66AK2E05: K2E板使用更大的NAND Flash后无法正常启动
Part Number: 66AK2E05
       我司基于EVMK2E开发板,设计了一款 K2E 的板。
       使用原来的512MB NAND Flash (MT29F4G08ABBDAH4),是正常工作的。
       为扩展空间,选用了一款 1GB 的NAND Flash 芯片,(MT29F8G08ADBDAH4)
       但是出现了Kernel 错误。
      以下是详细Log
U-Boot SPL 2013.01 (Jul 17 2020 - 16:43:24)
SF: Detected N25Q128A with page size 64 KiB, total 16 MiB
U-Boot 2013.01 (Jul 17 2020 - 16:43:24)
I2C:   ready
SPD csum OK; in SPD: D2 B0; computed 000000D2 B0
DDR3A Speed will be configured for 1600 Operation.
Detected SO-DIMM [18KSF51272HZ-1G6K2]
DDR3 speed 1600
DRAM: 4 GiB
Reseting entire DDR3 memory to 0 ...
DRAM:  2 GiB
NAND:  1024 MiB
Smart Reflex Class 0 temperature compensation enabled
tps544_init i2c write error
Smart Reflex Class 0 temperature compensation disabled
Net:   K2E_EMAC0
Warning: K2E_EMAC0 using MAC address from net device
, K2E_EMAC1, K2E_EMAC2, K2E_EMAC3, K2E_EMAC4, K2E_EMAC5, K2E_EMAC6, K2E_EMAC7
Hit any key to stop autoboot:  0
Creating 1 MTD partitions on "nand0":
0x000000180000-0x000040000000 : "mtd=2"
UBI: attaching mtd1 to ubi0
UBI: physical eraseblock size:   131072 bytes (128 KiB)
UBI: logical eraseblock size:    126976 bytes
UBI: smallest flash I/O unit:    2048
UBI: VID header offset:          2048 (aligned 2048)
UBI: data offset:                4096
UBI: attached mtd1 to ubi0
UBI: MTD device name:            "mtd=2"
UBI: MTD device size:            1022 MiB
UBI: number of good PEBs:        8176
UBI: number of bad PEBs:         4
UBI: max. allowed volumes:       128
UBI: wear-leveling threshold:    4096
UBI: number of internal volumes: 1
UBI: number of user volumes:     3
UBI: available PEBs:             0
UBI: total number of reserved PEBs: 8176
UBI: number of PEBs reserved for bad PEB handling: 81
UBI: max/mean erase counter: 1/0
UBIFS: mounted UBI device 0, volume 0, name "boot"
UBIFS: mounted read-only
UBIFS: file system size:   4571136 bytes (4464 KiB, 4 MiB, 36 LEBs)
UBIFS: journal size:       1142785 bytes (1116 KiB, 1 MiB, 8 LEBs)
UBIFS: media format:       w4/r0 (latest is w4/r0)
UBIFS: default compressor: LZO
UBIFS: reserved for root:  0 bytes (0 KiB)
Loading file 'securedb.key.bin' to addr 0x0c000000 with size 28 (0x0000001c)...
Done
Loading file 'uImage-k2e-evm.dtb' to addr 0x87000000 with size 46081 (0x0000b401)...
Done
Loading file 'skern-k2e-evm.bin' to addr 0x0c140000 with size 45056 (0x0000b000)...
Done
Loading file 'uImage-keystone-evm.bin' to addr 0x88000000 with size 4175080 (0x003fb4e8)...
