TDA4 8.0 制作如下烧入SD卡:
Run vision apps on EVM in Linux+RTOS mode (via SD card boot)
使用的例程为C7x Kernel Application
但是报错:login incorrect
我输入的是root,不能进入。
整个log如下所示:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2021.09.24 19:12:10 =~=~=~=~=~=~=~=~=~=~=~=
U-Boot SPL 2021.01-g53e79d0e89 (Aug 04 2021 - 23:32:00 +0000)
Model: Texas Instruments K3 J721E SoC
Board: J721EX-PM2-SOM rev E8
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE: BL31: v2.5(release):08.00.00.004-dirty
NOTICE: BL31: Built : 22:30:09, Aug 4 2021
U-Boot SPL 2021.01-g53e79d0e89 (Aug 04 2021 - 22:33:28 +0000)
Detected: J7X-BASE-CPB rev E3
Detected: J7X-VSC8514-ETH rev E2
U-Boot 2021.01-g53e79d0e89 (Aug 04 2021 - 22:33:28 +0000)
SoC: J721E SR2.0
DRAM: 4 GiB
Flash: 0 Bytes
MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Net: am65_cpsw_nuss_slave ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
eth0: ethernet@46000000
Hit any key to stop autoboot: 2 1 0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
483 bytes read in 8 ms (58.6 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
1 bytes read in 10 ms (0 Bytes/s)
Already setup.
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
2555068 bytes read in 120 ms (20.3 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 2555068 bytes: Success!
506776 bytes read in 35 ms (13.8 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 506776 bytes: Success!
Failed to load '/lib/firmware/j7-main-r5f1_0-fw'
Failed to load '/lib/firmware/j7-main-r5f1_1-fw'
1579120 bytes read in 79 ms (19.1 MiB/s)
Load Remote Processor 6 with data@addr=0x82000000 1579120 bytes: Success!
Load Remote Processor 7 with data@addr=0x82000000 1579120 bytes: Success!
10403824 bytes read in 194 ms (51.1 MiB/s)
Load Remote Processor 8 with data@addr=0x82000000 10403824 bytes: Success!
19137024 bytes read in 812 ms (22.5 MiB/s)
97586 bytes read in 15 ms (6.2 MiB/s)
10737 bytes read in 10 ms (1 MiB/s)
## Flattened Device Tree blob at 88000000
Booting using the fdt blob at 0x88000000
Loading Device Tree to 000000008fee5000, end 000000008fffffff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 5.10.41-g4c2eade9f7 (adas@adas) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Thu Aug 19 11:33:19 CST 2021
[ 0.000000] Machine model: Texas Instruments K3 J721E SoC
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 576 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000aeffffff]
[ 0.000000] node 0: [mem 0x00000000af000000-0x00000000afffffff]
[ 0.000000] node 0: [mem 0x00000000b0000000-0x00000000b7ffffff]
[ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff]
[ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000fbffffff]
[ 0.000000] node 0: [mem 0x00000000fc000000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x000000088fffffff]
[ 0.000000] node 0: [mem 0x0000000890000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[ 0.000000] cma: Failed to reserve 512 MiB
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 65472
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57344k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=1f9bd483-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x000000009a800000-0x000000009e800000] (64MB)
[ 0.000000] Memory: 2319360K/4194304K available (10816K kernel code, 1344K rwdata, 4288K rodata, 1856K init, 758K bss, 1874944K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8a0800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008a00b0000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a00c0000
[ 0.000000] random: get_random_bytes called from start_kernel+0x32c/0x4d4 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008403] Console: colour dummy device 80x25
[ 0.012968] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023638] pid_max: default: 32768 minimum: 301
[ 0.028385] LSM: Security Framework initializing
[ 0.033132] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[ 0.040701] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[ 0.049727] rcu: Hierarchical SRCU implementation.
[ 0.054786] Platform MSI: msi-controller@1820000 domain created
[ 0.061059] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.070364] EFI services will not be available.
[ 0.075135] smp: Bringing up secondary CPUs ...
[ 0.080345] Detected PIPT I-cache on CPU1
[ 0.080370] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.080381] GICv3: CPU1: using allocated LPI pending table @0x00000008a00d0000
[ 0.080417] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.080473] smp: Brought up 1 node, 2 CPUs
[ 0.109820] SMP: Total of 2 processors activated.
[ 0.114625] CPU features: detected: 32-bit EL0 Support
[ 0.119879] CPU features: detected: CRC32 instructions
[ 0.133704] CPU: All CPU(s) started at EL2
[ 0.137901] alternatives: patching kernel code
[ 0.142924] devtmpfs: initialized
[ 0.151401] KASLR disabled due to lack of seed
[ 0.156068] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.166031] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[ 0.173178] pinctrl core: initialized pinctrl subsystem
[ 0.178738] DMI not present or invalid.
[ 0.182964] NET: Registered protocol family 16
[ 0.187737] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.195069] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.203033] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.211314] thermal_sys: Registered thermal governor 'step_wise'
[ 0.211316] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.217720] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.231352] ASID allocator initialised with 65536 entries
[ 0.251981] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[ 0.258838] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[ 0.265595] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.273358] cryptd: max_cpu_qlen set to 1000
[ 0.279383] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[ 0.288212] vsys_3v3: supplied by evm_12v0
[ 0.292560] vsys_5v0: supplied by evm_12v0
[ 0.297191] iommu: Default domain type: Translated
[ 0.302320] SCSI subsystem initialized
[ 0.306444] mc: Linux media interface: v0.10
[ 0.310815] videodev: Linux video capture interface: v2.00
[ 0.316443] pps_core: LinuxPPS API ver. 1 registered
[ 0.321513] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.330850] PTP clock support registered
[ 0.334867] EDAC MC: Ver: 3.0.0
[ 0.338619] FPGA manager framework
[ 0.342124] Advanced Linux Sound Architecture Driver Initialized.
[ 0.348733] clocksource: Switched to clocksource arch_sys_counter
[ 0.355153] VFS: Disk quotas dquot_6.6.0
[ 0.359200] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[ 0.368855] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
[ 0.375150] NET: Registered protocol family 2
[ 0.379748] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
[ 0.388351] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[ 0.397134] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[ 0.405336] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[ 0.413293] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.420040] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[ 0.426930] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[ 0.434327] NET: Registered protocol family 1
[ 0.439041] RPC: Registered named UNIX socket transport module.
[ 0.445097] RPC: Registered udp transport module.
[ 0.449911] RPC: Registered tcp transport module.
