DM8168, usb error, device descriptor read/64, error -71
Other Parts Discussed in Thread: TVP5158
我们使用DM8168开发的新板块,目前usb报错
如下是系统启动时的日志信息:
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.37 (bigg@ubuntu) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #1 Tue Mar 12 09:31:05 CST 2013
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8168evm
vram size = 20971520 at 0x0
reserved size = 20971520 at 0x0
FB: Reserving 20971520 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8168 2.0
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 59904
Kernel command line: mem=256M console=ttyO2,115200n8 root=/dev/nfs rw nfsroot=100.0.7.154:/home/bigg/DVRRDK/DVRRDK_03.00.00.00/target/rfs_816x ip=100.0.7.144:100.0.7.154:100.0.6.1:255.255.255.0::eth0:off vram=20M notifyk.vpssm3_sva=0xBEE00000
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 236MB = 236MB total
Memory: 233856k/233856k available, 28288k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0x90800000 - 0xf8000000   (1656 MB)
    lowmem  : 0x80000000 - 0x90000000   ( 256 MB)
    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
      .init : 0x80008000 - 0x8003b000   ( 204 kB)
      .text : 0x8003b000 - 0x804e0000   (4756 kB)
      .data : 0x804e0000 - 0x80528fc0   ( 292 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:407
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ400
Trying to install interrupt handler for IRQ401
Trying to install interrupt handler for IRQ402
Trying to install interrupt handler for IRQ403
Trying to install interrupt handler for IRQ404
Trying to install interrupt handler for IRQ405
Trying to install interrupt handler for IRQ406
Trying to install type control for IRQ407
Trying to set irq flags for IRQ407
OMAP clockevent source: GPTIMER1 at 27000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 986.31 BogoMIPS (lpj=4931584)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 0
_omap_mux_get_by_name: Could not find signal i2c2_scl.i2c2_scl
_omap_mux_get_by_name: Could not find signal i2c2_sda.i2c2_sda
NOR: Can't request GPMC CS
registered ti816x_sr device
pm_dbg_init: only OMAP3 supported
registered ti81xx_vpss device
registered ti81xx_vidout device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
ti81xx_pcie: Invoking PCI BIOS...
ti81xx_pcie: Setting up Host Controller...
ti81xx_pcie: Register base mapped @0x90820000
ti81xx_pcie: Starting PCI scan...
PCI: bus0: Fast back to back transfers enabled
bio: create slab <bio-0> at 0
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
USBSS revision 4ea20809
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
omap_i2c omap_i2c.2: bus 2 rev4.0 at 100 kHz
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, host, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
musb-hdrc musb-hdrc.0: MUSB HDRC host driver
musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.37 musb-hcd
usb usb1: SerialNumber: musb-hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
musb-hdrc musb-hdrc.0: USB Host mode controller at 9081e000 using DMA, IRQ 18
musb-hdrc musb-hdrc.1: dma type: dma-cppi41
MUSB controller-1 revision 4ea20800
musb-hdrc musb-hdrc.1: MUSB HDRC host driver
musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.37 musb-hcd
usb usb2: SerialNumber: musb-hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
musb-hdrc musb-hdrc.1: USB Host mode controller at 90826800 using DMA, IRQ 19
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
msgmni has been set to 456
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
console [ttyO2] enabled
brd: module loaded
loop: module loaded
ahci ahci.0: forcing PORTS_IMPL to 0x3
ahci ahci.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x100 irq 16
ata2: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x180 irq 16
m25p80 spi1.0: found m25p05-nonjedec, expected w25x32
m25p80 spi1.0: m25p05-nonjedec (64 Kbytes)
Creating 4 MTD partitions on "spi_flash":
0x000000000000-0x000000040000 : "U-Boot"
mtd: partition "U-Boot" extends beyond the end of device "spi_flash" -- size truncated to 0x10000
0x000000010000-0x000000012000 : "U-Boot Env"
mtd: partition "U-Boot Env" is out of reach -- disabled
0x000000000000-0x000000280000 : "Kernel"
mtd: partition "Kernel" extends beyond the end of device "spi_flash" -- size truncated to 0x10000
0x000000010000-0x000000010000 : "File System"
mtd: partition "File System" is out of reach -- disabled
omap2-nand driver initializing
NAND device: Maf ID: 0x2c, Chip ID: 0xca (Micron, )
 erasesize: 0x20000, writesize: 2048, oobsize: 64
Creating 6 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x000000580000 : "U-Boot Logo"
0x000000580000-0x0000009c0000 : "Kernel"
0x0000009c0000-0x00000d1e0000 : "File System"
0x00000d1e0000-0x000010000000 : "Reserved"
usb 1-1: new high speed USB device using musb-hdrc and address 2
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffd
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver dm9601
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.0.0)
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
notify_init : notify drivercreated  for  remote proc id 2 at physical Address 0xbee00000
usbcore: registered new interface driver snd-usb-audio
Registered tvp5158 audio codec
asoc: tvp5158-hifi <-> davinci-mcasp.0 mapping ok
asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok
ALSA device list:
  #0: TI81XX EVM
TCP cubic registered
NET: Registered protocol family 17
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
smartreflex-ti816x: ti816x_sr_probe done!
omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
usb 1-1: device descriptor read/64, error -71
usb 1-1: new high speed USB device using musb-hdrc and address 3
davinci_mdio davinci_mdio.0: resetting idled controller
net eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, id=282f014)
usb 1-1: new high speed USB device using musb-hdrc and address 4
usb 1-1: device not accepting address 4, error -71
IP-Config: Gateway not on directly connected network.
usb 1-1: new high speed USB device using musb-hdrc and address 5
usb 1-1: device not accepting address 5, error -71
hub 1-0:1.0: unable to enumerate USB device on port 1
ata1: SATA link down (SStatus 0 SControl 300)
ata2: SATA link down (SStatus 0 SControl 300)
PHY: 0:01 - Link is Up - 100/Full
VFS: Mounted root (nfs filesystem) on device 0:15.
devtmpfs: mounted
Freeing init memory: 204K
INIT: version 2.86 booting
Error opening /dev/fb0: No such file or directory
Please wait: booting...
