Part Number: TDA3XEVM
TI专家好,
我在PROCESSOR_SDK_RADAR_03_08_00_00基础上修改了vision_sdk\build\Rules.make中MAKEAPPNAME=apps;MAKECONFIG=tda3xx_evm_bios_radar,编译一直会出现错误如下,利用
rm –rf binaries删除编译文件后,运行gmake -s depend能正常运行,但是运行gmake -s一直会报错,生成的编译核文件不完整,而且经常会出现类似的错误,请问有没有什么解决办法,这个编译比较慢,如果都编译到最后报出错误会非常耗时,麻烦帮忙看看是啥问题,非常感谢。
$ gmake -s
E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: ipc_PATH does not exist! ()
# Compiling tda3xx-evm:ipu1_0:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_algorithm: algorithmLink_cfg.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_algorithm: algorithmLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_algorithm: algorithmLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_algorithm
# Compiling tda3xx-evm:ipu1_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_algorithm: algorithmLink_cfg.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_algorithm: algorithmLink_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_algorithm: algorithmLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_algorithm
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_cfg.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_algorithm
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_cfg.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_algorithm
# Compiling tda3xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda3xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_cfg.c
# Compiling tda3xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_tsk.c
# Compiling tda3xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:arp32_1:release:links_common_algorithm
# Compiling tda3xx-evm:ipu1_0:release:links_common_dup: dupLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_dup: dupLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_dup
# Compiling tda3xx-evm:ipu1_1:release:links_common_dup: dupLink_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_dup: dupLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_dup
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_dup: dupLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_dup
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_dup: dupLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_dup
# Compiling tda3xx-evm:arp32_1:release:links_common_dup: dupLink_tsk.c
# Compiling tda3xx-evm:arp32_1:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:arp32_1:release:links_common_dup
# Compiling tda3xx-evm:ipu1_0:release:links_common_gate: gateLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_gate: gateLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_gate
# Compiling tda3xx-evm:ipu1_1:release:links_common_gate: gateLink_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_gate: gateLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_gate
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_gate: gateLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_gate
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_gate: gateLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_gate
# Compiling tda3xx-evm:arp32_1:release:links_common_gate: gateLink_tsk.c
# Compiling tda3xx-evm:arp32_1:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:arp32_1:release:links_common_gate
# Compiling tda3xx-evm:ipu1_0:release:links_common_ipcIn: ipcInLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_ipcIn: ipcInLink_drv.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_ipcIn: ipcInLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_ipcIn
# Compiling tda3xx-evm:ipu1_1:release:links_common_ipcIn: ipcInLink_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_ipcIn: ipcInLink_drv.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_ipcIn: ipcInLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_ipcIn
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcIn: ipcInLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcIn: ipcInLink_drv.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_ipcIn
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcIn: ipcInLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcIn: ipcInLink_drv.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_ipcIn
# Compiling tda3xx-evm:arp32_1:release:links_common_ipcIn: ipcInLink_tsk.c
# Compiling tda3xx-evm:arp32_1:release:links_common_ipcIn: ipcInLink_drv.c
# Compiling tda3xx-evm:arp32_1:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:arp32_1:release:links_common_ipcIn
# Compiling tda3xx-evm:ipu1_0:release:links_common_ipcOut: ipcOutLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_ipcOut: ipcOutLink_drv.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_ipcOut: ipcOutLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_ipcOut
# Compiling tda3xx-evm:ipu1_1:release:links_common_ipcOut: ipcOutLink_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_ipcOut: ipcOutLink_drv.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_ipcOut: ipcOutLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_ipcOut
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcOut: ipcOutLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcOut: ipcOutLink_drv.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_ipcOut
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcOut: ipcOutLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcOut: ipcOutLink_drv.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_ipcOut
# Compiling tda3xx-evm:arp32_1:release:links_common_ipcOut: ipcOutLink_tsk.c
# Compiling tda3xx-evm:arp32_1:release:links_common_ipcOut: ipcOutLink_drv.c
# Compiling tda3xx-evm:arp32_1:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:arp32_1:release:links_common_ipcOut
# Compiling tda3xx-evm:ipu1_0:release:links_common_merge: mergeLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_merge: mergeLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_merge
# Compiling tda3xx-evm:ipu1_1:release:links_common_merge: mergeLink_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_merge: mergeLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_merge
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_merge: mergeLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_merge
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_merge: mergeLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_merge
# Compiling tda3xx-evm:arp32_1:release:links_common_merge: mergeLink_tsk.c
# Compiling tda3xx-evm:arp32_1:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:arp32_1:release:links_common_merge
# Compiling tda3xx-evm:ipu1_0:release:links_common_null: nullLink_tsk.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_null
# Compiling tda3xx-evm:ipu1_1:release:links_common_null: nullLink_tsk.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_null
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_null: nullLink_tsk.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_null
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_null: nullLink_tsk.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_null
# Compiling tda3xx-evm:arp32_1:release:links_common_null: nullLink_tsk.c
# Archiving tda3xx-evm:arp32_1:release:links_common_null
# Compiling tda3xx-evm:ipu1_0:release:links_common_network_tx: networkTxLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_network_tx: networkTxLink_drv.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_network_tx
# Compiling tda3xx-evm:ipu1_1:release:links_common_network_tx: networkTxLink_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_network_tx: networkTxLink_drv.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_network_tx
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_network_tx: networkTxLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_network_tx: networkTxLink_drv.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_network_tx