[ 0.454715] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.461299] PCI: CLS 0 bytes, default 64
[ 0.465643] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.475990] Initialise system trusted keyrings
[ 0.480610] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[ 0.488874] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.495079] NFS: Registering the id_resolver key type
[ 0.500275] Key type id_resolver registered
[ 0.504547] Key type id_legacy registered
[ 0.508666] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.515514] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.523155] 9p: Installing v9fs 9p2000 file system support
[ 0.547862] Key type asymmetric registered
[ 0.552049] Asymmetric key parser 'x509' registered
[ 0.557048] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.564606] io scheduler mq-deadline registered
[ 0.569231] io scheduler kyber registered
[ 0.574430] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.580612] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 0.589055] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.595314] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.603097] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.611167] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 0.620510] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
[ 0.630149] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
[ 0.638045] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 0.650907] brd: module loaded
[ 0.656960] loop: module loaded
[ 0.660484] sysfs: cannot create duplicate filename '/devices/platform/dma_buf_phys'
[ 0.668411] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.10.41-g4c2eade9f7 #1
[ 0.675610] Hardware name: Texas Instruments K3 J721E SoC (DT)
[ 0.681565] Call trace:
[ 0.684068] dump_backtrace+0x0/0x1a0
[ 0.687804] show_stack+0x18/0x68
[ 0.691188] dump_stack+0xd0/0x12c
[ 0.694658] sysfs_warn_dup+0x60/0x80
[ 0.698393] sysfs_create_dir_ns+0xe0/0xf8
[ 0.702574] kobject_add_internal+0x98/0x288
[ 0.706930] kobject_add+0x94/0x100
[ 0.710492] device_add+0xe0/0x748
[ 0.713960] platform_device_add+0x100/0x238
[ 0.718317] platform_device_register_full+0xcc/0x150
[ 0.723475] dma_buf_phys_init+0x6c/0x9c
[ 0.727477] do_one_initcall+0x54/0x1b8
[ 0.731390] kernel_init_freeable+0x1d4/0x23c
[ 0.735837] kernel_init+0x14/0x114
[ 0.739394] ret_from_fork+0x10/0x34
[ 0.743059] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't try to register things with the same name in the same directory.
[ 0.756224] megasas: 07.714.04.00-rc1
[ 0.761138] libphy: Fixed MDIO Bus: probed
[ 0.765777] tun: Universal TUN/TAP device driver, 1.6
[ 0.771182] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.777587] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.783655] sky2: driver version 1.30
[ 0.787893] VFIO - User Level meta-driver version: 0.3
[ 0.793569] i2c /dev entries driver
[ 0.797716] sdhci: Secure Digital Host Controller Interface driver
[ 0.804032] sdhci: Copyright(c) Pierre Ossman
[ 0.808647] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.814945] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.821259] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.828363] optee: probing for conduit method.
[ 0.832920] optee: revision 3.12 (3d47a131)
[ 0.833167] optee: initialized driver
[ 0.842470] NET: Registered protocol family 17
[ 0.847082] 9pnet: Installing 9P2000 support
[ 0.851466] Key type dns_resolver registered
[ 0.855950] Loading compiled-in X.509 certificates
[ 0.865053] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.871382] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.879422] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
[ 0.905720] random: fast init done
[ 0.928570] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 0.936149] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[ 0.942251] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.948316] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[ 0.954695] pca953x 3-0020: supply vcc not found, using dummy regulator
[ 0.961528] pca953x 3-0020: using no AI
[ 0.989465] pca953x 3-0022: supply vcc not found, using dummy regulator
[ 0.996263] pca953x 3-0022: using AI
[ 1.000528] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
[ 1.006503] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
[ 1.012744] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
[ 1.019235] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 1.028615] omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz
[ 1.034884] pca953x 5-0020: supply vcc not found, using dummy regulator
[ 1.041702] pca953x 5-0020: using no AI
[ 1.069379] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
[ 1.075433] omap_i2c 2040000.i2c: bus 6 rev0.12 at 100 kHz
[ 1.081386] omap_i2c 2050000.i2c: bus 7 rev0.12 at 100 kHz
[ 1.087771] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[ 1.097735] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[ 1.106533] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[ 1.116356] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 1.134147] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 1.141840] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 1.150118] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 1.158397] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.168740] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
[ 2.175148] pci_bus 0000:00: root bus resource [bus 00-0f]
[ 2.180753] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[ 2.190444] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
[ 2.197493] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[ 2.203632] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 2.213501] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 2.223390] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
[ 2.233351] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[ 2.243320] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
[ 2.253280] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
[ 2.263264] pci 0000:00:00.0: supports D1
[ 2.267358] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 2.273230] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
[ 2.285263] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.293451] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[ 2.303427] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[ 2.313387] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[ 2.325168] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01
[ 2.331938] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 2.337220] pcieport 0000:00:00.0: PME: Signaling with IRQ 49
[ 2.343604] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.351276] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 2.359556] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 2.367834] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.376371] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
[ 3.382783] pci_bus 0001:00: root bus resource [bus 00-0f]
[ 3.388389] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[ 3.398257] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
[ 3.405302] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
[ 3.411506] pci 0001:00:00.0: supports D1
[ 3.415600] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
[ 3.423450] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.433522] pci_bus 0001:01: busn_res: [bus 01-0f] end is updated to 01
[ 3.440289] pci 0001:00:00.0: PCI bridge to [bus 01]
[ 3.445556] pcieport 0001:00:00.0: PME: Signaling with IRQ 52
[ 3.451880] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[ 3.459553] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
[ 3.467831] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[ 3.476109] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 4.486410] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
[ 4.492833] pci_bus 0002:00: root bus resource [bus 00-0f]
[ 4.498438] pci_bus 0002:00: root bus resource [io 0x20000-0x2ffff] (bus address [0x1000-0x10fff])
[ 4.507685] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
[ 4.518462] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
[ 4.524663] pci 0002:00:00.0: supports D1
[ 4.528757] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
[ 4.536604] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 4.546669] pci_bus 0002:01: busn_res: [bus 01-0f] end is updated to 01
[ 4.553441] pci 0002:00:00.0: PCI bridge to [bus 01]
[ 4.558712] pcieport 0002:00:00.0: PME: Signaling with IRQ 55
[ 4.565436] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[ 4.575315] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 4.582074] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 4.591005] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[ 4.601159] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 4.607918] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 4.615870] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[ 4.625236] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
[ 4.633982] printk: console [ttyS2] enabled
[ 4.642419] printk: bootconsole [ns16550a0] disabled
[ 4.652862] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
[ 4.661778] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
[ 4.671370] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 4.681887] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[ 4.692040] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[ 4.702278] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[ 4.713009] scsi host0: ufshcd
[ 4.734837] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
[ 4.756737] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 4.764384] libphy: 46000f00.mdio: probed
[ 4.769789] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 4.778097] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 4.792089] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 4.800892] mmc0: CQHCI version 5.10
