_2 (EDMA3_TPCC2_BASE + 0x1020) // EER Control
#define ICR_2 (EDMA3_TPCC2_BASE + 0x1070) // ICR Control
#define ECR_2 (EDMA3_TPCC2_BASE + 0x1008) // ECR Control
#define IECRH_2 (EDMA3_TPCC2_BASE + 0x105C) // IECRH Control
#define IECR_2 (EDMA3_TPCC2_BASE + 0x1058) // IECR Control
#define EECRH_2 (EDMA3_TPCC2_BASE + 0x102C) // EECRH Control
#define EECR_2 (EDMA3_TPCC2_BASE + 0x1028) // EECR Control
// GPIO definitions
#define GPIO_BASE 0x02320000
#define GPIO_BITEN (*(unsigned int*)(GPIO_BASE + 0x0008)) // BITEN Control
#define GPIO_DIR (*(unsigned int*)(GPIO_BASE + 0x0010)) // DIR Control
#define GPIO_OUT_DATA (*(unsigned int*)(GPIO_BASE + 0x0014)) // OUT_DATA Control
#define GPIO_IN_DATA (*(unsigned int*)(GPIO_BASE + 0x0020)) // IN_DATA Register
#define GPIO_CLR_RIS_TRIG (*(unsigned int*)(GPIO_BASE + 0x0028)) // CLR_RIS_TRIG Control
#define GPIO_CLR_FAL_TRIG (*(unsigned int*)(GPIO_BASE + 0x0030)) // CLR_FAL_TRIG Control
#define GPIO_DEFAULT_DIR 0xFFFF2CFF // GP08,GP09,GP12,GP14,GP15 (Nand) are outputs
#define GPIO_DEFAULT_OUT 0x0000D000 // GP15, GP14, GP12 default to HIGH
// Used for eeprom programming
#define LITTLE_END 1
#define BIG_END 2
// SGMII definitions
#define SGMII_SERDES_BASE 0x02090000
#define SGMII_SLIVER_BASE1 0x02090900
#define SGMII_SLIVER_BASE2 0x02090940
#define SGMII_SERDES_CONTROL_PORT1 (*(unsigned int*)(SGMII_SERDES_BASE + 0x210))
#define SGMII_SERDES_MR_ADV_PORT1 (*(unsigned int*)(SGMII_SERDES_BASE + 0x218))
#define SGMII_SERDES_AUX_CFG_PORT1 (*(unsigned int*)(SGMII_SERDES_BASE + 0x238))
#define SGMII_SERDES_CONTROL_PORT0 (*(unsigned int*)(SGMII_SERDES_BASE + 0x110))
#define SGMII_SERDES_MR_ADV_PORT0 (*(unsigned int*)(SGMII_SERDES_BASE + 0x118))
#define SGMII_SERDES_AUX_CFG_PORT0 (*(unsigned int*)(SGMII_SERDES_BASE + 0x138))
#define SGMII_SLIVER_MACCONTROL1 (*(unsigned int*)(SGMII_SLIVER_BASE1 + 0x004))
#define SGMII_SLIVER_MAXLEN1 (*(unsigned int*)(SGMII_SLIVER_BASE1 + 0x010))
#define SGMII_SLIVER_MACCONTROL2 (*(unsigned int*)(SGMII_SLIVER_BASE2 + 0x004))
#define SGMII_SLIVER_MAXLEN2 (*(unsigned int*)(SGMII_SLIVER_BASE2 + 0x010))
#define CPSW3G_BASE 0x02090800
#define CPSW3G_CONTROL_REG (*(unsigned int*)(CPSW3G_BASE + 0x004))
#define CPSW3G_STAT_PORT_REG (*(unsigned int*)(CPSW3G_BASE + 0x00C))
#define CPSW3G_ALE_CONTROL_REG (*(unsigned int*)(CPSW3G_BASE + 0x608))
#define CPSW3G_ALE_PORT_0_CTL_REG (*(unsigned int*)(CPSW3G_BASE + 0x640))
#define CPSW3G_ALE_PORT_1_CTL_REG (*(unsigned int*)(CPSW3G_BASE + 0x644))
#define CPSW3G_ALE_PORT_2_CTL_REG (*(unsigned int*)(CPSW3G_BASE + 0x648))
#define CPSW3G_ALE_PORT_STATE_FORWARD 0x3
//TIMER 0 definitions
#define TIMER0_CNTLO (*(unsigned int*)(0x02200010))
#define TIMER0_CNTHI (*(unsigned int*)(0x02200014))
#define TIMER0_PRDLO (*(unsigned int*)(0x02200018))
#define TIMER0_PRDHI (*(unsigned int*)(0x0220001C))
#define TIMER0_TCR (*(unsigned int*)(0x02200020))
#define TIMER0_TGCR (*(unsigned int*)(0x02200024))
#define L2EDSTAT 0x01846004
#define L2EDCMD 0x01846008
#define L2EDADDR 0x0184600C
#define L2EDCPEC 0x01846018
#define L2EDCNEC 0x0184601C
#define L2EDCEN 0x01846030
#define L1PEDSTAT 0x01846404
#define L1PEDCMD 0x01846408
#define L1PEDADDR 0x0184640C
#define SMCERRAR 0x0BC00008
#define SMCERRXR 0x0BC0000C
#define SMEDCC 0x0BC00010
#define SMCEA 0x0BC00014
#define SMSECC 0x0BC00018
#define PLL_REINIT_MAX_COUNT (10)
// Flag for i2c eeprom programming process
int i2cprog=0;
* The delay function is called from wherever a delay is needed. The parameter is the
* delay period (in milliseconds)
Delay_milli_seconds(myDelay)
Set_Timeout(myDelay);
while(Get_Timeout());
Kill_Timeout();
* @brief Simple DDR3 test
* @details
* This function performs a simple DDR3 test for a memory range
* specified below and returns -1 for failure and 0 for success.
#define DDR3_TEST_START_ADDRESS (0x80000000)
#define DDR3_TEST_END_ADDRESS (DDR3_TEST_START_ADDRESS + (4 * 100))
ddr3_memory_test ()
unsigned int index, value;
GEL_TextOut( "DDR3 memory test... Started\n" );
/* Write a pattern */
for (index = DDR3_TEST_START_ADDRESS; index < DDR3_TEST_END_ADDRESS; index += 4) {
*index = index;
/* Read and check the pattern */
value = *index;
if (value != index) {
GEL_TextOut( "DDR3 memory test... Failed\n" );
return -1;
/* Write a pattern for complementary values */
*index = ~index;
value = *index;
if (value != ~index) {
return -1;
GEL_TextOut( "DDR3 memory test... Passed\n" );
return 0;
* NAME
* StartUp
* PURPOSE:
* Perform CCS Memory Map configuration.
* This function is called each time CCS is started.
* USAGE
* This routine is a callback routine and called by CCS only.
* RETURN VALUE
* NONE
* REFERENCE
StartUp( )
i2cprog=0;
Setup_Memory_Map( );
* NAME
* OnTargetConnect
* PURPOSE:
* Setup almost everything ready for a new debug session:
* DSP modules and EVM board modules, at target connection.
* Do nothing if target is in realtime mode.
* This routine is called when you connect to the target board.
* IMPORTANT: this routine won't attempt to connect to the target
* if the target is not in real-time mode and that the dsp boot
* mode switches are not set in emulation boot mode.
* USAGE
* RETURN VALUE
* NONE
* REFERENCE
OnTargetConnect( )
i2cprog=0;
GEL_TextOut( "\nConnecting Target...\n" );
// Displays current DSP core info
Core_Info();
// Check if target is not in real-time mode. If it is in stop mode,
// initialize everything. In real-time mode, do nothing to connect
// unobtrusively...
if (!GEL_IsInRealtimeMode())
// Validates if emulation boot mode
if (DEVSTAT & 0x0000000E)
GEL_TextOut("No initialization performed since bootmode = %x \n",,,,,(DEVSTAT >> 1 ) & 0xF);
GEL_TextOut("You can manually initialize with GlobalDefaultSetup\n");
else
// Comment the following line at production application test
// when the application need to initialize everything, but not the
// GEL file.
Global_Default_Setup_Silent();
} else {
GEL_TextOut("No initialization performed in real time mode\n");
* NAME
* OnReset
* PURPOSE:
* Called by CCS when you do in menu Debug->Reset.
* USAGE
* RETURN VALUE
* NONE
* REFERENCE
OnReset( int nErrorCode )
* NAME
* OnPreFileLoaded
* PURPOSE:
* Called by CCS when you do in menu File->LoadProgram, File->LoadSymbols,
* etc, before loading anything.
* USAGE
* RETURN VALUE
* NONE
* REFERENCE
OnPreFileLoaded()
// Purge all the cache
Invalidate_Cache();
// Disable interrupts
IER = 0;
// Is used to be sure dsp is ready to load a file
// Can be comment out if not needed...
GEL_TextOut( "GEL Reset...\n" );
GEL_Reset();
GEL_TextOut( "GEL Reset... Done.\n" );
* NAME
* OnFileLoaded
* PURPOSE:
* etc, after loading completed.
* USAGE
* RETURN VALUE
* NONE
* REFERENCE
OnFileLoaded(int nErrorCode, int bSymbolsOnly)
// Check for errors in loading program
if (nErrorCode)
GEL_TextOut("OnFileLoaded: error occured while loading a file code %d\n",,2,,,nErrorCode);
else
// Allows only core 0 can do i2c programming
if (DNUM == 0)
// Checks if eeprom i2c programming was started
if (i2cprog!=0)
// Test for little endian
if (i2cprog==LITTLE_END)
// For little endian
// Remove i2c eeprom switch
i2cprog=0;
GEL_TextOut("Loading Write_Image_2DSP_EEprom (LITTLE ENDIAN) data file... \n");
// Load data file to program
GEL_MemoryLoad(0x900000, 0, 0x10000, "$(GEL_file_dir)\\dsprom.dat");
GEL_TextOut("Loading Write_Image_2DSP_EEprom (LITTLE ENDIAN) parameter file... \n");
// Load i2c programmer parameters file
GEL_MemoryLoad(0x800000, 0, 0x60, "$(GEL_file_dir)\\..\\i2crom\\params_le.dat");
GEL_TextOut("Running Write_Image_2DSP_EEprom (LITTLE ENDIAN) programmer... \n");
// Programs the dsp eeprom
GEL_Run();
GEL_TextOut("Starting Write_Image_2DSP_EEprom... Done.\n");
else
// For big endian
i2cprog=0;
GEL_TextOut("Loading Write_Image_2DSP_EEprom (BIG ENDIAN) data file... \n");
GEL_TextOut("Loading Write_Image_2DSP_EEprom (BIG ENDIAN) parameter file... \n");
GEL_MemoryLoad(0x800000, 0, 0x60, "$(GEL_file_dir)\\..\\i2crom\\params_be.dat");
GEL_TextOut("Running Write_Image_2DSP_EEprom (BIG ENDIAN) programmer... \n");
GEL_Run();
i2cprog=0;
* NAME
* OnHalt
* PURPOSE:
* Called by CCS each time the cpu is halted.
* You may use it to do specific custom action each the cpu is halted
* (Displays some info with GEL_TextOut, etc).
