Part Number: TDA4VM
你好,请教下这个工程ti-processor-sdk-rtos-j721e-evm-07_01_00_11可以用CCS做单步调试吗?是跑在TDA4开发板上的,板上有linux操作系统。
Part Number: TDA4VM
导入MCU的可执行文件后提示:MCU_Cortex_R5_0: Breakpoint Manager: One or more breakpoints will not relocate to new symbolic locations until the target halts.无法运行,是什么原因呢?
Load the debug version of the firmware binaries on the HLOS file system, and boot device.上面链接中的这一步正确执行了吗?
“板上有linux操作系统。”请问ARM核有跑linux吗?如果有跑的话,不能用6.3. Debugging without HLOS running on A72 (RTOS-only / baremetal)这里的步骤。要用我之前讲的6.4. Debugging with HLOS running on A72 (Linux / QNX)
