dm8148的nand flash启动问题
Other Parts Discussed in Thread: PCF8575
软件:ezsdk5.02
硬件:tmdxevm8148
我用mkfs.jffs2制作的文件系统,路径为:/usr/local/ezsdk/filesystem/arago_base_tisdk_image_dm814x_evm
命令为:mkfs.jffs2 -p -d /usr/local/ezsdk/filesystem/arago_base_tisdk_image_dm814x_evm -l -q -o rootfs.bin -v -n,
启动后触摸屏显示不正常,屏幕白了一半,另一半上有彩色的细条
1,请问我用的这个目录对吗?还是用另外的一个啊?用另外一个目录做出的文件系统好大,300M左右
2,nand flash启动后,怎样使触摸屏显示正常?
3,怎样执行omx上面得demo程序如capture_encoder等程序
4,我可以改为ezsdk5.05的软件版本吗?
下面是启动参数和log,请看一下nand flash启动是不是正常的?
nand flash已经有坏块了
printenv
bootdelay=3
baudrate=115200
autoload=yes
verify=yes
bootfile=uImage
ramdisk_file=ramdisk.gz
loadaddr=0x81000000
script_addr=0x80900000
loadbootscript=fatload mmc 0 ${script_addr} boot.scr
bootscript= echo Running bootscript from MMC/SD to set the ENV...; source ${scri
pt_addr}
ethaddr=00:18:32:63:1d:2b
ethact=cpsw
filesize=273760
fileaddr=81000000
ipaddr=192.168.1.123
serverip=192.168.1.111
bootcmd=nandecc sw;nand read 0x81000000 0x280000 0x440000;bootm 0x81000000
stdin=serial
stdout=serial
stderr=serial
bootargs=console=ttyO0,115200n8 root=/dev/mtdblock4 rw rootfstype=jffs2 mem=100M
 earlyprintk notifyk.vpssm3_sva=0xBF900000 vram=50M ti814xfb.vram=0:16M,1:16M,2:
6M ip=off noinitrd
Environment size: 688/8188 bytes
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.37 (x0029463@swubn01) (gcc version 4.3.3 (Sourcery G++ Lite 20
09q1-203) ) #1 Thu Nov 10 23:48:02 IST 2011
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8148evm
bootconsole [earlycon0] enabled
vram size = 52428800 at 0x0
reserved size = 52428800 at 0x0
FB: Reserving 52428800 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8148 2.0
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 12600
Kernel command line: console=ttyO0,115200n8 root=/dev/mtdblock4 rw rootfstype=jf
fs2 mem=100M earlyprintk notifyk.vpssm3_sva=0xBF900000 vram=50M ti814xfb.vram=0:
16M,1:16M,2:6M ip=off noinitrd
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 50MB = 50MB total
Memory: 44800k/44800k available, 57600k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xc6800000 - 0xf8000000   ( 792 MB)
    lowmem  : 0xc0000000 - 0xc6400000   ( 100 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .init : 0xc0008000 - 0xc003a000   ( 200 kB)
      .text : 0xc003a000 - 0xc04de000   (4752 kB)
      .data : 0xc04de000 - 0xc0526300   ( 289 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:407
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ400
Trying to install interrupt handler for IRQ401
Trying to install interrupt handler for IRQ402
Trying to install interrupt handler for IRQ403
Trying to install interrupt handler for IRQ404
Trying to install interrupt handler for IRQ405
Trying to install interrupt handler for IRQ406
Trying to install type control for IRQ407
Trying to set irq flags for IRQ407
OMAP clockevent source: GPTIMER1 at 20000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 598.01 BogoMIPS (lpj=2990080)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 4
registered ti814x_vpss device
registered TI814x on-chip HDMI device
NOR: Can't request GPMC CS
registered ti81xx_vidout device
Debugfs: Only enabling/disabling deep sleep and wakeup timer is supported now
Registered ti81xx_fb device
ti81xx_pcie: Invoking PCI BIOS...
ti81xx_pcie: Setting up Host Controller...
ti81xx_pcie: Register base mapped @0xc6820000
ti81xx_pcie: Starting PCI scan...