Done
## installed monitor, freq [208333333], status 0
## Booting kernel from Legacy Image at 88000000 ...
   Image Name:   Linux-3.10.72
   Created:      2020-09-06   6:55:54 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    4175016 Bytes = 4 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 87000000
   Booting using the fdt blob at 0x87000000
   Loading Kernel Image ... OK
OK
   Using Device Tree in place at 87000000, end 8700e400
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 3.10.72 (root@athena-VirtualBox) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #1 SMP Sun Sep 6 14:55:43 CST 2020
[    0.000000] CPU: ARMv7 Processor [412fc0f4] revision 4 (ARMv7), cr=30c7387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] Machine: KeyStone2, model: Texas Instruments Keystone 2 SoC
[    0.000000] switching to high address space at 0x800000000
[    0.000000] cma: CMA: reserved 16 MiB at 2e800000
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] PERCPU: Embedded 8 pages/cpu @c2875000 s11264 r8192 d13312 u32768
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 915984
[    0.000000] Kernel command line: console=ttyS0,115200n8 rootwait=1 rootfstype=ubifs root=ubi0:rootfs rootflags=sync rw ubi.mtd=2,2048
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1536MB 2048MB = 3584MB total
[    0.000000] Memory: 3615280k/3615280k available, 54736k reserved, 2891776K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc075cb5c   (7507 kB)
[    0.000000]       .init : 0xc075d000 - 0xc07b0c00   ( 335 kB)
[    0.000000]       .data : 0xc07b2000 - 0xc081a398   ( 417 kB)
[    0.000000]        .bss : 0xc081a398 - 0xc084c5fc   ( 201 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] ipc irq: irqchip registered, range 512-539
[    0.000000] Main PLL clk (1250000000 Hz), parent (100000000 Hz),postdiv = 2, mult = 24, prediv = 0
[    0.000000] Generic PLL clk (1000000000 Hz), parent (100000000 Hz),postdiv = 2, mult = 19, prediv = 0
[    0.000000] Generic PLL clk (400000000 Hz), parent (100000000 Hz),postdiv = 4, mult = 15, prediv = 0
[    0.000000] Architected local timer running at 208.33MHz (phys).
[    0.000000] Switching to timer-based delay loop
[    0.000000] sched_clock: ARM arch timer >56 bits at 208333kHz, resolution 614/128ns
[    0.000000] keystone timer clock @208333333 MHz
[    0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
[    0.000000] Console: colour dummy device 80x30
[   34.649869] Calibrating delay loop (skipped), value calculated using timer frequency.. 416.66 BogoMIPS (lpj=2083333)
[   34.649878] pid_max: default: 4096 minimum: 301
[   34.650006] Mount-cache hash table entries: 512
[   34.657184] CPU: Testing write buffer coherency: ok
[   34.657343] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[   34.657351] psci: probing function IDs from device-tree
[   34.657365] Setting up static identity map for 0xc0530260 - 0xc05302b8
[   34.662473] CPU1: Booted secondary processor
[   34.662498] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[   34.667356] CPU2: Booted secondary processor
[   34.667381] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[   34.672222] CPU3: Booted secondary processor
[   34.672247] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[   34.672316] Brought up 4 CPUs
[   34.672332] SMP: Total of 4 processors activated (1666.66 BogoMIPS).
[   34.672337] CPU: All CPU(s) started in SVC mode.
[   34.672759] devtmpfs: initialized
[   34.684909] NET: Registered protocol family 16
[   34.685767] DMA: preallocated 256 KiB pool for atomic coherent allocations
[   34.696210] No ATAGs?
[   34.696225] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[   34.696232] hw-breakpoint: maximum watchpoint size is 8 bytes.
[   34.706168] bio: create slab <bio-0> at 0
[   34.706530] keystone-pcie: keystone_pcie_rc_init - start
[   34.706550] keystone2_pcie_serdes_setup for domain 0
[   34.708666] keystone2_pcie_serdes_setup done domain 0, en_link_train = 1
[   34.708693] keystone-pcie: MEM 0x0000000050000000..0x000000005fffffff -> 0x0000000050000000
[   34.708701] keystone-pcie: IO 0x0000000023250000..0x0000000023253fff -> 0x0000000000000000
[   34.708730] keystone-pcie: pcie - number of legacy irqs = 4
[   34.708771] keystone-pcie: pcie - number of MSI host irqs = 8, msi_irqs = 32
[   34.809632] keystone-pcie: Doing PCI Setup...Done
[   34.809637] keystone-pcie: Starting PCI scan, nr 0...
[   34.809758] PCI host bridge to bus 0000:00
[   34.809767] pci_bus 0000:00: root bus resource [mem 0x50000000-0x5fffffff]
[   34.809774] pci_bus 0000:00: root bus resource [io  0x0000-0x3fff]
[   34.809780] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[   34.809820] PCI: bus0: Fast back to back transfers enabled
[   34.809835] keystone-pcie: Ending PCI scan...