* USAGE
* RETURN VALUE
* NONE
* REFERENCE
OnHalt()
* NAME
* OnRestart
* PURPOSE:
* Called by CCS each time you do Debug->Restart.
* Put the C6X in known good state in relation to cache, EDMA, IRQ
* USAGE
* RETURN VALUE
* NONE
* REFERENCE
OnRestart( int nErrorCode )
// Allows only core 0 to access EDMA controller
if (DNUM == 0)
// Disable EDMA3 events and interrupts and clear any pending events. */
GEL_TextOut("Disable all EDMA3 interrupts and events.\n");
// EDMA controller 0
*(int*)IECRH_0 = 0xFFFFFFFF; // IECRH (disable high interrupts enable)
*(int*)EECRH_0 = 0xFFFFFFFF; // EECRH (disable high events enable)
*(int*)ICRH_0 = 0xFFFFFFFF; // ICRH (clear high interrupts pending)
*(int*)ECRH_0 = 0xFFFFFFFF; // ECRH (clear high events pending)
*(int*)IECR_0 = 0xFFFFFFFF; // IECR (disable low interrupts enable)
*(int*)EECR_0 = 0xFFFFFFFF; // EECR (disable low events enable)
*(int*)ICR_0 = 0xFFFFFFFF; // ICR (clear low interrupts pending)
*(int*)ECR_0 = 0xFFFFFFFF; // ECR (clear low events pending)
// EDMA controller 1
*(int*)IECRH_1 = 0xFFFFFFFF; // IECRH (disable high interrupts enable)
*(int*)EECRH_1 = 0xFFFFFFFF; // EECRH (disable high events enable)
*(int*)ICRH_1 = 0xFFFFFFFF; // ICRH (clear high interrupts pending)
*(int*)ECRH_1 = 0xFFFFFFFF; // ECRH (clear high events pending)
*(int*)IECR_1 = 0xFFFFFFFF; // IECR (disable low interrupts enable)
*(int*)EECR_1 = 0xFFFFFFFF; // EECR (disable low events enable)
*(int*)ICR_1 = 0xFFFFFFFF; // ICR (clear low interrupts pending)
*(int*)ECR_1 = 0xFFFFFFFF; // ECR (clear low events pending)
// EDMA controller 2
*(int*)IECRH_2 = 0xFFFFFFFF; // IECRH (disable high interrupts enable)
*(int*)EECRH_2 = 0xFFFFFFFF; // EECRH (disable high events enable)
*(int*)ICRH_2 = 0xFFFFFFFF; // ICRH (clear high interrupts pending)
*(int*)ECRH_2 = 0xFFFFFFFF; // ECRH (clear high events pending)
*(int*)IECR_2 = 0xFFFFFFFF; // IECR (disable low interrupts enable)
*(int*)EECR_2 = 0xFFFFFFFF; // EECR (disable low events enable)
*(int*)ICR_2 = 0xFFFFFFFF; // ICR (clear low interrupts pending)
*(int*)ECR_2 = 0xFFFFFFFF; // ECR (clear low events pending)
IER = 0;
* NAME
* Global_Default_Setup_Silent
* PURPOSE:
* DSP modules and EVM board modules.
* USAGE
* This routine can be called as:
* Global_Default_Setup_Silent()
* RETURN VALUE
* NONE
* REFERENCE
float gel_ver = GEL_VERSION;
int count;
/* DDR PLL settings for 1333 MHz */
unsigned int PLLM_DDR = 19;
unsigned int PLLD_DDR = 0;
/* PASS PLL settings for 1050 MHz */
unsigned int PLLM_PASS = 20;
unsigned int PLLD_PASS = 0;
int status;
// Set DSP cache to pre defined values...
GEL_TextOut( "C6678L GEL file Ver is %f \n",,,,, (float) (gel_ver/1.0));
GEL_TextOut( "Global Default Setup...\n" );
Set_DSP_Cache();
// Only core 0 can set these
if (DNUM == 0)
for (count = 0; count < PLL_REINIT_MAX_COUNT; count++) {
// Setup Pll1 DSP @ TARGET_FREQ
status = Init_PLL(PLL1_M, PLL1_D);
if (status == -1) {
GEL_TextOut( "Error in Setting up main PLL, please power cycle the board and re-run Global Default Setup...\n" );
while (1);
if (!count) {
// Setup all Power Domains on
Set_Psc_All_On( );
// Setup Pll3 pass clk @ 1050 MHz
Init_Pll3(PLLM_PASS, PLLD_PASS);
// Setup Pll2 DDR3 PLL @ 667 MHz
Init_Pll2(PLLM_DDR, PLLD_DDR);
GEL_TextOut( "DDR begin (1333 auto)\n");
xmc_setup();
ddr3_setup_auto_lvl_1333(0);
GEL_TextOut( "DDR done\n");
if(ddr3_memory_test() == 0) {
break;
if (count == PLL_REINIT_MAX_COUNT) {
GEL_TextOut( "PLL and DDR Initialization failed ...\n");
} else {
GEL_TextOut( "PLL and DDR Initialization completed(%d) ...\n",,,,, count);
// Configure SGMII SERDES
configSGMIISerdes();
GEL_TextOut( "Enabling EDC ...\n");
EnableEDC_OneforAll();
GEL_TextOut( "Enabling EDC ...Done \n");
GEL_TextOut( "Configuring CPSW ...\n");
setCpSwConfig();
GEL_TextOut( "Configuring CPSW ...Done \n");
GEL_TextOut( "Global Default Setup... Done.\n" );
* NAME
* Wait_Soft
* PURPOSE:
* Wait for a specified delay in number of empty loop.
* USAGE
* Wait_Soft(nloop)
* nloop - (i) number of empty loop to do for delay
* RETURN VALUE
* NONE
* REFERENCE
Wait_Soft( int nloop )
int i;
// 1 sec ~ 40000 loop on P4 3.4GHz
for( i = 0 ; i < nloop ; i++ )
* NAME
* prog_pll1_values
* PURPOSE:
* USAGE
* Wait_Soft(nloop)
* RETURN VALUE
* NONE
* REFERENCE
prog_pll1_values(unsigned int pll_multiplier, unsigned int pll_divider, unsigned int odiv)
int TEMP;
/* Check the Range for the parameters */
if (odiv > 15)
GEL_TextOut ( " invalid output divide range, should be less than 15... \n");
if (pll_multiplier > 4095)
GEL_TextOut ( " invalid pll multiplier range, should be less than 4095... \n");
if (pll_divider > 63)
GEL_TextOut ( " invalid pll multiplier range, should be less than 63... \n");
/* Set the PLL Multiplier, Divider, BWADJ *
* The PLLM[5:0] bits of the multiplier are controlled by the PLLM Register *
* inside the PLL Controller and the PLLM[12:6] bits are controlled by the *
* chip-level MAINPLLCTL0 Register. *
* PLL Control Register (PLLM) Layout *
* |31...6 |5...0 | *
* |Reserved |PLLM | *
* Main PLL Control Register (MAINPLLCTL0) *
* |31...24 |23...19 |18...12 | 11...6 |5...0 | *
* |BWADJ[7:0]| Reserved |PLLM[12:6] | Reserved | PLLD | */
/* Set pll multipler (13 bit field) */
PLL1_PLLM = (pll_multiplier & 0x0000003F); /* bits[5:0] */
TEMP = (pll_multiplier & 0x1FC0) >> 6;/* bits[12:6] */
MAINPLLCTL0 &=~(0x0007F000); /*Clear PLLM field */
MAINPLLCTL0 |=((TEMP << 12) & 0x0007F000);
/* Set the BWADJ (12 bit field) *
* BWADJ[11:8] and BWADJ[7:0] are located in MAINPLLCTL0 and MAINPLLCTL1 *
* registers. BWADJ[11:0] should be programmed to a value equal to half of *
* PLLM[12:0] value (round down if PLLM has an odd value) *
* Example: If PLLM = 15, then BWADJ = 7 */
TEMP = ((pll_multiplier + 1) >> 1) - 1; /* Divide the pllm by 2 */
MAINPLLCTL0 &=~(0xFF000000); /* Clear the BWADJ Field */
MAINPLLCTL0 |= ((TEMP << 24) & 0xFF000000);
MAINPLLCTL1 &=~(0x0000000F); /* Clear the BWADJ field */
MAINPLLCTL1 |= ((TEMP >> 8) & 0x0000000F);
/* Set the pll divider (6 bit field) *
* PLLD[5:0] is located in MAINPLLCTL0 */
MAINPLLCTL0 &= ~(0x0000003F); /* Clear the Field */
MAINPLLCTL0 |= (pll_divider & 0x0000003F);
/* Set the OUTPUT DIVIDE (4 bit field) in SECCTL */
PLL1_SECCTL &= ~(0x00780000); /* Clear the field */
PLL1_SECCTL |= ((odiv << 19) & 0x00780000) ;
menuitem "EVMC6678L HW Setup";
* NAME
* Init PLL
* PURPOSE:
* Performs the main PLL initialization
* USAGE
* This function can be called as below.
