dm368,dvsdk4.02,在编译codec engine,修改xdcpath.mak文件,需要修改如下的环境变量。
CE_INSTALL_DIR := _your_CE_installation_directory_/codec_engine_2_26_02_11
XDC_INSTALL_DIR := _your_XDCTOOLS_installation_directory/xdctools_3_16_00_18
BIOS_INSTALL_DIR := _your_BIOS_installation_directory/bios_5_41_00_06
DSPLINK_INSTALL_DIR := _your_DSPLink_installation_directory/dsplink-1_64-prebuilt
CE_INSTALL_DIR、XDC_INSTALL_DIR我知道路径是什么地方。
BIOS_INSTALL_DIR、DSPLINK_INSTALL_DIR该怎么设置呢?
###@###-desktop:/opt/dvsdk$ sudo find -name bios
./dmai_2_20_00_15/packages/ti/sdo/dmai/apps/image_decode_io/bios
./dmai_2_20_00_15/packages/ti/sdo/dmai/apps/video_decode_io/bios
./dmai_2_20_00_15/packages/ti/sdo/dmai/apps/image_decode_io1/bios
./dmai_2_20_00_15/packages/ti/sdo/dmai/apps/video_encode_io/bios
./dmai_2_20_00_15/packages/ti/sdo/dmai/apps/audio_encode_io1/bios
./dmai_2_20_00_15/packages/ti/sdo/dmai/apps/speech_decode_io1/bios
./dmai_2_20_00_15/packages/ti/sdo/dmai/apps/audio_decode_io1/bios
./dmai_2_20_00_15/packages/ti/sdo/dmai/apps/image_encode_io1/bios
./dmai_2_20_00_15/packages/ti/sdo/dmai/apps/audio_decode_io/bios
./dmai_2_20_00_15/packages/ti/sdo/dmai/apps/video_encode_io1/bios
./dmai_2_20_00_15/packages/ti/sdo/dmai/apps/image_encode_io/bios
./dmai_2_20_00_15/packages/ti/sdo/dmai/apps/video_decode_io2/bios
./dmai_2_20_00_15/packages/ti/sdo/dmai/apps/speech_encode_io1/bios
./dmai_2_20_00_15/packages/ti/sdo/dmai/bios
./codec-engine_2_26_02_11/packages/ti/sdo/ce/osal/bios
./codec-engine_2_26_02_11/packages/ti/sdo/ce/ipc/bios
./codec-engine_2_26_02_11/xdoc/ti/bios
./codec-engine_2_26_02_11/xdoc/ti/sdo/ce/osal/bios
./codec-engine_2_26_02_11/xdoc/ti/sdo/ce/ipc/bios
###@###-desktop:/opt/dvsdk$ sudo find -name dsplink
./codec-engine_2_26_02_11/packages/ti/dsplink
./codec-engine_2_26_02_11/packages/ti/sdo/ce/ipc/dsplink
./codec-engine_2_26_02_11/xdoc/ti/dsplink
./codec-engine_2_26_02_11/xdoc/ti/sdo/ce/ipc/dsplink
./codec-engine_2_26_02_11/examples/apps/system_files/OMAPL137/build/dsplink
./codec-engine_2_26_02_11/examples/apps/system_files/DM6467/build/dsplink
./codec-engine_2_26_02_11/examples/apps/system_files/OMAPL138/build/dsplink
./codec-engine_2_26_02_11/examples/apps/system_files/OMAP2530/build/dsplink
./codec-engine_2_26_02_11/examples/apps/system_files/DM357/build/dsplink
./codec-engine_2_26_02_11/examples/apps/system_files/DM6446/build/dsplink
./codec-engine_2_26_02_11/examples/apps/system_files/OMAP3530/build/dsplink
