TDA4VM: TDA4VM RAW摄像头
Part Number: TDA4VM
你好,我们使用TDA4VM开发板,7.3版本的SDK,现在需要调试摄像头,摄像头使用的是ds90ub960-----ds90ub953-----imx390,需要使用摄像头输出RAW数据
使用的demo是vx_app_multi_cam,现在没有摄像头的数据输出,不知道是哪里的问题,能帮助我们吗?
root@j7-evm:/opt/vision_apps# ./run_app_multi_cam.sh
APP: Init ... !!!
MEM: Init ... !!!
MEM: Initialized DMA HEAP (fd=4) !!!
MEM: Init ... Done !!!
IPC: Init ... !!!
IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
    34.864945 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
    34.873266 s:  VX_ZONE_INIT:Enabled
    34.873288 s:  VX_ZONE_ERROR:Enabled
    34.873293 s:  VX_ZONE_WARNING:Enabled
    34.873779 s:  VX_ZONE_INIT:[tivxInit:71] Initialization Done !!!
    34.873921 s:  VX_ZONE_INIT:[tivxHostInit:48] Initialization Done for HOST !!!
    34.875623 s: ISS: Enumerating sensors ... !!!
[   29.317693] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[   29.331624] Bridge firewalling registered
    35.276134 s: ISS: Enumerating sensors ... found 0 : IMX390-UB953_D3
    35.276164 s: ISS: Enumerating sensors ... found 1 : AR0233-UB953_MARS
    35.276186 s: ISS: Enumerating sensors ... found 2 : AR0820-UB953_LI
    35.276191 s: ISS: Enumerating sensors ... found 3 : UB9xxx_RAW12_TESTPATTERN
    35.276196 s: ISS: Enumerating sensors ... found 4 : UB96x_UYVY_TESTPATTERN
    35.276201 s: ISS: Enumerating sensors ... found 5 : GW_AR0233_UYVY
    35.276205 s: ISS: Enumerating sensors ... found 6 : GW_IMX390_UYVY
7 sensor(s) found
Supported sensor list:
a : IMX390-UB953_D3
b : AR0233-UB953_MARS
c : AR0820-UB953_LI
d : UB9xxx_RAW12_TESTPATTERN
e : UB96x_UYVY_TESTPATTERN
f : GW_AR0233_UYVY
g : GW_IMX390_UYVY
Select a sensor above or press '0' to autodetect the sensor
a
selectedSensor = 0!
Sensor selected : IMX390-UB953_D3
Querying IMX390-UB953_D3
    36.435681 s: ISS: Querying sensor [IMX390-UB953_D3] ... !!!
    36.435806 s: ISS: Querying sensor [IMX390-UB953_D3] ... Done !!!
GRAPH: app_multi_cam_graph (#nodes =   8, #executions =      0)
 NODE:   CAPTURE1:             capture_node: avg =      0 usecs, min/max = 18446744073709551 /      0 usecs, #executions =          0
 NODE: VPAC_VISS1:                viss_node: avg =      0 usecs, min/max = 18446744073709551 /      0 usecs, #executions =          0
 NODE:     IPU1-0:                aewb_node: avg =      0 usecs, min/max = 18446744073709551 /      0 usecs, #executions =          0
 NODE:      A72-0:      viss_h3a_write_node: avg =      0 usecs, min/max = 18446744073709551 /      0 usecs, #executions =          0
 NODE:  VPAC_MSC1:              mosaic_node: avg =      0 usecs, min/max = 18446744073709551 /      0 usecs, #executions =          0
 NODE:   DISPLAY1:              DisplayNode: avg =      0 usecs, min/max = 18446744073709551 /      0 usecs, #executions =          0
 NODE:      A72-0:      viss_img_write_node: avg =      0 usecs, min/max = 18446744073709551 /      0 usecs, #executions =          0
 NODE:      A72-0:       capture_write_node: avg =      0 usecs, min/max = 18446744073709551 /      0 usecs, #executions =          0
 PERF:           FILEIO: avg =      0 usecs, min/max = 4294967295 /      0 usecs, #executions =          0
 PERF:            TOTAL: avg =      4 usecs, min/max =      3 /      6 usecs, #executions =          2
 PERF:            TOTAL: 250000. 0 FPS