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_network_tx: networkTxLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_network_tx: networkTxLink_drv.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_network_tx
# Compiling tda3xx-evm:arp32_1:release:links_common_network_tx: networkTxLink_tsk.c
# Compiling tda3xx-evm:arp32_1:release:links_common_network_tx: networkTxLink_drv.c
# Archiving tda3xx-evm:arp32_1:release:links_common_network_tx
# Compiling tda3xx-evm:ipu1_0:release:links_common_network_rx: networkRxLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_network_rx: networkRxLink_drv.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_network_rx
# Compiling tda3xx-evm:ipu1_1:release:links_common_network_rx: networkRxLink_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_network_rx: networkRxLink_drv.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_network_rx
# Compiling tda3xx-evm:ipu1_0:release:links_common_nullSrc: nullSrcLink_tsk.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_nullSrc
# Compiling tda3xx-evm:ipu1_1:release:links_common_nullSrc: nullSrcLink_tsk.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_nullSrc
# Compiling tda3xx-evm:ipu1_0:release:links_common_select: selectLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_select: selectLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_select
# Compiling tda3xx-evm:ipu1_1:release:links_common_select: selectLink_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_select: selectLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_select
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_select: selectLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_select: selectLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_select
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_select: selectLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_select: selectLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_select
# Compiling tda3xx-evm:arp32_1:release:links_common_select: selectLink_tsk.c
# Compiling tda3xx-evm:arp32_1:release:links_common_select: selectLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:arp32_1:release:links_common_select
# Compiling tda3xx-evm:ipu1_0:release:links_common_sync: syncLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_sync: syncLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_sync
# Compiling tda3xx-evm:ipu1_1:release:links_common_sync: syncLink_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_sync: syncLink_tsk_create_single_mbx.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_sync
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_sync: syncLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_sync
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_sync: syncLink_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_sync
# Compiling tda3xx-evm:arp32_1:release:links_common_sync: syncLink_tsk.c
# Compiling tda3xx-evm:arp32_1:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
# Archiving tda3xx-evm:arp32_1:release:links_common_sync
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_display: displayLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_display: displayLink_drv.c
# Archiving tda3xx-evm:ipu1_0:release:links_ipu_display
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_display_ctrl: displayCtrlLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_display_ctrl: displayCtrlLink_drv.c
# Archiving tda3xx-evm:ipu1_0:release:links_ipu_display_ctrl
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_capture: issCaptureLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_capture: issCaptureLink_drv.c
# Archiving tda3xx-evm:ipu1_0:release:links_ipu_iss_capture
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_vip_capture: captureLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_vip_capture: captureLink_drv.c
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_vip_capture: captureLink_subframe_drv.c
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_vip_capture: captureLink_displaywb_drv.c
# Archiving tda3xx-evm:ipu1_0:release:links_ipu_vip_capture
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_dssM2mWb: dssM2mWbLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_dssM2mWb: dssM2mWbLink_drv.c
# Archiving tda3xx-evm:ipu1_0:release:links_ipu_dssM2mWb
# Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_clk.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_remote_log_server.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_buf.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_mbx.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_mem.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_prf.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_que.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_tsk_multi_mbx.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_ipc_que.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_remote_log_client.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_global_time.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_buf_ext.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_timer_reconfig.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_link_stats_collector.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_pm.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_spinlock.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: safety_osal.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_cio.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_l3_emif_bw.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_boot_slaves.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_esm.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_ipu_ecc.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_dcc.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_execp_trace_local_m4.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_uart.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_dma.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: dma_cfg/utils_dma_edma3cc.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: dma_cfg/utils_dma_edma3cc_ipu_a15_intr.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_cbuf_ocmc.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_qspi.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_idle_m4.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_temperature.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_stat_collector.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_prcm_stats.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_emif_ecc.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_l3fw.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: stat_collector_utils/sci.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: stat_collector_utils/cToolsHelper.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_mcspi.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_mem_ipu1_0.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: dma_cfg/utils_dma_cfg_ipu1_0.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_taskTimer.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: stat_collector_utils/sci_config_tda3x.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_iss.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: ndk/ndk_nsp_hooks.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: network_api.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: network_tfdtp_api.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: file_api.c