[   34.809842] keystone-pcie: keystone_pcie_rc_init - end
[   34.809886] keystone-pcie: keystone_pcie_rc_init - start
[   34.809903] keystone2_pcie_serdes_setup for domain 1
[   34.812018] keystone2_pcie_serdes_setup done domain 1, en_link_train = 1
[   34.812043] keystone-pcie: MEM 0x0000000060000000..0x000000006fffffff -> 0x0000000060000000
[   34.812051] keystone-pcie: IO 0x0000000023260000..0x0000000023263fff -> 0x0000000000004000
[   34.812078] keystone-pcie: pcie - number of legacy irqs = 4
[   34.812118] keystone-pcie: pcie - number of MSI host irqs = 8, msi_irqs = 32
[   34.919596] keystone-pcie: Doing PCI Setup...Done
[   34.919602] keystone-pcie: Starting PCI scan, nr 0...
[   34.919717] PCI host bridge to bus 0001:00
[   34.919725] pci_bus 0001:00: root bus resource [mem 0x60000000-0x6fffffff]
[   34.919732] pci_bus 0001:00: root bus resource [io  0x4000-0x7fff]
[   34.919738] pci_bus 0001:00: No busn resource found for root bus, will use [bus 00-ff]
[   34.919775] PCI: bus0: Fast back to back transfers enabled
[   34.919789] keystone-pcie: Ending PCI scan...
[   34.919794] keystone-pcie: keystone_pcie_rc_init - end
[   34.919997] vgaarb: loaded
[   34.920283] SCSI subsystem initialized
[   34.920842] usbcore: registered new interface driver usbfs
[   34.920917] usbcore: registered new interface driver hub
[   34.921009] usbcore: registered new device driver usb
[   34.922041] pps_core: LinuxPPS API ver. 1 registered
[   34.922046] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[   34.922108] PTP clock support registered
[   34.922238] keystone-hwqueue hwqueue.36: qmgr start queue 0, number of queues 8192
[   34.922310] keystone-hwqueue hwqueue.36: added qmgr start queue 0, num of queues 8192, reg_peek f0040000, reg_status f0006000, reg_config f0008000, reg_region f000a000, reg_push f0080000, reg_pop f00c0000
[   34.923037] keystone-hwqueue hwqueue.36: qos: sched port @8096, drop sched @8000
[   34.924006] keystone-hwqueue hwqueue.36: qos: sched port @6496, drop sched @6400
[   34.924932] keystone-hwqueue hwqueue.36: added pool pool-rio: 1024 descriptors of size 128
[   34.924941] keystone-hwqueue hwqueue.36: added pool pool-xge: 1024 descriptors of size 128
[   34.924950] keystone-hwqueue hwqueue.36: added pool pool-crypto: 1024 descriptors of size 128
[   34.924958] keystone-hwqueue hwqueue.36: added pool pool-net: 15360 descriptors of size 128
[   34.924967] keystone-hwqueue hwqueue.36: added pool pool-udma: 240 descriptors of size 256
[   34.925086] keystone-hwqueue hwqueue.36: failed to set up pool pool-rio 1024
[   34.925923] keystone-hwqueue hwqueue.36: registered queues 0-8191
[   34.926172] keystone-hwqueue hwqueue.36: qos version 0x200010b, magic valid
[   34.926654] keystone-hwqueue hwqueue.36: qos version 0x200010b, magic valid
[   34.927446] keystone-hwqueue hwqueue.36: no region for pool pool-rio
[   34.931458] keystone-pktdma 2a08000.pktdma: registered 4 logical channels, flows 32, tx chans: 32, rx chans: 32, loopback
[   34.935983] keystone-pktdma 24186000.pktdma: registered 44 logical channels, flows 128, tx chans: 21, rx chans: 91
[   34.936468] keystone-pktdma 2fa1000.pktdma: registered 4 logical channels, flows 32, tx chans: 16, rx chans: 16
[   34.936596] Switching to clocksource arch_sys_counter
[   34.953545] NET: Registered protocol family 2
[   34.954007] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[   34.954114] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[   34.954218] TCP: Hash tables configured (established 8192 bind 8192)
[   34.954258] TCP: reno registered
[   34.954266] UDP hash table entries: 512 (order: 2, 16384 bytes)
[   34.954291] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[   34.954456] NET: Registered protocol family 1
[   34.954591] RPC: Registered named UNIX socket transport module.
[   34.954597] RPC: Registered udp transport module.
[   34.954601] RPC: Registered tcp transport module.
[   34.954605] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   34.954970] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[   35.028542] bounce pool size: 64 pages
[   35.035246] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   35.035407] NTFS driver 2.1.30 [Flags: R/O].