[ 4.804826] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 4.812528] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
[ 4.824558] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
[ 4.835904] scsi 0:0:0:49488: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[ 4.840737] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 4.844896] scsi 0:0:0:49476: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[ 4.862108] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
[ 4.870900] vdd_mmc1: supplied by vsys_3v3
[ 4.875879] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 4.882766] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 4.889591] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[ 4.896406] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[ 4.903205] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[ 4.912820] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 4.922869] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[ 4.935612] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
[ 4.940852] mtd: 47040000.spi.0: partitioning exceeds flash size, truncating
[ 4.947893] mtd: 47040000.spi.0: skipping zero sized partition
[ 4.953714] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[ 4.960313] Creating 7 MTD partitions on "47040000.spi.0":
[ 4.965791] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 4.971805] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 4.977486] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 4.983289] 0x000000680000-0x0000006c0000 : "ospi.env"
[ 4.988800] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[ 4.994504] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
[ 5.000632] 0x000000800000-0x000004000000 : "ospi.rootfs"
[ 5.008782] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
[ 5.018562] mmc0: Command Queue Engine enabled
[ 5.023005] mmc0: new HS400 MMC card at address 0001
[ 5.028271] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[ 5.032907] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[ 5.038919] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[ 5.044913] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
[ 5.052747] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 5.060427] libphy: 46000f00.mdio: probed
[ 5.065690] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 5.073993] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 5.087574] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 5.094502] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 5.101713] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 5.107998] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 5.118442] mmc1: CQHCI version 5.10
[ 5.122248] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 5.135060] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 5.142463] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 5.149775] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 5.157083] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[ 5.165147] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 5.180657] ALSA device list:
[ 5.183626] No soundcards found.
[ 6.191468] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 6.199504] Waiting for root device PARTUUID=1f9bd483-02...
[ 6.254603] mmc1: new ultra high speed DDR50 SDHC card at address 0001
[ 6.261460] mmcblk1: mmc1:0001 SD 14.8 GiB
[ 6.268133] mmcblk1: p1 p2
[ 6.948456] EXT4-fs (mmcblk1p2): recovery complete
[ 6.954392] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 6.962501] VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 6.973009] devtmpfs: mounted
[ 6.976352] Freeing unused kernel memory: 1856K
[ 6.980913] Run /sbin/init as init process
[ 7.241819] systemd[1]: System time before build time, advancing clock.
[ 7.315924] NET: Registered protocol family 10
[ 7.320893] Segment Routing with IPv6
[ 7.337121] systemd[1]: Configuration file /etc/systemd/system.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.350592] systemd[1]: Configuration file /etc/systemd/system.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.365799] systemd[1]: Configuration file /lib/systemd/system.conf.d/00-systemd-conf.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.381248] systemd[1]: Configuration file /lib/systemd/system.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.402307] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 7.424048] systemd[1]: Detected architecture arm64.
Welcome to [1mArago 2020.09[0m!
[ 7.469444] systemd[1]: Set hostname to <j7-evm>.
[ 7.622562] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.637023] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.655530] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.669655] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.685489] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.699728] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.715496] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.730602] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.751238] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.766429] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.783696] systemd[1]: Configuration file /lib/systemd/system/sysinit.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.798019] systemd[1]: Configuration file /lib/systemd/system/sysinit.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.816160] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.831620] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.849323] systemd[1]: Configuration file /lib/systemd/system/systemd-update-done.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.864773] systemd[1]: Configuration file /lib/systemd/system/systemd-update-done.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.882054] systemd[1]: Configuration file /etc/systemd/system/systemd-udevd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.896987] systemd[1]: Configuration file /etc/systemd/system/systemd-udevd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.913908] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-kernel.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.929383] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-kernel.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.946840] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-control.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.962377] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-control.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.979846] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-trigger.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.995384] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-trigger.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.012774] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.028482] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.046046] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup-dev.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.062102] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup-dev.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.080189] systemd[1]: Configuration file /lib/systemd/system/systemd-timesyncd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.095463] systemd[1]: Configuration file /lib/systemd/system/systemd-timesyncd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.113052] systemd[1]: Configuration file /lib/systemd/system/time-sync.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.127548] systemd[1]: Configuration file /lib/systemd/system/time-sync.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.143719] systemd[1]: Configuration file /lib/systemd/system/time-set.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.158127] systemd[1]: Configuration file /lib/systemd/system/time-set.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.174176] systemd[1]: Configuration file /lib/systemd/system/systemd-sysusers.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.189365] systemd[1]: Configuration file /lib/systemd/system/systemd-sysusers.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.206310] systemd[1]: Configuration file /lib/systemd/system/systemd-sysctl.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.221327] systemd[1]: Configuration file /lib/systemd/system/systemd-sysctl.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.238050] systemd[1]: Configuration file /lib/systemd/system/systemd-random-seed.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.253499] systemd[1]: Configuration file /lib/systemd/system/systemd-random-seed.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.271599] systemd[1]: Configuration file /lib/systemd/system/systemd-modules-load.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.287139] systemd[1]: Configuration file /lib/systemd/system/systemd-modules-load.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.304762] systemd[1]: Configuration file /lib/systemd/system/systemd-machine-id-commit.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.320734] systemd[1]: Configuration file /lib/systemd/system/systemd-machine-id-commit.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.338667] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-flush.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.354293] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-flush.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.371800] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-catalog-update.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.388207] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-catalog-update.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.406662] systemd[1]: Configuration file /lib/systemd/system/systemd-hwdb-update.