Other Parts Discussed in Thread: TPS65916, TMP102
我们选用飞凌嵌入式的核心板,用的AM5718芯片,目前共有3套,都出现过核心板掉电现象,但底板给核心板供电的DC5V正常,附件是两次掉电U盘内存储的LOG文件,其中有两个有关温度的信息:
有散热器但忘记开风扇:Nov 24 02:45:20 ok5718-idk user.emerg kernel: [31329.394634] thermal thermal_zone5: critical temperature reached(255 C),shutting down
有散热器且开风扇:Nov 25 18:12:19 ok5718-idk user.emerg kernel: [ 2691.074642] thermal thermal_zone5: critical temperature reached(127 C),shutting down
第一个255℃不可能达到这么高温度吧,第二个风扇的功率足够大,127℃也感觉不应该;不知道大家有没有遇到的这样的情况,下一步的测试验证方向是哪里?
第一个掉电前log:
第二个掉电前log:
Nov 25 18:12:19 ok5718-idk daemon.warn systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
Nov 25 18:12:19 ok5718-idk daemon.warn systemd[1]: sysinit.target: Found dependency on alignment.service/start
Nov 25 18:12:19 ok5718-idk daemon.warn systemd[1]: sysinit.target: Found dependency on basic.target/stop
Nov 25 18:12:19 ok5718-idk daemon.warn systemd[1]: sysinit.target: Found dependency on sysinit.target/start
Nov 25 18:12:19 ok5718-idk daemon.warn systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
Nov 25 18:12:19 ok5718-idk daemon.err systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
Nov 25 18:12:19 ok5718-idk daemon.info systemd[1]: Stopping Update UTMP about System Boot/Shutdown...
Nov 25 18:12:19 ok5718-idk daemon.info systemd[1]: Stopped target System Time Synchronized.
Nov 25 18:12:19 ok5718-idk daemon.info systemd[1]: Stopping Network Time Synchronization...
Nov 25 18:12:19 ok5718-idk daemon.info systemd[1]: Stopped target Multi-User System.
Nov 25 18:12:19 ok5718-idk daemon.info charon: 00[DMN] signal of type SIGINT received. Shutting down
Nov 25 18:12:19 ok5718-idk daemon.info charon: 00[KNL] received netlink error: Address family not supported by protocol (97)
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[DMN] Starting IKE charon daemon (strongSwan 5.5.0, Linux 4.9.41, armv7l)
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[CFG] opening PKCS#11 library failed: /usr/lib/softhsm/libsecstore.so.1: cannot open shared object file: No such file or directory
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[KNL] received netlink error: Address family not supported by protocol (97)
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[KNL] unable to create IPv4 routing table rule
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[CFG] loading ca certificates from '/etc/ipsec.d/cacerts'
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[LIB] file coded in unknown format, discarded
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[LIB] building CRED_CERTIFICATE - X509 failed, tried 5 builders
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[CFG] loading ca certificate from '/etc/ipsec.d/cacerts/.gitignore' failed
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[CFG] loading aa certificates from '/etc/ipsec.d/aacerts'
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[CFG] loading AA certificate from '/etc/ipsec.d/aacerts/.gitignore' failed
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[CFG] loading ocsp signer certificates from '/etc/ipsec.d/ocspcerts'
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[CFG] loading certificate from '/etc/ipsec.d/ocspcerts/.gitignore' failed
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[CFG] loading attribute certificates from '/etc/ipsec.d/acerts'
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[LIB] building CRED_CERTIFICATE - X509_AC failed, tried 3 builders
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[CFG] loading attribute certificate from '/etc/ipsec.d/acerts/.gitignore' failed
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[CFG] loading crls from '/etc/ipsec.d/crls'
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[LIB] building CRED_CERTIFICATE - X509_CRL failed, tried 4 builders
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[CFG] loading crl from '/etc/ipsec.d/crls/.gitignore' failed
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[CFG] loading secrets from '/etc/ipsec.secrets'
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[CFG] opening secrets file '/etc/ipsec.secrets' failed: No such file or directory
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[LIB] loaded plugins: charon pkcs11 aes des rc2 sha2 sha1 md5 random nonce x509 revocation constraints pubkey pkcs1 pkcs7 pkcs8 pkcs12 pgp dnskey sshkey pem openssl fips-prf xcbc cmac hmac ctr curl sqlite attr kernel-netl
Nov 25 18:12:19 ok5718-idk daemon.info avahi-daemon[621]: Got SIGTERM, quitting.