PCI: bus0: Fast back to back transfers enabled
bio: create slab <bio-0> at 0
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
pcf857x 1-0021: gpios 128..143 on a pcf8575
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, host, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
musb-hdrc musb-hdrc.0: MUSB HDRC host driver
musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.37 musb-hcd
usb usb1: SerialNumber: musb-hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
musb-hdrc musb-hdrc.0: USB Host mode controller at c681e000 using DMA, IRQ 18
musb-hdrc musb-hdrc.1: dma type: dma-cppi41
musb-hdrc musb-hdrc.1: MUSB HDRC host driver
musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.37 musb-hcd
usb usb2: SerialNumber: musb-hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
musb-hdrc musb-hdrc.1: USB Host mode controller at c6826800 using DMA, IRQ 19
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
msgmni has been set to 87
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled, bootconsole disabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
brd: module loaded
loop: module loaded
ahci ahci.0: forcing PORTS_IMPL to 0x1
ahci ahci.0: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc apst
scsi0 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x100 irq 16
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca (Micron )
Creating 6 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000020000 : "U-Boot-min"
0x000000020000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x0000006c0000 : "Kernel"
0x0000006c0000-0x00000cee0000 : "File System"
0x00000cee0000-0x000010000000 : "Reserved"
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffc
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver dm9601
usbcore: registered new interface driver cdc_acm
cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapter
s
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
ata1: SATA link down (SStatus 0 SControl 300)
qt602240_ts 1-004a: Family ID: 128 Variant ID: 1 Version: 22 Build: 171
qt602240_ts 1-004a: Matrix X Size: 18 Matrix Y Size: 12 Object Num: 17
input: AT42QT602240/ATMXT224 Touchscreen as /devices/platform/omap/omap_i2c.1/i2
c-1/1-004a/input/input0
omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.0.0)
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
notify_init : notify drivercreated  for  remote proc id 2 at physical Address 0x
bf900000
usbcore: registered new interface driver snd-usb-audio
asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
ALSA device list:
  #0: TI81XX EVM
TCP cubic registered
NET: Registered protocol family 17
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
Detected MACID=0:18:32:63:1d:2b
omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
VFS: Mounted root (jffs2 filesystem) on device 31:4.
devtmpfs: mounted
Freeing init memory: 200K
INIT: version 2.86 booting
Please wait: booting...
Error opening /dev/fb0: No such file or directory
Starting udev
udevd (76): /proc/76/oom_adj is deprecated, please use /proc/76/oom_score_adj in
stead.
Write verify error (ECC OK or unused) at 00eed000. Wrote:
00000000: 85 19 02 e0 44 00 00 00 1d fb f7 98 10 13 00 00
00000010: 01 00 00 00 a4 81 00 00 00 00 00 00 00 00 00 00
00000020: 86 43 6d 38 86 43 6d 38 86 43 6d 38 00 00 00 00
00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000040: 45 c7 7d 29 85 19 01 e0 2c 00 00 00 5f 56 f1 e0
00000050: 0c 13 00 00 1c 26 00 00 10 13 00 00 86 43 6d 38
00000060: 04 08 69 29 53 4a 64 01 f4 f4 4f 8f 75 74 6d 70
00000070: 85 19 02 e0 6d 00 00 00 a9 1b cd 45 10 13 00 00
00000080: 02 00 00 00 a4 81 00 00 00 00 00 00 80 01 00 00
00000090: 86 43 6d 38 86 43 6d 38 86 43 6d 38 00 00 00 00
000000a0: 29 00 00 00 80 01 00 00 06 00 6d 70 41 85 25 5c
000000b0: 77 44 c0 66 78 5e 62 65 60 60 30 04 62 42 a0 38
000000c0: 93 90 8a 51 79 58 08 b4 39 e7 5a 64 9d 61 c6 19
000000d0: 20 00 01 84 2c 01 10 60 00 e6 3b 03 ba ff ff ff
000000e0: 85 19 02 e0 4d 00 00 00 97 b4 ff e5 11 13 00 00