[   35.035623] jffs2: version 2.2. (NAND) ?? 2001-2006 Red Hat, Inc.
[   35.035907] msgmni has been set to 1445
[   35.037241] NET: Registered protocol family 38
[   35.037412] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[   35.037419] io scheduler noop registered
[   35.037424] io scheduler deadline registered
[   35.037530] io scheduler cfq registered (default)
[   35.038257] keystone-udma udma0.37: registered udma device udma0
[   35.088761] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[   35.090158] 2530c00.serial: ttyS0 at MMIO 0x2530c00 (irq = 309) is a 16550A
[   35.997567] console [ttyS0] enabled
[   36.001642] 2531000.serial: ttyS1 at MMIO 0x2531000 (irq = 312) is a 16550A
[   36.011489] loop: module loaded
[   36.014735] at24 0-0050: 131072 byte 24c1024 EEPROM, writable, 1 bytes/write
[   36.022927] Generic platform RAM MTD, (c) 2004 Simtec Electronics
[   36.029830] ONFI param page 0 valid
[   36.033308] ONFI flash detected
[   36.036449] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xa3 (Micron MT29F8G08ADBDAH4), 1024MiB, page size: 2048, OOB size: 64
[   36.048136] Bad block table found at page 524224, version 0x01
[   36.054335] Bad block table found at page 524160, version 0x01
[   36.060433] 3 ofpart partitions found on MTD device 30000000.nand
[   36.066517] Creating 3 MTD partitions on "30000000.nand":
[   36.071904] 0x000000000000-0x000000100000 : "u-boot"
[   36.077454] 0x000000100000-0x000000180000 : "params"
[   36.082938] 0x000000180000-0x000020000000 : "ubifs"
[   36.088519] davinci_nand 30000000.nand: controller rev. 2.5
[   36.094637] spi_davinci 21000400.spi: master is unqueued, this is deprecated
[   36.101925] m25p80 spi32766.0: found n25q128a11, expected n25q128
[   36.108018] m25p80 spi32766.0: n25q128a11 (16384 Kbytes)
[   36.113325] 2 ofpart partitions found on MTD device spi32766.0
[   36.119150] Creating 2 MTD partitions on "spi32766.0":
[   36.124274] 0x000000000000-0x000000080000 : "u-boot-spl"
[   36.130162] 0x000000080000-0x000001000000 : "test"
[   36.135803] spi_davinci 21000400.spi: Controller at 0xf00b6400
[   36.141918] spi_davinci 21000600.spi: master is unqueued, this is deprecated
[   36.148961] spi_davinci 21000600.spi: Controller at 0xf00b8600
[   36.155057] spi_davinci 21000800.spi: master is unqueued, this is deprecated
[   36.162100] spi_davinci 21000800.spi: Controller at 0xf00ba800
[   36.168905] tun: Universal TUN/TAP device driver, 1.6
[   36.173943] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[   36.225790] davinci_mdio 24200f00.mdio: davinci mdio revision 1.7
[   36.231869] libphy: 24200f00.mdio: probed
[   36.236417] davinci_mdio 24200f00.mdio: phy[0]: device 24200f00.mdio:00, driver Marvell 88E1510
[   36.245099] davinci_mdio 24200f00.mdio: phy[1]: device 24200f00.mdio:01, driver Marvell 88E1510
[   36.254099] keystone-netcp 24000000.netcp: number of serdeses 2
[   36.260024] keystone-netcp 24000000.netcp: Missing cpts_clock_mult property in the DT.
[   36.267934] keystone-netcp 24000000.netcp: Missing cpts_clock_shift property in the DT.
[   36.275927] keystone-netcp 24000000.netcp: Missing cpts_clock_div property in the DT.
