各位工程师好,
我现在正在研究多核加载,按照processors.wiki.ti.com/.../MCSDK_Image_Processing_Demonstration_Guide
中的步骤,
The build script <MCSDK INSTALL DIR>\demos\image_processing\utils\mad\evmc66##l\build_mad_image.bat can be used to re-create the image
我向使用脚本重新生成镜像,将mcsdk_2_01_02_06\demos\image_processing\utils\mad\evmc6678l目录下的build_mad_image.bat
改为
@set PATH="D:\ti\ccsv5\tools\compiler\c6000_7.4.1";%PATH%
@rd /s /q tmp
python ..\..\..\..\..\tools\boot_loader\mad-utils\map-tool\maptool.py config-files\maptoolCfg_evmc6678l.json
只改了编译器路径,其他没有动
python安装的是2.7.4
运行bat后,结果有错误,显示:
C:\ti\mcsdk_2_01_02_06\demos\image_processing\utils\mad\evmc6678l>build_mad_ima
e.bat
C:\ti\mcsdk_2_01_02_06\demos\image_processing\utils\mad\evmc6678l>python ..\..\
evmc6678l.json
C:\ti\mcsdk_2_01_02_06\demos\image_processing\utils\mad\evmc6678l>"strip6x" -o=
/tmp/strippedImages\master.strip ./images/appImages\master
/tmp/strippedImages\slave.strip ./images/appImages\slave
C:\ti\mcsdk_2_01_02_06\demos\image_processing\utils\mad\evmc6678l>"ofd6x" -x -o
c:\users\eric\appdata\local\temp\tmptzlw7d.xml "./tmp/strippedImages\master.str
p"
c:\users\eric\appdata\local\temp\tmpi8niie.xml "./tmp/strippedImages\slave.stri
Info: Incompatible permissions for segment: 11 application: master in partitio
: DDR3-ROMFS
Info: Incompatible permissions for segment: 10 application: master in partitio
: MSMCSRAM_MASTER
Info: Incompatible permissions for segment: 12 application: master in partitio
: MSMCSRAM_MASTER
Info: Incompatible permissions for segment: 8 application: master in partition
L2SRAM
Info: Incompatible permissions for segment: 0 application: master in partition
L2SRAM
Info: Incompatible permissions for segment: 2 application: master in partition
L2SRAM
Info: Incompatible permissions for segment: 5 application: master in partition
L2SRAM
Info: Incompatible permissions for segment: 6 application: master in partition
L2SRAM
Info: Incompatible permissions for segment: 7 application: master in partition
L2SRAM
Info: Incompatible permissions for segment: 1 application: master in partition
L2SRAM
Info: Incompatible permissions for segment: 3 application: master in partition
L2SRAM
Info: Incompatible permissions for segment: 14 application: master in partitio
: L2SRAM
Info: Incompatible permissions for segment: 13 application: master in partitio
: L2SRAM
Info: Incompatible permissions for segment: 2 application: slave in partition:
L2SRAM
Info: Incompatible permissions for segment: 0 application: slave in partition:
L2SRAM
Info: Incompatible permissions for segment: 3 application: slave in partition:
L2SRAM
Info: Incompatible permissions for segment: 1 application: slave in partition:
L2SRAM
Info: Incompatible permissions for segment: 6 application: slave in partition:
L2SRAM
Info: Incompatible permissions for segment: 5 application: slave in partition:
L2SRAM
ERROR: Unassigned segment found: master :seg-idx: 4
UserGuide中说Incompatible permissions for segment问题可以忽略,但是那个错误是什么问题呢?
