TMS320C6455: 处理器论坛
Part Number: TMS320C6455
工程师ccs3.3的,现在移植到ccs5.2修改了一些报错能成功编译。
1 在main函数开头加入断点。
2 连接仿真器,加载编译出来的6455.out文件后自动运行了。
3 这时候并没有跑到main函数断点出。
4 点击暂停按钮,单步执行,一直在汇编里跑进不了main函数断点。
请问下这个有人遇到过没?是ccs5.2配置问题还是代码问题呢?感激不尽!
  • 在ccs3.3中运行是可以的吗?
    ccs->run->debug configuration是否设置为main函数处停下,具体参考以下链接:
    software-dl.ti.com/.../ccs_debug-main.html
  • debug configuration是否设置为main的,请知悉!
  • debug configuration是设置为main,请知悉!还有其它原因吗?
  • 能跑到程序的入口点c_int00吗?
  • 跑不到啊;暂停后,单步执行,一直在汇编B0C1D6FC地址跑,但是我们的norflash是接到EMIFA CE3地址是B000 0000 - B07F FFFF,像是程序跑飞了。
  • 加载.out的时候,提示earlier errors prevent reading of target memory at memory B0000000等,加载后运行,暂停,单步执行现在又跑到e0001840了
  • cmd文件贴出来看一下,加大堆栈试一下。
    调试界面的截图请贴出来。
  • /*   Do *not* directly modify this file.  It was    */
    /*   generated by the Configuration Tool; any  */
    /*   changes risk being overwritten.                */
    /* INPUT dsk6455.cdb */
    /* MODULE PARAMETERS */
    -u _c6455_init
    GBL_USERINITFXN = _c6455_init;
    -u IRAM
    MEM_SEGZERO = IRAM;
    -u IRAM
    MEM_MALLOCSEG = IRAM;
    -u _CLK_gethtime
    CLK_TIMEFXN = _CLK_gethtime;
    -u HWI_F_dispatch
    CLK_HOOKFXN = HWI_F_dispatch;
    -u _KNL_tick
    PRD_THOOKFXN = _KNL_tick;
    -u IRAM
    RTDX_DATAMEMSEG = IRAM;
    -u IRAM
    HST_DSMBUFSEG = IRAM;
    -u GBL_NULL
    SWI_EHOOKFXN = GBL_NULL;
    -u GBL_NULL
    SWI_IHOOKFXN = GBL_NULL;
    -u SWI_F_exec
    SWI_EXECFXN = SWI_F_exec;
    -u SWI_F_run
    SWI_RUNFXN = SWI_F_run;
    -u IRAM
    TSK_STACKSEG = IRAM;
    -u __HOOK_doCreate
    TSK_VCREATEFXN = __HOOK_doCreate;
    -u __HOOK_doDelete
    TSK_VDELETEFXN = __HOOK_doDelete;
    -u __HOOK_doExit
    TSK_VEXITFXN = __HOOK_doExit;
    -u IDL_F_stub
    IDL_CALIBRFXN = IDL_F_stub;
    -u _UTL_doAbort
    SYS_ABORTFXN = _UTL_doAbort;
    -u _UTL_doError
    SYS_ERRORFXN = _UTL_doError;
    -u _UTL_halt
    SYS_EXITFXN = _UTL_halt;
    -u _UTL_doPutc
    SYS_PUTCFXN = _UTL_doPutc;
    -u _FXN_F_nop
    GIO_CREATEFXN = _FXN_F_nop;
    -u _FXN_F_nop
    GIO_DELETEFXN = _FXN_F_nop;
    -u _FXN_F_nop
    GIO_PENDFXN = _FXN_F_nop;
    -u _FXN_F_nop
    GIO_POSTFXN = _FXN_F_nop;
    /* OBJECT ALIASES */
    _CACHE_L1P = CACHE_L1P;
    _CACHE_L1D = CACHE_L1D;
    _IRAM = IRAM;
    _FLASHBOOT = FLASHBOOT;
    _FLASHREST = FLASHREST;
    _PRD_clock = PRD_clock;
    _prdNdk = prdNdk;
    _prdtimerTick = prdtimerTick;
    _prdGetRadStatus = prdGetRadStatus;
    _RTA_fromHost = RTA_fromHost;
    _RTA_toHost = RTA_toHost;
    _HWI_RESET = HWI_RESET;
    _HWI_NMI = HWI_NMI;
    _HWI_RESERVED0 = HWI_RESERVED0;
    _HWI_RESERVED1 = HWI_RESERVED1;
    _HWI_INT4 = HWI_INT4;
    _HWI_INT5 = HWI_INT5;
    _HWI_INT6 = HWI_INT6;
    _HWI_INT7 = HWI_INT7;
    _HWI_INT8 = HWI_INT8;
