Part Number: SK-TDA4VM
3.2.1.3.2. Cleaning the Kernel Sources
etastc8@etastc8-VirtualBox:~/KernelSourceCode$ make ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu-distclean
Building the Linux Kernel DTBs
make -C /home/etastc8/KernelSourceCode/board-support/linux-5.10.41+gitAUTOINC+4c2eade9f7-g4c2eade9f7 ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu-distclean tisdk_j7-evm_defconfig
make[1]: Entering directory '/home/etastc8/KernelSourceCode/board-support/linux-5.10.41+gitAUTOINC+4c2eade9f7-g4c2eade9f7'
scripts/Kconfig.include:39: compiler 'aarch64-none-linux-gnu-distcleangcc' not found
scripts/kconfig/Makefile:88: recipe for target 'tisdk_j7-evm_defconfig' failed
make[2]: *** [tisdk_j7-evm_defconfig] Error 1
Makefile:603: recipe for target 'tisdk_j7-evm_defconfig' failed
make[1]: *** [tisdk_j7-evm_defconfig] Error 2
make[1]: Leaving directory '/home/etastc8/KernelSourceCode/board-support/linux-5.10.41+gitAUTOINC+4c2eade9f7-g4c2eade9f7'
Makefile:222: recipe for target 'linux-dtbs' failed
make: *** [linux-dtbs] Error 2