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.422115] systemd[1]: Configuration file /lib/systemd/system/systemd-hwdb-update.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.439444] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.path is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.455416] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.path is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.473510] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.489741] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.507950] systemd[1]: Configuration file /lib/systemd/system/systemd-vconsole-setup.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.523661] systemd[1]: Configuration file /lib/systemd/system/systemd-vconsole-setup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.541214] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.556492] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.573695] systemd[1]: Configuration file /lib/systemd/system/initrd-cleanup.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.588714] systemd[1]: Configuration file /lib/systemd/system/initrd-cleanup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.605447] systemd[1]: Configuration file /lib/systemd/system/initrd.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.619687] systemd[1]: Configuration file /lib/systemd/system/initrd.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.635620] systemd[1]: Configuration file /lib/systemd/system/rescue.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.649860] systemd[1]: Configuration file /lib/systemd/system/rescue.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.667971] systemd[1]: Configuration file /lib/systemd/system/remote-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.682481] systemd[1]: Configuration file /lib/systemd/system/remote-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.698861] systemd[1]: Configuration file /lib/systemd/system/remote-fs-pre.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.713714] systemd[1]: Configuration file /lib/systemd/system/remote-fs-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.730691] systemd[1]: Configuration file /lib/systemd/system/network-online.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.745627] systemd[1]: Configuration file /lib/systemd/system/network-online.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.762939] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd-wait-online.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.779176] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd-wait-online.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.797624] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.812820] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.830163] systemd[1]: Configuration file /lib/systemd/system/network-pre.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.844838] systemd[1]: Configuration file /lib/systemd/system/network-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.861204] systemd[1]: Configuration file /lib/systemd/system/network.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.875531] systemd[1]: Configuration file /lib/systemd/system/network.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.891759] systemd[1]: Configuration file /lib/systemd/system/nss-lookup.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.906347] systemd[1]: Configuration file /lib/systemd/system/nss-lookup.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.922599] systemd[1]: Configuration file /lib/systemd/system/graphical.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.937098] systemd[1]: Configuration file /lib/systemd/system/graphical.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.955132] systemd[1]: Configuration file /lib/systemd/system/multi-user.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.969733] systemd[1]: Configuration file /lib/systemd/system/multi-user.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.990280] systemd[1]: Configuration file /lib/systemd/system/systemd-user-sessions.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.005920] systemd[1]: Configuration file /lib/systemd/system/systemd-user-sessions.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.023661] systemd[1]: Configuration file /lib/systemd/system/nss-user-lookup.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.038690] systemd[1]: Configuration file /lib/systemd/system/nss-user-lookup.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.055482] systemd[1]: Configuration file /lib/systemd/system/systemd-resolved.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.070671] systemd[1]: Configuration file /lib/systemd/system/systemd-resolved.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.088021] systemd[1]: Configuration file /lib/systemd/system/systemd-logind.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.103036] systemd[1]: Configuration file /lib/systemd/system/systemd-logind.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.120505] systemd[1]: Configuration file /lib/systemd/system/dbus.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.134570] systemd[1]: Configuration file /lib/systemd/system/dbus.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.150340] systemd[1]: Configuration file /lib/systemd/system/user.slice is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.164321] systemd[1]: Configuration file /lib/systemd/system/user.slice is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.179870] systemd[1]: Configuration file /lib/systemd/system/slices.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.194108] systemd[1]: Configuration file /lib/systemd/system/slices.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.209891] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.path is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.225602] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.path is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.243357] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.259328] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.277311] systemd[1]: Configuration file /lib/systemd/system/strongswan-starter.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.292672] systemd[1]: Configuration file /lib/systemd/system/strongswan-starter.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.309779] systemd[1]: Configuration file /lib/systemd/system/snmpd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.324016] systemd[1]: Configuration file /lib/systemd/system/snmpd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.339858] systemd[1]: Configuration file /lib/systemd/system/rpcbind.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.354268] systemd[1]: Configuration file /lib/systemd/system/rpcbind.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.370337] systemd[1]: Configuration file /lib/systemd/system/rpcbind.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.384659] systemd[1]: Configuration file /lib/systemd/system/rpcbind.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.400549] systemd[1]: Configuration file /lib/systemd/system/rpcbind.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.414872] systemd[1]: Configuration file /lib/systemd/system/rpcbind.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.430931] systemd[1]: Configuration file /lib/systemd/system/rngd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.445081] systemd[1]: Configuration file /lib/systemd/system/rngd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.460846] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-settle.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.476294] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-settle.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.493598] systemd[1]: Configuration file /lib/systemd/system/ofono.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.507839] systemd[1]: Configuration file /lib/systemd/system/ofono.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.523629] systemd[1]: Configuration file /lib/systemd/system/nfs-statd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.538210] systemd[1]: Configuration file /lib/systemd/system/nfs-statd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.554486] systemd[1]: Configuration file /lib/systemd/system/kdump.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.568722] systemd[1]: Configuration file /lib/systemd/system/kdump.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.584498] systemd[1]: Configuration file /lib/systemd/system/irqbalanced.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.599253] systemd[1]: Configuration file /lib/systemd/system/irqbalanced.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.615570] systemd[1]: Configuration file /lib/systemd/system/iptables.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.630065] systemd[1]: Configuration file /lib/systemd/system/iptables.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.646162] systemd[1]: Configuration file /lib/systemd/system/ip6tables.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.660744] systemd[1]: Configuration file /lib/systemd/system/ip6tables.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.676948] systemd[1]: Configuration file /lib/systemd/system/gplv3-notice.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.691790] systemd[1]: Configuration file /lib/systemd/system/gplv3-notice.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.708335] systemd[1]: Configuration file /lib/systemd/system/getty.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.722486] systemd[1]: Configuration file /lib/systemd/system/getty.