Starting udev
udevd (82): /proc/82/oom_adj is deprecated, please use /proc/82/oom_score_adj instead.
udev: starting version 141
udevd-event[93]: error changing netif name eth0 to eth6: Device or resource busy
Root filesystem already rw, not remounting
Caching udev devnodes
Populating dev cachemv: cannot rename '/tmp/devices': No such file or directory
ALSA: Restoring mixer settings...
NOT configuring network interfaces: / is an NFS mount
Sun Apr 17 08:07:00 UTC 2011
INIT: Entering runlevel: 5
Starting system message bus: dbus.
Starting telnet daemon.
Starting syslogd/klogd: done
Starting thttpd.
/etc/rc5.d/S99startapp: line 6: syntax error: "fi" unexpected
Applying sync command
 _   _ ___  _   _         _
| | | |    | ||| |___ ___| | _ ___
| |_| | |) |  ~  | . |  _| |/_|  -|
|_____|___ /____/ ___|_| |_| _|-__|
DVR_Netra Board (2011.04)
其中,用红色字体标明的是kernel中打印的与usb相关的日志信息,红色加粗字体,是usb口报错的信息。
此时进入系统,执行lsub,获得如下内容:
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
如果插入u盘时,会打印如下日志:
 usb 2-1: new high speed USB device using musb-hdrc and address 6
usb 2-1: device descriptor read/64, error -71
usb 2-1: new high speed USB device using musb-hdrc and address 7
usb 2-1: new high speed USB device using musb-hdrc and address 8
usb 2-1: device not accepting address 8, error -71
usb 2-1: new high speed USB device using musb-hdrc and address 9
usb 2-1: device not accepting address 9, error -71
hub 2-0:1.0: unable to enumerate USB device on port 1
关于硬件的管腿的连接,目前VDD_USB0_VBUS/VDD_USB1_VBUS都是连的正5V。
期待你们的答复,谢谢。
  • 你使用的是什么开发包?PSP的版本多少?另外有没有尝试通过一个USB hub再接U盘?
  • 使用的软件开发包DVRRDK_03.00.00.00
    尝试连接了USB hub,打印信息如下:
    usb 2-1: new high speed USB device using musb-hdrc and address 2
    usb 2-1: new high speed USB device using musb-hdrc and address 3
    usb 2-1: new high speed USB device using musb-hdrc and address 4
    usb 2-1: new high speed USB device using musb-hdrc and address 5
    usb 2-1: new high speed USB device using musb-hdrc and address 10
    usb 2-1: new high speed USB device using musb-hdrc and address 11
    usb 2-1: new high speed USB device using musb-hdrc and address 12
    usb 2-1: new high speed USB device using musb-hdrc and address 13
    usb 2-1: new high speed USB device using musb-hdrc and address 14
    usb 2-1: new high speed USB device using musb-hdrc and address 15
    usb 2-1: new high speed USB device using musb-hdrc and address 16
    usb 2-1: new high speed USB device using musb-hdrc and address 17
    usb 2-1: new high speed USB device using musb-hdrc and address 18
    usb 2-1: new high speed USB device using musb-hdrc and address 19
    usb 2-1: new high speed USB device using musb-hdrc and address 20
    usb 2-1: new high speed USB device using musb-hdrc and address 21
    usb 2-1: new high speed USB device using musb-hdrc and address 22
    usb 2-1: new high speed USB device using musb-hdrc and address 23
    usb 2-1: new high speed USB device using musb-hdrc and address 24
    usb 2-1: new high speed USB device using musb-hdrc and address 25
    usb 2-1: new high speed USB device using musb-hdrc and address 26
    usb 2-1: new high speed USB device using musb-hdrc and address 27
    usb 2-1: new high speed USB device using musb-hdrc and address 28
    usb 2-1: new high speed USB device using musb-hdrc and address 29
    usb 2-1: new high speed USB device using musb-hdrc and address 30
    usb 2-1: new high speed USB device using musb-hdrc and address 31
    usb 2-1: new high speed USB device using musb-hdrc and address 32
    usb 2-1: new high speed USB device using musb-hdrc and address 33
    usb 2-1: new high speed USB device using musb-hdrc and address 34
    usb 2-1: new high speed USB device using musb-hdrc and address 35
    usb 2-1: new high speed USB device using musb-hdrc and address 36
    usb 2-1: new high speed USB device using musb-hdrc and address 37
    usb 2-1: new high speed USB device using musb-hdrc and address 38
    usb 2-1: new high speed USB device using musb-hdrc and address 39
    usb 2-1: new high speed USB device using musb-hdrc and address 40
  • 请问您这个问题现在解决了么?在下也遇到同样的问题,急求解答!!谢谢。。。
  • 你好,请问这个问题解决了吗?能不能把解决方法共享一下?感激不尽呀。现在正在纠结中。