# Compiling tda3xx-evm:ipu1_0:release:utils_common: file_api_dma.c
# Archiving tda3xx-evm:ipu1_0:release:utils_common
# Compiling tda3xx-evm:ipu1_1:release:utils_common: tda3xx/utils_clk.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_remote_log_server.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_buf.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_mbx.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_mem.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_prf.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_que.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_tsk_multi_mbx.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_ipc_que.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_remote_log_client.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_global_time.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_buf_ext.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_timer_reconfig.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_link_stats_collector.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_pm.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_spinlock.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: safety_osal.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_cio.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_iss.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_execp_trace_remote_m4.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_dma.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: dma_cfg/utils_dma_edma3cc.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: dma_cfg/utils_dma_edma3cc_ipu_a15_intr.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: dma_cfg/utils_dma_cfg_ipu1_1.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_idle_m4.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_stat_collector.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: stat_collector_utils/sci.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: stat_collector_utils/cToolsHelper.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_qspi.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: ndk/ndk_nsp_hooks.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: network_api.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: network_tfdtp_api.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: file_api.c
# Compiling tda3xx-evm:ipu1_1:release:utils_common: file_api_dma.c
# Archiving tda3xx-evm:ipu1_1:release:utils_common
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: tda3xx/utils_clk.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_remote_log_server.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_buf.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_mbx.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_mem.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_prf.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_que.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_tsk_multi_mbx.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_ipc_que.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_remote_log_client.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_global_time.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_buf_ext.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_timer_reconfig.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_link_stats_collector.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_pm.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_spinlock.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: safety_osal.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_cio.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_execp_trace_dsp.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_dma.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: dma_cfg/utils_dma_edma3cc.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: dma_cfg/utils_dma_cfg_dsp1.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: dma_cfg/utils_dma_edma3cc_dsp_intr.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_idle_c66x.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: network_api.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: network_tfdtp_api.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_cache_c66x.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_l3fw.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_xmc_mpu.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_ecc_c66x.c
# Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_taskTimer.c
# Archiving tda3xx-evm:c66xdsp_1:release:utils_common
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: tda3xx/utils_clk.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_remote_log_server.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_buf.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_mbx.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_mem.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_prf.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_que.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_tsk_multi_mbx.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_ipc_que.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_remote_log_client.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_global_time.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_buf_ext.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_timer_reconfig.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_link_stats_collector.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_pm.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_spinlock.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: safety_osal.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_cio.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_execp_trace_dsp.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_dma.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: dma_cfg/utils_dma_edma3cc.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: dma_cfg/utils_dma_cfg_dsp2.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: dma_cfg/utils_dma_edma3cc_dsp_intr.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_idle_c66x.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: network_api.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: network_tfdtp_api.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_cache_c66x.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_l3fw.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_xmc_mpu.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_ecc_c66x.c
# Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_taskTimer.c
