Part Number: TMS320C6678
console 输出为:[C66xx_1] Ipc_start successfully
[C66xx_2] Ipc_start successfully
[C66xx_0] Ipc_start successfully
[C66xx_1] Notify_registerEvent for masterCore0 successfully
[C66xx_2] Notify_registerEvent for masterCore0 successfully
[C66xx_1] ti.sysbios.gates.GateMutex: line 99: assertion failure: A_badContext: bad calling context. See GateMutex API doc for details.
[C66xx_2] ti.sysbios.gates.GateMutex: line 99: assertion failure: A_badContext: bad calling context. See GateMutex API doc for details.
[C66xx_1] xdc.runtime.Error.raise: terminating execution
[C66xx_2] xdc.runtime.Error.raise: terminating execution
代码:
* Copyright (c) 2012, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* ======== notify_multicore.c ========
* Single-image version of Notify example
* See notify_multicore.k file for expected output.
#include <xdc/std.h>
/* -----------------------------------XDC.RUNTIME module Headers */
#include <xdc/runtime/System.h>
#include <xdc/runtime/Timestamp.h>
/* ----------------------------------- IPC module Headers */
#include <ti/ipc/MultiProc.h>
#include <ti/ipc/Notify.h>
#include <ti/ipc/Ipc.h>
/* ----------------------------------- BIOS6 module Headers */
#include <ti/sysbios/knl/Semaphore.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/BIOS.h>
/* ----------------------------------- To get globals from .cfg Header */
#include <xdc/cfg/global.h>
#define INTERRUPT_LINE 0
/* Notify event number that the app uses */
#define EVENTID 10
/* Number of times to run the loop */
#define NUMLOOPS 10
UInt32 seq = 0;
UInt16 recvProcId;
int i = 0;
UInt16 srcProc, dstProc,localProc;
void sleep(int time){
int start = Timestamp_get32();
while(Timestamp_get32()-start<time);
* ======== cbFxn ========
* This function was registered with Notify. It is called when any event is
* sent to this processor.
Void cbFxn(UInt16 procId, UInt16 lineId,
UInt32 eventId, UArg arg, UInt32 payload)
/* The payload is a sequence number. */
recvProcId = procId;
seq = payload;
System_printf("IPC ISR SUCCESS!");
Semaphore_post(semHandle);
//Semaphore_post(semHandle1);
i++;
* ======== tsk0_func ========
* Sends an event to the next processor then pends on a semaphore.
* The semaphore is posted by the callback function.
Void tsk0_func(UArg arg0, UArg arg1)
int status;
if (MultiProc_self() == 0) {
/* Send an event to the next processor */
status = Notify_sendEvent(1, 0, 10, NULL, TRUE);
if (status < 0) {
System_abort("Notify_sendEvent for slaveCore1 failed\n");
status = Notify_sendEvent(2, 0, 10, NULL, TRUE);
if (status < 0) {
System_abort("Notify_sendEvent for slaveCore2 failed\n");
/* Wait to be released by the cbFxn posting the semaphore */
Semaphore_pend(semHandle, BIOS_WAIT_FOREVER); // 主核等待从核完成其工作返回
System_printf("MasterCore0 Received Event from All SloverCores\n");
else {
/* wait forever on a semaphore, semaphore is posted in callback */
Semaphore_pend(semHandle, BIOS_WAIT_FOREVER); // 等待主核通知开始执行任务
System_printf("SlaverCore%d Received Event from MasterCore0\n", MultiProc_self());
status = Notify_sendEvent(0, 0, 10, NULL, TRUE);
if (status < 0) {
System_abort("sendEvent to MasterCore0 failed\n");
System_printf("SlaverCore%d sent Event to MasterCore0 \n", MultiProc_self());