[   36.284682] keystone-netcp 24000000.netcp: cpsw serdes 0 config done lanes(mask) 0x3
[   36.293126] keystone-netcp 24000000.netcp: cpsw serdes 1 config done lanes(mask) 0x0
[   36.301662] keystone-netcp 24000000.netcp: Created interface "eth0"
[   36.307930] keystone-netcp 24000000.netcp: dma_chan_name nettx0
[   36.314556] keystone-netcp 24000000.netcp: Created interface "eth1"
[   36.320827] keystone-netcp 24000000.netcp: dma_chan_name nettx1
[   36.327472] keystone-netcp 24000000.netcp: Created interface "eth2"
[   36.333729] keystone-netcp 24000000.netcp: dma_chan_name nettx2
[   36.340385] keystone-netcp 24000000.netcp: Created interface "eth3"
[   36.346652] keystone-netcp 24000000.netcp: dma_chan_name nettx3
[   36.353297] keystone-netcp 24000000.netcp: Created interface "eth4"
[   36.359563] keystone-netcp 24000000.netcp: dma_chan_name nettx4
[   36.366227] keystone-netcp 24000000.netcp: Created interface "eth5"
[   36.372486] keystone-netcp 24000000.netcp: dma_chan_name nettx5
[   36.379153] keystone-netcp 24000000.netcp: Created interface "eth6"
[   36.385412] keystone-netcp 24000000.netcp: dma_chan_name nettx6
[   36.392072] keystone-netcp 24000000.netcp: Created interface "eth7"
[   36.398340] keystone-netcp 24000000.netcp: dma_chan_name nettx7
[   36.404529] keystone-netcp 24000000.netcp: pdsp 0 firmware: keystone/pa_in0_pdsp0.fw
[   36.412265] keystone-netcp 24000000.netcp: pdsp 1 firmware: keystone/pa_in0_pdsp1.fw
[   36.420001] keystone-netcp 24000000.netcp: pdsp 2 firmware: keystone/pa_in1_pdsp0.fw
[   36.427734] keystone-netcp 24000000.netcp: pdsp 3 firmware: keystone/pa_in1_pdsp1.fw
[   36.435462] keystone-netcp 24000000.netcp: pdsp 4 firmware: keystone/pa_in2_pdsp0.fw
[   36.443195] keystone-netcp 24000000.netcp: pdsp 5 firmware: keystone/pa_in3_pdsp0.fw
[   36.450929] keystone-netcp 24000000.netcp: pdsp 6 firmware: keystone/pa_in4_pdsp0.fw
[   36.458662] keystone-netcp 24000000.netcp: pdsp 7 firmware: keystone/pa_in4_pdsp1.fw
[   36.466396] keystone-netcp 24000000.netcp: pdsp 8 firmware: keystone/pa_post_pdsp0.fw
[   36.474211] keystone-netcp 24000000.netcp: pdsp 9 firmware: keystone/pa_post_pdsp1.fw
[   36.482031] keystone-netcp 24000000.netcp: pdsp 10 firmware: keystone/pa_eg0_pdsp0.fw
[   36.489851] keystone-netcp 24000000.netcp: pdsp 11 firmware: keystone/pa_eg0_pdsp1.fw
[   36.497671] keystone-netcp 24000000.netcp: pdsp 12 firmware: keystone/pa_eg0_pdsp2.fw
[   36.505487] keystone-netcp 24000000.netcp: pdsp 13 firmware: keystone/pa_eg1_pdsp0.fw
[   36.513307] keystone-netcp 24000000.netcp: pdsp 14 firmware: keystone/pa_eg2_pdsp0.fw
[   36.521871] keystone-netcp 24000000.netcp: Packet Accelerator PDSP 0 Firmware Version 0x03000105
[   36.530646] keystone-netcp 24000000.netcp: Packet Accelerator PDSP 1 Firmware Version 0x03000105
[   36.539419] keystone-netcp 24000000.netcp: Packet Accelerator PDSP 2 Firmware Version 0x03000105
[   36.548193] keystone-netcp 24000000.netcp: Packet Accelerator PDSP 3 Firmware Version 0x03000105
[   36.556966] keystone-netcp 24000000.netcp: Packet Accelerator PDSP 4 Firmware Version 0x03000105
[   36.565739] keystone-netcp 24000000.netcp: Packet Accelerator PDSP 5 Firmware Version 0x03000105
[   36.574507] keystone-netcp 24000000.netcp: Packet Accelerator PDSP 6 Firmware Version 0x03000105
[   36.583280] keystone-netcp 24000000.netcp: Packet Accelerator PDSP 7 Firmware Version 0x03000105
[   36.592053] keystone-netcp 24000000.netcp: Packet Accelerator PDSP 8 Firmware Version 0x03000105
[   36.600825] keystone-netcp 24000000.netcp: Packet Accelerator PDSP 9 Firmware Version 0x03000105