# Archiving tda3xx-evm:c66xdsp_2:release:utils_common
# Compiling tda3xx-evm:arp32_1:release:utils_common: tda3xx/utils_clk.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_remote_log_server.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_buf.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_mbx.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_mem.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_prf.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_que.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_tsk.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_tsk_multi_mbx.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_ipc_que.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_remote_log_client.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_global_time.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_buf_ext.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_timer_reconfig.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_link_stats_collector.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_pm.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_spinlock.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: safety_osal.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_cio.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_dma.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: dma_cfg/utils_dma_edma3cc.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: dma_cfg/utils_dma_cfg_eve.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: dma_cfg/utils_dma_edma3cc_eve_intr.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_vip_interrupt.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_execp_trace_eve.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: network_api.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: network_tfdtp_api.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_idle_arp32.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: utils_l3fw.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: eveprofiler/utils_eve_profile.c
# Compiling tda3xx-evm:arp32_1:release:utils_common: eveprofiler/sctm.c
# Archiving tda3xx-evm:arp32_1:release:utils_common
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_linkApi.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_linkApi_local.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_common.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_ipc.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_ipc_msgq.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_tsk_multi_mbx.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_openvxipc.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_work_queue_if.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_work_queue_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_work_queue_unit_test.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_initDeinitLinks.c
# Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_ipc_ipc_lib.c
# Archiving tda3xx-evm:ipu1_0:release:links_common_system
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_linkApi.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_linkApi_local.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_common.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_ipc.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_ipc_msgq.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_tsk_multi_mbx.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_openvxipc.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_work_queue_if.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_work_queue_tsk.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_work_queue_unit_test.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_initDeinitLinks.c
# Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_ipc_ipc_lib.c
# Archiving tda3xx-evm:ipu1_1:release:links_common_system
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_linkApi.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_linkApi_local.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_common.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_ipc.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_ipc_msgq.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_tsk_multi_mbx.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_openvxipc.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_work_queue_if.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_work_queue_tsk.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_work_queue_unit_test.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_initDeinitLinks.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_ipc_ipc_lib.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_common_system
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_linkApi.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_linkApi_local.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_common.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_ipc.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_ipc_msgq.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_tsk_multi_mbx.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_openvxipc.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_work_queue_if.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_work_queue_tsk.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_work_queue_unit_test.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_initDeinitLinks.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_ipc_ipc_lib.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_common_system
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_linkApi.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_linkApi_local.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_common.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_ipc.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_ipc_msgq.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_tsk_multi_mbx.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_openvxipc.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_work_queue_if.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_work_queue_tsk.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_work_queue_unit_test.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_initDeinitLinks.c
# Compiling tda3xx-evm:arp32_1:release:links_common_system: system_ipc_ipc_lib.c
# Archiving tda3xx-evm:arp32_1:release:links_common_system
# Compiling tda3xx-evm:c66xdsp_1:release:links_dsp_system: system_c6xdsp.c
# Compiling tda3xx-evm:c66xdsp_1:release:links_dsp_system: systemLink_tsk_c6xdsp.c
# Archiving tda3xx-evm:c66xdsp_1:release:links_dsp_system
# Compiling tda3xx-evm:c66xdsp_2:release:links_dsp_system: system_c6xdsp.c
# Compiling tda3xx-evm:c66xdsp_2:release:links_dsp_system: systemLink_tsk_c6xdsp.c
# Archiving tda3xx-evm:c66xdsp_2:release:links_dsp_system
# Compiling tda3xx-evm:arp32_1:release:links_eve_system: system_eve.c
# Compiling tda3xx-evm:arp32_1:release:links_eve_system: systemLink_tsk_eve.c
# Compiling tda3xx-evm:arp32_1:release:links_eve_system: systemLink_tsk_eve_multi_mbx.c
# Archiving tda3xx-evm:arp32_1:release:links_eve_system
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_system: system_bsp_init.c
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_system: system_ipu1_0.c