* Init_PLL()
* RETURN VALUE
* iresult = 0: Success; -1=fail
* REFERENCE
* NOTE
* Note that this function requires pll_mult and pll_div arguments to be
* actual register values, i.e., the values are original values - 1
* (pll_* = calculated_value_of_pll_* - 1)
hotmenu Init_PLL(int pll_mult, int pll_div )
int i, TEMP;
/* Default dividers */
unsigned int div2=3, div5=5, div8=64;
int dsp_freq;
int dsp_freM,dsp_freD;
GEL_TextOut ( "Main PLL (PLL1) Setup ... \n");
/*Unlock Boot Config*/
KICK0 = 0x83E70B13;
KICK1 = 0x95A4F1E0;
// Only core0 can set PLL
if (DNUM == 0)
/* Wait for Stabilization time (min 100 us) *
* The below loop is good enough for the Gel file to get minimum of *
* 100 micro seconds, this should be appropriately modified for port *
* to a C function *
* Minimum delay in GEL can be 1 milli seconds, so program to 1ms=1000us, *
* more than required, but should be Okay */
Delay_milli_seconds(1);
/* If PLL previously configured in RBL, avoid di/dt supply excursion by *
* matching PLL output to RefClk rate *
* if RBL configures the PLL, the BYPASS bit would be set to '0' */
TEMP = PLL1_SECCTL & 0x00800000; /* Check the Bit 23 value */
if (TEMP != 0) /* PLL BYPASS is enabled, we assume if not in Bypass ENSAT = 1 */
GEL_TextOut ( "PLL in Bypass ... \n");
/* Usage Note 9: For optimal PLL operation, the ENSAT bit in the PLL control *
* registers for the Main PLL, DDR3 PLL, and PA PLL should be set to 1. *
* The PLL initialization sequence in the boot ROM sets this bit to 0 and *
* could lead to non-optimal PLL operation. Software can set the bit to the *
* optimal value of 1 after boot *
* Ref: www.ti.com/.../sprz334b.pdf *
* |31...7 |6 |5 4 |3...0 | *
* |Reserved |ENSAT |Reserved |BWADJ[11:8]| */
MAINPLLCTL1 = MAINPLLCTL1 | 0x00000040;
/* Clear PLLENSRC bit */
PLL1_PLLCTL &= ~(1 << 5);
/* Clear PLLEN bit */
PLL1_PLLCTL &= ~(1 << 0);
/* Wait for 4 RefClks *
* Assuming slowest Ref clock of 25MHz, min: 160 ns delay */
/* Bypass needed to perform PWRDN cycle for C6670 and C6678 *
* Needed on all devices when in NOBOOT, I2C or SPI boot modes *
* Ref: Figure 4-2 of www.ti.com/.../sprugv2a.pdf *
* PLL Secondary Control Register (SECCTL) Layout *
* |31...24 |23 |22...19 |18...0 | *
* |Reserved |BYPASS |OUTPUT DIVIDE |Reserved | */
PLL1_SECCTL |= 0x00800000; /* Set the Bit 23 */
/* Advisory 8: Multiple PLLs May Not Lock After Power-on Reset Issue *
* In order to ensure proper PLL startup, the PLL power_down pin needs to be *
* toggled. This is accomplished by toggling the PLLPWRDN bit in the PLLCTL *
* register. This needs to be done before the main PLL initialization *
* sequence *
* Ref: Figure 4-1 of www.ti.com/.../sprugv2a.pdf *
* PLL Control Register (PLLCTL) Layout *
* |31...4 |3 |2 |1 |0 | *
* |Reserved |PLLRST |Reserved |PLLPWRDN |Reserved | */
PLL1_PLLCTL |= 0x00000002; /*Power Down the PLL */
/* Stay in a loop such that the bit is set for 5 祍 (minimum) and *
* then clear the bit. */
Delay_milli_seconds(1); /* This is more than required delay */
/* Power up the PLL */
PLL1_PLLCTL &= ~(0x00000002);
/* Place PLL in Reset, In PLLCTL, write PLLRST = 1 (PLL is reset) */
PLL1_PLLCTL |= 0x00000008;
/* Wait for PLL Reset assertion Time (min: 50 us) *
//Delay_milli_seconds(1);
/* Program the necessary multipliers/dividers and BW adjustments */
prog_pll1_values(pll_mult, pll_div, 1);
/* go stat bit needs to be zero here */
/* Read the GOSTAT bit in PLLSTAT to make sure the bit returns to 0 to *
* indicate that the GO operation has completed */
/* wait for the GOSTAT, but don't trap if lock is never read */
for (i = 0; i < 1000; i++)
if ( (PLL1_STAT & 0x00000001) == 0 ) {
break;
if ( i == 1000 ) {
GEL_TextOut ( "Error while waiting for GOSTAT bit returning to 0 ... \n");
return(-1);
/* Set PLL dividers if needed */
PLL1_DIV2 = (0x8000) | (div2 - 1);
PLL1_DIV5 = (0x8000) | (div5 - 1);
PLL1_DIV8 = (0x8000) | (div8 - 1);
/* Program ALNCTLn */
/* Set bit 1, 4 and 7 */
PLL1_ALNCTL |= ( (1 << 1) | (1 << 4) | (1 << 7));
/* Set GOSET bit in PLLCMD to initiate the GO operation to change the divide *
* values and align the SYSCLKs as programmed */
PLL1_CMD |= 0x00000001;
/* wait for the phase adj */
break;
if ( i == 1000 ) {
return(-1);
/* Wait for the PLL Reset duration time (min: 7us ) */
/*In PLLCTL, write PLLRST = 0 to bring PLL out of reset */
PLL1_PLLCTL &= ~(0x00000008);
* PLL Lock Delay needs to be 500 RefClk periods * (PLLD + 1)
* i.e., Wait for at least 500 * CLKIN cycles * (PLLD + 1) (PLL lock time)
* Using 2000 25ns RefClk periods per DM
* Wait for PLL to lock min 50 micro seconds
PLL1_SECCTL &= ~(0x00800000); /* Release Bypass */
/* Set the PLLEN */
PLL1_PLLCTL |= (1 << 0);
// Compute the real dsp freq (*100)
dsp_freq = (((REF_CLOCK_KHZ/10) * ((pll_mult+1)/2))/(pll_div+1));
// Displayed frequency setup
// dsp freq in MHz
dsp_freM = dsp_freq / 100;
// dsp freq first decimal if freq expressed in MHz
dsp_freD = ((dsp_freq - dsp_freM * 100) + 5) / 10;
// Add roundup unit to MHz displayed and reajust decimal value if necessary...
if (dsp_freD > 9)
dsp_freD = dsp_freD - 10;
dsp_freM = dsp_freM + 1;
// Print freq info...
GEL_TextOut( "PLL1 Setup for DSP @ %d.%d MHz.\n",,,,, dsp_freM, dsp_freD );
GEL_TextOut( " SYSCLK2 = %f MHz, SYSCLK5 = %f MHz.\n",,,,, ((float)(dsp_freq/100)/div2), ((float)(dsp_freq/100)/div5));
GEL_TextOut( " SYSCLK8 = %f MHz.\n",,,,, ((float)(dsp_freq/100)/div8));
GEL_TextOut( "PLL1 Setup... Done.\n" );
return (0);
else
GEL_TextOut("DSP core #%d cannot set PLL1.\n",,2,,,DNUM);
return(-1);
* NAME
* Set_PSC_State
* PURPOSE:
* Set a new power state for the specified domain id in a power controler
* domain. Wait for the power transition to complete.
* USAGE
* Set_PSC_State(unsigned int pd,unsigned int id,unsigned int state)
* pd - (i) power domain.
* id - (i) module id to use for module in the specified power domain
* state - (i) new state value to set
* 0 = RESET
* 1 = SYNC RESET
* 2 = DISABLE
* 3 = ENABLE
* RETURN VALUE
* 0 if ok, !=0 for error
* REFERENCE
unsigned int* mdctl;
unsigned int* mdstat;
unsigned int* pdctl;
int ret=0;
// GEL_TextOut( "Set_PSC_State for pd = %d \n",,2,,,pd);
// Only core0 can set PSC
if (DNUM == 0)
mdctl = ( unsigned int* )(PSC_MDCTL_BASE + ( 4 * id ));
mdstat = ( unsigned int* )( PSC_MDSTAT_BASE + ( 4 * id ));
pdctl = ( unsigned int* )(PSC_PDCTL_BASE + ( 4 * pd ));
// If state is already set, do nothing
if ( ( *mdstat & 0x1f ) == state )
return(0);
Wait_Soft(150);
// Check if we got timeout error while waiting
if (PSC_PTSTAT & (0x1 << pd))
GEL_TextOut( "Set_PSC_State... Timeout Error #01 pd=%d, md=%d!\n",,2,,,pd,id);
ret=1;
else
// Set power domain control
*pdctl = (*pdctl) | 0x00000001;
// Set MDCTL NEXT to new state
*mdctl = ((*mdctl) & ~(0x1f)) | state;
// Start power transition by setting PTCMD GO to 1
PSC_PTCMD = (PSC_PTCMD) | (0x1<<pd);
// Wait for PTSTAT GOSTAT to clear
Wait_Soft(150);
if ((PSC_PTSTAT & (0x1 << pd)) != 0 ) {
GEL_TextOut( "Set_PSC_State... Timeout Error #02 pd=%d, md=%d!\n",,2,,,pd,id);
return 1;
// Verify state changed
Wait_Soft(150);
if(( *mdstat & 0x1f ) != state ) {
if ((pd == 2) && (id == 9) ) {
GEL_TextOut( "Security Accelerator disabled!\n",,2,,);
} else {
GEL_TextOut( "Set_PSC_State... Timeout Error #03 pd=%d, md=%d!\n",,2,,,pd,id);
return 1;
else
GEL_TextOut("DSP core #%d cannot set PSC.\n",,2,,,DNUM);
// GEL_TextOut( "Exit Set_PSC_State \n");
return(ret);
* NAME
* RoundToHigherInt
* PURPOSE:
* This routine will round a float value to higher int.
* ex.: RoundToHigherInt(7.1)=8, RoundToHigherInt(7.7)=8,
* RoundToHigherInt(7.0)=7
* USAGE
* RoundToHigherInt(fValue)
* fValue - (i) float value to be converted.
* RETURN VALUE
* Converted int value.
* REFERENCE
int iResult,iTemp;
double fTemp, fSTolP, fSTolN, fPar, fZero;
fSTolP = 1.0e-7;
fSTolN = -1.0e-7;
fPar = fValue;
fZero = 0.0;
// Compute a truncated value for fValue
iTemp = fPar;
// Convert int value to double floating point
fTemp = iTemp;
// Compute difference between truncated int and value to be converted
fTemp = fPar - fTemp;
// If value to be converted is positive
if (fPar >= fZero)
// Verify equality by allowing single precision least digit tolerance 1e-7
// to catch (int + fSTolP) like exact int value
if ((fTemp >= fZero) && (fTemp < fSTolP))
// Do not adjust int because wright on it
iResult = iTemp;
else
// adjust to upper int
iResult = iTemp + 1;
else
fTemp = 1 - fTemp;
// Negative converted value
if (((fTemp >= fZero) && (fTemp < fSTolP)))
// adjust to lower int cause we missed it
iResult = iTemp - 1;
else
iResult = iTemp;
//GEL_TextOut("ceil value:%f, int:%d\n",,,,,fValue, iResult);
return(iResult);
* NAME
* TimeToField
* PURPOSE:
* This routine will convert a ddr timing value in sec to a field integer
* value for the ddr timing registers.
* Does not validate register field overflow!
* USAGE
* TimeToField(fValue, freq, position)
* fValue - (i) float timing value in sec (to be converted).
* freq - (i) ddr frequency value in Hz.
* position - (i) position of field within register.
* RETURN VALUE
* Converted int ddr field value at correct position.
* REFERENCE
int iResult;
double fTemp;
// Convert to double float
fTemp = fValue;
iResult = RoundToHigherInt((fTemp * freq)-1);
iResult = iResult << position;
return(iResult);
* NAME
* ClckToField
* PURPOSE:
* This routine will convert a ddr timing value in clock period unit to
* a field integer value for the ddr timing registers.
* USAGE
* ClckToField(value, position)
* value - (i) timing value in clock unit (to be converted).
* RETURN VALUE
* REFERENCE
int iResult;
iResult = (value - 1) << position;
return(iResult);
* NAME
* Set_Wait
* PURPOSE:
* Wait for a specified delay in msec.
* USAGE
* Set_Wait(msec)
* msec - (i) delay period in msec
* RETURN VALUE
* NONE
* REFERENCE
Set_Wait(msec)
// Temporary call a soft loop
// 1 sec ~ 23500 loop on P4 3.4GHz because of CCS 4.x slow Set_Timeout problem
Wait_Soft(msec*24);
menuitem "EVMC6678L Init Functions";
* NAME
* Init_Functions_Help
* PURPOSE:
* Prints the help for the init functions menu.
