Part Number: TDA2SX
采用TDA2SX 录制视频时,发现视频闪烁不停,三条链路,其中两条是正常的,有一条录制出来的视频闪烁;
Hello, Cherry,
currently, this issue is resovled via replacing the algorithm link, but the root cause which make the video flashes hasn't been found. could you kindly give some advices on possible reasons for this phenomenon, thanks in advance.
best regards!
ohenry
Hi Cherry,
Nice to hear from you and thanks for your kindly help.
to the question"
Are you asking the reason why the algorithm link is causing flicker in video?
The answer is yes. and the explanation from your colleague make sense.
after reviewing this question, I think that other possible reason to this question maybe this:
algorithm link makes the frame rate on this link decreases since it spends a lot of time to process frames, when frame rate decrease, encoder keep the constant output fps, so it had to insert some blank frame or green frame into video, when user play the video, the flicker happens.
thanks and have a good day!
BR.