# Compiling tda3xx-evm:ipu1_0:release:links_ipu_system: systemLink_tsk_ipu1.c
# Archiving tda3xx-evm:ipu1_0:release:links_ipu_system
# Compiling tda3xx-evm:ipu1_1:release:links_ipu_system: system_ipu1_1.c
# Compiling tda3xx-evm:ipu1_1:release:links_ipu_system: systemLink_tsk_ipu1.c
# Archiving tda3xx-evm:ipu1_1:release:links_ipu_system
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/radarprocess/radarProcessLink_algPlugin.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarframecopy/radarFrameCopy.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/common/alg_functions.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font10_yuv.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font11_yuv.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font12_yuv.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font13_yuv.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font02.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font00.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: common/alg_ivision.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/usecases/radar_capture_only/chains_radarcaptureonly.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/usecases/radar_capture_only/chains_radarcaptureonly_priv.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/usecases/radar_objectdetect_display/chains_radarobjectdetectdisplay.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/usecases/radar_objectdetect_display/chains_radarobjectdetectdisplay_priv.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/usecases/radar_objectdetect_null/chains_radarobjectdetectnull.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/usecases/radar_objectdetect_null/chains_radarobjectdetectnull_priv.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/usecases/radar_capture_process/chains_radarcaptureprocess.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/usecases/radar_capture_process/chains_radarcaptureprocess_priv.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radardraw/radarDraw.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radardraw/radarDraw_priv.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarfft2/radarFft2.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarpeakdetect/radarPkDetect.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarbeamform/radarBeamForm.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/common/chains_main_bios_radar.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/common/chains_main_bios_settings_radar.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/common/chains_common.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/common/chains_radar_main.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/common/chains_common_radar.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/common/chains_common_sample_ar12xx_config.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/common/chains_radar_file_io.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/common/chains_radar_util_read_params.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/common/chains_common_ar12xx.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font01.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font03.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font04.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font05.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font06.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font07.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font08.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font09.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font14.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_ti_logo_white.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_ti_logo_white_1.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_ti_logo_white_small.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mmc_wr.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_echo.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mem_rd.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_qspi_wr.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mmc_wr_proxy.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_sys_reset.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mem_save.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_device_comm.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_cons/network_cons_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/network_cons/network_cons_ipc.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/osal/chains_common_osal.c
# Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: common/sample.cpp
# Archiving tda3xx-evm:ipu1_0:release:app_alg_plugins
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/radarprocess/radarProcessLink_algPlugin.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarframecopy/radarFrameCopy.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/common/alg_functions.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font10_yuv.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font11_yuv.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font12_yuv.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font13_yuv.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font02.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font00.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: common/alg_ivision.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radardraw/radarDraw.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radardraw/radarDraw_priv.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarfft2/radarFft2.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarpeakdetect/radarPkDetect.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarbeamform/radarBeamForm.c
# Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: common/sample.cpp
# Archiving tda3xx-evm:c66xdsp_1:release:app_alg_plugins
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: common/sample_vcop_array_add_uns_short_kernel.k
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/radarprocess/radarProcessLink_algPlugin.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarframecopy/radarFrameCopy.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/common/alg_functions.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font10_yuv.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font11_yuv.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font12_yuv.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font13_yuv.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font02.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/draw2d/draw2d_font00.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: common/alg_ivision.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarfft2/radarFft_work.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarpeakdetect/radarPkDetect_work.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/radarbeamform/radarBeamForm_work.c
# Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: common/sample.cpp
# Archiving tda3xx-evm:arp32_1:release:app_alg_plugins
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/common/chains_main_bios_settings.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/common/chains_main_bios.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/board/board_tda2xx_ti_evm.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_tsk.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_cpu_load.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_tidl_od_layout.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/link_stats_monitor/link_stats_monitor.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/devices/lcd.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/devices/hdmi_tx.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/devices/eth_cam.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/modules/devcontrol/devControl_handler.c
# Compiling tda3xx-evm:ipu1_0:release:app_libs: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/rtos/usecases/common/chains_common.c
# Archiving tda3xx-evm:ipu1_0:release:app_libs
whoami: unknown option -- g
Try 'whoami --help' for more information.