* USAGE
* Called from GEL menu only
* RETURN VALUE
* NONE
* REFERENCE
hotmenu Init_Functions_Help()
GEL_TextOut("\n\n");
GEL_TextOut(" INIT FUNCTIONS MENU HELP\n");
GEL_TextOut(" ------------------------\n\n");
GEL_TextOut("This menu is to do EVM & DSP initialization.\n\n");
GEL_TextOut("Global_Default_Setup: same function as when connecting to target. Will do:\n");
GEL_TextOut(" Set_DSP_Cache, Set_Pll1(TARGET_MULTIPLIER), Set_Pll2_666_7_MHz,\n");
GEL_TextOut(" Set_Psc_All_On, Set_Pin_Board.\n");
GEL_TextOut("Set_DSP_Cache: setup DSP default cache settings (for L1P, L1D, L2).\n");
GEL_TextOut("Set_Pll1_xxx_MHz: setup DSP speed (PLL1) to specified MHz.\n");
GEL_TextOut("Set_Pll2_666_7_MHz: setup ddr speed (PLL2) to specified MHz.\n");
GEL_TextOut("Set_Psc_All_On: power-on all DSP peripherals domain/modules.\n");
GEL_TextOut("Set_Pin_Board: setup all DSP IO pins and also EVM settings to default.\n\n");
* NAME
* PURPOSE:
* USAGE
* Global_Default_Setup()
* RETURN VALUE
* NONE
* REFERENCE
hotmenu Global_Default_Setup()
* NAME
* Set_DSP_Cache
* PURPOSE:
* Setup the DSP caches with predefined cache size.
* USAGE
* Set_DSP_Cache()
* RETURN VALUE
* NONE
* REFERENCE
hotmenu Set_DSP_Cache( )
int l1p, l1d, l2;
GEL_TextOut( "Setup Cache... \n");
// Modify for the desired cache settings needed
CACHE_L1PCFG = 4; // L1P on, MAX size
CACHE_L1DCFG = 4; // L1D on, MAX size
CACHE_L2CFG = 0; // L2 off, use as RAM
l1p = (CACHE_L1PCFG & 0x7);
if ( l1p == 0 )
GEL_TextOut( "L1P = 0K \n" );
if ( l1p == 1 )
GEL_TextOut( "L1P = 4K \n" );
if ( l1p == 2 )
GEL_TextOut( "L1P = 8K \n" );
if ( l1p == 3 )
GEL_TextOut( "L1P = 16K \n" );
if ( l1p >= 4 )
GEL_TextOut( "L1P = 32K \n" );
l1d = (CACHE_L1DCFG & 0x7);
if ( l1d == 0 )
GEL_TextOut( "L1D = 0K \n" );
if ( l1d == 1 )
GEL_TextOut( "L1D = 4K \n" );
if ( l1d == 2 )
GEL_TextOut( "L1D = 8K \n" );
if ( l1d == 3 )
GEL_TextOut( "L1D = 16K \n" );
if ( l1d >= 4 )
GEL_TextOut( "L1D = 32K \n" );
l2 = (CACHE_L2CFG & 0x7);
if ( l2 == 0 )
GEL_TextOut( "L2 = ALL SRAM \n" );
if ( l2 == 1 )
GEL_TextOut( "L2 = 31/32 SRAM \n" );
if ( l2 == 2 )
GEL_TextOut( "L2 = 15/16 SRAM \n" );
if ( l2 == 3 )
GEL_TextOut( "L2 = 7/8 SRAM \n" );
if ( l2 == 4 )
GEL_TextOut( "L2 = 3/4 SRAM \n" );
if ( l2 == 5 )
GEL_TextOut( "L2 = 1/2 SRAM \n" );
if ( l2 >= 6 )
GEL_TextOut( "L2 = ALL CACHE \n" );
GEL_TextOut( "Setup Cache... Done.\n");
* NAME
* Set_Pll2_666_7_MHz
* PURPOSE:
* Setup PLL 2 DDR @ 666.7 MHz with External clock
* USAGE
* Set_Pll2_666_7_MHz()
* RETURN VALUE
* NONE
* REFERENCE
hotmenu Set_Pll2_666_7_MHz( )
Set_Pll2();
* NAME
* Set_Psc_All_On
* PURPOSE:
* Enable all PSC modules and DSP power domains on ALWAYSON, and wait
* for these power transitions to complete.
* USAGE
* Set_Psc_All_On()
* RETURN VALUE
* NONE
* REFERENCE
hotmenu Set_Psc_All_On( )
unsigned int i=0;
if (DNUM == 0)
GEL_TextOut( "Power on all PSC modules and DSP domains... \n");
Set_PSC_State(PD0, LPSC_EMIF25_SPI, PSC_ENABLE);
Set_PSC_State(PD0, LPSC_TSIP, PSC_ENABLE);
Set_PSC_State(PD1, LPSC_TETB_TRC, PSC_ENABLE);
Set_PSC_State(PD2, LPSC_PKTPROC, PSC_ENABLE);
Set_PSC_State(PD2, LPSC_CPGMAC, PSC_ENABLE);
Set_PSC_State(PD2, LPSC_Crypto, PSC_ENABLE);
Set_PSC_State(PD3, LPSC_PCIEX, PSC_ENABLE);
Set_PSC_State(PD4, LPSC_SRIO, PSC_ENABLE);
Set_PSC_State(PD5, LPSC_Hyperbridge, PSC_ENABLE);
Set_PSC_State(PD7, LPSC_MSMCSRAM, PSC_ENABLE);
GEL_TextOut( "Power on all PSC modules and DSP domains... Done.\n" );
else
* NAME
* Set_Pin_Board
* PURPOSE:
* Configure DSP IO pin and board for normal operation
* USAGE
* Set_Pin_Board()
* RETURN VALUE
* =1 SUCCESS, =0 FAIL
* REFERENCE
hotmenu Set_Pin_Board( )
int iResult=1,iData;
// Only core0 can set GPIO
if (DNUM == 0)
GEL_TextOut( "Set Board and DSP IO Pins... \n" );
// Configure DSP GP IO related to board functions
GPIO_BITEN=0; // Disable GPIO irq
GPIO_OUT_DATA=GPIO_DEFAULT_OUT; // Set pins correct out values
GPIO_DIR=GPIO_DEFAULT_DIR; // Configure io directions for EVM
// Checks if we got an error
if (iResult)
GEL_TextOut( "Set Board and DSP IO Pins... Done.\n" );
else
GEL_TextOut( "Set Board and DSP IO Pins... ERROR!\n",,2,, );
else
GEL_TextOut("DSP core #%d cannot set IO.\n",,2,,,DNUM);
return(iResult);
menuitem "EVMC6678L Debug Tools";
* NAME
* Debug_Tools_Help
* PURPOSE:
* Prints the help for the debug tools menu.
* USAGE
* RETURN VALUE
* NONE
* REFERENCE
hotmenu Debug_Tools_Help()
GEL_TextOut(" DEBUG TOOLS MENU HELP\n");
GEL_TextOut(" ---------------------\n\n");
GEL_TextOut("This menu is to do some specifics debug functions on EVM, or to get\n");
GEL_TextOut(" some debug informations.\n\n");
GEL_TextOut("Invalidate_Cache: allows to purge all DSP cache (destroy L1P, L1D, L2).\n");
GEL_TextOut("Flush_Cache: allows to flush all DSP cache (L1P, L1D, L2) to lower\n");
GEL_TextOut(" memory and then invalidates the cache contents.\n");
GEL_TextOut("Core_Info: displays the DSP core id where GEL is currently running.\n");
GEL_TextOut("Ask_MDIO_Control: ask for MDIO control access to the PHY.\n");
GEL_TextOut("Release_MDIO_Control: release of MDIO control access to the PHY.\n");
GEL_TextOut("Displays_Dsp_Role_Info: displays if the current dsp is dsp1 or dsp2.\n");
GEL_TextOut("Dump_FPGA_Registers: displays a list of all FPGA internal registers values.\n\n");
//GEL_TextOut("Write_Image_2DSP_EEprom: write compiled dsp eeprom boot image to dsp eeprom,\n");
//GEL_TextOut(" last compiled image endianess must match current dsp mode.\n\n");
* NAME
* Invalidate_Cache
* PURPOSE:
* Invalidate L1P, L1D and L2 cache (purge all cache contents).
* USAGE
* Invalidate_Cache()
* RETURN VALUE
* NONE
* REFERENCE
hotmenu Invalidate_Cache()
GEL_TextOut( "Invalidate All Cache...\n" );
/* Invalidate L1P cache */
*(int*)L1PINV = 1;
// Wait for cache operation to finish
// Wait for transition to finish for max timeout time...
while(( *(int*)L1PINV & 0x0001 ) ) Wait_Soft(150);
/* Invalidate L1D cache */
*(int*)L1DINV = 1;
while( ( *(int*)L1DINV & 0x0001 ) ) Wait_Soft(150);
/* Invalidate L2 cache */
*(int*)L2INV = 1;
while( ( *(int*)L2INV & 0x0001 ) )Wait_Soft(150);
GEL_TextOut( "Invalidate All Cache... Done.\n" );
* NAME
* Flush_Cache
* PURPOSE:
* Invalidate L1P, FLUSH L1D and L2 cache (writeback dirty lines to
* lower memory and invalidates cache content).
* USAGE
* Flush_Cache()
* RETURN VALUE
* NONE
* REFERENCE
hotmenu Flush_Cache()
GEL_TextOut( "Flush All Cache...\n" );
*(int*)L1PINV = 1;
/* Flush L1D cache (writeback dirty lines to lower memory and invalidate all) */
*(int*)L1DWBINV = 1;
while( ( *(int*)L1DWBINV & 0x0001 ) ) Wait_Soft(150);
/* Flush L2 cache (writeback dirty lines to lower memory and invalidate all) */
*(int*)L2WBINV = 1;
while(( *(int*)L2WBINV & 0x0001 ) ) Wait_Soft(150);
GEL_TextOut( "Flush All Cache... Done.\n" );
* NAME
* Core_Info
* PURPOSE:
* Display on the screen information about the current running DSP core
* USAGE
* Called from program or GEL menu
* RETURN VALUE
* REFERENCE
hotmenu Core_Info( )
GEL_TextOut("DSP core #%d\n",,1,,,DNUM);
menuitem "Memory Map";
* NAME
* Memory_Map_Help
* PURPOSE:
* Prints the help for the memory map menu.
* USAGE
* RETURN VALUE
* NONE
* REFERENCE
hotmenu Memory_Map_Help()
GEL_TextOut(" MEMORY MAP MENU HELP\n");
GEL_TextOut(" --------------------\n\n");
GEL_TextOut("This menu is to do CCS memory map configuration for DSP.\n\n");
GEL_TextOut("Setup_Memory_Map: Configure CCS memory map to match DSP memory map (called at GEL init.).\n");
GEL_TextOut("Clear_Memory_Map: Clears (disables) CCS memory map configuration.\n\n");
* NAME
* Set_Timeout
* PURPOSE:
* Starts a timeout period of msec. The running timeout period can be
* query with Get_Timeout. To kill a running timeout before the end,
* call Kill_Timeout. Only one timeout period can be used at any time.
* A timeout period can be used to measure a period of time while doing
* anything else. Not accurate, sets timer at least as big as desired.
* USAGE
* Set_Timeout(msec)
* msec - (i) timeout period in msec (not very precise < sec range)
* RETURN VALUE
* NONE
* REFERENCE
Set_Timeout(msec)
// Cancel the current timer if not already expired
GEL_CancelTimer(TIMEOUT_ID);
// Starts the timeout period
_GEL_Global_Timeout1=1;
// Setup a callback routine with specified timeout
GEL_SetTimer(msec, TIMEOUT_ID, "_Timeout_Callback()");
* NAME
* Get_Timeout
* PURPOSE:
* Query the running state of a timeout period started by Set_Timeout.