    _HWI_INT9 = HWI_INT9;
    _HWI_INT10 = HWI_INT10;
    _HWI_INT11 = HWI_INT11;
    _HWI_INT12 = HWI_INT12;
    _HWI_INT13 = HWI_INT13;
    _HWI_INT14 = HWI_INT14;
    _HWI_INT15 = HWI_INT15;
    _EVENT4 = EVENT4;
    _EVENT5 = EVENT5;
    _EVENT6 = EVENT6;
    _EVENT7 = EVENT7;
    _EVENT8 = EVENT8;
    _EVENT9 = EVENT9;
    _EVENT10 = EVENT10;
    _EVENT11 = EVENT11;
    _EVENT12 = EVENT12;
    _EVENT13 = EVENT13;
    _EVENT14 = EVENT14;
    _EVENT15 = EVENT15;
    _EVENT16 = EVENT16;
    _EVENT17 = EVENT17;
    _EVENT18 = EVENT18;
    _EVENT19 = EVENT19;
    _EVENT20 = EVENT20;
    _EVENT21 = EVENT21;
    _EVENT22 = EVENT22;
    _EVENT23 = EVENT23;
    _EVENT24 = EVENT24;
    _EVENT25 = EVENT25;
    _EVENT26 = EVENT26;
    _EVENT27 = EVENT27;
    _EVENT28 = EVENT28;
    _EVENT29 = EVENT29;
    _EVENT30 = EVENT30;
    _EVENT31 = EVENT31;
    _EVENT32 = EVENT32;
    _EVENT33 = EVENT33;
    _EVENT34 = EVENT34;
    _EVENT35 = EVENT35;
    _EVENT36 = EVENT36;
    _EVENT37 = EVENT37;
    _EVENT38 = EVENT38;
    _EVENT39 = EVENT39;
    _EVENT40 = EVENT40;
    _EVENT41 = EVENT41;
    _EVENT42 = EVENT42;
    _EVENT43 = EVENT43;
    _EVENT44 = EVENT44;
    _EVENT45 = EVENT45;
    _EVENT46 = EVENT46;
    _EVENT47 = EVENT47;
    _EVENT48 = EVENT48;
    _EVENT49 = EVENT49;
    _EVENT50 = EVENT50;
    _EVENT51 = EVENT51;
    _EVENT52 = EVENT52;
    _EVENT53 = EVENT53;
    _EVENT54 = EVENT54;
    _EVENT55 = EVENT55;
    _EVENT56 = EVENT56;
    _EVENT57 = EVENT57;
    _EVENT58 = EVENT58;
    _EVENT59 = EVENT59;
    _EVENT60 = EVENT60;
    _EVENT61 = EVENT61;
    _EVENT62 = EVENT62;
    _EVENT63 = EVENT63;
    _EVENT64 = EVENT64;
    _EVENT65 = EVENT65;
    _EVENT66 = EVENT66;
    _EVENT67 = EVENT67;
    _EVENT68 = EVENT68;
    _EVENT69 = EVENT69;
    _EVENT70 = EVENT70;
    _EVENT71 = EVENT71;
    _EVENT72 = EVENT72;
    _EVENT73 = EVENT73;
    _EVENT74 = EVENT74;
    _EVENT75 = EVENT75;
    _EVENT76 = EVENT76;
    _EVENT77 = EVENT77;
    _EVENT78 = EVENT78;
    _EVENT79 = EVENT79;
    _EVENT80 = EVENT80;
    _EVENT81 = EVENT81;
    _EVENT82 = EVENT82;
    _EVENT83 = EVENT83;
    _EVENT84 = EVENT84;
    _EVENT85 = EVENT85;
    _EVENT86 = EVENT86;
    _EVENT87 = EVENT87;
    _EVENT88 = EVENT88;
    _EVENT89 = EVENT89;
    _EVENT90 = EVENT90;
    _EVENT91 = EVENT91;
    _EVENT92 = EVENT92;
    _EVENT93 = EVENT93;
    _EVENT94 = EVENT94;
    _EVENT95 = EVENT95;
    _EVENT96 = EVENT96;
    _EVENT97 = EVENT97;
    _EVENT98 = EVENT98;
    _EVENT99 = EVENT99;
    _EVENT100 = EVENT100;
    _EVENT101 = EVENT101;
    _EVENT102 = EVENT102;
    _EVENT103 = EVENT103;
    _EVENT104 = EVENT104;
    _EVENT105 = EVENT105;
    _EVENT106 = EVENT106;
    _EVENT107 = EVENT107;
    _EVENT108 = EVENT108;
    _EVENT109 = EVENT109;