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.739061] systemd[1]: Configuration file /lib/systemd/system/serial-getty@.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.753994] systemd[1]: Configuration file /lib/systemd/system/serial-getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.771564] systemd[1]: Configuration file /lib/systemd/system/rc-local.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.786066] systemd[1]: Configuration file /lib/systemd/system/rc-local.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.802285] systemd[1]: Configuration file /lib/systemd/system/getty-pre.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.816787] systemd[1]: Configuration file /lib/systemd/system/getty-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.833178] systemd[1]: Configuration file /lib/systemd/system/serial-getty@.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.848107] systemd[1]: Configuration file /lib/systemd/system/serial-getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.864961] systemd[1]: Configuration file /lib/systemd/system/getty@.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.879279] systemd[1]: Configuration file /lib/systemd/system/getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.895857] systemd[1]: Configuration file /lib/systemd/system/docker.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.910181] systemd[1]: Configuration file /lib/systemd/system/docker.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.926433] systemd[1]: Configuration file /lib/systemd/system/docker.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.940669] systemd[1]: Configuration file /lib/systemd/system/docker.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.956504] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[ 9.976226] systemd[1]: Configuration file /lib/systemd/system/demo.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.990375] systemd[1]: Configuration file /lib/systemd/system/demo.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.006136] systemd[1]: Configuration file /lib/systemd/system/dbus.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.020293] systemd[1]: Configuration file /lib/systemd/system/dbus.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.036037] systemd[1]: Configuration file /lib/systemd/system/crond.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.050278] systemd[1]: Configuration file /lib/systemd/system/crond.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.066062] systemd[1]: Configuration file /lib/systemd/system/bt-enable.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.080648] systemd[1]: Configuration file /lib/systemd/system/bt-enable.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.096908] systemd[1]: Configuration file /lib/systemd/system/avahi-daemon.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.111752] systemd[1]: Configuration file /lib/systemd/system/avahi-daemon.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.128668] systemd[1]: Configuration file /lib/systemd/system/avahi-daemon.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.143427] systemd[1]: Configuration file /lib/systemd/system/avahi-daemon.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.159975] systemd[1]: Configuration file /lib/systemd/system/atd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.174040] systemd[1]: Configuration file /lib/systemd/system/atd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.190513] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp-runlevel.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.206744] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp-runlevel.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.225021] systemd[1]: Configuration file /lib/systemd/system/rescue.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.239345] systemd[1]: Configuration file /lib/systemd/system/rescue.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.255279] systemd[1]: Configuration file /lib/systemd/system/initrd-parse-etc.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.270469] systemd[1]: Configuration file /lib/systemd/system/initrd-parse-etc.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.287479] systemd[1]: Configuration file /lib/systemd/system/initrd-root-device.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.302755] systemd[1]: Configuration file /lib/systemd/system/initrd-root-device.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.319832] systemd[1]: Configuration file /lib/systemd/system/basic.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.333980] systemd[1]: Configuration file /lib/systemd/system/basic.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.349784] systemd[1]: Configuration file /lib/systemd/system/timers.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.364021] systemd[1]: Configuration file /lib/systemd/system/timers.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.381202] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.timer is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.396740] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.414305] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.430017] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.447561] systemd[1]: Configuration file /lib/systemd/system/logrotate.timer is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.461970] systemd[1]: Configuration file /lib/systemd/system/logrotate.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.478015] systemd[1]: Configuration file /lib/systemd/system/logrotate.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.492598] systemd[1]: Configuration file /lib/systemd/system/logrotate.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.508872] systemd[1]: Configuration file /lib/systemd/system/initrd-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.523365] systemd[1]: Configuration file /lib/systemd/system/initrd-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.539520] systemd[1]: Configuration file /lib/systemd/system/initrd-root-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.554449] systemd[1]: Configuration file /lib/systemd/system/initrd-root-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.571169] systemd[1]: Configuration file /lib/systemd/system/initrd-udevadm-cleanup-db.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.587136] systemd[1]: Configuration file /lib/systemd/system/initrd-udevadm-cleanup-db.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.605157] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.620519] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.637698] systemd[1]: Configuration file /lib/systemd/system/paths.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.651847] systemd[1]: Configuration file /lib/systemd/system/paths.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 10.667524] systemd[1]: Configuration file /lib/systemd/system/sys-kernel-debug.mount is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.710933] random: systemd: uninitialized urandom read (16 bytes read)
[[0;32m OK [0m] Created slice [0;1;39msystem-getty.slice[0m.
[ 10.736810] random: systemd: uninitialized urandom read (16 bytes read)
[[0;32m OK [0m] Created slice [0;1;39msystem-serial\x2dgetty.slice[0m.
[ 10.760804] random: systemd: uninitialized urandom read (16 bytes read)
[[0;32m OK [0m] Created slice [0;1;39mUser and Session Slice[0m.
[[0;32m OK [0m] Started [0;1;39mDispatch Password …ts to Console Directory Watch[0m.
[[0;32m OK [0m] Started [0;1;39mForward Password R…uests to Wall Directory Watch[0m.
[[0;32m OK [0m] Reached target [0;1;39mPaths[0m.
[[0;32m OK [0m] Reached target [0;1;39mRemote File Systems[0m.
[[0;32m OK [0m] Reached target [0;1;39mSlices[0m.
[[0;32m OK [0m] Reached target [0;1;39mSwap[0m.
[[0;32m OK [0m] Listening on [0;1;39mRPCbind Server Activation Socket[0m.
[[0;32m OK [0m] Reached target [0;1;39mRPC Port Mapper[0m.
[[0;32m OK [0m] Listening on [0;1;39mProcess Core Dump Socket[0m.
[[0;32m OK [0m] Listening on [0;1;39minitctl Compatibility Named Pipe[0m.
[[0;32m OK [0m] Listening on [0;1;39mJournal Socket (/dev/log)[0m.
[[0;32m OK [0m] Listening on [0;1;39mJournal Socket[0m.
[[0;32m OK [0m] Listening on [0;1;39mNetwork Service Netlink Socket[0m.
[[0;32m OK [0m] Listening on [0;1;39mudev Control Socket[0m.
[[0;32m OK [0m] Listening on [0;1;39mudev Kernel Socket[0m.
Mounting [0;1;39mHuge Pages File System[0m...
Mounting [0;1;39mPOSIX Message Queue File System[0m...
Mounting [0;1;39mKernel Debug File System[0m...
Mounting [0;1;39mTemporary Directory (/tmp)[0m...
Starting [0;1;39mCreate list of st…odes for the current kernel[0m...
Starting [0;1;39mStart psplash boot splash screen[0m...
[[0;32m OK [0m] Started [0;1;39mHardware RNG Entropy Gatherer Daemon[0m.
Starting [0;1;39mRPC Bind[0m...
Starting [0;1;39mJournal Service[0m...
Starting [0;1;39mLoad Kernel Modules[0m...
[ 11.223099] systemd-journald[165]: Configuration file /etc/systemd/journald.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
Starting [0;1;39mRemount Root and Kernel File Systems[0m...
[ 11.249329] systemd-journald[165]: Configuration file /etc/systemd/journald.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 11.266871] cryptodev: loading out-of-tree module taints kernel.
[ 11.273391] systemd-journald[165]: Configuration file /lib/systemd/journald.conf.d/00-systemd-conf.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 11.278591] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
Starting [0;1;39mudev Coldplug all Devices[0m...
[ 11.300984] cryptodev: driver 1.10 loaded.
[ 11.307172] systemd-journald[165]: Configuration file /lib/systemd/journald.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[[0;32m OK [0m] Started [0;1;39mRPC Bind[0m.
[[0;32m OK [0m] Mounted [0;1;39mHuge Pages File System[0m.
