Other Parts Discussed in Thread: TVP5158
我使用DVRRDK_04.01.00.02 开发包,在linux下解压后,
使用 make dvr_rdk 编译的时候一直报错。。
# dvr_rdk_mcfw_api: ti816x-evm: Building dependancies
/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../ti_tools/cgt_a8/arago/linux-devkit/bin/arm-arago-linux-gnueabi-gcc
-DTI_816X_BUILD -DPLATFORM_EVM_SI -DUTILS_ASSERT_ENABLE -DSYSTEM_ETH_OFFLOAD_ENABLE -DSYSTEM_ETH_OFFLOAD_CORE_DSP -DTI816X_DVR -DENABLE_FB -D_GNU_SOURCE -DTI816X_2G_DDR
-I../inc -I../priv -I. -I/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../dvr_rdk
-I/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../dvr_rdk/mcfw/src_linux/osa/inc
-I/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../ti_tools/syslink/syslink_2_20_02_20/packages
-I/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../ti_tools/ipc/ipc_1_24_03_32/packages
-I/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../dvr_rdk/mcfw/interfaces
-I/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../dvr_rdk/mcfw/interfaces/common_def
-I/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../ti_tools/xdais/xdais_7_22_00_03/packages
-I/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../ti_tools/codecs/REL.500.V.H264AVC.D.HP.IVAHD.02.00.08.00/500.V.H264AVC.D.HP.IVAHD.02.00/IVAHD_001/Inc
-I/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../ti_tools/codecs/REL.500.V.MPEG4.D.IVAHD.01.00.11.00/500.V.MPEG4.D.ASP.IVAHD.01.00/IVAHD_001/Inc
-I/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../ti_tools/codecs/REL.500.V.MPEG2.D.IVAHD.01.00.12.00/500.V.MPEG2.D.IVAHD.01.00/IVAHD_001/inc
-I/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../ti_tools/codecs/REL.500.V.H264AVC.E.IVAHD.02.00.06.00/500.V.H264AVC.E.IVAHD.02.00/IVAHD_001/Inc
-I/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../ti_tools/codecs/REL.500.V.MJPEG.D.IVAHD.01.00.06.00/500.V.MJPEG.D.IVAHD.01.00/IVAHD_001/Inc
-I/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../ti_tools/codecs/REL.500.V.MJPEG.E.IVAHD.01.00.04.00/500.V.MJPEG.E.IVAHD.01.00/IVAHD_001/Inc
-I/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../ti_tools/codecs/REL.500.V.MPEG4.E.SP.IVAHD.01.00.01.00/500.V.MPEG4.E.SP.IVAHD.01.00/IVAHD_001/Inc
-I/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../dvr_rdk/mcfw/src_linux/devices/inc
-I/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../dvr_rdk/mcfw/src_linux/devices/tvp5158/inc
-I/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../dvr_rdk/mcfw/src_linux/devices/sii9022a/inc
-I/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../dvr_rdk/mcfw/src_linux/devices/thsfilters/inc
-I/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../dvr_rdk/mcfw/src_linux/devices/tw2968/inc
-I/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../ti_tools/linux_lsp/kernel/linux-dvr-rdk/usr/include
-I/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../ti_tools/linux_lsp/kernel/linux-dvr-rdk/arch/arm/include/ ti_vcap.c ti_venc.c ti_vcap_device.c ti_vdis.c ti_vgrpx.c ti_vdec.c ti_vdis_hdmi_ctrl_priv.c ti_vsys.c ti_audio.c -M > MAKEFILE.DEPEND
ti_vdis_hdmi_ctrl_priv.c:17:30: fatal error: linux/ti81xxhdmi.h: No such file or directory
compilation terminated.
/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/../dvr_rdk/makerules/common_footer_a8.mk:38: recipe for target 'depend' failed
make[3]: *** [depend] Error 1
make[3]: Leaving directory '/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/mcfw/src_linux/mcfw_api'
MAKEFILE.MK:34: recipe for target 'mcfw_api' failed
make[2]: *** [mcfw_api] Error 2
make[2]: Leaving directory '/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/mcfw/src_linux'
MAKEFILE.MK:3: recipe for target 'dvr_rdk' failed
make[1]: *** [dvr_rdk] Error 2
make[1]: Leaving directory '/home/zb/work/DVRRDK_04.01.00.02/dvr_rdk/mcfw/src_linux'
Makefile:54: recipe for target 'dvr_rdk_linux' failed
make: *** [dvr_rdk_linux] Error 2
正常的话,dvr_rdk_mcfw_api 编译在dvr_rdk/mcfw/src_linux/devices/tw2968/inc 这里就应该结束了啊,
为什么后面还会跑到 内核kernel里面去?
错误信息里面提到的fatal error: linux/ti81xxhdmi.h 头文件,是存在的啊。