    _EVENT110 = EVENT110;
    _EVENT111 = EVENT111;
    _EVENT112 = EVENT112;
    _EVENT113 = EVENT113;
    _EVENT114 = EVENT114;
    _EVENT115 = EVENT115;
    _EVENT116 = EVENT116;
    _EVENT117 = EVENT117;
    _EVENT118 = EVENT118;
    _EVENT119 = EVENT119;
    _EVENT120 = EVENT120;
    _EVENT121 = EVENT121;
    _EVENT122 = EVENT122;
    _EVENT123 = EVENT123;
    _EVENT124 = EVENT124;
    _EVENT125 = EVENT125;
    _EVENT126 = EVENT126;
    _EVENT127 = EVENT127;
    _KNL_swi = KNL_swi;
    _PRD_swi = PRD_swi;
    _TSK_idle = TSK_idle;
    _TSK_Exec_NetCmd = TSK_Exec_NetCmd;
    _TSK_Exec_RADCMD = TSK_Exec_RADCMD;
    _IDL_cpuLoad = IDL_cpuLoad;
    _LNK_dataPump = LNK_dataPump;
    _RTA_dispatcher = RTA_dispatcher;
    _LOG_system = LOG_system;
    _IDL_busyObj = IDL_busyObj;
    _HOOK_KNL = HOOK_KNL;
    _hookNdk = hookNdk;
    /* MODULE GBL */
    SECTIONS {
       .vers (COPY): {} /* version information */
    -priority
    --trampolines
    -llnkrtdx.a64P
    -ldrivers.a64P         /* device drivers support */
    -lsioboth.a64P         /* supports both SIO models */
    -lbiosTCI6482.a64P     /* BIOS clock specific library */
    -lbios.a64P            /* DSP/BIOS support */
    -lrtdx64xplus.lib      /* RTDX support */
    -lrts64plus.lib        /* C and C++ run-time library support */
    _GBL_CACHE = GBL_CACHE;
    _BCACHE_bootInit=_FXN_F_nop;
    /* MODULE MEM */
    -stack 0x2800
    MEMORY {
       CACHE_L1P   : origin = 0xe00000,    len = 0x8000
       CACHE_L1D   : origin = 0xf00000,    len = 0x8000
       IRAM        : origin = 0x800000,    len = 0x200000
       FLASHBOOT   : origin = 0xb0020000,  len = 0x400
       FLASHREST   : origin = 0xb0020400,  len = 0x2dfc00
    /* MODULE CLK */
    SECTIONS {
       .clk: {
            *(.clk)
       } > IRAM, RUN_START(CLK_A_TABBEG)
    _CLK_PRD = CLK_PRD;
    _CLK_COUNTSPMS = CLK_COUNTSPMS;
    _CLK_REGS = CLK_REGS;
    _CLK_USETIMER = CLK_USETIMER;
    _CLK_TIMERNUM = CLK_TIMERNUM;
    _CLK_TDDR = CLK_TDDR;
    /* MODULE PRD */
    SECTIONS {
       .prd: RUN_START(PRD_A_TABBEG), RUN_END(PRD_A_TABEND) {
       } > IRAM
    PRD_A_TABLEN = 3;
    /* MODULE RTDX */
    _RTDX_interrupt_mask = 0x0;
    /* MODULE HST */
    _LNK_dspFrameReadyMask = LNK_dspFrameReadyMask;
    _LNK_dspFrameRequestMask = LNK_dspFrameRequestMask;
    _LNK_readDone = LNK_readDone;
    _LNK_readFail = LNK_readFail;
    _LNK_readPend = LNK_readPend;
    _LNK_writeFail = LNK_writeFail;
    _HWI_CFGDISPATCHED = HWI_CFGDISPATCHED;
    /* MODULE SWI */
    SECTIONS {
       .swi: RUN_START(SWI_A_TABBEG), RUN_END(SWI_A_TABEND) {
       } > IRAM
    SWI_A_TABLEN = 2;
    /* MODULE TSK */
    SECTIONS {
       .tsk: {
            *(.tsk)
       } > IRAM
    /* MODULE IDL */
    SECTIONS {