[   36.609597] keystone-netcp 24000000.netcp: Packet Accelerator PDSP 10 Firmware Version 0x03000105
[   36.618457] keystone-netcp 24000000.netcp: Packet Accelerator PDSP 11 Firmware Version 0x03000105
[   36.627320] keystone-netcp 24000000.netcp: Packet Accelerator PDSP 12 Firmware Version 0x03000105
[   36.636181] keystone-netcp 24000000.netcp: Packet Accelerator PDSP 13 Firmware Version 0x03000105
[   36.645035] keystone-netcp 24000000.netcp: Packet Accelerator PDSP 14 Firmware Version 0x03000105
[   36.654628] keystone-netcp 24000000.netcp: could not find interface 2 node in device tree
[   36.662799] keystone-netcp 24000000.netcp: Attach of module keystone-qos declined with -19
[   36.671060] keystone-netcp 24000000.netcp: could not find interface 3 node in device tree
[   36.679228] keystone-netcp 24000000.netcp: Attach of module keystone-qos declined with -19
[   36.687482] keystone-netcp 24000000.netcp: could not find interface 4 node in device tree
[   36.695649] keystone-netcp 24000000.netcp: Attach of module keystone-qos declined with -19
[   36.703899] keystone-netcp 24000000.netcp: could not find interface 5 node in device tree
[   36.712066] keystone-netcp 24000000.netcp: Attach of module keystone-qos declined with -19
[   36.720320] keystone-netcp 24000000.netcp: could not find interface 6 node in device tree
[   36.728487] keystone-netcp 24000000.netcp: Attach of module keystone-qos declined with -19
[   36.736742] keystone-netcp 24000000.netcp: could not find interface 7 node in device tree
[   36.744903] keystone-netcp 24000000.netcp: Attach of module keystone-qos declined with -19
[   36.753170] keystone-netcp 24000000.netcp: Attach of module keystone-sa declined with -19
[   36.761338] keystone-netcp 24000000.netcp: Attach of module keystone-sa declined with -19
[   36.769505] keystone-netcp 24000000.netcp: Attach of module keystone-sa declined with -19
[   36.777672] keystone-netcp 24000000.netcp: Attach of module keystone-sa declined with -19
[   36.785839] keystone-netcp 24000000.netcp: Attach of module keystone-sa declined with -19
[   36.794000] keystone-netcp 24000000.netcp: Attach of module keystone-sa declined with -19
[   36.803481] dwc3 2690000.dwc3: no usb2 phy configured
[   36.808537] platform 2690000.dwc3: Driver dwc3 requests probe deferral
[   36.815490] usbcore: registered new interface driver usb-storage
[   36.821622] usbcore: registered new interface driver usbserial
[   36.827510] usbcore: registered new interface driver usbserial_generic
[   36.834082] usbserial: USB Serial support registered for generic
[   36.840146] usbcore: registered new interface driver ch341
[   36.845687] usbserial: USB Serial support registered for ch341-uart
[   36.852000] usbcore: registered new interface driver cp210x
[   36.857627] usbserial: USB Serial support registered for cp210x
[   36.863597] usbcore: registered new interface driver ftdi_sio
[   36.869397] usbserial: USB Serial support registered for FTDI USB Serial Device
[   36.876758] usbcore: registered new interface driver pl2303
[   36.882376] usbserial: USB Serial support registered for pl2303
[   36.888681] mousedev: PS/2 mouse device common for all mice
[   36.894414] i2c /dev entries driver
[   36.898501] watchdog 22f0080.wdt: heartbeat 60 sec
[   36.905053] keystone-crypto 24080000.crypto: crypto accelerator enabled
[   36.911938] usbcore: registered new interface driver usbhid
[   36.917502] usbhid: USB HID core driver
[   36.921624]  remoteproc0: 2620844.dsp0 is available
[   36.926498]  remoteproc0: Note: remoteproc is still under development and considered experimental.