return (void*)0;
* ======== main ========
* Synchronizes all processors (in Ipc_start), calls BIOS_start, and registers
* for an incoming event
int main(Int argc, Char* argv[])
int status;
status = Ipc_start();
if (status < 0) {
System_abort("Ipc_start failed\n");
System_printf("Ipc_start successfully\n");
if(MultiProc_self() == 0)//0是主核,1-7是从核
do{
status = Ipc_attach(1);
}while(status < 0);// 完成从核1的连接
do{
status = Ipc_attach(2);
}while(status < 0);// 完成从核2的连接
status = Notify_registerEvent(1, 0, 10, (Notify_FnNotifyCbck)cbFxn, NULL);
if (status < 0) {
System_abort("Notify_registerEvent for slaveCore1 failed\n");
}// 完成从核1的事件注册
status = Notify_registerEvent(2, 0, 10, (Notify_FnNotifyCbck)cbFxn, NULL);
if (status < 0) {
System_abort("Notify_registerEvent for slaveCore2 failed\n");
}// 完成从核2的事件注册
else{
do{
status = Ipc_attach(0);
}while(status < 0);// 完成主核0的连接
status = Notify_registerEvent(0, 0, 10, (Notify_FnNotifyCbck)cbFxn, NULL);
if (status < 0) {
System_abort("Notify_registerEvent for masterCore0 failed\n");
}// 完成主核0的事件注册
System_printf("Notify_registerEvent for masterCore0 successfully\n");
BIOS_start();
return 0;
cfg:
* are met:
var MultiProc = xdc.useModule('ti.sdo.utils.MultiProc');
* Get the list of names that the build device supports.
* I.e. ["CORE0", "CORE1", "CORE2" ... ]
var nameList = MultiProc.getDeviceProcNames();
* Since this is a single-image example, we don't (at build-time) which
* processor we're building for. We therefore supply 'null'
* as the local procName and use MultiProc_setLocalId to set the procId
* at runtime.
MultiProc.setConfig(null, nameList);
var System = xdc.useModule('xdc.runtime.System');
var SysStd = xdc.useModule('xdc.runtime.SysStd');
System.SupportProxy = SysStd;
/* Modules explicitly used in the application */
var Notify = xdc.useModule('ti.sdo.ipc.Notify');
var Ipc = xdc.useModule('ti.sdo.ipc.Ipc');
var BIOS = xdc.useModule('ti.sysbios.BIOS');
BIOS.heapSize = 0x8000;
var Task = xdc.useModule('ti.sysbios.knl.Task');
var TimeStamp = xdc.useModule('xdc.runtime.Timestamp');
var tsk0 = Task.create('&tsk0_func');
tsk0.instance.name = "tsk0";
/* To avoid wasting shared memory for MessageQ transports */
for (var i = 0; i < 3; i++) {
Ipc.setEntryMeta({
remoteProcId: i,
setupMessageQ: false,
setupNotify: true,
/* Synchronize all processors (this will be done in Ipc_start) */
Ipc.procSync = Ipc.ProcSync_PAIR;
/* Shared Memory base address and length */
var SHAREDMEM = 0x0C000000;
var SHAREDMEMSIZE = 0x00200000;
* Need to define the shared region. The IPC modules use this
* to make portable pointers. All processors need to add this
* call with their base address of the shared memory region.
* If the processor cannot access the memory, do not add it.
var SharedRegion = xdc.useModule('ti.sdo.ipc.SharedRegion');
SharedRegion.setEntryMeta(0,
{ base: SHAREDMEM,
len: SHAREDMEMSIZE,
ownerProcId: 0,
isValid: true,
/* Create a semaphore with count 0 */
var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore');
Program.global.semHandle = Semaphore.create(0);
Program.global.semHandle1 = Semaphore.create(0);
* @(#) ti.sdo.ipc.examples.multicore.evm667x; 1, 0, 0, 0,1; 5-22-2012 16:36:06; /db/vtree/library/trees/ipc/ipc-h32/src/ xlibrary