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[JOB] spawning 16 worker threads
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 05[KNL] interface can0 activated
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 08[KNL] interface can1 activated
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: 00[DMN] signal of type SIGINT received. Shutting down
Nov 25 18:12:19 ok5718-idk daemon.info systemd[1]: Stopping strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf...
Nov 25 18:12:19 ok5718-idk daemon.info avahi-daemon[621]: Leaving mDNS multicast group on interface eth1.IPv4 with address 192.168.1.35.
Nov 25 18:12:19 ok5718-idk daemon.info lighttpd[1041]: 2021-11-25 18:12:18: (../../lighttpd-1.4.41/src/server.c.1821) server stopped by UID = 0 PID = 1
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: charon stopped after 200 ms
Nov 25 18:12:19 ok5718-idk daemon.info ipsec[909]: ipsec starter stopped
Nov 25 18:12:19 ok5718-idk daemon.info systemd[1]: Stopping Login Service...
Nov 25 18:12:19 ok5718-idk user.notice kernel: klogd: exiting
Nov 25 18:12:19 ok5718-idk daemon.info systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
Nov 25 18:12:19 ok5718-idk authpriv.info ipsec_starter[909]: charon stopped after 200 ms
Nov 25 18:12:19 ok5718-idk daemon.info systemd[1]: Stopping Kernel Logging Service...
Nov 25 18:12:19 ok5718-idk authpriv.info ipsec_starter[909]: ipsec starter stopped
Nov 25 18:12:19 ok5718-idk daemon.info systemd[1]: Stopping Load/Save Screen Backlight Brightness of backlight:backlight...
Nov 25 18:12:19 ok5718-idk daemon.info avahi-daemon[621]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.0.232.
Nov 25 18:12:19 ok5718-idk daemon.info systemd[1]: Stopping Load/Save Random Seed...
Nov 25 18:12:19 ok5718-idk daemon.info avahi-daemon[621]: avahi-daemon 0.6.32 exiting.
Nov 25 18:12:19 ok5718-idk daemon.info systemd[1]: Stopped target Sound Card.
Nov 25 18:12:19 ok5718-idk local0.info snmpd[998]: Received TERM or STOP signal... shutting down...
Nov 25 18:12:19 ok5718-idk daemon.info systemd[1]: Stopping Simple Network Management Protocol (SNMP) Daemon....
Nov 25 18:12:19 ok5718-idk daemon.info ofonod[604]: Terminating
Nov 25 18:12:19 ok5718-idk daemon.info systemd[1]: Stopping helloworld...
Nov 25 18:12:19 ok5718-idk daemon.notice dbus[640]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service'
Nov 25 18:12:19 ok5718-idk daemon.info systemd[1]: Stopped target Timers.
Nov 25 18:12:19 ok5718-idk daemon.info ofonod[604]: Exit
Nov 25 18:12:19 ok5718-idk daemon.info systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Nov 25 18:12:19 ok5718-idk daemon.info systemd[1]: Stopping Lightning Fast Webserver With Light System Requirements...
Nov 25 18:12:19 ok5718-idk daemon.info systemd[1]: Stopped target Login Prompts.
Nov 25 18:12:19 ok5718-idk daemon.info systemd[1]: Stopping Getty on tty1...
Nov 25 18:12:19 ok5718-idk daemon.info systemd[1]: Stopping Serial Getty on ttyS2...
Nov 25 18:12:19 ok5718-idk daemon.info systemd[1]: Stopping Telephony service...
Nov 25 18:12:19 ok5718-idk daemon.info systemd[1]: Closed RPCbind Server Activation Socket.
Nov 25 18:12:19 ok5718-idk syslog.info syslogd exiting