[[0;32m OK [0m] Mounted [0;1;39mPOSIX Message Queue File System[0m.
[[0;32m OK [0m] Mounted [0;1;39mKernel Debug File System[0m.
[[0;32m OK [0m] Mounted [0;1;39mTemporary Directory (/tmp)[0m.
[[0;32m OK [0m] Started [0;1;39mJournal Service[0m.
[[0;32m OK [0m] Started [0;1;39mCreate list of sta… nodes for the current kernel[0m.
[[0;1;31mFAILED[0m] Failed to start [0;1;39mStart psplash boot splash screen[0m.
See 'systemctl status psplash-start.service' for details.
[[0;1;38;5;185mDEPEND[0m] Dependency failed for [0;1;39mStar…progress communication helper[0m.
[[0;32m OK [0m] Started [0;1;39mLoad Kernel Modules[0m.
[[0;32m OK [0m] Started [0;1;39mRemount Root and Kernel File Systems[0m.
Mounting [0;1;39mKernel Configuration File System[0m...
Starting [0;1;39mFlush Journal to Persistent Storage[0m...
[ 11.558854] systemd-journald[165]: Received client request to flush runtime journal.
Starting [0;1;39mApply Kernel Variables[0m...
Starting [0;1;39mCreate Static Device Nodes in /dev[0m...
[[0;32m OK [0m] Mounted [0;1;39mKernel Configuration File System[0m.
[[0;32m OK [0m] Started [0;1;39mFlush Journal to Persistent Storage[0m.
[[0;32m OK [0m] Started [0;1;39mApply Kernel Variables[0m.
[[0;32m OK [0m] Started [0;1;39mCreate Static Device Nodes in /dev[0m.
[[0;32m OK [0m] Reached target [0;1;39mLocal File Systems (Pre)[0m.
Mounting [0;1;39m/media/ram[0m...
Mounting [0;1;39m/var/volatile[0m...
Starting [0;1;39mudev Kernel Device Manager[0m...
[[0;32m OK [0m] Mounted [0;1;39m/media/ram[0m.
[[0;32m OK [0m] Mounted [0;1;39m/var/volatile[0m.
Starting [0;1;39mLoad/Save Random Seed[0m...
[[0;32m OK [0m] Reached target [0;1;39mLocal File Systems[0m.
Starting [0;1;39mCreate Volatile Files and Directories[0m...
[[0;32m OK [0m] Started [0;1;39mudev Coldplug all Devices[0m.
[[0;32m OK [0m] Started [0;1;39mCreate Volatile Files and Directories[0m.
Starting [0;1;39mNetwork Time Synchronization[0m...
Starting [0;1;39mUpdate UTMP about System Boot/Shutdown[0m...
[[0;32m OK [0m] Started [0;1;39mudev Kernel Device Manager[0m.
[[0;32m OK [0m] Started [0;1;39mUpdate UTMP about System Boot/Shutdown[0m.
[[0;32m OK [0m] Started [0;1;39mNetwork Time Synchronization[0m.
[[0;32m OK [0m] Reached target [0;1;39mSystem Initialization[0m.
[[0;32m OK [0m] Started [0;1;39mDaily Cleanup of Temporary Directories[0m.
[[0;32m OK [0m] Reached target [0;1;39mSystem Time Set[0m.
[[0;32m OK [0m] Reached target [0;1;39mSystem Time Synchronized[0m.
[[0;32m OK [0m] Started [0;1;39mDaily rotation of log files[0m.
[[0;32m OK [0m] Reached target [0;1;39mTimers[0m.
[[0;32m OK [0m] Listening on [0;1;39mAvahi mDNS/DNS-SD Stack Activation Socket[0m.
[[0;32m OK [0m] Listening on [0;1;39mD-Bus System Message Bus Socket[0m.
Starting [0;1;39mDocker Socket for the API[0m.
[[0;32m OK [0m] Listening on [0;1;39mdropbear.socket[0m.
Starting [0;1;39mReboot and dump vmcore via kexec[0m...
[[0;32m OK [0m] Listening on [0;1;39mDocker Socket for the API[0m.
[[0;32m OK [0m] Reached target [0;1;39mSockets[0m.
[[0;32m OK [0m] Reached target [0;1;39mBasic System[0m.
[[0;32m OK [0m] Started [0;1;39mJob spooling tools[0m.
[[0;32m OK [0m] Started [0;1;39mPeriodic Command Scheduler[0m.
[[0;32m OK [0m] Started [0;1;39mD-Bus System Message Bus[0m.
Starting [0;1;39mPrint notice about GPLv3 packages[0m...
Starting [0;1;39mIPv6 Packet Filtering Framework[0m...
Starting [0;1;39mIPv4 Packet Filtering Framework[0m...
[[0;32m OK [0m] Started [0;1;39mirqbalance daemon[0m.
Starting [0;1;39mTelephony service[0m...
Starting [0;1;39mrc.pvr.service[0m...
Starting [0;1;39mLogin Service[0m...
[[0;32m OK [0m] Started [0;1;39mReboot and dump vmcore via kexec[0m.
[[0;32m OK [0m] Started [0;1;39mIPv6 Packet Filtering Framework[0m.
[[0;32m OK [0m] Started [0;1;39mIPv4 Packet Filtering Framework[0m.
[[0;32m OK [0m] Reached target [0;1;39mNetwork (Pre)[0m.
Starting [0;1;39mNetwork Service[0m...
[[0;32m OK [0m] Started [0;1;39mTelephony service[0m.
[ 12.589202] PVR_K: 241: Read BVNC 22.104.208.318 from HW device registers
[ 12.600276] PVR_K: 241: RGX Device registered with BVNC 22.104.208.318
[ 12.609339] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 0
[[0;32m OK [0m] Started [0;1;39mLogin Service[0m.
[ 12.678104] ina2xx 4-0040: power monitor ina226 (Rshunt = 10000 uOhm)
[[0;32m OK [0m] Started [0;1;39mNetwork Service[0m.
Starting [0;1;39mWait for Network to be Configured[0m...
Starting [0;1;39mNetwork Name Resolution[0m...
[ 12.726513] Bluetooth: Core ver 2.22
[ 12.732973] NET: Registered protocol family 31
[ 12.740800] Bluetooth: HCI device and connection manager initialized
[ 12.752768] Bluetooth: HCI socket layer initialized
[ 12.760784] Bluetooth: L2CAP socket layer initialized
[ 12.768778] Bluetooth: SCO socket layer initialized
[[0;32m OK [0m] Started [0;1;39mNetwork Name Resolution[0m.