* (see Set_Timeout for more info).
* USAGE
* Get_Timeout()
* RETURN VALUE
* 0:expired, 1:running
* REFERENCE
Get_Timeout()
if (!_GEL_Global_Timeout1)
// Return the global timeout status 1=running, 0=expired
return _GEL_Global_Timeout1;
* NAME
* Kill_Timeout
* PURPOSE:
* Cancel a running timeout period before it expires
* USAGE
* Kill_Timeout()
* RETURN VALUE
* NONE
* REFERENCE
Kill_Timeout()
// The timeout period is expired
_GEL_Global_Timeout1=0;
* NAME
* _Timeout_Callback
* PURPOSE:
* Internal Callback function used by Set_timeout
* USAGE
* This routine must not be called by itself.
* RETURN VALUE
* NONE
* REFERENCE
_Timeout_Callback()
* NAME
* Setup_Memory_Map
* PURPOSE:
* Setup the Memory Map for EVMC6678L.
* Defined memory location avoid debugger access outside these locations.
* USAGE
* Setup_Memory_Map()
* RETURN VALUE
* NONE
* REFERENCE
* Based on TMS320C6678 datasheet.
hotmenu Setup_Memory_Map( )
GEL_TextOut("Setup_Memory_Map...\n",,);
GEL_MapOn( );
GEL_MapReset( );
GEL_MapAddStr( 0x00800000, 0, 0x00080000, "R|W|AS4", 0 ); // Local L2 SRAM
GEL_MapAddStr( 0x00E00000, 0, 0x00008000, "R|W|AS4", 0 ); // Local L1P SRAM
GEL_MapAddStr( 0x00F00000, 0, 0x00008000, "R|W|AS4", 0 ); // Local L1D SRAM
GEL_MapAddStr( 0x01000000, 0, 0x01C00000, "R|W|AS4", 0 ); // C66x CorePac Registers
GEL_MapAddStr( 0x01D00000, 0, 0x00000080, "R|W|AS4", 0 ); // Tracer 0
GEL_MapAddStr( 0x01D08000, 0, 0x00000080, "R|W|AS4", 0 ); // Tracer 1
GEL_MapAddStr( 0x01D10000, 0, 0x00000080, "R|W|AS4", 0 ); // Tracer 2
GEL_MapAddStr( 0x01D18000, 0, 0x00000080, "R|W|AS4", 0 ); // Tracer 3
GEL_MapAddStr( 0x01D20000, 0, 0x00000080, "R|W|AS4", 0 ); // Tracer 4
GEL_MapAddStr( 0x01D28000, 0, 0x00000080, "R|W|AS4", 0 ); // Tracer 5
GEL_MapAddStr( 0x01D30000, 0, 0x00000080, "R|W|AS4", 0 ); // Tracer 6
GEL_MapAddStr( 0x01D38000, 0, 0x00000080, "R|W|AS4", 0 ); // Tracer 7
GEL_MapAddStr( 0x01D40000, 0, 0x00000080, "R|W|AS4", 0 ); // Tracer 8
GEL_MapAddStr( 0x01D48000, 0, 0x00000080, "R|W|AS4", 0 ); // Tracer 9
GEL_MapAddStr( 0x01D50000, 0, 0x00000080, "R|W|AS4", 0 ); // Tracer 10
GEL_MapAddStr( 0x01D58000, 0, 0x00000080, "R|W|AS4", 0 ); // Tracer 11
GEL_MapAddStr( 0x01D60000, 0, 0x00000080, "R|W|AS4", 0 ); // Tracer 12
GEL_MapAddStr( 0x01D68000, 0, 0x00000080, "R|W|AS4", 0 ); // Tracer 13
GEL_MapAddStr( 0x01D70000, 0, 0x00000080, "R|W|AS4", 0 ); // Tracer 14
GEL_MapAddStr( 0x01D78000, 0, 0x00000080, "R|W|AS4", 0 ); // Tracer 15
GEL_MapAddStr( 0x01E00000, 0, 0x00040000, "R|W|AS4", 0 ); // TSIP 0
GEL_MapAddStr( 0x01E80000, 0, 0x00040000, "R|W|AS4", 0 ); // TSIP 1
GEL_MapAddStr( 0x02000000, 0, 0x00090000, "R|W|AS4", 0 ); // Packet Accelerator Configuration
GEL_MapAddStr( 0x02090000, 0, 0x00030000, "R|W|AS4", 0 ); // Ethernet Switch Subsystem Configuration
GEL_MapAddStr( 0x020C0000, 0, 0x00040000, "R|W|AS4", 0 ); // Crypto Subsystem Configuration
GEL_MapAddStr( 0x02200000, 0, 0x00000080, "R|W|AS4", 0 ); // Timer0
GEL_MapAddStr( 0x02210000, 0, 0x00000080, "R|W|AS4", 0 ); // Timer1
GEL_MapAddStr( 0x02220000, 0, 0x00000080, "R|W|AS4", 0 ); // Timer2
GEL_MapAddStr( 0x02230000, 0, 0x00000080, "R|W|AS4", 0 ); // Timer3
GEL_MapAddStr( 0x02240000, 0, 0x00000080, "R|W|AS4", 0 ); // Timer4
GEL_MapAddStr( 0x02250000, 0, 0x00000080, "R|W|AS4", 0 ); // Timer5
GEL_MapAddStr( 0x02260000, 0, 0x00000080, "R|W|AS4", 0 ); // Timer6
GEL_MapAddStr( 0x02270000, 0, 0x00000080, "R|W|AS4", 0 ); // Timer7
GEL_MapAddStr( 0x02280000, 0, 0x00000080, "R|W|AS4", 0 ); // Timer8
GEL_MapAddStr( 0x02290000, 0, 0x00000080, "R|W|AS4", 0 ); // Timer9
GEL_MapAddStr( 0x022A0000, 0, 0x00000080, "R|W|AS4", 0 ); // Timer10
GEL_MapAddStr( 0x022B0000, 0, 0x00000080, "R|W|AS4", 0 ); // Timer11
GEL_MapAddStr( 0x022C0000, 0, 0x00000080, "R|W|AS4", 0 ); // Timer12
GEL_MapAddStr( 0x022D0000, 0, 0x00000080, "R|W|AS4", 0 ); // Timer13
GEL_MapAddStr( 0x022E0000, 0, 0x00000080, "R|W|AS4", 0 ); // Timer14
GEL_MapAddStr( 0x022F0000, 0, 0x00000080, "R|W|AS4", 0 ); // Timer15
GEL_MapAddStr( 0x02310000, 0, 0x00000200, "R|W|AS4", 0 ); // PLL Controller
GEL_MapAddStr( 0x02320000, 0, 0x00000100, "R|W|AS4", 0 ); // GPIO
GEL_MapAddStr( 0x02330000, 0, 0x00000400, "R|W|AS4", 0 ); // SmartReflex
GEL_MapAddStr( 0x02350000, 0, 0x00001000, "R|W|AS4", 0 ); // Power Sleep Controller
GEL_MapAddStr( 0x02360000, 0, 0x00000400, "R|W|AS4", 0 ); // Memory Protection Unit (MPU) 0
GEL_MapAddStr( 0x02368000, 0, 0x00000400, "R|W|AS4", 0 ); // Memory Protection Unit (MPU) 1
GEL_MapAddStr( 0x02370000, 0, 0x00000400, "R|W|AS4", 0 ); // Memory Protection Unit (MPU) 2
GEL_MapAddStr( 0x02378000, 0, 0x00000400, "R|W|AS4", 0 ); // Memory Protection Unit (MPU) 3
GEL_MapAddStr( 0x02440000, 0, 0x00004000, "R|W|AS4", 0 ); // DSP Trace Formatter 0
GEL_MapAddStr( 0x02450000, 0, 0x00004000, "R|W|AS4", 0 ); // DSP Trace Formatter 1
GEL_MapAddStr( 0x02460000, 0, 0x00004000, "R|W|AS4", 0 ); // DSP Trace Formatter 2
GEL_MapAddStr( 0x02470000, 0, 0x00004000, "R|W|AS4", 0 ); // DSP Trace Formatter 3
GEL_MapAddStr( 0x02480000, 0, 0x00004000, "R|W|AS4", 0 ); // DSP Trace Formatter 4
GEL_MapAddStr( 0x02490000, 0, 0x00004000, "R|W|AS4", 0 ); // DSP Trace Formatter 5
GEL_MapAddStr( 0x024A0000, 0, 0x00004000, "R|W|AS4", 0 ); // DSP Trace Formatter 6
GEL_MapAddStr( 0x024B0000, 0, 0x00004000, "R|W|AS4", 0 ); // DSP Trace Formatter 7
GEL_MapAddStr( 0x02530000, 0, 0x00000080, "R|W|AS4", 0 ); // I2C Data & Control
GEL_MapAddStr( 0x02540000, 0, 0x00000040, "R|W|AS4", 0 ); // UART
GEL_MapAddStr( 0x02600000, 0, 0x00002000, "R|W|AS4", 0 ); // Secondary Interrupt Controller (INTC) 0
GEL_MapAddStr( 0x02604000, 0, 0x00002000, "R|W|AS4", 0 ); // Secondary Interrupt Controller (INTC) 1
GEL_MapAddStr( 0x02608000, 0, 0x00002000, "R|W|AS4", 0 ); // Secondary Interrupt Controller (INTC) 2
GEL_MapAddStr( 0x0260C000, 0, 0x00002000, "R|W|AS4", 0 ); // Secondary Interrupt Controller (INTC) 3
GEL_MapAddStr( 0x02620000, 0, 0x00000400, "R|W|AS4", 0 ); // Chip-Level Registers
GEL_MapAddStr( 0x02640000, 0, 0x00000800, "R|W|AS4", 0 ); // Semaphore
GEL_MapAddStr( 0x02700000, 0, 0x00008000, "R|W|AS4", 0 ); // EDMA Channel Controller (TPCC) 0
GEL_MapAddStr( 0x02720000, 0, 0x00008000, "R|W|AS4", 0 ); // EDMA Channel Controller (TPCC) 1
GEL_MapAddStr( 0x02740000, 0, 0x00008000, "R|W|AS4", 0 ); // EDMA Channel Controller (TPCC) 2
GEL_MapAddStr( 0x02760000, 0, 0x00000400, "R|W|AS4", 0 ); // EDMA TPCC0 Transfer Controller (TPTC) 0
GEL_MapAddStr( 0x02768000, 0, 0x00000400, "R|W|AS4", 0 ); // EDMA TPCC0 Transfer Controller (TPTC) 1
GEL_MapAddStr( 0x02770000, 0, 0x00000400, "R|W|AS4", 0 ); // EDMA TPCC1 Transfer Controller (TPTC) 0