C:/Users/WANGKU~1/AppData/Local/Temp/2/make25472-1.sh: line 1: findstr: command not found
# Invoking configuro...
processed file: E:\PROCESSOR_SDK_RADAR_03_08_00_00\vision_sdk\binaries\apps\tda3xx_evm_bios_radar\maketemp_configuro_cmd_arp32_1.bat
E:\PROCESSOR_SDK_RADAR_03_08_00_00\vision_sdk\links_fw\src\rtos\bios_app_common\tda3xx\eve1>E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/windows/xdctools_3_32_01_22_core/xs xdc.tools.configuro --generationOnly -o E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/arp32_1/release/vision_sdk_configuro -t ti.targets.arp32.elf.ARP32_far -p ti.platforms.evmTDA3XX:EVE_1 -r release -c E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/cg_tools/windows/arp32_1.0.7 -b E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/build/rtos/tda3xx/config_arp32.bld --cfgArgs "{mode: \"\", coreName:\"EVE-1\", platformMem: \"DDR_MEM_128M\"}" MAIN_APP_eve1.cfg
making package.mak (because of package.bld) ...
# !!! Current build platform is [tda3xx-evm] !!!
# !!! Core is [arp32_1] !!!
generating interfaces for package vision_sdk_configuro (because package/package.xdc.inc is older than package.xdc) ...
configuring MAIN_APP_eve1.xearp32F from package/cfg/MAIN_APP_eve1_pearp32F.cfg ...
Loading Eve1.cfg for tda3xx-evm
generating custom ti.sysbios library makefile ...
Starting build of library sources ...
cd E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src
E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/windows/xdctools_3_32_01_22_core/gmake.exe -f E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/makefile.libs GEN_SRC_DIR=E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src
making E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/sysbios/sysbios.aearp32F ...
gmake[1]: Entering directory `E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/sysbios'
clearp32F E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/BIOS.c ...
asmearp32F E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/family/arp32/Hwi_switch_asm.sarp32 ...
asmearp32F E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/family/arp32/Hwi_disp_always.sarp32 ...
asmearp32F E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/family/arp32/TaskSupport_asm.sarp32 ...
arearp32F BIOS.obj arp32_Hwi_switch_asm.obj arp32_Hwi_disp_always.obj arp32_TaskSupport_asm.obj ...
gmake[1]: Leaving directory `E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/sysbios'
Build of libraries done.
# Configuro done!
# Making tda3xx-evm:arp32_1:release:vision_sdk_lib...
# Compiling tda3xx-evm:arp32_1:release:vision_sdk: src/main_common_eve1.c
# Compiling tda3xx-evm:arp32_1:release:vision_sdk: src/tlb_config_eve1.c
# Compiling tda3xx-evm:arp32_1:release:vision_sdk: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/common/main_app/tda3xx/eve1/src/main_eve1.c
# Compiling tda3xx-evm:arp32_1:release:vision_sdk: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/common/app_init/app_init_eve.c
# Compiling generated MAIN_APP_eve1_pearp32F.oearp32F
# Linking into E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/vision_sdk/bin/tda3xx-evm/vision_sdk_arp32_1_release.xearp32F...
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda3xx/cfg/link_eve.cmd", line 12: warning:
no matching section
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda3xx/cfg/link_eve.cmd", line 13: warning:
no matching section
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda3xx/cfg/link_eve.cmd", line 18: warning:
no matching section
# E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/vision_sdk/bin/tda3xx-evm/vision_sdk_arp32_1_release.xearp32F created.