[[0;32m OK [0m] Reached target [0;1;39mNetwork[0m.
[[0;32m OK [0m] Reached target [0;1;39mHost and Network Name Lookups[0m.
Starting [0;1;39mAvahi mDNS/DNS-SD Stack[0m...
Starting [0;1;39mEnable and configure wl18xx bluetooth stack[0m...
[[0;32m OK [0m] Started [0;1;39mNFS status monitor for NFSv2/3 locking.[0m.
Starting [0;1;39mSimple Network Ma…ent Protocol (SNMP) Daemon.[0m...
Starting [0;1;39mPermit User Sessions[0m...
[[0;32m OK [0m] Started [0;1;39mEnable and configure wl18xx bluetooth stack[0m.
[[0;32m OK [0m] Started [0;1;39mPermit User Sessions[0m.
[[0;32m OK [0m] Started [0;1;39mGetty on tty1[0m.
[[0;32m OK [0m] Started [0;1;39mSerial Getty on ttyS2[0m.
[[0;32m OK [0m] Started [0;1;39mSerial Getty on ttyS3[0m.
[[0;32m OK [0m] Reached target [0;1;39mLogin Prompts[0m.
Starting [0;1;39mSynchronize System and HW clocks[0m...
[[0;1;31mFAILED[0m] Failed to start [0;1;39mSynchronize System and HW clocks[0m.
See 'systemctl status sync-clocks.service' for details.
[[0;32m OK [0m] Started [0;1;39mAvahi mDNS/DNS-SD Stack[0m.
[ 12.943303] ina2xx 4-0041: power monitor ina226 (Rshunt = 10000 uOhm)
[ 12.993632] ina2xx 4-0042: power monitor ina226 (Rshunt = 10000 uOhm)
[ 13.030225] ina2xx 4-0043: power monitor ina226 (Rshunt = 10000 uOhm)
[ 13.058156] ina2xx 4-0044: power monitor ina226 (Rshunt = 10000 uOhm)
[ 13.084886] ina2xx 4-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[ 13.131627] ina2xx 4-0046: power monitor ina226 (Rshunt = 10000 uOhm)
[ 13.153932] ina2xx 4-0047: power monitor ina226 (Rshunt = 10000 uOhm)
[ 13.190846] ina2xx 4-0048: power monitor ina226 (Rshunt = 10000 uOhm)
[ 13.226254] ina2xx 4-0049: power monitor ina226 (Rshunt = 10000 uOhm)
[ 13.260582] ina2xx 4-004a: power monitor ina226 (Rshunt = 10000 uOhm)
[ 13.314859] ina2xx 4-004b: power monitor ina226 (Rshunt = 10000 uOhm)
[ 13.383714] ina2xx 4-004c: power monitor ina226 (Rshunt = 10000 uOhm)
[ 13.422944] ina2xx 4-004d: power monitor ina226 (Rshunt = 10000 uOhm)
[ 13.461927] ina2xx 4-004e: power monitor ina226 (Rshunt = 10000 uOhm)
[ 13.516198] img_dec 4300000.video-decoder: decoder registered as /dev/video0
[ 13.537319] ina2xx 4-004f: power monitor ina226 (Rshunt = 10000 uOhm)
[ 13.819512] random: crng init done
[ 13.822910] random: 7 urandom warning(s) missed due to ratelimiting
[[0;32m OK [0m] Started [0;1;39mLoad/Save Random Seed[0m.
[ 14.031600] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
[ 14.052475] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 14.229647] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
[ 14.331893] platform 41000000.r5f: configured R5F for IPC-only mode
[ 14.355814] remoteproc remoteproc0: 4d80800000.dsp is available
[ 14.415432] CAN device driver interface
[ 14.453113] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 14.492944] remoteproc remoteproc0: attaching to 4d80800000.dsp
[ 14.504878] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
[ 14.521816] remoteproc remoteproc1: 41000000.r5f is available
[ 14.546462] remoteproc remoteproc1: attaching to 41000000.r5f
[ 14.556764] remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
[ 14.617815] platform 41000000.r5f: R5F core initialized in IPC-only mode
[[0;32m OK [0m] Started [0;1;39mSimple Network Man…ement Protocol (SNMP) Daemon.[0m.
[ 14.747997] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 14.751322] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[ 14.828907] remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 14.945498] remoteproc0#vdev0buffer: registered virtio0 (type 7)
[ 15.043103] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached
[ 15.065315] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 15.077535] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
[ 15.087032] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
[ 15.145452] remoteproc1#vdev0buffer: registered virtio1 (type 7)
[ 15.204014] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
[ 15.265340] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
[ 15.289663] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
[ 15.297567] remoteproc remoteproc1: remote processor 41000000.r5f is now attached
[ 15.413621] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
[ 15.474346] platform 5c00000.r5f: configured R5F for IPC-only mode
[ 15.556254] remoteproc remoteproc2: 4d81800000.dsp is available
[ 15.623825] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 15.708823] remoteproc remoteproc2: attaching to 4d81800000.dsp
[ 15.761025] remoteproc remoteproc3: 5c00000.r5f is available
[ 15.784122] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
[ 15.876607] remoteproc remoteproc3: attaching to 5c00000.r5f
[ 15.914421] remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
[ 16.017140] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[ 16.109174] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 16.114696] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
[ 16.148485] remoteproc2#vdev0buffer: registered virtio2 (type 7)
[ 16.165386] remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 16.213975] remoteproc remoteproc2: remote processor 4d81800000.dsp is now attached
[ 16.258508] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 16.263485] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
[ 16.301644] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
[ 16.313393] remoteproc3#vdev0buffer: registered virtio3 (type 7)
NOTICE: This file system contains the following GPLv3 packages:
autoconf
bash-dev
bash
bc
binutils
cifs-utils
c[ 16.352874] remoteproc remoteproc3: remote processor 5c00000.r5f is now attached
oreutils-stdbuf
coreutils
cpio
cpp-symlinks
cpp
dosfstools
elfutils
g++-symlinks
g++
gawk
gcc-symlinks
gcc[ 16.370348] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
gdb
gdbserver
gettext
glmark2
gstreamer1.0-libav-dev
gstreamer1.0-libav
gzip
less
libasm1
libbfd
libdw1
[ 16.385058] remoteproc remoteproc4: 64800000.dsp is available
libelf1
libgdbm-compat4
libgdbm-dev
libgdbm6
libgettextlib
libgettextsrc
libgmp-dev
libgmp10
libgmpxx4
libidn[ 16.405692] platform 5d00000.r5f: configured R5F for IPC-only mode
2-0
libidn2-dev
libmpc3
libmpfr6
libreadline-dev
libreadline8
libunistring-dev
libunistring2
m4-dev
m4
make
nettle-dev
nettle
parted
python3-rfc3987
python3-strict-rfc3339
tar
which
zeromq
If you do not wish to distribute GPLv3 components please remove
the above packages prior to[ 16.441075] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[[0;32m OK [0m] Started [0;1;39mPrint notice about GPLv3 packages[0m.
