我使用的开发板是OMPL137,开发环境是CCS3.3,现在单个的文件能被编译,但是所有文件一起编译就会出现以下问题:
>> error: linking files for incompatible targets (library
'C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/lnkrtdx.a674',
member 'rtdx.o674')
'C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios6747.a674',
member 'clk.o674')
'C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a674',
member 'knl_read.o674')
member 'hook_getenv.o674')
>> warning: creating output section $build.attributes without SECTIONS
specification
>> error: errors in input - ./bin/helloWorld.out not built
由于bios_5_31_02版本太低,我下了一个bios_5_33_06,将bios_5_33_06覆盖了原有的bios_5_31_02所有文件。
希望您能够帮助我上面的问题。期待您的回复!