C:/Users/WANGKU~1/AppData/Local/Temp/2/make17268-1.sh: line 1: findstr: command not found
processed file: E:\PROCESSOR_SDK_RADAR_03_08_00_00\vision_sdk\binaries\apps\tda3xx_evm_bios_radar\maketemp_configuro_cmd_c66xdsp_1.bat
E:\PROCESSOR_SDK_RADAR_03_08_00_00\vision_sdk\links_fw\src\rtos\bios_app_common\tda3xx\dsp1>E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/windows/xdctools_3_32_01_22_core/xs xdc.tools.configuro --generationOnly -o E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_1/release/vision_sdk_configuro -t ti.targets.elf.C66 -p ti.platforms.evmTDA3XX:DSP_1 -r release -c E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/cg_tools/windows/ti-cgt-c6000_8.2.4 -b E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/build/rtos/tda3xx/config_c66.bld --cfgArgs "{mode: \"\", coreName:\"DSP-1\", platformMem: \"DDR_MEM_128M\"}" MAIN_APP_c6xdsp1.cfg
# !!! Core is [c66xdsp_1] !!!
configuring MAIN_APP_c6xdsp1.xe66 from package/cfg/MAIN_APP_c6xdsp1_pe66.cfg ...
Loading Dsp1.cfg for tda3xx-evm
warning: ti.sysbios.family.c66.Cache: "E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/family/c66/Cache.xs", line 340: ti.sysbios.family.c66.Cache : Cache settings were changed in user configuration. User configuration options will override platform settings. Check your memory map to make sure that Cache does not conflict with your L1/L2 memory placement. To avoid conflicts between L1/L2 memory and cache, we recommended specifying cache sizes along with memory sizes in a platform package.
cd E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src
E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/windows/xdctools_3_32_01_22_core/gmake.exe -f E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/makefile.libs GEN_SRC_DIR=E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src
making E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/sysbios/sysbios.ae66 ...
gmake[1]: Entering directory `E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/sysbios'
cle66 E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/BIOS.c ...
remark #24038-D: --optimize_with_debug is deprecated and will be removed in a
subsequent release. The behavior is enabled by default.
asme66 E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/family/c64p/Exception_asm.s64P ...
asme66 E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/family/c64p/Hwi_asm.s62 ...
asme66 E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/family/c64p/Hwi_asm_switch.s62 ...
asme66 E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/family/c64p/Hwi_disp_always.s64P ...
asme66 E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/timers/dmtimer/Timer_asm.s64P ...
asme66 E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/rts/ti/tls_get_tp.asm ...
asme66 E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/ti/sysbios/family/c62/TaskSupport_asm.s62 ...
are66 BIOS.obj c64p_Exception_asm.obj c64p_Hwi_asm.obj c64p_Hwi_asm_switch.obj c64p_Hwi_disp_always.obj dmtimer_Timer_asm.obj ti_tls_get_tp.obj c62_TaskSupport_asm.obj ...
gmake[1]: Leaving directory `E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/sysbios'
# Configuro done!
# Making tda3xx-evm:c66xdsp_1:release:vision_sdk_lib...
# Compiling tda3xx-evm:c66xdsp_1:release:vision_sdk: src/main_common_c6xdsp1.c
# Compiling tda3xx-evm:c66xdsp_1:release:vision_sdk: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/common/main_app/tda3xx/dsp1/src/main_c6xdsp1.c
# Compiling tda3xx-evm:c66xdsp_1:release:vision_sdk: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/common/app_init/app_init_dsp.c
# Compiling generated MAIN_APP_c6xdsp1_pe66.oe66
# Linking into E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/vision_sdk/bin/tda3xx-evm/vision_sdk_c66xdsp_1_release.xe66...
# E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/vision_sdk/bin/tda3xx-evm/vision_sdk_c66xdsp_1_release.xe66 created.
