Part Number: TDA4VM
TDA4VM 上存在多个 EHPWM 实例。如何在 PSDKLA 上启用它们?
Part Number: TDA4VM
diff --git a/arch/arm64/boot/dts/ti/k3-j721e-main.dtsi b/arch/arm64/boot/dts/ti/k3-j721e-main.dtsi
index 8675a4887..619532f9e 100644
--- a/arch/arm64/boot/dts/ti/k3-j721e-main.dtsi
+++ b/arch/arm64/boot/dts/ti/k3-j721e-main.dtsi
@@ -71,8 +71,74 @@
#mux-control-cells = <1>;
mux-reg-masks = <0x4000 0x8000000>, /* USB0 to SERDES0/3 mux */
<0x4010 0x8000000>; /* USB1 to SERDES1/2 mux */
+ tbclk_ctrl: tbclk_ctrl@4140 {
+ compatible = "syscon";
+ reg = <0x4140 0x18>;
+ ehrpwm_tbclk: clk0 {
+ compatible = "ti,am654-ehrpwm-tbclk";
+ #clock-cells = <1>;
+ ti,tbclk-syscon = <&tbclk_ctrl>;
+ ehrpwm0: pwm@3000000 {
+ compatible = "ti,am654-ehrpwm", "ti,am3352-ehrpwm";
+ #pwm-cells = <3>;
+ reg = <0x0 0x3000000 0x0 0x100>;
+ power-domains = <&k3_pds 83 TI_SCI_PD_EXCLUSIVE>;
+ clocks = <&ehrpwm_tbclk 0>, <&k3_clks 83 0>;
+ clock-names = "tbclk", "fck";
+ ehrpwm1: pwm@3010000 {
+ #pwm-cells = <3>;
+ reg = <0x0 0x3010000 0x0 0x100>;
+ power-domains = <&k3_pds 84 TI_SCI_PD_EXCLUSIVE>;
+ clocks = <&ehrpwm_tbclk 1>, <&k3_clks 84 0>;
+ ehrpwm2: pwm@3020000 {
+ #pwm-cells = <3>;
+ reg = <0x0 0x3020000 0x0 0x100>;
+ power-domains = <&k3_pds 85 TI_SCI_PD_EXCLUSIVE>;
+ clocks = <&ehrpwm_tbclk 2>, <&k3_clks 85 0>;
+ ehrpwm3: pwm@3030000 {
+ #pwm-cells = <3>;
+ reg = <0x0 0x3030000 0x0 0x100>;
+ power-domains = <&k3_pds 86 TI_SCI_PD_EXCLUSIVE>;
+ clocks = <&ehrpwm_tbclk 3>, <&k3_clks 86 0>;
+ ehrpwm4: pwm@3040000 {
+ #pwm-cells = <3>;
+ reg = <0x0 0x3040000 0x0 0x100>;
+ power-domains = <&k3_pds 87 TI_SCI_PD_EXCLUSIVE>;
+ clocks = <&ehrpwm_tbclk 4>, <&k3_clks 87 0>;
+ ehrpwm5: pwm@3050000 {
+ #pwm-cells = <3>;
+ reg = <0x0 0x3050000 0x0 0x100>;
+ power-domains = <&k3_pds 88 TI_SCI_PD_EXCLUSIVE>;
+ clocks = <&ehrpwm_tbclk 5>, <&k3_clks 88 0>;
所有 6 个实例均作为上述补丁的一部分启用。
所有与 EHRPWM 相关的 CONFIG 都已启用。因此,通过添加上述 DT 节点,应该能够查看 sysfs 节点。