GEL_MapAddStr( 0x02778000, 0, 0x00000400, "R|W|AS4", 0 ); // EDMA TPCC1 Transfer Controller (TPTC) 1
GEL_MapAddStr( 0x02780000, 0, 0x00000400, "R|W|AS4", 0 ); // EDMA TPCC1 Transfer Controller (TPTC) 2
GEL_MapAddStr( 0x02788000, 0, 0x00000400, "R|W|AS4", 0 ); // EDMA TPCC1 Transfer Controller (TPTC) 3
GEL_MapAddStr( 0x02790000, 0, 0x00000400, "R|W|AS4", 0 ); // EDMA TPCC2 Transfer Controller (TPTC) 0
GEL_MapAddStr( 0x02798000, 0, 0x00000400, "R|W|AS4", 0 ); // EDMA TPCC2 Transfer Controller (TPTC) 1
GEL_MapAddStr( 0x027A0000, 0, 0x00000400, "R|W|AS4", 0 ); // EDMA TPCC2 Transfer Controller (TPTC) 2
GEL_MapAddStr( 0x027A8000, 0, 0x00000400, "R|W|AS4", 0 ); // EDMA TPCC2 Transfer Controller (TPTC) 3
GEL_MapAddStr( 0x027D0000, 0, 0x00004000, "R|W|AS4", 0 ); // TI Embedded Trace Buffer (TETB) - Core 0
GEL_MapAddStr( 0x027E0000, 0, 0x00004000, "R|W|AS4", 0 ); // TI Embedded Trace Buffer (TETB) - Core 1
GEL_MapAddStr( 0x027F0000, 0, 0x00004000, "R|W|AS4", 0 ); // TI Embedded Trace Buffer (TETB) - Core 2
GEL_MapAddStr( 0x02800000, 0, 0x00004000, "R|W|AS4", 0 ); // TI Embedded Trace Buffer (TETB) - Core 3
GEL_MapAddStr( 0x02810000, 0, 0x00004000, "R|W|AS4", 0 ); // TI Embedded Trace Buffer (TETB) - Core 4
GEL_MapAddStr( 0x02820000, 0, 0x00004000, "R|W|AS4", 0 ); // TI Embedded Trace Buffer (TETB) - Core 5
GEL_MapAddStr( 0x02830000, 0, 0x00004000, "R|W|AS4", 0 ); // TI Embedded Trace Buffer (TETB) - Core 6
GEL_MapAddStr( 0x02840000, 0, 0x00004000, "R|W|AS4", 0 ); // TI Embedded Trace Buffer (TETB) - Core 7
GEL_MapAddStr( 0x02850000, 0, 0x00008000, "R|W|AS4", 0 ); // TI Embedded Trace Buffer (TETB) - System
GEL_MapAddStr( 0x02900000, 0, 0x00008000, "R|W|AS4", 0 ); // Serial RapidIO Configuration
GEL_MapAddStr( 0x02A00000, 0, 0x00100000, "R|W|AS4", 0 ); // Queue Manager Subsystem Configuration
GEL_MapAddStr( 0x08000000, 0, 0x00010000, "R|W|AS4", 0 ); // Extended Memory Controller (XMC) Configuration
GEL_MapAddStr( 0x0BC00000, 0, 0x00100000, "R|W|AS4", 0 ); // Multicore Shared Memory Controller (MSMC) Config
GEL_MapAddStr( 0x0C000000, 0, 0x00400000, "R|W|AS4", 0 ); // Multicore Shared Memory (MSM)
GEL_MapAddStr( 0x10800000, 0, 0x00100000, "R|W|AS4", 0 ); // Core0 L2 SRAM
GEL_MapAddStr( 0x10E00000, 0, 0x00008000, "R|W|AS4", 0 ); // Core0 L1P SRAM
GEL_MapAddStr( 0x10F00000, 0, 0x00008000, "R|W|AS4", 0 ); // Core0 L1D SRAM
GEL_MapAddStr( 0x11800000, 0, 0x00100000, "R|W|AS4", 0 ); // Core1 L2 SRAM
GEL_MapAddStr( 0x11E00000, 0, 0x00008000, "R|W|AS4", 0 ); // Core1 L1P SRAM
GEL_MapAddStr( 0x11F00000, 0, 0x00008000, "R|W|AS4", 0 ); // Core1 L1D SRAM
GEL_MapAddStr( 0x12800000, 0, 0x00100000, "R|W|AS4", 0 ); // Core2 L2 SRAM
GEL_MapAddStr( 0x12E00000, 0, 0x00008000, "R|W|AS4", 0 ); // Core2 L1P SRAM
GEL_MapAddStr( 0x12F00000, 0, 0x00008000, "R|W|AS4", 0 ); // Core2 L1D SRAM
GEL_MapAddStr( 0x13800000, 0, 0x00100000, "R|W|AS4", 0 ); // Core3 L2 SRAM
GEL_MapAddStr( 0x13E00000, 0, 0x00008000, "R|W|AS4", 0 ); // Core3 L1P SRAM
GEL_MapAddStr( 0x13F00000, 0, 0x00008000, "R|W|AS4", 0 ); // Core3 L1D SRAM
GEL_MapAddStr( 0x14800000, 0, 0x00100000, "R|W|AS4", 0 ); // Core4 L2 SRAM
GEL_MapAddStr( 0x14E00000, 0, 0x00008000, "R|W|AS4", 0 ); // Core4 L1P SRAM
GEL_MapAddStr( 0x14F00000, 0, 0x00008000, "R|W|AS4", 0 ); // Core4 L1D SRAM
GEL_MapAddStr( 0x15800000, 0, 0x00100000, "R|W|AS4", 0 ); // Core5 L2 SRAM
GEL_MapAddStr( 0x15E00000, 0, 0x00008000, "R|W|AS4", 0 ); // Core5 L1P SRAM
GEL_MapAddStr( 0x15F00000, 0, 0x00008000, "R|W|AS4", 0 ); // Core5 L1D SRAM
GEL_MapAddStr( 0x16800000, 0, 0x00100000, "R|W|AS4", 0 ); // Core6 L2 SRAM
GEL_MapAddStr( 0x16E00000, 0, 0x00008000, "R|W|AS4", 0 ); // Core6 L1P SRAM
GEL_MapAddStr( 0x16F00000, 0, 0x00008000, "R|W|AS4", 0 ); // Core6 L1D SRAM
GEL_MapAddStr( 0x17800000, 0, 0x00100000, "R|W|AS4", 0 ); // Core7 L2 SRAM
GEL_MapAddStr( 0x17E00000, 0, 0x00008000, "R|W|AS4", 0 ); // Core7 L1P SRAM
GEL_MapAddStr( 0x17F00000, 0, 0x00008000, "R|W|AS4", 0 ); // Core7 L1D SRAM
GEL_MapAddStr( 0x20000000, 0, 0x00100000, "R|W|AS4", 0 ); // System Trace Manager (STM) Configuration
GEL_MapAddStr( 0x20B00000, 0, 0x00020000, "R|W|AS4", 0 ); // Boot ROM
GEL_MapAddStr( 0x20BF0000, 0, 0x00000400, "R|W|AS4", 0 ); // SPI
GEL_MapAddStr( 0x21000000, 0, 0x00000100, "R|W|AS4", 0 ); // DDR3 EMIF Configuration
GEL_MapAddStr( 0x21400000, 0, 0x00000080, "R|W|AS4", 0 ); // Hyperlink Config (local)
/* Uncomment the following line to see the hyperlink remote config registers.
* Accessing the remote registers, even indirectly (by dragging a memory window
* to be big enough to cover the remote registers) will result in a fatal error if
* hyperlink is powered on but the link has not been established.
// GEL_MapAddStr( 0x21400080, 0, 0x00000080, "R|W|AS4", 0 ); // Hyperlink Config (remote)
GEL_MapAddStr( 0x21800000, 0, 0x00008000, "R|W|AS4", 0 ); // PCIe Config
GEL_MapAddStr( 0x34000000, 0, 0x00200000, "R|W|AS4", 0 ); // Queue Manager Subsystem Data
GEL_MapAddStr( 0x34C00000, 0, 0x00030000, "R|W|AS4", 0 ); // TAC Data
GEL_MapAddStr( 0x40000000, 0, 0x10000000, "R|W|AS4", 0 ); // Hyperlink Data
GEL_MapAddStr( 0x50000000, 0, 0x10000000, "R|W|AS4", 0 ); // SRIO Data
GEL_MapAddStr( 0x60000000, 0, 0x10000000, "R|W|AS4", 0 ); // PCIe Data
GEL_MapAddStr( 0x70000000, 0, 0x04000000, "R|W|AS4", 0 ); // EMIF16 CS2 NAND
GEL_MapAddStr( 0x74000000, 0, 0x04000000, "R|W|AS4", 0 ); // EMIF16 CS3 NAND
GEL_MapAddStr( 0x78000000, 0, 0x04000000, "R|W|AS4", 0 ); // EMIF16 CS4 NOR
GEL_MapAddStr( 0x7C000000, 0, 0x04000000, "R|W|AS4", 0 ); // EMIF16 CS5 SRAM
GEL_MapAddStr( 0x80000000, 0, 0x80000000, "R|W|AS4", 0 ); // DDR3 EMIF Data
GEL_TextOut( "Setup_Memory_Map... Done.\n" );
* NAME
* Clear_Memory_Map
* PURPOSE:
* Clear the Memory Map in CCS.
* All memory locations are not verified anymore by CCS.
* USAGE
* Clear_Memory_Map()
* RETURN VALUE
* NONE
* REFERENCE
hotmenu Clear_Memory_Map( )
GEL_TextOut( "Clear_Memory_Map...\n" );
GEL_MapOff( );
GEL_MapReset( );
GEL_TextOut( "Clear_Memory_Map... Done.\n" );
/* xmc_setup() */
/* XMC MPAX register setting to access DDR3 config space */
#define XMPAX2_L (*(int*)(XMC_BASE_ADDR + 0x00000010))
#define XMPAX2_H (*(int*)(XMC_BASE_ADDR + 0x00000014))
xmc_setup()
/* mapping for ddr emif registers XMPAX*2 */
XMPAX2_L = 0x100000FF; /* replacement addr + perm*/
XMPAX2_H = 0x2100000B; /* base addr + seg size (64KB)*/ //"1B"-->"B" by xj
GEL_TextOut( "XMC Setup ... Done \n" );
/* ddr3_setup() */
/* DDR3 initialization */
int flag;
ddr3_setup_auto_lvl_1333()
int i,TEMP,startlo, stoplo,starthi, stophi;
KICK0 = KICK0_UNLOCK;
KICK1 = KICK1_UNLOCK;
/* Wait for PLL to lock = min 500 ref clock cycles.