000000f0: 01 00 00 00 ff a1 00 00 00 00 00 00 09 00 00 00
00000100: 88 43 6d 38 88 43 6d 38 88 43 6d 38 00 00 00 00
00000110: 09 00 00 00 09 00 00 00 00 00 00 00 3f 14 ce 56
00000120: 2d 97 04 51 74 65 73 74 2d 6c 69 6e 6b ff ff ff
00000130: 85 19 01 e0 35 00 00 00 4a 4e e0 cd e3 01 00 00
00000140: 08 04 00 00 11 13 00 00 88 43 6d 38 0d 0a 00 00
00000150: 95 c7 83 4a 37 15 a1 b8 2e 69 73 2d 77 72 69 74
00000160: 65 61 62 6c 65 ff ff ff 85 19 01 e0 35 00 00 00
00000170: 4a 4e e0 cd e3 01 00 00 09 04 00 00 00 00 00 00
00000180: 88 43 6d 38 0d 00 00 00 8b d0 d5 49 37 15 a1 b8
00000190: 2e 69 73 2d 77 72 69 74 65 61 62 6c 65 ff ff ff
000001a0: 85 19 02 e0 44 00 00 00 1d fb f7 98 12 13 00 00
000001b0: 01 00 00 00 a4 81 00 00 00 00 00 00 00 00 00 00
000001c0: 88 43 6d 38 88 43 6d 38 88 43 6d 38 00 00 00 00
000001d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000001e0: d2 dd c5 21 85 19 01 e0 3f 00 00 00 2e ae 5d a2
000001f0: e3 01 00 00 0a 04 00 00 12 13 00 00 88 43 6d 38
00000200: 17 08 00 00 93 53 9d 86 df 3d a5 4a 37 30 2d 70
00000210: 65 72 73 69 73 74 65 6e 74 2d 6e 65 74 2e 72 75
00000220: 6c 65 73 ff 85 19 02 e0 8d 00 00 00 91 5a b2 93
00000230: 12 13 00 00 02 00 00 00 a4 81 00 00 00 00 00 00
00000240: 49 00 00 00 88 43 6d 38 88 43 6d 38 88 43 6d 38
00000250: 00 00 00 00 49 00 00 00 49 00 00 00 00 00 00 00
00000260: ef 56 6c a0 89 4b 0e a3 23 20 54 68 69 73 20 66
00000270: 69 6c 65 20 77 61 73 20 61 75 74 6f 6d 61 74 69
00000280: 63 61 6c 6c 79 20 67 65 6e 65 72 61 74 65 64 20
00000290: 62 79 20 74 68 65 20 2f 6c 69 62 2f 75 64 65 76
000002a0: 2f 77 72 69 74 65 5f 6e 65 74 5f 72 75 6c 65 73
000002b0: 0a ff ff ff 85 19 02 e0 86 00 00 00 90 dd b3 44
000002c0: 12 13 00 00 03 00 00 00 a4 81 00 00 00 00 00 00
000002d0: 8a 00 00 00 88 43 6d 38 88 43 6d 38 88 43 6d 38
000002e0: 48 00 00 00 42 00 00 00 42 00 00 00 00 00 00 00
000002f0: 96 1f ce 70 55 66 02 ae 0a 23 20 70 72 6f 67 72
00000300: 61 6d 2c 20 72 75 6e 20 62 79 20 74 68 65 20 70
00000310: 65 72 73 69 73 74 65 6e 74 2d 6e 65 74 2d 67 65
00000320: 6e 65 72 61 74 6f 72 2e 72 75 6c 65 73 20 72 75
00000330: 6c 65 73 20 66 69 6c 65 2e 0a ff ff 85 19 02 e0
00000340: 48 00 00 00 a5 44 21 d2 12 13 00 00 04 00 00 00
00000350: a4 81 00 00 00 00 00 00 8c 00 00 00 88 43 6d 38
00000360: 88 43 6d 38 88 43 6d 38 88 00 00 00 04 00 00 00
00000370: 04 00 00 00 00 00 00 00 a4 c3 06 13 30 1a ba 73
00000380: 2e 0a 23 0a 85 19 02 e0 83 00 00 00 a2 2d 6d 73
00000390: 12 13 00 00 05 00 00 00 a4 81 00 00 00 00 00 00
000003a0: cb 00 00 00 88 43 6d 38 88 43 6d 38 88 43 6d 38
000003b0: 8c 00 00 00 3f 00 00 00 3f 00 00 00 00 00 00 00
000003c0: 25 d7 2b 38 c5 1a 4f fd 23 20 59 6f 75 20 63 61
000003d0: 6e 20 6d 6f 64 69 66 79 20 69 74 2c 20 61 73 20
000003e0: 6c 6f 6e 67 20 61 73 20 79 6f 75 20 6b 65 65 70
000003f0: 20 65 61 63 68 20 72 75 6c 65 20 6f 6e 20 61 20
00000400: 73 69 6e 67 6c 65 0a ff 85 19 02 e0 7b 00 00 00
00000410: ea 13 bf 30 12 13 00 00 06 00 00 00 a4 81 00 00
00000420: 00 00 00 00 ff 00 00 00 88 43 6d 38 88 43 6d 38
00000430: 88 43 6d 38 c8 00 00 00 37 00 00 00 37 00 00 00
00000440: 00 00 00 00 07 d1 47 d1 44 2c f0 fa 6c 65 0a 23
00000450: 20 6c 69 6e 65 2c 20 61 6e 64 20 63 68 61 6e 67
00000460: 65 20 6f 6e 6c 79 20 74 68 65 20 76 61 6c 75 65
00000470: 20 6f 66 20 74 68 65 20 4e 41 4d 45 3d 20 6b 65
00000480: 79 2e 0a ff 85 19 02 e0 48 00 00 00 a5 44 21 d2
00000490: 12 13 00 00 07 00 00 00 a4 81 00 00 00 00 00 00
000004a0: 00 01 00 00 88 43 6d 38 88 43 6d 38 88 43 6d 38
000004b0: fc 00 00 00 04 00 00 00 04 00 00 00 00 00 00 00
000004c0: 68 85 de 3e ef 1c 27 70 79 2e 0a 0a 85 19 02 e0
000004d0: 54 00 00 00 82 ac ee c8 12 13 00 00 08 00 00 00
000004e0: a4 81 00 00 00 00 00 00 10 01 00 00 88 43 6d 38
000004f0: 88 43 6d 38 88 43 6d 38 00 01 00 00 10 00 00 00
00000500: 10 00 00 00 00 00 00 00 33 cd dc 14 e6 a1 3b 5b
00000510: 23 20 6e 65 74 20 64 65 76 69 63 65 20 28 29 0a
00000520: 85 19 02 e0 ba 00 00 00 89 9a 4e fe 12 13 00 00
00000530: 09 00 00 00 a4 81 00 00 00 00 00 00 91 01 00 00
00000540: 88 43 6d 38 88 43 6d 38 88 43 6d 38 10 01 00 00
