AM4376: SDK版本07.03.00.005 ,内核无法编译
Part Number: AM4376
SDK版本
进入SDK安装目录的linux目录下,root权限,输入如下命令
export PATH=/d/sdk-am437x-07.03.00.005/linux-devkit/sysroots/x86_64-arago-linux/usr/bin:$PAHT
make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabihf- tisdk_am437x-evm_defconfig
报错:
Command 'make' is available in '/usr/bin/make'
The command could not be located because '/usr/bin' is not included in the PATH environment variable.
make: command not found
请问是什么原因?