With refclk = 100MHz, = 5000 ns = 5us */
/***************** 3.2 DDR3 PLL Configuration ************/
/* Done before */
/**************** 3.0 Leveling Register Configuration ********************/
/* Using partial automatic leveling due to errata */
/**************** 3.3 Leveling register configuration ********************/
DDR3_CONFIG_REG_0 &= ~(0x007FE000); // clear ctrl_slave_ratio field
DDR3_CONFIG_REG_0 |= 0x00200000; // set ctrl_slave_ratio to 0x100
DDR3_CONFIG_REG_12 |= 0x08000000; // Set invert_clkout = 1
DDR3_CONFIG_REG_0 |= 0xF; // set dll_lock_diff to 15
//From 4.2.1 Executing Partial Automatic Leveling -- Start
DDR3_CONFIG_REG_23 |= 0x00000200; //Set bit 9 = 1 to use forced ratio leveling for read DQS
//From 4.2.1 Executing Partial Automatic Leveling -- End
//Values with invertclkout = 1
/**************** 3.3 Partial Automatic Leveling ********************/
DATA0_WRLVL_INIT_RATIO = 0x5E;
DATA1_WRLVL_INIT_RATIO = 0x5E;
DATA2_WRLVL_INIT_RATIO = 0x5E;
DATA3_WRLVL_INIT_RATIO = 0x51;
DATA4_WRLVL_INIT_RATIO = 0x38;
DATA5_WRLVL_INIT_RATIO = 0x3A;
DATA6_WRLVL_INIT_RATIO = 0x24;
DATA7_WRLVL_INIT_RATIO = 0x20;
DATA8_WRLVL_INIT_RATIO = 0x44;
DATA0_GTLVL_INIT_RATIO = 0xDD;
DATA1_GTLVL_INIT_RATIO = 0xDD;
DATA2_GTLVL_INIT_RATIO = 0xBE;
DATA3_GTLVL_INIT_RATIO = 0xCA;
DATA4_GTLVL_INIT_RATIO = 0xA9;
DATA5_GTLVL_INIT_RATIO = 0xA7;
DATA6_GTLVL_INIT_RATIO = 0x9E;
DATA7_GTLVL_INIT_RATIO = 0xA1;
DATA8_GTLVL_INIT_RATIO = 0xBA;
//Do a PHY reset. Toggle DDR_PHY_CTRL_1 bit 15 0->1->0
DDR_DDRPHYC &= ~(0x00008000);
DDR_DDRPHYC |= (0x00008000);
/***************** 3.4 Basic Controller and DRAM Configuration ************/
DDR_SDRFC = 0x00005162; // enable configuration
/* DDR_SDTIM1 = 0x1113783C; */
TEMP = 0;
TEMP |= 0x8 << 25; // T_RP bit field 28:25
TEMP |= 0x8 << 21; // T_RCD bit field 24:21
TEMP |= 0x9 << 17; // T_WR bit field 20:17
TEMP |= 0x17 << 12; // T_RAS bit field 16:12
TEMP |= 0x20 << 6; // T_RC bit field 11:6
TEMP |= 0x7 << 3; // T_RRD bit field 5:3
TEMP |= 0x4; // T_WTR bit field 2:0
DDR_SDTIM1 = TEMP;
/* DDR_SDTIM2 = 0x30717FE3; */
TEMP = 0;
TEMP |= 0x3 << 28; // T_XP bit field 30:28
TEMP |= 0x71 << 16; // T_XSNR bit field 24:16
TEMP |= 0x1ff << 6; // T_XSRD bit field 15:6
TEMP |= 0x4 << 3; // T_RTP bit field 5:3
TEMP |= 0x3; // T_CKE bit field 2:0
DDR_SDTIM2 = TEMP;
/* DDR_SDTIM3 = 0x559F86AF; */
TEMP = 0;
TEMP |= 0x5 << 28; // T_PDLL_UL bit field 31:28 (fixed value)
TEMP |= 0x5 << 24; // T_CSTA bit field 27:24 (fixed value)
TEMP |= 0x4 << 21; // T_CKESR bit field 23:21
TEMP |= 0x3f << 15; // T_ZQCS bit field 20:15
TEMP |= 0x6a << 4; // T_RFC bit field 12:4
TEMP |= 0xf; // T_RAS_MAX bit field 3:0 (fixed value)
DDR_SDTIM3 = TEMP;
DDR_DDRPHYC = 0x0010010F;
DDR_ZQCFG = 0x70073214;
DDR_PMCTL = 0x0;
/* DDR_SDCFG = 0x63062A32; */
/* New value with DYN_ODT disabled and SDRAM_DRIVE = RZQ/7 //0x63222A32; // last config write DRAM init occurs */
TEMP = 0;
TEMP |= 0x3 << 29; // SDRAM_TYPE bit field 31:29 (fixed value)
TEMP |= 0x0 << 27; // IBANK_POS bit field 28:27
TEMP |= 0x3 << 24; // DDR_TERM bit field 26:24
TEMP |= 0x0 << 21; // DYN_ODT bit field 22:21
TEMP |= 0x1 << 18; // SDRAM_DRIVE bit field 19:18
TEMP |= 0x2 << 16; // CWL bit field 17:16
TEMP |= 0x0 << 14; // NM bit field 15:14
TEMP |= 0xA << 10; // CL bit field 13:10
TEMP |= 0x4 << 7; // ROWSIZE bit field 9:7
TEMP |= 0x3 << 4; // IBANK bit field 6:4
TEMP |= 0x0 << 3; // EBANK bit field 3:3
TEMP |= 0x2; // PAGESIZE bit field 2:0
DDR_SDCFG = TEMP;
//Wait 600us for HW init to complete
DDR_SDRFC = 0x00001450; //Refresh rate = (7.8*666MHz)
/**************** 4.2.1 Executing Partial Automatic Leveling ********************/
DDR_RDWR_LVL_RMP_CTRL = 0x80000000; //enable full leveling
DDR_RDWR_LVL_CTRL = 0x80000000; //Trigger full leveling - This ignores read DQS leveling result and uses ratio forced value
//(0x34) instead
//Wait for min 1048576 DDR clock cycles for leveling to complete = 1048576 * 1.5ns = 1572864ns = 1.57ms.
//Actual time = ~10-15 ms
GEL_TextOut("\nDDR3 initialization is complete.\n");
menuitem "CPSW Functions";
hotmenu configSGMIISerdes()
GEL_TextOut( "configSGMIISerdes Setup... Begin\n" );
/* Unlock Chip Level Registers */
SGMII_SERDES_CONTROL_PORT1 = 0x0;
SGMII_SERDES_CONTROL_PORT0 = 0x0;
/* Multiply to be 8 with Quarter Rate in the Rx registers */
SGMII_SERDES_CFGPLL = 0x00000041;
/* Wait */
Wait_Soft(100);
//31:25 Reserved 0000000
//23:24 LOOPBACK 00
// 22 ENOC 1
//21:18 EQ 0001
//17:15 CDR 001 -- first order threshold of 17
//14:12 LOS 000 -- tie off
//11:10 ALIGN 01 -- Comma Aligned
//09:07 TERM 100 -- tie off (100)
// 06 INVPAIR 0
//05:04 RATE 01 -- tie off (10) //00 = Full Rate, 01 = Half Rate (*0.5), 10 = Quarter Rate (*0.25)
//03:01 BUSWIDTH 000 -- tie off
// 00 ENRX 1
// 0000 0000 0100 0100 0000 0010 0001 0001 = 0x0044_0211 -- My estimated value
// 0000 0000 0100 0100 0000 0100 0001 0001 = 0x0044_0411 -- New DV value
// 0000 0000 0000 1000 0000 1000 0100 0001 = 0x0008_0841 -- Original DV value
SGMII_SERDES_CFGRX0 = 0x00700621;
SGMII_SERDES_CFGRX1 = 0x00700621;
//31:22 Reserved 0
//21:20 LOOPBACK 00
//19:18 RDTCT 00 -- tie off
// 17 ENIDL 0 -- tie off
// 16 MYSNC 1 -- tie off
//15:12 DEMPHASIS ???? - 0001 Lets give some de-emphasis
//11:08 SWING ????
// 07 CM 1 -- tie off
// 06 INVPAIR 0
// 00 ENTX 1
// 0000 0000 0011 0001 ???? ???? 1001 0001 = 0x0031_1E91 -- My estimated value
// 0000 0000 0000 0001 0000 1111 0001 0001 = 0x0001_0F11 -- New DV value
// 0000 0000 0100 0000 0001 1110 0100 0001 = 0x0040_1e41 -- Original DV value
SGMII_SERDES_CFGTX0 = 0x000108A1;
SGMII_SERDES_CFGTX1 = 0x000108A1;
SGMII_SERDES_AUX_CFG_PORT0 = 0x00000041;
SGMII_SERDES_AUX_CFG_PORT1 = 0x00000041;
/* waitforclock() */
Wait_Soft(1000);
SGMII_SERDES_MR_ADV_PORT0 = 0x1;
SGMII_SERDES_MR_ADV_PORT1 = 0x1;
Wait_Soft(100);
SGMII_SERDES_CONTROL_PORT1 = 0x1;
SGMII_SERDES_CONTROL_PORT0 = 0x1;
/*Configuring Sliver */
SGMII_SLIVER_MAXLEN2 = 0x2520;
SGMII_SLIVER_MAXLEN1 = 0x2520;
SGMII_SLIVER_MACCONTROL2 = 0xA1;
SGMII_SLIVER_MACCONTROL1 = 0xA1;
/* Lock Chip Level Registers */
KICK0 = KICK_LOCK;
KICK1 = KICK_LOCK;
GEL_TextOut("\nSGMII SERDES has been configured.\n");
/* Initialize switch configuration */
hotmenu setCpSwConfig()
/* Enable Port 0 */
CPSW3G_CONTROL_REG = 0x4;
CPSW3G_STAT_PORT_REG = 0xF;
/* Enable ALE. */
CPSW3G_ALE_CONTROL_REG = 0x80000000;
/* Enable ALE port state to Forward */
CPSW3G_ALE_PORT_0_CTL_REG = 0x3;
CPSW3G_ALE_PORT_1_CTL_REG = 0x3;
CPSW3G_ALE_PORT_2_CTL_REG = 0x3;
menuitem "PA PLL Functions";
/* Print the current PA PLL configuration */
hotmenu getPaPllConfig()
unsigned int passclksel = (DEVSTAT & PASSCLKSEL_MASK);
unsigned int papllctl0val = PAPLLCTL0;
unsigned int papllbypass;
unsigned int papllod;
unsigned int papllclkf;
unsigned int papllclkr;
unsigned int paplloutput;
if (passclksel == PASSCLKSEL_MASK) GEL_TextOut("PA PLL is using PASS_CLK as the input\n");
else GEL_TextOut("PA PLL is using SYSCLK/ALTCORECLK as the input\n");
papllbypass = (papllctl0val & PA_PLL_BYPASS_MASK);
if (papllbypass == PA_PLL_BYPASS_MASK) GEL_TextOut("PA PLL is in bypass mode\n");
else GEL_TextOut("PA PLL is in PLL mode\n");
papllod = (((papllctl0val & PA_PLL_CLKOD_MASK) >> 19) + 1);
GEL_TextOut("PA PLL fixed output divider = %d\n",,,,, papllod);
papllclkf = (((papllctl0val & PA_PLL_CLKF_MASK) >> 6) + 1);
GEL_TextOut("PA PLL programmable multiplier = %d\n",,,,, papllclkf);
papllclkr = (((papllctl0val & PA_PLL_CLKR_MASK) >> 0) +1);
GEL_TextOut("PA PLL programmable divider = %d\n",,,,, papllclkr);
/* Final multiply/divide value */
paplloutput = ((papllclkf)/(papllod * papllclkr));
GEL_TextOut("the output frequency should be %d times the PA reference clock\n",,,,, paplloutput);
* NAME
* Init_Pll2 (unsigned int multiplier, unsigned int divider)
* PURPOSE:
* Setup PLL 2 frequency for DDR3 clock.
* The Frequency is based on an external ddr3 clk input ref of 66.65 MHz clock.