[   36.935444]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[   36.945804]  remoteproc0: no firmware found
[   36.950087] rproc-user 2620844.dsp0: registered misc device dsp0
[   36.956106] rproc-user dspmem.38: kick gpio
[   36.960389] rproc-user dspmem.38: registered misc device dspmem
[   36.966583] oprofile: using arm/armv7-ca15
[   36.970773] ipip: IPv4 over IPv4 tunneling driver
[   36.975819] gre: GRE over IPv4 demultiplexor driver
[   36.980685] ip_gre: GRE over IPv4 tunneling driver
[   36.986160] TCP: cubic registered
[   36.989464] Initializing XFRM netlink socket
[   36.994118] NET: Registered protocol family 10
[   36.999692] NET: Registered protocol family 17
[   37.004137] NET: Registered protocol family 15
[   37.008619] Bridge firewalling registered
[   37.012620] 8021q: 802.1Q VLAN Support v1.8
[   37.018414] sctp: Hash tables configured (established 65536 bind 65536)
[   37.025209] NET: Registered protocol family 41
[   37.029775] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[   37.037436] Registering SWP/SWPB emulation handler
[   37.244040] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   37.249538] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[   37.257667] xhci-hcd xhci-hcd.0.auto: irq 184, io mem 0x02690000
[   37.263727] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   37.270514] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   37.277729] usb usb1: Product: xHCI Host Controller
[   37.282594] usb usb1: Manufacturer: Linux 3.10.72 xhci-hcd
[   37.288073] usb usb1: SerialNumber: xhci-hcd.0.auto
[   37.293345] hub 1-0:1.0: USB hub found
[   37.297103] hub 1-0:1.0: 1 port detected
[   37.301179] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   37.306667] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[   37.314373] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[   37.321154] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   37.328370] usb usb2: Product: xHCI Host Controller
[   37.333235] usb usb2: Manufacturer: Linux 3.10.72 xhci-hcd
[   37.338713] usb usb2: SerialNumber: xhci-hcd.0.auto
[   37.343936] hub 2-0:1.0: USB hub found
[   37.347691] hub 2-0:1.0: 1 port detected
[   37.351967] UBI: attaching mtd2 to ubi0
[   38.927289] UBI: scanning is finished
[   38.931075] UBI error: ubi_read_volume_table: the layout volume was not found
[   38.939581] UBI error: ubi_attach_mtd_dev: failed to attach mtd2, error -22
[   38.946546] UBI error: ubi_init: cannot attach mtd2
[   38.953719] UBIFS error (pid 1): ubifs_mount: cannot open "ubi0:rootfs", error -19
[   38.961288] VFS: Cannot open root device "ubi0:rootfs" or unknown-block(0,0): error -19
[   38.969280] Please append a correct "root=" boot option; here are the available partitions:
[   38.977627] 1f00            1024 mtdblock0  (driver?)
[   38.982671] 1f01             512 mtdblock1  (driver?)
[   38.987721] 1f02          522752 mtdblock2  (driver?)
[   38.992764] 1f03             512 mtdblock3  (driver?)
[   38.997811] 1f04           15872 mtdblock4  (driver?)
[   39.002853] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[   39.011102] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 3.10.72 #1
[   39.017117] [<c00159c0>] (unwind_backtrace+0x0/0xf8) from [<c0011abc>] (show_stack+0x10/0x14)
[   39.025632] [<c0011abc>] (show_stack+0x10/0x14) from [<c05251fc>] (panic+0x90/0x1ec)
[   39.033368] [<c05251fc>] (panic+0x90/0x1ec) from [<c075dfa8>] (mount_block_root+0x184/0x230)
[   39.041794] [<c075dfa8>] (mount_block_root+0x184/0x230) from [<c075e1f4>] (prepare_namespace+0x8c/0x18c)
[   39.051260] [<c075e1f4>] (prepare_namespace+0x8c/0x18c) from [<c075dc48>] (kernel_init_freeable+0x180/0x1c8)
