完全看不懂,然后就没反应了
/ # insmod cmemk.ko phys_start=0x88000000 phys_end=0x88200000 pools=2x831488,4x4096
CMEMK module: built on Apr 8 2013 at 14:40:48
Reference Linux version 2.6.32
File /home/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/
sdo/linuxutils/cmem/src/module/cmemk.c
allocated heap buffer 0xc9800000 of size 0x66000
BUG: scheduling while atomic: insmod/1156/0x00000105
Modules linked in: cmemk+) irqk edmak dm365mmap [last unloaded: cmemk]
Pid: 1156, comm: insmod
CPU: 0 Not tainted (2.6.32-17-ridgerun #2)
PC is at idr_get_empty_slot+0x8/0x2b0
LR is at ida_get_new_above+0x58/0x1f8
pc : [<c0179210>] lr : [<c0179510>] psr: 60000013
sp : c572dc14 ip : c572dc40 fp : c572dc94
r10: c0427654 r9 : 00000010 r8 : 00000000
r7 : 00000010 r6 : c572c000 r5 : 00000011 r4 : c5190500
r3 : 000000ff r2 : c572dc4c r1 : 00000011 r0 : c0427654
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 0005317f Table: 8571c000 DAC: 00000015
[<c002cf48>] (show_regs+0x0/0x50) from [<c0038a64>] (__schedule_bug+0x4c/0x60)
r5:c04e104e1cc0 r4:ffffffff
[<c02fed68>] (schedule+0x0/0x390) from [<c002bfb0>] (ret_slow_syscall+0x0/0x10)
Bad mode in data abort handler detected
Internal error: Oops - bad mode: 0 [#1] PREEMPT
last sysfs file: /sys/devices/virtual/irqk/irqk/dev
Modules linked in: cmemk+) irqk edmak dm36dgerun #2)
PC is at 0xc50f73c0
LR is at 0x35
pc : [<c50f73c0>] lr : [<00000035>] psr: 00000017
sp : c572bfb8 ip : 000000c2 fp : c572d908
r10: c572d95c r9 : 00000000 r8 : c50f6bd8
r7 : c028af70 r6 : c01f8e08 r5 : 00000000 r4 : 00000000
r3 : c50b2800 r2 : c002b074 r1 : c572d8e0 r0 : c572d95c
Flags: nzcv IRQs on FIQs on Mode ABT_32 ISA ARM Segment kernel
