8168加载硬盘运行./r文件出现问题
setenv bootcmd 'tftp 0x81000000 uImage_dvr;bootm 0x81000000'后,8168加载硬盘运行./r文件出现问题,求解:
*** Bootargs Validated for mem param ***
*** Bootargs Validated for notifyk.vpssm3 params ***
Kernel bootargs validated
[c6xdsp ] Remote Debug Shared Memory @ 0xbf000000
[m3video] Remote Debug Shared Memory @ 0xbf005020
[m3vpss ] Remote Debug Shared Memory @ 0xbf00a040
syslink: disagrees about version of symbol module_layout
insmod: error inserting './kermod/syslink.ko': -1 Invalid module format
Setting DMM priority for [DUCATI ] to [0] ( 0x4e000624 = 0x08000000 )
Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
Setting DMM priority for [HDVICP1 ] to [2] ( 0x4e000634 = 0x000a0000 )
Setting DMM priority for [HDVICP2 ] to [2] ( 0x4e000634 = 0x00a00000 )
OsalDrv driver open: /dev/syslinkipc_Osal: No such file or directory
OsalDrv driver close: /dev/syslinkipc_Osal: Bad file descriptor
/dev/syslinkipc_MultiProc: No such file or directory
MultiProc driver close: : Bad file descriptor
SharedRegion driver open: : No such file or directory
SharedRegion driver close: : Bad file descriptor
/dev/syslinkipc_GateMP: No such file or directory
/dev/syslinkipc_MessageQ: No such file or directory
MessageQ driver close: : Bad file descriptor
Notify driver open: /dev/syslinkipc_Notify: No such file or directory
Notify driver close: /dev/syslinkipc_Notify: Bad file descriptor
ProcMgr driver open: /dev/syslinkipc_ProcMgr: No such file or directory
ProcMgr driver close: /dev/syslinkipc_ProcMgr: Bad file descriptor
/dev/syslinkipc_HeapBufMP: No such file or directory
/dev/syslinkipc_HeapMemMP: No such file or directory
/dev/syslinkipc_ListMP: No such file or directory
/dev/syslinkipc_RingIO: No such file or directory
RingIO driver close: : Bad file descriptor
/dev/syslinkipc_RingIOShm: No such file or directory
/dev/syslinkipc_ClientNotifyMgr: No such file or directory
ClientNotifyMgr driver close: : Bad file descriptor
/dev/syslinkipc_FrameQBufMgr: No such file or directory
FrameQBufMgr driver close: : Bad file descriptor
/dev/syslinkipc_FrameQ: No such file or directory
FrameQ driver close: : Bad file descriptor
/dev/syslinkipc_Ipc: No such file or directory
Assertion at Line no: 349 in /opt/rdk/DVRRDK_03.00.00.00/dvr_rdk/../ti_tools/syslink/syslink_2_10_02_17_patched/packages/ti/syslink/utils/hlos/usr/MultiProc.c: (MultiProc_module->refCount > 0) : failed
Invalid <Core name> specified!
Usage : ./fw_load.out <startup|shutdown> <Core name> [File path]
Supported core names:
Note: [File path] argument is only required when first argument is 'startup'
/dev/syslinkipc_HeapMemosa_kermod: disagrees about version of symbol module_layout
insmod: error inserting '../kermod/osa_kermod.ko': -1 Invalid module format
BusyBox v1.13.2 (2011-04-05 20:26:24 IST) multi-call binary
Usage: mknod [OPTIONS] NAME TYPE MAJOR MINOR
Create a special file (block, character, or pipe)
Options:
-m Create the special file using the specified mode (default a=rw)
TYPEs include:
b: Make a block device
c or u: Make a character device
p: Make a named pipe (MAJOR and MINOR are ignored)