[   39.061076] [<c075dc48>] (kernel_init_freeable+0x180/0x1c8) from [<c051ef08>] (kernel_init+0x8/0xe4)
[   39.070195] [<c051ef08>] (kernel_init+0x8/0xe4) from [<c000dc38>] (ret_from_fork+0x14/0x3c)
[   39.078531] CPU3: stopping
[   39.081232] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 3.10.72 #1
[   39.087234] [<c00159c0>] (unwind_backtrace+0x0/0xf8) from [<c0011abc>] (show_stack+0x10/0x14)
[   39.095747] [<c0011abc>] (show_stack+0x10/0x14) from [<c0013ccc>] (handle_IPI+0xfc/0x130)
[   39.103910] [<c0013ccc>] (handle_IPI+0xfc/0x130) from [<c000854c>] (gic_handle_irq+0x54/0x5c)
[   39.112422] [<c000854c>] (gic_handle_irq+0x54/0x5c) from [<c052b500>] (__irq_svc+0x40/0x50)
[   39.120756] Exception stack(0xee0d7f98 to 0xee0d7fe0)
[   39.125794] 7f80:                                                       c288d918 00000000
[   39.133955] 7fa0: 00000d9c 00000000 ee0d6000 ee0d6000 c07ba458 ee0d6000 c05334a0 c0816a3d
[   39.142117] 7fc0: c0817210 00000000 00000000 ee0d7fe0 c000ed88 c000ed8c 60000013 ffffffff
[   39.150281] [<c052b500>] (__irq_svc+0x40/0x50) from [<c000ed8c>] (arch_cpu_idle+0x28/0x30)
[   39.158533] [<c000ed8c>] (arch_cpu_idle+0x28/0x30) from [<c0058618>] (cpu_startup_entry+0x50/0x1b4)
[   39.167564] [<c0058618>] (cpu_startup_entry+0x50/0x1b4) from [<80521f84>] (0x80521f84)
[   39.175465] CPU1: stopping
[   39.178163] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 3.10.72 #1
[   39.184164] [<c00159c0>] (unwind_backtrace+0x0/0xf8) from [<c0011abc>] (show_stack+0x10/0x14)
[   39.192676] [<c0011abc>] (show_stack+0x10/0x14) from [<c0013ccc>] (handle_IPI+0xfc/0x130)
[   39.200840] [<c0013ccc>] (handle_IPI+0xfc/0x130) from [<c000854c>] (gic_handle_irq+0x54/0x5c)
[   39.209350] [<c000854c>] (gic_handle_irq+0x54/0x5c) from [<c052b500>] (__irq_svc+0x40/0x50)
[   39.217684] Exception stack(0xee0d3f98 to 0xee0d3fe0)
[   39.222722] 3f80:                                                       c287d918 00000000
[   39.230884] 3fa0: 000017be 00000000 ee0d2000 ee0d2000 c07ba458 ee0d2000 c05334a0 c0816a3d
[   39.239045] 3fc0: c0817210 00000000 00000000 ee0d3fe0 c000ed88 c000ed8c 60000013 ffffffff
[   39.247210] [<c052b500>] (__irq_svc+0x40/0x50) from [<c000ed8c>] (arch_cpu_idle+0x28/0x30)
[   39.255461] [<c000ed8c>] (arch_cpu_idle+0x28/0x30) from [<c0058618>] (cpu_startup_entry+0x50/0x1b4)
[   39.264490] [<c0058618>] (cpu_startup_entry+0x50/0x1b4) from [<80521f84>] (0x80521f84)
[   39.272390] CPU0: stopping
[   39.275088] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.10.72 #1
[   39.281089] [<c00159c0>] (unwind_backtrace+0x0/0xf8) from [<c0011abc>] (show_stack+0x10/0x14)
[   39.289601] [<c0011abc>] (show_stack+0x10/0x14) from [<c0013ccc>] (handle_IPI+0xfc/0x130)
[   39.297764] [<c0013ccc>] (handle_IPI+0xfc/0x130) from [<c000854c>] (gic_handle_irq+0x54/0x5c)
[   39.306274] [<c000854c>] (gic_handle_irq+0x54/0x5c) from [<c052b500>] (__irq_svc+0x40/0x50)
[   39.314606] Exception stack(0xc07b3f68 to 0xc07b3fb0)
[   39.319646] 3f60:                   c2875918 00000000 000012fa 00000000 c07b2000 c07b2000
[   39.327807] 3f80: c07ba458 c07b2000 c05334a0 c0816a3d c0817210 00000000 00000000 c07b3fb0
[   39.335967] 3fa0: c000ed88 c000ed8c 60000113 ffffffff
[   39.341009] [<c052b500>] (__irq_svc+0x40/0x50) from [<c000ed8c>] (arch_cpu_idle+0x28/0x30)
[   39.349260] [<c000ed8c>] (arch_cpu_idle+0x28/0x30) from [<c0058618>] (cpu_startup_entry+0x50/0x1b4)
[   39.358293] [<c0058618>] (cpu_startup_entry+0x50/0x1b4) from [<c075da70>] (start_kernel+0x300/0x358)
[   39.367411] [<c075da70>] (start_kernel+0x300/0x358) from [<80008084>] (0x80008084)
    U-boot 的NAND Flash 信息都差不多, 除了Bad block 信息不一样。
MT29F8G08ADBDAH4                           MT29F4G08ABBDAH4
     请问大家有什么好办法,让我定位哪里出问题?