C:/Users/WANGKU~1/AppData/Local/Temp/2/make15448-1.sh: line 1: findstr: command not found
processed file: E:\PROCESSOR_SDK_RADAR_03_08_00_00\vision_sdk\binaries\apps\tda3xx_evm_bios_radar\maketemp_configuro_cmd_c66xdsp_2.bat
E:\PROCESSOR_SDK_RADAR_03_08_00_00\vision_sdk\links_fw\src\rtos\bios_app_common\tda3xx\dsp2>E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/windows/xdctools_3_32_01_22_core/xs xdc.tools.configuro --generationOnly -o E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro -t ti.targets.elf.C66 -p ti.platforms.evmTDA3XX:DSP_2 -r release -c E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/cg_tools/windows/ti-cgt-c6000_8.2.4 -b E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/build/rtos/tda3xx/config_c66.bld --cfgArgs "{mode: \"\", coreName:\"DSP-2\", platformMem: \"DDR_MEM_128M\"}" MAIN_APP_c6xdsp2.cfg
# !!! Core is [c66xdsp_2] !!!
configuring MAIN_APP_c6xdsp2.xe66 from package/cfg/MAIN_APP_c6xdsp2_pe66.cfg ...
Loading Dsp2.cfg for tda3xx-evm
cd E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src
E:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/windows/xdctools_3_32_01_22_core/gmake.exe -f E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src/makefile.libs GEN_SRC_DIR=E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src
making E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src/sysbios/sysbios.ae66 ...
gmake[1]: Entering directory `E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src/sysbios'
gmake[1]: Leaving directory `E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src/sysbios'
# Configuro done!
# Making tda3xx-evm:c66xdsp_2:release:vision_sdk_lib...
# Compiling tda3xx-evm:c66xdsp_2:release:vision_sdk: src/main_common_c6xdsp2.c
# Compiling tda3xx-evm:c66xdsp_2:release:vision_sdk: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/common/main_app/tda3xx/dsp2/src/main_c6xdsp2.c
# Compiling tda3xx-evm:c66xdsp_2:release:vision_sdk: E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/src/common/app_init/app_init_dsp.c
# Compiling generated MAIN_APP_c6xdsp2_pe66.oe66
# Linking into E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/vision_sdk/bin/tda3xx-evm/vision_sdk_c66xdsp_2_release.xe66...
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 170: error:
program will not fit into available memory. run placement with alignment
fails for section ".far" size 0x193800 . Available memory ranges:
DSP2_DATA_MEM size: 0x40000 unused: 0x0 max hole: 0x0
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 153: error:
program will not fit into available memory. placement with alignment fails
for section ".text" size 0x48da4 . Available memory ranges:
DSP2_CODE_MEM size: 0x40000 unused: 0x0 max hole: 0x0
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 156: error:
fails for section "GROUP_1" size 0x5c . Available memory ranges:
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 171: error:
for section ".args" size 0x64 . Available memory ranges:
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 189: error:
for section ".text:_c_int00" size 0xa0 . Available memory ranges:
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 172: error:
fails for section ".cio" size 0x127 . Available memory ranges:
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 168: error:
for section ".switch" size 0x155 . Available memory ranges:
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 181: error:
for section ".vecs" size 0x200 . Available memory ranges:
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 167: error:
fails for section ".fardata" size 0x242ff . Available memory ranges:
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 165: error:
for section ".const" size 0xc0368 . Available memory ranges:
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 183: error:
fails for section ".bss:taskStackSection" size 0x122000 . Available memory
ranges:
"E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/obj/vision_sdk/tda3xx-evm/c66xdsp_2/release/vision_sdk_configuro/linker_mod.cmd", line 162: error:
for section ".cinit" size 0x43c0 . Available memory ranges:
error: errors encountered during linking;
_radar/vision_sdk/bin/tda3xx-evm/vision_sdk_c66xdsp_2_release.xe66" not
built
gmake[7]: *** [E:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda3xx_evm_bios_radar/vision_sdk/bin/tda3xx-evm/vision_sdk_c66xdsp_2_release.xe66] Error 1
gmake[6]: *** [c66xdsp_2] Error 2
gmake[5]: *** [apps_dsp2] Error 2
gmake[4]: *** [apps] Error 2
gmake[3]: *** [apps] Error 2
gmake[2]: *** [apps_exe] Error 2
gmake[1]: *** [apps] Error 2
gmake: *** [vision_sdk] Error 2
