Part Number: TDA4VM
在BOOT MODE PIN脚设置中,MMC/SDCARD的配置中,第4个BOOT MODE PIN的0、1分别对应:Filesystem mode 和Raw Mode
这个Filesystem mode 和Raw Mode是和SD卡的什么特性相关?一般情况需要把这个BOOT MODE PIN设为0还是1?
感谢您的指导和支持!
资料中此部分的描述如下图:
您可以看一下TRM文档4.2.1.1 Main Module,ROM bootloader读取的方式不一样。
RAW mode方式:
Block Path This path is used by the SPI, I2C, UART, eMMC, Ethernet and MMC/SD cards in raw mode. In this mode data is received from the peripheral in blocks. Blocks are accumulated in the boot buffer until a full X.509 certificate header has been received, at which point this full certificate and any subsequent blocks are passed to the DMSC as they arrive.
文件系统方式:
Filesystem Path This path is used by the MMC/SD cards in filesystem mode. This mode executes exactly like in the block path, except that the boot image location is defined by a filesystem.