00000550: 76 00 00 00 81 00 00 00 06 00 00 00 81 46 8b 28
00000560: a3 f7 0b 8d 78 5e 0a 0e 75 0a 8e 0c 0e 71 f5 b5
00000570: b5 55 ca 4b 2d 51 d2 51 70 74 0e f1 f4 f7 03 72
00000580: 13 53 52 80 5c 97 20 cf 30 d7 a0 60 20 df 5e 0b
00000590: 24 1b 12 12 54 0d 94 29 4a 2d 2e ae 05 0a 1a 18
000005a0: 58 19 5a 58 19 1b 59 99 19 5b 19 a6 58 19 25 c1
000005b0: d4 94 54 16 a4 82 14 18 02 05 bc 5d 83 fc 5c 7d
000005c0: 80 9c d4 92 0c 90 21 00 01 e4 e7 e8 eb 0a e6 18
000005d0: 28 71 01 04 18 00 13 6a 23 2c ff ff 85 19 04 20
000005e0: 24 02 00 00 b6 d3 19 9f 00 00 00 00 00 00 00 00
000005f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000600: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000610: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000620: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000630: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000640: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000650: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000660: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000670: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000680: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000690: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000006a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000006b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000006c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000006d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000006e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000006f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000700: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000710: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000720: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000730: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000740: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000750: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000760: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000770: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000780: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000790: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000007a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000007b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000007c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000007d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000007e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000007f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Read back:
00000100: 88 43 6d 38 88 43 6d 38 88 47 6d 38 00 00 00 00
00000200: 17 0a 00 00 93 53 9d 86 df 3d a5 4a 37 30 2d 70
00000490: 12 13 00 00 07 00 00 00 a4 81 00 00 80 00 00 00
Remounting root file system...
Caching udev devnodes
ALSA: Restoring mixer settings...
No state is present for card EVM
Found hardware: "" "" "" "" ""
Hardware is initialized using a generic method
Configuring e2fsprogs.
update-alternatives: Error: cannot register alternative chattr to /usr/bin/chatt
r since it is already registered to /bin/chattr
update-alternatives: Linking //sbin/uuidd to uuidd.util-linux-ng
Configuring update-modules.
Configuring dbus.
 Adding system startup for /etc/init.d/dbus-1.
/etc/modutils/ipv6: line 1: ipv6: not found
Error while executing /etc/modutils/ipv6, aborting
Configuring network interfaces...
CPSW phy found : id is : 0x4dd074
udhcpc (v1.13.2) started
Sending discover...
PHY: 0:01 - Link is Up - 0/Half
PHY: 0:01 - Link is Down
PHY: 0:00 - Link is Up - 100/Full
Sending discover...
Sending discover...
No lease, forking to background
done.
Setting up IP spoofing protection: rp_filter.
Fri Nov 11 01:29:00 UTC 2011
INIT: Entering runlevel: 5
Starting system message bus: dbus.
Starting telnet daemon.
Starting syslogd/klogd: done
Starting thttpdNET: Registered protocol family 10
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org dm814x-evm ttyO0
Arago 2011.09 dm814x-evm ttyO0
dm814x-evm login: root
root@dm814x-evm:~#