[ 16.576806] remoteproc remoteproc4: attaching to 64800000.dsp
[ 16.609402] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
[ 16.622738] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
[ 16.643252] remoteproc remoteproc4: unsupported resource 65538
[ 16.681036] remoteproc remoteproc5: 5d00000.r5f is available
[ 16.718657] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[ 16.767722] remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
[ 16.812827] remoteproc remoteproc5: attaching to 5d00000.r5f
[ 16.885166] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[[0;32m OK [0m] Created slice [0;1;39msystem-systemd\x2dfsck.slice[0m.
[ 16.966290] virtio_rpmsg_bus virtio4: rpmsg host is online
[ 16.968315] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
[ 17.001196] remoteproc5#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[ 17.083483] remoteproc4#vdev0buffer: registered virtio4 (type 7)
[ 17.113735] virtio_rpmsg_bus virtio5: rpmsg host is online
[ 17.118358] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
[ 17.128921] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
[ 17.139724] remoteproc5#vdev0buffer: registered virtio5 (type 7)
[ 17.140880] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
[ 17.157119] remoteproc remoteproc5: remote processor 5d00000.r5f is now attached
[ 17.160827] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
[ 17.176297] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
[ 17.188846] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
[ 17.196016] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
[ 17.199479] remoteproc remoteproc4: remote processor 64800000.dsp is now attached
[ 17.208824] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
[ 17.223875] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
[ 17.237037] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
[ 17.244283] virtio_rpmsg_bus virtio3: creating channel ti.ethfw.notifyservice addr 0x1e
[ 17.260859] virtio_rpmsg_bus virtio3: creating channel rpmsg-kdrv addr 0x1a
[ 17.268611] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethswitch-device-0: Device info: permissions: 07FFFFFF uart_id: 2
[ 17.284729] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethswitch-device-0: FW ver 0.1 (rev 1) 24/Sep/2021 SHA:
[ 17.295620] platform 5e00000.r5f: configured R5F for remoteproc mode
[ 17.300804] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
[ 17.315659] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded
[ 17.326091] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:00000003 rdev_mtu:1522 flow_id:172 tx_psil_dst_id:4A00
[ 17.344877] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
[ 17.376274] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[ 17.570439] remoteproc remoteproc6: 5e00000.r5f is available
[ 17.692201] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[ 17.701371] remoteproc remoteproc6: powering up 5e00000.r5f
[[0;32m OK [0m] Found device [0;1;39m/dev/mmcblk1p1[0m.[ 17.712787] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[ 17.716772] platform 5f00000.r5f: configured R5F for remoteproc mode
[ 17.732781] remoteproc remoteproc6: request_firmware failed: -2
Starting [0;1;39mFile System Check on /dev/mmcblk1p1[0m...
[ 17.796191] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[ 17.861466] remoteproc remoteproc7: 5f00000.r5f is available
[ 17.989816] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
[ 18.002428] remoteproc remoteproc7: powering up 5f00000.r5f
[ 18.008040] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
[ 18.024750] remoteproc remoteproc7: request_firmware failed: -2
[ 18.366387] usbcore: registered new interface driver usbfs
[ 18.458881] remoteproc remoteproc8: b034000.pru is available
[ 18.575610] remoteproc remoteproc9: b004000.rtu is available
[ 18.597355] usbcore: registered new interface driver hub
[ 18.703191] usbcore: registered new device driver usb
[ 18.715129] remoteproc remoteproc10: b00a000.txpru is available
[ 18.787236] remoteproc remoteproc11: b038000.pru is available
[ 18.818451] remoteproc remoteproc12: b006000.rtu is available
[ 18.841868] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[ 18.841910] PVR_K: 958: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
[ 18.866149] remoteproc remoteproc13: b00c000.txpru is available
[ 18.905402] remoteproc remoteproc14: b134000.pru is available
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| [ 18.933319] remoteproc remoteproc15: b104000.rtu is available
|__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org j7-evm ttyS2
Arago 2020.09 j7-evm ttyS2
j7-evm login: [ 18.957524] remoteproc remoteproc16: b10a000.txpru is available
[ 18.989395] remoteproc remoteproc17: b138000.pru is available
[ 19.009363] remoteproc remoteproc18: b106000.rtu is available
[ 19.041361] remoteproc remoteproc19: b10c000.txpru is available
[ 19.788874] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac started
[ 19.952499] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 19.961227] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[ 20.001505] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[ 20.016851] xhci-hcd xhci-hcd.2.auto: irq 613, io mem 0x06410000
[ 20.028897] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 20.040770] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 20.047983] usb usb1: Product: xHCI Host Controller
[ 20.060735] usb usb1: Manufacturer: Linux 5.10.41-g4c2eade9f7 xhci-hcd
[ 20.067256] usb usb1: SerialNumber: xhci-hcd.2.auto
[ 20.073034] hub 1-0:1.0: USB hub found
[ 20.077186] hub 1-0:1.0: 1 port detected
[ 20.089675] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 20.100759] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[ 20.112745] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[ 20.124768] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 20.136783] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 20.152736] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 20.160014] usb usb2: Product: xHCI Host Controller
[ 20.164907] usb usb2: Manufacturer: Linux 5.10.41-g4c2eade9f7 xhci-hcd
[ 20.171425] usb usb2: SerialNumber: xhci-hcd.2.auto
[ 20.181191] hub 2-0:1.0: USB hub found
[ 20.188744] hub 2-0:1.0: 1 port detected
[ 20.428743] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 20.585016] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[ 20.596732] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 20.608734] usb 1-1: SerialNumber: E7070871A7A1
[ 20.613744] hub 1-1:1.0: USB hub found
[ 20.620756] hub 1-1:1.0: 4 ports detected
j7-evm login:
j7-evm login:
j7-evm login: root
Login incorrect
j7-evm login:
