DRA744: 关于SDIO DMA异常
Part Number: DRA744
insmod bcmdhd驱动后,在wifi发送扫描或者其它指令时,sdio驱动DMA报异常:omap_hsmmc 480d1000.mmc: MMC start dma failure
在此处代码触发异常:
static int omap_hsmmc_setup_dma_transfer(struct omap_hsmmc_host *host, struct mmc_request *req){
/* Sanity check: all the SG entries must be aligned by block size. */
 for (i = 0; i < data->sg_len; i++) {
  struct scatterlist *sgl;
  sgl = data->sg + i;
  if (sgl->length % data->blksz)
            return -EINVAL;
请问是什么原因导致这种异常发生?
