Part Number: TMS320C6678
这是我的初始化,不知道他在什么地方卡住了。
C66xx_0: GEL Output: Setup_Memory_Map...
C66xx_0: GEL Output: Setup_Memory_Map... Done.
C66xx_1: GEL Output: Setup_Memory_Map...
C66xx_1: GEL Output: Setup_Memory_Map... Done.
C66xx_2: GEL Output: Setup_Memory_Map...
C66xx_2: GEL Output: Setup_Memory_Map... Done.
C66xx_3: GEL Output: Setup_Memory_Map...
C66xx_3: GEL Output: Setup_Memory_Map... Done.
C66xx_4: GEL Output: Setup_Memory_Map...
C66xx_4: GEL Output: Setup_Memory_Map... Done.
C66xx_5: GEL Output: Setup_Memory_Map...
C66xx_5: GEL Output: Setup_Memory_Map... Done.
C66xx_6: GEL Output: Setup_Memory_Map...
C66xx_6: GEL Output: Setup_Memory_Map... Done.
C66xx_7: GEL Output: Setup_Memory_Map...
C66xx_7: GEL Output: Setup_Memory_Map... Done.
Connecting Target...
C66xx_0: GEL Output: DSP core #0
C66xx_0: GEL Output: No initialization performed since bootmode = 0x0000000F
C66xx_0: GEL Output: You can manually initialize with GlobalDefaultSetup
正确的初始化:
C66xx_0: GEL Output: C6678L GEL file Ver is 1.0
C66xx_0: GEL Output: Global Default Setup...
C66xx_0: GEL Output: Main PLL (PLL1) Setup ...
C66xx_0: GEL Output: PLL in Bypass ...
C66xx_0: GEL Output: PLL1 Setup for DSP @ 1000.0 MHz.
C66xx_0: GEL Output: SYSCLK2 = 333.333344 MHz, SYSCLK5 = 200.0 MHz.
C66xx_0: GEL Output: SYSCLK8 = 15.625 MHz.
C66xx_0: GEL Output: PLL1 Setup... Done.
C66xx_0: GEL Output: Power on all PSC modules and DSP domains...
C66xx_0: GEL Output: Power on all PSC modules and DSP domains... Done.
C66xx_0: GEL Output: PA PLL (PLL3) Setup ...
C66xx_0: GEL Output: PA PLL Setup... Done.
C66xx_0: GEL Output: DDR3 PLL (PLL2) Setup ...
C66xx_0: GEL Output: DDR3 PLL Setup... Done.
C66xx_0: GEL Output: DDR begin (1333 auto)
C66xx_0: GEL Output: XMC Setup ... Done
DDR3 initialization is complete.
C66xx_0: GEL Output: DDR done
C66xx_0: GEL Output: DDR3 memory test... Started
C66xx_0: GEL Output: DDR3 memory test... Passed
C66xx_0: GEL Output: PLL and DDR Initialization completed(0) ...
C66xx_0: GEL Output: Enabling EDC ...
C66xx_0: GEL Output: L1P error detection logic is enabled.
C66xx_0: GEL Output: L2 error detection/correction logic is enabled.
C66xx_0: GEL Output: MSMC error detection/correction logic is enabled.
C66xx_0: GEL Output: Enabling EDC ...Done
C66xx_0: GEL Output: Global Default Setup... Done.
这个问题是可能我在什么地方配置有问题,但是确实找不到问题,各位路过的大佬请帮个忙呀。