* USAGE
* Init_Pll2( unsigned int multiplier, unsigned int divider)
* multiplier - (i) Multiplier
* divider - (i) Divider
* Note that the values above are actual register values, i.e.,
* the computed values - 1
* RETURN VALUE
* None
* REFERENCE
Init_Pll2(unsigned int multiplier, unsigned int divider)
unsigned int temp, i;
GEL_TextOut ( "DDR3 PLL (PLL2) Setup ... \n");
KICK0 = 0x83E70B13;
KICK1 = 0x95A4F1E0;
if (DNUM == 0)
* DDR3PLLCTL1 Bit map *
DDR3PLLCTL1 |= 0x00000040;
/* Put the PLL in PLL Mode *
* DDR3PLLCTL0 Bit map *
* |31...24 |23 |22...19 |18...6 |5...0 | *
* |BWADJ[7:0] |BYPASS |Reserved |PLLM |PLLD | */
DDR3PLLCTL0 |= 0x00800000; /* Set the Bit 23 */
/* Wait for the PLL Reset time (min: 5 us) */
/* In PLL Controller, reset the PLL (bit 13 in DDR3PLLCTL1 register) */
DDR3PLLCTL1 |= 0x00002000;
/* Set the divider values */
DDR3PLLCTL0 &= ~(0x0000003F);
DDR3PLLCTL0 |= (divider & 0x0000003F);
/* Set the Multipler values */
DDR3PLLCTL0 &= ~(0x0007FFC0);
DDR3PLLCTL0 |= ((multiplier << 6) & 0x0007FFC0 );
/* Set the BWADJ */
temp = ((multiplier + 1) >> 1) - 1;
DDR3PLLCTL0 &= ~(0xFF000000);
DDR3PLLCTL0 |= ((temp << 24) & 0xFF000000);
DDR3PLLCTL1 &= ~(0x0000000F);
DDR3PLLCTL1 |= ((temp >> 8) & 0x0000000F);
/*In DDR3PLLCTL1, write PLLRST = 0 to bring PLL out of reset */
DDR3PLLCTL1 &= ~(0x00002000);
/* Wait at least 500 * REFCLK cycles * PLLD (this is the PLL lock time) */
DDR3PLLCTL0 &= ~(0x00800000); /* ReSet the Bit 23 */
GEL_TextOut( "DDR3 PLL Setup... Done.\n" );
else
GEL_TextOut("DSP core #%d cannot set DDR3 PLL\n",,2,,,DNUM);
* NAME
* Init_Pll3
* PURPOSE:
* Setup PLL 3 frequency for DSP PASS clock.
* The Frequency is based on an external pass clk input ref of 122.88 MHz clock.
* USAGE
* Init_Pll3( unsigned int multiplier, unsigned int divider)
* REFERENCE
Init_Pll3(unsigned int multiplier, unsigned int divider)
GEL_TextOut ( "PA PLL (PLL3) Setup ... \n");
KICK0 = 0x83E70B13;
KICK1 = 0x95A4F1E0;
if (DNUM == 0)
* registers for the Main PLL, PA PLL, and PA PLL should be set to 1. *
* PAPLLCTL1 Bit map *
PAPLLCTL1 |= 0x00000040;
* PAPLLCTL0 Bit map *
PAPLLCTL0 |= 0x00800000; /* Set the Bit 23 */
/* In PLL Controller, reset the PLL (bit 14), set PLLSEL (bit 13) in PAPLLCTL1 register) */
PAPLLCTL1 |= 0x00006000;
PAPLLCTL0 &= ~(0x0000003F);
PAPLLCTL0 |= (divider & 0x0000003F);
PAPLLCTL0 &= ~(0x0007FFC0);
PAPLLCTL0 |= ((multiplier << 6) & 0x0007FFC0 );
/* Set the BWADJ */
PAPLLCTL0 &= ~(0xFF000000);
PAPLLCTL0 |= ((temp << 24) & 0xFF000000);
PAPLLCTL1 &= ~(0x0000000F);
PAPLLCTL1 |= ((temp >> 8) & 0x0000000F);
/*In PAPLLCTL1, write PLLRST = 0 to bring PLL out of reset */
PAPLLCTL1 &= ~(0x00004000);
PAPLLCTL0 &= ~(0x00800000); /* ReSet the Bit 23 */
GEL_TextOut( "PA PLL Setup... Done.\n" );
else
GEL_TextOut("DSP core #%d cannot set PA PLL\n",,2,,,DNUM);
/* EVMC6678L MENU */
menuitem "DDR EVMC6678L Functions";
* NAME
* Init XMC
* PURPOSE:
* Performs the Extended Memory Controller Setup
* USAGE
* InitXMC()
* RETURN VALUE
* NONE
* REFERENCE
hotmenu InitXMC()
xmc_setup();
* NAME
* Init Emif
* PURPOSE:
* Performs the External Memory Interface initialization
* USAGE
* InitEmif()
* RETURN VALUE
* NONE
* REFERENCE
hotmenu InitEmif_EVM()
/* L2 EDC Functions */
/* Enable/Disable L2 EDC and Check the Status */
/*Enable EDC on L2*/
CGEM_enableL2EDC ()
unsigned int status = 0;
*(unsigned int *)(L2EDCMD) = 0x1; //enable EDC
//Check the status
status = *(unsigned int *)(L2EDSTAT);
if ((status<<28) == 0x10000000)
GEL_TextOut("L2 error detection/correction logic is enabled.\n",,2,,);
else
GEL_TextOut("L2 error detection/correction logic enable is failed.\n",,2,,);
/*Disable EDC on L2*/
CGEM_disableL2EDC ()
*(unsigned int *)(L2EDCMD) = 0x4;
//Check the status
if ((status<<28) == 0x40000000)
GEL_TextOut("L2 error detection/correction logic is disabled.\n",,2,,);
else
GEL_TextOut("L2 error detection/correction logic disable is failed.\n",,2,,);
/*Enable EDC on DMC reads from an external address (Hits L2 cache) if L2EDCMD is enabled*/
CGEM_enableEDCDMCExternal ()
*(unsigned int *)(L2EDCEN) |= 0x1; //Set DL2CEN(bit0)=1
/*Enable EDC on PMC reads from an external address (Hits L2 cache) if L2EDCMD is enabled*/
CGEM_enableEDCPMCExternal ()
*(unsigned int *)(L2EDCEN) |= 0x2; //Set PL2CEN(bit1)=1
/*Enable EDC on DMC reads from L2SRAM if L2EDCMD is enabled*/
CGEM_enableEDCDMCL2SRAM ()
*(unsigned int *)(L2EDCEN) |= 0x4; //Set DL2SEN(bit2)=1
/*Enable EDC on PMC reads from L2SRAM if L2EDCMD is enabled*/
CGEM_enableEDCPMCL2SRAM ()
*(unsigned int *)(L2EDCEN) |= 0x8; //Set PL2SEN(bit3)=1
/*Enable EDC on SDMA reads from L2SRAM if L2EDCMD is enabled. This includes SRAM under cache*/
CGEM_enableEDCSDMAL2SRAM ()
*(unsigned int *)(L2EDCEN) |= 0x10; //Set SDMAEN(bit4)=1
/*Enable all bits in L2EDCEN*/
CGEM_enableEDCL2EDCEN ()
//Set DL2CEN(bit0),PL2CEN(bit1),DL2SEN(bit2),PL2SEN(bit3),SDMAEN(bit4)=1
*(unsigned int *)(L2EDCEN) |= 0x1F;
/*Disable all bits in L2EDCEN*/
CGEM_disableEDCL2EDCEN ()
//Clear DL2CEN(bit0),PL2CEN(bit1),DL2SEN(bit2),PL2SEN(bit3),SDMAEN(bit4)=0
*(unsigned int *)(L2EDCEN) &= 0xFFFFFFE0;
/* L1P EDC Functions */
/* Enable/Disable L1P EDC and Check the Status */
/*Enable EDC on L1P*/
CGEM_enableL1PEDC ()
*(unsigned int *)(L1PEDCMD) = 0x1; //Set EN(bit0)=1
//Check the status
status = *(unsigned int *)(L1PEDSTAT);
GEL_TextOut("L1P error detection logic is enabled.\n",,2,,);
else
GEL_TextOut("L1P error detection logic enable is failed.\n",,2,,);
/*Disable EDC on L1P*/
CGEM_disableL1PEDC ()
*(unsigned int *)(L1PEDCMD) = 0x4; //Set DIS(bit2)=1
//Check the status
GEL_TextOut("L1P error detection logic is disabled.\n",,2,,);
else
GEL_TextOut("L1P error detection logic disable is failed.\n",,2,,);
/* MSMC EDC Functions */
/* Enable/Disable MSMC EDC and Check the Status */
/*Enable EDC on MSMC*/
MSMC_enableEDC ()
*(unsigned int *)(SMEDCC) &= 0x7FFFFFFF; //Clear SEN(bit31)=0
*(unsigned int *)(SMEDCC) |= 0x40000000; //Set ECM(bit30)=1
//Check the status
status = *(unsigned int *)(SMEDCC);
if ((status>>30)==0x1)
GEL_TextOut("MSMC error detection/correction logic is enabled.\n",,2,,);
else
GEL_TextOut("MSMC error detection/correction logic enable is failed.\n",,2,,);
/* Note: Once MSMC EDC is enabled, error correction stays enabled until the MSMC is reset */
/* EVMC6678L EDC MENU */
menuitem "EVMC6678L EDC Functions";
* NAME
* Enable the EDC functions
* PURPOSE:
* Performs the the EDC enable for All of L1 and L2 memory
* USAGE
* EnableEDC_OneforAll()
* RETURN VALUE
* NONE
* REFERENCE
hotmenu EnableEDC_OneforAll()
CGEM_enableL1PEDC();
CGEM_enableEDCL2EDCEN();
CGEM_enableL2EDC();
MSMC_enableEDC();
* NAME
* PURPOSE:
* Performs the the EDC enable for L1P
* USAGE
* L1PEDCEnable()
* RETURN VALUE
* NONE
* REFERENCE
hotmenu L1PEDCEnable()
* NAME
* PURPOSE:
* Performs the the EDC enable for L2 memory
* USAGE
* L2EDCEnable()
* RETURN VALUE
* NONE
* REFERENCE
hotmenu L2EDCEnable()
CGEM_enableL2EDC();
* NAME
* PURPOSE:
* Performs the the EDC enable for MSMC memory
* USAGE
* MSMC_enableEDC()
* RETURN VALUE
* NONE
* REFERENCE
hotmenu MSMCEDCEnable()
MSMC_enableEDC();
* NAME
* Disable the EDC functions
* PURPOSE:
* Performs the the EDC disable for All of L1 and L2 memory
* USAGE
* DisableEDC_OneforAll()
* RETURN VALUE
* NONE
* REFERENCE
hotmenu DisableEDC_OneforAll()
CGEM_disableL1PEDC();
CGEM_disableEDCL2EDCEN();
CGEM_disableL2EDC();
* NAME
* PURPOSE:
* Performs the the EDC disable for L1P memory
* USAGE
* CGEM_disableL1PEDC()
* RETURN VALUE
* NONE
* REFERENCE
hotmenu L1PEDCDisable()
* NAME
* PURPOSE:
* Performs the the EDC disable for L2 memory
* USAGE
* L2EDCDisable()
* RETURN VALUE
* NONE
* REFERENCE
hotmenu L2EDCDisable()
果