       .idl: {
            *(.idl)
       } > IRAM, RUN_START(IDL_A_TABBEG)
       .idlcal: {
            *(.idlcal)
       } > IRAM, RUN_START(IDL_A_CALBEG)
    LOG_A_TABLEN = 1; _LOG_A_TABLEN = 1;
    PIP_A_TABLEN = 2;
    SECTIONS {
            .hwi_vec: {
                *(.hwi_vec)
            } run > IRAM align = 0x400, RUN_START(HWI_A_VECS), load  > FLASHREST
            .gblinit:   {} > FLASHREST
            .sysinit:   {} > FLASHREST
            .sysdata: {} > IRAM
            .dsm: {} > IRAM
            .mem: 	  {} > IRAM
            .gio:     {} > IRAM
            .sys:     {} > IRAM
            .sysregs: {} > IRAM
            .hwi: {}  > IRAM
            .TSK_idle$stk: {
                *(.TSK_idle$stk)
            } > IRAM
            .TSK_Exec_NetCmd$stk: {
                *(.TSK_Exec_NetCmd$stk)
            } > IRAM
            .TSK_Exec_RADCMD$stk: {
                *(.TSK_Exec_RADCMD$stk)
            } > IRAM
            .bios:    {} load > FLASHREST, run > IRAM
            .trcdata:   {} load > FLASHREST, run > IRAM
            .rtdx_text: {} load > FLASHREST, run  > IRAM
            /* LOG_system buffer */
            .LOG_system$buf: align = 0x100 {} > IRAM
            .rtdx_data: align = 0x40 { . += 0x80; *(.rtdx_data) }   > IRAM
           /* RTA_fromHost buffer */
           .hst1: align = 0x4 {} > IRAM
           /* RTA_toHost buffer */
           .hst0: align = 0x4 {} > IRAM
            .args: align=4 fill=0 {
                *(.args)
                . += 0x4;
            } > IRAM
            .trace: fill = 0x0  align = 0x4 {
               _SYS_PUTCBEG = .;
               . += 0x200;
               _SYS_PUTCEND = . - 1;
            } > IRAM
            .hst: RUN_START(HST_A_TABBEG), RUN_START(_HST_A_TABBEG), RUN_END(HST_A_TABEND), RUN_END(_HST_A_TABEND) {
            } > IRAM
            .log: RUN_START(LOG_A_TABBEG), RUN_START(_LOG_A_TABBEG), RUN_END(LOG_A_TABEND), RUN_END(_LOG_A_TABEND) {
            } > IRAM
            .pip: RUN_START(PIP_A_TABBEG), RUN_START(_PIP_A_TABBEG), RUN_END(PIP_A_TABEND), RUN_END(_PIP_A_TABEND) {
            } > IRAM
            .sts: RUN_START(STS_A_TABBEG), RUN_START(_STS_A_TABBEG), RUN_END(STS_A_TABEND), RUN_END(_STS_A_TABEND) {
            } > IRAM
            .stack: align = 0x8 {
                GBL_stackbeg = .;
                *(.stack)
                GBL_stackend = GBL_stackbeg + 0x2800 - 1;
                _HWI_STKBOTTOM = GBL_stackbeg + 0x2800 - 8;
                _HWI_STKTOP = GBL_stackbeg;
            } > IRAM
            .IRAM$heap: {
                . += 0x40000;
            } RUN_START(IRAM$B), RUN_START(_IRAM_base), RUN_SIZE(IRAM$L), RUN_SIZE(_IRAM_length) > IRAM
     *  Copyright 2007 by Texas Instruments Incorporated.
     *  All rights reserved. Property of Texas Instruments Incorporated.
     *  Restricted rights to use, duplicate or disclose this code are
     *  granted through contract.
     *  @(#) TCP/IP_Network_Developers_Kit 1.92.00.22 01-10-2007 (ndk-b22)
    //-ldsk6455cfg.cmd
    // Specify below whether you want these NDK special memory sections to be
    // placed in a specific memory section. By default they are placed in the .far space.
    //   .far:NDK_PACKETMEM - Packet buffer memory (defined in HAL/OS libs)
    //   .far:NDK_MMBUFFER  - Scatchpad memory used by mmAlloc()
    //   .far:NDK_OBJMEM    - Large arrays (defined by example code only)
    SECTIONS
        .boot_load : >  FLASHBOOT
        .text      : load = FLASHREST, run = IRAM
        .const     : load = FLASHREST, run = IRAM
        .printf    : load = FLASHREST, run = IRAM
        .cinit      > 	FLASHREST
        .pinit      > 	FLASHREST
        .switch     > 	FLASHREST
        .binit      > 	FLASHREST
        .bss        >   IRAM
        .far        >   IRAM
        .data       >   IRAM
        .cio        >   IRAM
  • 请问下如何增加堆栈呢?谢谢
  • 您是直接将代码load到flash中的吗?在GEL文件中配置的读写时序?能否直接将代码放到内部ram或者DDR上跑了试一下。
    堆栈可以直接在cmd中配heap和stack。
  • 我不太清楚是不是直接load到flash了,哪儿看出直接load到flash了。
  • GEL用的系统自带的DSK6455.gel
  • 如何配置成load到RAM运行。具体在CMD怎么加堆栈呢,没改过,谢谢
  • section部分指向IRAM。例如修改 .text > IRAM。
    SECTIONS
    .cinit > FLASHREST
    .pinit > FLASHREST
    .switch > FLASHREST
    .binit > FLASHREST
    .bss > IRAM
    .far > IRAM
    .data > IRAM
    .cio > IRAM
  • 我已经按照你说的把myc6455.cmd的全部改成IRAM了但是load的时候还是跑到B0000000 emifa ce3的地址去了
    //-ldsk6455cfg.cmd
    SECTIONS
        .boot_load >  IRAM
        .text      > IRAM
        .const     > IRAM
        .printf    > IRAM
        .cinit      > 	IRAM
        .pinit      > 	IRAM
        .switch     > 	IRAM
        .binit      > 	IRAM
        .bss        >   IRAM
        .far        >   IRAM
        .data       >   IRAM
        .cio        >   IRAM
    这是我修改成IRAM的cmd文件
  • dsk6455cdb.txt这是cdb文件,由于后缀cdb不能上传,只能改成txt
  •  global STACKSIZE :: 10240 {
    inst iHeapSize :: 0x8000 {
    修改堆栈大小是不是cdb文件的以上2个地方?
  • cbd文件早期ccs上的文件吗?现在已经不用了。都是在cmd文件中配置。
    例如:
    -stack 0x1000
    -heap 0x2000
  • cdb文件是CCS3.3工程上面的;cmd文件是cdb生成的,所以只能在cdb改堆栈大小。
  • 从dsk6455cfg.cmd文件最后面内容看stack=0x2800 heap=0x4000,这个还要改大吗?
  • 现在load到emifa的nor flash,运行进不了main函数,昨天改了load到IRAM不起作用是哪儿的问题呢?
  • 在ccs3.3中是可以正常运行的是吗?导入例程试一下是否可以正常load。
    以下链接有一个从ccs3.3移植到新版ccs的文档也仔细阅读看一下。
    https://www.ti.com.cn/cn/lit/an/zhcaa58a/zhcaa58a.pdf
    堆栈可以尝试加大看一下有没有帮助。
  • CCS3.3是好的;例程在哪下载呢?;堆栈已经分别加大到0x100000  0x8000了是一样的效果;移植应该没问题都编译过了
  • 问题已经解决,配置成IRAM运行就可以了。
