这是我用Matlab导出来的dat文件
这是加载后存储空间中的数据
下面是TI .dat 头信息的说明。您的.dat文件中pageNum是0,请查看程序空间是否正确?
The header information for data files uses this syntax:
MagicNumber—fixed at 1651.
Format—a number from 1 to 4, indicating the format of the samples in the file.
This number represents a data format: (1) hexadecimal, (2) integer, (3) long, (4) float, or (9) Use new scheme
StartingAddress—starting address of the block that was saved.
PageNum—page number the block was taken from.
Length—number of samples in the block.
NewFormat—Format (9); the new scheme. This is optional when usign the legacy formats 1 - 4
