答:
以下示例可用作参考:
MCU1_0 的修改如下:
diff --git a/build/build_cdd_ipc_profile_app_mcu1-0_debug.sh b/build/build_cdd_ipc_profile_app_mcu1-0_debug.sh new file mode 100755 index 0000000..fe38549 --- /dev/null +++ b/build/build_cdd_ipc_profile_app_mcu1-0_debug.sh @@ -0,0 +1 @@ +make cdd_ipc_profile_app CORE=mcu1_0 BUILD_OS_TYPE=tirtos BUILD_PROFILE=debug -sj diff --git a/mcuss_demos/mcal_config/CddIpc_Demo_Cfg/output/generated/soc/j721e/mcu1_0/src/Cdd_IpcCfg.c b/mcuss_demos/mcal_config/CddIpc_Demo_Cfg/output/generated/soc/j721e/mcu1_0/src/Cdd_IpcCfg.c index 734050f..2368166 100755 --- a/mcuss_demos/mcal_config/CddIpc_Demo_Cfg/output/generated/soc/j721e/mcu1_0/src/Cdd_IpcCfg.c +++ b/mcuss_demos/mcal_config/CddIpc_Demo_Cfg/output/generated/soc/j721e/mcu1_0/src/Cdd_IpcCfg.c @@ -1,64 +1,64 @@ -/* -* -* Copyright (c) 2019 Texas Instruments Incorporated -* -* All rights reserved not granted herein. -* -* Limited License. -* -* Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive -* license under copyrights and patents it now or hereafter owns or controls to make, -* have made, use, import, offer to sell and sell ("Utilize") this software subject to the -* terms herein. With respect to the foregoing patent license, such license is granted -* solely to the extent that any such patent is necessary to Utilize the software alone. -* The patent license shall not apply to any combinations which include this software, -* other than combinations with devices manufactured by or for TI ("TI Devices"). -* No hardware patent is licensed hereunder. -* -* Redistributions must preserve existing copyright notices and reproduce this license -* (including the above copyright notice and the disclaimer and (if applicable) source -* code license limitations below) in the documentation and/or other materials provided -* with the distribution -* -* Redistribution and use in binary form, without modification, are permitted provided -* that the following conditions are met: -* -* * No reverse engineering, decompilation, or disassembly of this software is -* permitted with respect to any software provided in binary form. -* -* * any redistribution and use are licensed by TI for use only with TI Devices. -* -* * Nothing shall obligate TI to provide you with source code for the software -* licensed and provided to you in object code. -* -* If software source code is provided to you, modification and redistribution of the -* source code are permitted provided that the following conditions are met: -* -* * any redistribution and use of the source code, including any resulting derivative -* works, are licensed by TI for use only with TI Devices. -* -* * any redistribution and use of any object code compiled from the source code -* and any resulting derivative works, are licensed by TI for use only with TI Devices. -* -* Neither the name of Texas Instruments Incorporated nor the names of its suppliers -* -* may be used to endorse or promote products derived from this software without -* specific prior written permission. -* -* DISCLAIMER. -* -* THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS -* OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES -* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. -* IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT, -* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, -* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, -* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY -* OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE -* OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED -* OF THE POSSIBILITY OF SUCH DAMAGE. -* -*/ +/* +* +* Copyright (c) 2019 Texas Instruments Incorporated +* +* All rights reserved not granted herein. +* +* Limited License. +* +* Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive +* license under copyrights and patents it now or hereafter owns or controls to make, +* have made, use, import, offer to sell and sell ("Utilize") this software subject to the +* terms herein. With respect to the foregoing patent license, such license is granted +* solely to the extent that any such patent is necessary to Utilize the software alone. +* The patent license shall not apply to any combinations which include this software, +* other than combinations with devices manufactured by or for TI ("TI Devices"). +* No hardware patent is licensed hereunder. +* +* Redistributions must preserve existing copyright notices and reproduce this license +* (including the above copyright notice and the disclaimer and (if applicable) source +* code license limitations below) in the documentation and/or other materials provided +* with the distribution +* +* Redistribution and use in binary form, without modification, are permitted provided +* that the following conditions are met: +* +* * No reverse engineering, decompilation, or disassembly of this software is +* permitted with respect to any software provided in binary form. +* +* * any redistribution and use are licensed by TI for use only with TI Devices. +* +* * Nothing shall obligate TI to provide you with source code for the software +* licensed and provided to you in object code. +* +* If software source code is provided to you, modification and redistribution of the +* source code are permitted provided that the following conditions are met: +* +* * any redistribution and use of the source code, including any resulting derivative +* works, are licensed by TI for use only with TI Devices. +* +* * any redistribution and use of any object code compiled from the source code +* and any resulting derivative works, are licensed by TI for use only with TI Devices. +* +* Neither the name of Texas Instruments Incorporated nor the names of its suppliers +* +* may be used to endorse or promote products derived from this software without +* specific prior written permission. +* +* DISCLAIMER. +* +* THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS +* OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES +* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. +* IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT, +* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, +* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, +* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY +* OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE +* OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED +* OF THE POSSIBILITY OF SUCH DAMAGE. +* +*/
/** * \file Cdd_IpcCfg.c @@ -209,9 +209,9 @@ CDD_IPC_CONFIG_DATA_SECTION CONST(struct Cdd_IpcChannelType_s, { .id = CddIpcConf_IpcComChanId_Cdd_IpcMcu21, /**< Unique identifiers for a channel */ - .localEp = 21U, + .localEp = 41U, /**< Local End Point identifier, on which MCAL/AUTOSAR is hosted */ - .remoteEp = 21U, + .remoteEp = 61U, /**< Remote End Point identifier, on remote cores */ .remoteProcId = CDD_IPC_CORE_MCU2_1, /**< Remote Processor Identifier */ @@ -270,9 +270,9 @@ CDD_IPC_CONFIG_DATA_SECTION CONST(Cdd_IpcConfigType, CDD_IPC_CONFIG_DATA)
.vertIoCfg = { - .vertIoRingAddr = (void *)0xaa000000U, + .vertIoRingAddr = (void *)0xB0000000U, /**< Defines address that shall be shared between cores */ - .vertIoRingSize = 0x1c00000U, + .vertIoRingSize = 0x02000000U, /**< Size of the shared memory */ .reserved = 0U, /**< Future use if any */ diff --git a/mcuss_demos/profiling/cddIpc/cddIpc_profile.c b/mcuss_demos/profiling/cddIpc/cddIpc_profile.c index 139f05b..fe9f0da 100755 --- a/mcuss_demos/profiling/cddIpc/cddIpc_profile.c +++ b/mcuss_demos/profiling/cddIpc/cddIpc_profile.c @@ -109,6 +109,7 @@ void Cdd_IpcProfilePrepareTxBufs(void); void Cdd_IpcProfilePrintProfiledValues(uint32 itr, uint32 rxLength, uint64_t ***); uint32 Cdd_IpcProfileCore(uint32 commId, SemaphoreP_Handle newIpcRxMsgRcvd); +uint32 Cdd_IpcPingRemoteCore(uint32 commId, SemaphoreP_Handle newIpcRxMsgRcvd); void Cdd_IpcProfileCheckCtrlMsg(uint32 *pMcu21Flag, uint32 *pMpu10Flag);
/* ========================================================================== */ @@ -202,7 +203,7 @@ uint32 Cdd_IpcProfileTest(void) ctrlMsgFromMpu10Valid = 0U;
#if (STD_ON == CDD_IPC_ANNOUNCE_API) - const char announceMsg[CDD_IPC_MAX_CTRL_MSG_LEN] = "ti.ipc4.ping-pong"; + const char announceMsg[CDD_IPC_MAX_CTRL_MSG_LEN] = "ti.ipc4.cdd-ipc"; #endif
Cdd_IpcProfilePrepareTxBufs(); @@ -250,7 +251,7 @@ uint32 Cdd_IpcProfileTest(void) AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "\n"); AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME " Starting Profiling" " for MCU 2 1 \n"); - rtnVal = Cdd_IpcProfileCore( + rtnVal = Cdd_IpcPingRemoteCore( CddIpcConf_IpcComChanId_Cdd_IpcMcu21, Cdd_NewIpcRxMsgRcvd); AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME "\n"); @@ -377,6 +378,64 @@ uint32 Cdd_IpcProfileCore(uint32 commId, SemaphoreP_Handle newIpcRxMsgRcvd) return rtnVal; }
+#define NUMMSGS 2 /* number of message sent per task */ +#define MSGSIZE 512 + +uint32 Cdd_IpcPingRemoteCore(uint32 commId, SemaphoreP_Handle newIpcRxMsgRcvd) +{ + volatile uint64_t preTimeStamp, postTimeStamp; + int32_t i; + char buf[MSGSIZE]; + uint32 rtnVal = E_OK; + uint32 len; + + for (i = 0; i < NUMMSGS; i++) + { + /* Send data to remote endPt: */ + len = snprintf(buf, MSGSIZE-1, "ping %d", i); + buf[len++] = '\0'; + + rtnVal = Cdd_IpcSendMsg(commId, &buf[0U], len); + if (E_OK == rtnVal) + { + AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME + " sent %s MSG to comm[%d]\n", + &buf[0U], commId); + } + else + { + AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME + " failed to send to comm[%d]\n", commId); + break; + } + + SemaphoreP_pend(Cdd_NewIpcRxMsgRcvd, SemaphoreP_WAIT_FOREVER); + + rtnVal = Cdd_IpcReceiveMsg(commId, &buf[0U], &len); + if (E_NOT_OK == rtnVal) + { + AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME + " failed to receive from comm[%d]\n", commId); + break; + } + + /* Make it NULL terminated string */ + if(len >= MSGSIZE) + { + buf[MSGSIZE-1] = '\0'; + } + else + { + buf[len] = '\0'; + } + AppUtils_Printf(MSG_NORMAL, MSG_APP_NAME + " Received %s MSG from comm[%d]\n", + &buf[0U], commId); + } + + return rtnVal; +} + void Cdd_IpcProfileCheckCtrlMsg(uint32 *pMcu21Flag, uint32 *pMpu10Flag) { #if (STD_ON == CDD_IPC_ANNOUNCE_API) diff --git a/mcuss_demos/profiling/cddIpc/main_tirtos.c b/mcuss_demos/profiling/cddIpc/main_tirtos.c index 384264a..d20bec1 100755 --- a/mcuss_demos/profiling/cddIpc/main_tirtos.c +++ b/mcuss_demos/profiling/cddIpc/main_tirtos.c @@ -125,6 +125,13 @@ static uint8_t Cdd_IpcProfile_TaskStack[APP_TASK_STACK] __attribute__((aligned(3 /* ========================================================================== */ /* Function Definitions */ /* ========================================================================== */ +void StartupEmulatorWaitFxn (void) +{ + volatile uint32_t enableDebug = 0; + do + { + }while (enableDebug); +}
int main(void) { @@ -133,6 +140,9 @@ int main(void) Task_Params taskParams; sint32 ret = CSL_PASS;
+ /* This is for debug purpose - see the description of function header */ + StartupEmulatorWaitFxn(); + #ifdef UART_ENABLED AppUtils_Init(); #endif @@ -224,8 +234,8 @@ sint32 SetupSciServer(void) Sciserver_TirtosCfgPrms_t appPrms; Sciclient_ConfigPrms_t clientPrms;
- appPrms.taskPriority[SCISERVER_TASK_USER_LO] = 1; - appPrms.taskPriority[SCISERVER_TASK_USER_HI] = 4; + appPrms.taskPriority[SCISERVER_TASK_USER_LO] = 4; + appPrms.taskPriority[SCISERVER_TASK_USER_HI] = 5;
/* Sciclient needs to be initialized before Sciserver.Sciserver depends on * Sciclient API to execute message forwarding */ diff --git a/mcuss_demos/profiling/cddIpc/makefile b/mcuss_demos/profiling/cddIpc/makefile index 03ce507..bfbe7a0 100755 --- a/mcuss_demos/profiling/cddIpc/makefile +++ b/mcuss_demos/profiling/cddIpc/makefile @@ -44,8 +44,8 @@ INCLUDE_EXTERNAL_INTERFACES += xdc bios SRCS_COMMON = main_tirtos.c cddIpc_profile.c EXT_LIB_LIST_COMMON += $(osal_tirtos_LIBPATH)/$(SOC)/$(ISA_EXT)/$(BUILD_PROFILE_$(CORE))/$(osal_tirtos_LIBNAME).$(LIBEXT) # Enable XDC build for application by providing XDC CFG File per core -XDC_CFG_FILE_$(CORE) = $(PDK_INSTALL_PATH)/ti/build/$(SOC)/sysbios_$(ISA).cfg -XDC_CFG_UPDATE_$(CORE)=$(MCUSW_INSTALL_PATH)/mcuss_demos/profiling/cddIpc/overrides/$(SOC)/ipc_addendum.cfg +XDC_CFG_FILE_$(CORE) = $(MCUSW_INSTALL_PATH)/mcuss_demos/profiling/cddIpc/overrides/$(SOC)/sysbios_r5f.cfg +#XDC_CFG_UPDATE_$(CORE)=$(MCUSW_INSTALL_PATH)/mcuss_demos/profiling/cddIpc/overrides/$(SOC)/ipc_addendum.cfg export XDC_CFG_UPDATE_$(CORE)
# Common source files and CFLAGS across all platforms and cores @@ -57,7 +57,7 @@ SRCS_COMMON += app_utils_cdd_ipc.c
# Enable copy of vectors ifeq ($(ISA),$(filter $(ISA), r5f)) - SRCS_ASM_COMMON += utilsCopyVecs2ATcm.asm + SRCS_ASM_COMMON += ipcCopyVecs2Exc.asm endif
PACKAGE_SRCS_COMMON = . @@ -72,6 +72,8 @@ endif # SRCS_<core/SoC/platform-name> = # CFLAGS_LOCAL_<core/SoC/platform-name> =
+EXTERNAL_LNKCMD_FILE_LOCAL = $(MCUSW_INSTALL_PATH)/mcuss_demos/profiling/cddIpc/soc/$(SOC)/$(CORE)/linker_r5_sysbios.lds + # Include common make files ifeq ($(MAKERULEDIR), ) #Makerule path not defined, define this and assume relative path from ROOTDIR diff --git a/mcuss_demos/profiling/cddIpc/overrides/j721e/r5_mpu.xs b/mcuss_demos/profiling/cddIpc/overrides/j721e/r5_mpu.xs new file mode 100755 index 0000000..d0f627f --- /dev/null +++ b/mcuss_demos/profiling/cddIpc/overrides/j721e/r5_mpu.xs @@ -0,0 +1,190 @@ +/* + * + * Copyright (c) 2018 Texas Instruments Incorporated + * + * All rights reserved not granted herein. + * + * Limited License. + * + * Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive + * license under copyrights and patents it now or hereafter owns or controls to make, + * have made, use, import, offer to sell and sell ("Utilize") this software subject to the + * terms herein. With respect to the foregoing patent license, such license is granted + * solely to the extent that any such patent is necessary to Utilize the software alone. + * The patent license shall not apply to any combinations which include this software, + * other than combinations with devices manufactured by or for TI ("TI Devices"). + * No hardware patent is licensed hereunder. + * + * Redistributions must preserve existing copyright notices and reproduce this license + * (including the above copyright notice and the disclaimer and (if applicable) source + * code license limitations below) in the documentation and/or other materials provided + * with the distribution + * + * Redistribution and use in binary form, without modification, are permitted provided + * that the following conditions are met: + * + * * No reverse engineering, decompilation, or disassembly of this software is + * permitted with respect to any software provided in binary form. + * + * * any redistribution and use are licensed by TI for use only with TI Devices. + * + * * Nothing shall obligate TI to provide you with source code for the software + * licensed and provided to you in object code. + * + * If software source code is provided to you, modification and redistribution of the + * source code are permitted provided that the following conditions are met: + * + * * any redistribution and use of the source code, including any resulting derivative + * works, are licensed by TI for use only with TI Devices. + * + * * any redistribution and use of any object code compiled from the source code + * and any resulting derivative works, are licensed by TI for use only with TI Devices. + * + * Neither the name of Texas Instruments Incorporated nor the names of its suppliers + * + * may be used to endorse or promote products derived from this software without + * specific prior written permission. + * + * DISCLAIMER. + * + * THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS + * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES + * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. + * IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT, + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, + * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, + * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY + * OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE + * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED + * OF THE POSSIBILITY OF SUCH DAMAGE. + * + */ + +/* + * Note: Marking a region as shareable will cause the region to behave as outer shareable with write through + * no write-allocate caching policy irrespective of the actual cache policy set.Therefore, only select + * regions that are actually shared outside the R5 CPUSS must be marked as shared. + */ + +var MPU = xdc.useModule('ti.sysbios.family.arm.MPU'); +MPU.enableMPU = true; +MPU.enableBackgroundRegion = true; + +var attrs = new MPU.RegionAttrs(); +MPU.initRegionAttrsMeta(attrs); + +var index = 0; + +/* make all 4G as strongly ordered, non-cacheable */ +attrs.enable = true; +attrs.bufferable = false; +attrs.cacheable = false; +attrs.shareable = true; +attrs.noExecute = true; +attrs.accPerm = 1; /* RW at PL1 */ +attrs.tex = 0; +attrs.subregionDisableMask = 0; +MPU.setRegionMeta(index++, 0x00000000, MPU.RegionSize_4G, attrs); + +/* make ATCM as cacheable */ +attrs.enable = true; +attrs.bufferable = true; +attrs.cacheable = true; +attrs.shareable = false; +attrs.noExecute = false; +attrs.accPerm = 1; /* RW at PL1 */ +attrs.tex = 1; +attrs.subregionDisableMask = 0; +MPU.setRegionMeta(index++, 0x00000000, MPU.RegionSize_32K, attrs); + +/* make ATCM as cacheable */ +attrs.enable = true; +attrs.bufferable = true; +attrs.cacheable = true; +attrs.shareable = false; +attrs.noExecute = false; +attrs.accPerm = 1; /* RW at PL1 */ +attrs.tex = 1; +attrs.subregionDisableMask = 0; +MPU.setRegionMeta(index++, 0x41000000, MPU.RegionSize_32K, attrs); + +/* make BTCM as cacheable */ +attrs.enable = true; +attrs.bufferable = true; +attrs.cacheable = true; +attrs.shareable = false; +attrs.noExecute = false; +attrs.accPerm = 1; /* RW at PL1 */ +attrs.tex = 1; +attrs.subregionDisableMask = 0x0; +MPU.setRegionMeta(index++, 0x41010000, MPU.RegionSize_32K, attrs); + +/* MCU OCSRAM as cacheable */ +attrs.enable = true; +attrs.bufferable = true; +attrs.cacheable = true; +attrs.shareable = false; +attrs.noExecute = false; +attrs.accPerm = 1; /* RW at PL1 */ +attrs.tex = 1; +attrs.subregionDisableMask = 0; +MPU.setRegionMeta(index++, 0x41C00000, MPU.RegionSize_1M, attrs); + +/* make all MSMC as cacheable */ +attrs.enable = true; +attrs.bufferable = true; +attrs.cacheable = true; +attrs.shareable = false; +attrs.noExecute = false; +attrs.accPerm = 1; /* RW at PL1 */ +attrs.tex = 1; +attrs.subregionDisableMask = 0; +MPU.setRegionMeta(index++, 0x70000000, MPU.RegionSize_8M, attrs); + +/* make all 2G DDR as cacheable */ +attrs.enable = true; +attrs.bufferable = true; +attrs.cacheable = true; +attrs.shareable = false; +attrs.noExecute = false; +attrs.accPerm = 1; /* RW at PL1 */ +attrs.tex = 1; +attrs.subregionDisableMask = 0; +MPU.setRegionMeta(index++, 0x80000000, MPU.RegionSize_2G, attrs); + +/* Note: the next 4 MPU regions start address (second argument of MPU.setRegionMeta) + must cover the address range of APP_LOG_MEM, TIOVX_OBJ_DESC_MEM, IPC_VRING_MEM, + TIOVX_LOG_RT_MEM_ADDR in system_memory_map.html and MUST be 16M aligned + */ +var non_cache_base_addr = 0xB0000000; +var MB = 0x100000; + +attrs.enable = true; +attrs.bufferable = false; +attrs.cacheable = false; +attrs.shareable = true; +attrs.noExecute = true; +attrs.accPerm = 1; /* RW at PL1 */ +attrs.tex = 0; +attrs.subregionDisableMask = 0; +MPU.setRegionMeta(index++, non_cache_base_addr + 0*32*MB, MPU.RegionSize_32M, attrs); +MPU.setRegionMeta(index++, non_cache_base_addr + 1*32*MB, MPU.RegionSize_32M, attrs); +MPU.setRegionMeta(index++, non_cache_base_addr + 2*32*MB, MPU.RegionSize_32M, attrs); +MPU.setRegionMeta(index++, non_cache_base_addr + 3*32*MB, MPU.RegionSize_32M, attrs); + +/* make DDR_MCU1_0_IPC_ADDR as non-cache */ +/* Note: the next MPU regions start address (second argument of MPU.setRegionMeta) + must cover the address range of DDR_MCU1_0_IPC_ADDR + in system_memory_map.html and MUST be 1M aligned + */ +attrs.enable = true; +attrs.bufferable = false; +attrs.cacheable = false; +attrs.shareable = true; +attrs.noExecute = false; +attrs.accPerm = 1; /* RW at PL1 */ +attrs.tex = 0; +attrs.subregionDisableMask = 0; +MPU.setRegionMeta(index++, 0xA0000000, MPU.RegionSize_1M, attrs); + +xdc.print("# MPU setup for " + index + " entries !!!"); diff --git a/mcuss_demos/profiling/cddIpc/overrides/j721e/sysbios_r5f.cfg b/mcuss_demos/profiling/cddIpc/overrides/j721e/sysbios_r5f.cfg new file mode 100644 index 0000000..ff23dab --- /dev/null +++ b/mcuss_demos/profiling/cddIpc/overrides/j721e/sysbios_r5f.cfg @@ -0,0 +1,162 @@ +/* + * + * Copyright (c) 2018 Texas Instruments Incorporated + * + * All rights reserved not granted herein. + * + * Limited License. + * + * Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive + * license under copyrights and patents it now or hereafter owns or controls to make, + * have made, use, import, offer to sell and sell ("Utilize") this software subject to the + * terms herein. With respect to the foregoing patent license, such license is granted + * solely to the extent that any such patent is necessary to Utilize the software alone. + * The patent license shall not apply to any combinations which include this software, + * other than combinations with devices manufactured by or for TI ("TI Devices"). + * No hardware patent is licensed hereunder. + * + * Redistributions must preserve existing copyright notices and reproduce this license + * (including the above copyright notice and the disclaimer and (if applicable) source + * code license limitations below) in the documentation and/or other materials provided + * with the distribution + * + * Redistribution and use in binary form, without modification, are permitted provided + * that the following conditions are met: + * + * * No reverse engineering, decompilation, or disassembly of this software is + * permitted with respect to any software provided in binary form. + * + * * any redistribution and use are licensed by TI for use only with TI Devices. + * + * * Nothing shall obligate TI to provide you with source code for the software + * licensed and provided to you in object code. + * + * If software source code is provided to you, modification and redistribution of the + * source code are permitted provided that the following conditions are met: + * + * * any redistribution and use of the source code, including any resulting derivative + * works, are licensed by TI for use only with TI Devices. + * + * * any redistribution and use of any object code compiled from the source code + * and any resulting derivative works, are licensed by TI for use only with TI Devices. + * + * Neither the name of Texas Instruments Incorporated nor the names of its suppliers + * + * may be used to endorse or promote products derived from this software without + * specific prior written permission. + * + * DISCLAIMER. + * + * THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS + * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES + * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. + * IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT, + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, + * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, + * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY + * OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE + * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED + * OF THE POSSIBILITY OF SUCH DAMAGE. + * + */ + +var Program = xdc.useModule("xdc.cfg.Program"); + +var Startup = xdc.useModule("xdc.runtime.Startup"); +var SysStd = xdc.useModule("xdc.runtime.SysStd"); +var System = xdc.useModule("xdc.runtime.System"); +var Log = xdc.useModule("xdc.runtime.Log"); +var Assert = xdc.useModule("xdc.runtime.Assert"); +var Defaults = xdc.useModule('xdc.runtime.Defaults'); +var Error = xdc.useModule('xdc.runtime.Error'); +var Registry = xdc.useModule('xdc.runtime.Registry'); +var Main = xdc.useModule("xdc.runtime.Main"); +var Memory = xdc.useModule("xdc.runtime.Memory"); +var Diags = xdc.useModule("xdc.runtime.Diags"); +var Timestamp = xdc.useModule("xdc.runtime.Timestamp"); + +var BIOS = xdc.useModule("ti.sysbios.BIOS"); +var Task = xdc.useModule("ti.sysbios.knl.Task"); +var Idle = xdc.useModule("ti.sysbios.knl.Idle"); +var Semaphore = xdc.useModule("ti.sysbios.knl.Semaphore"); +var Clock = xdc.useModule("ti.sysbios.knl.Clock"); +var Queue = xdc.useModule('ti.sysbios.knl.Queue'); +var GateH = xdc.useModule('xdc.runtime.knl.GateH'); +var Event = xdc.useModule('ti.sysbios.knl.Event'); +var Hwi = xdc.useModule('ti.sysbios.hal.Hwi'); +var Cache = xdc.useModule('ti.sysbios.hal.Cache'); +var halCore = xdc.useModule('ti.sysbios.hal.Core'); +var HeapMem = xdc.useModule("ti.sysbios.heaps.HeapMem"); +var HeapBuf = xdc.useModule("ti.sysbios.heaps.HeapBuf"); +var SyncSem = xdc.useModule('ti.sysbios.syncs.SyncSem'); +var biosGates = xdc.useModule('ti.sysbios.gates.GateTask'); +var GateSwi = xdc.useModule('ti.sysbios.gates.GateSwi'); +var Load = xdc.useModule('ti.sysbios.utils.Load'); + +/* BIOS library type */ +BIOS.libType = BIOS.LibType_Custom; + +/* Clock tick in microseconds */ +Clock.tickPeriod = 1000; + +/* Stack size when NULL is passed as stack during TSK create */ +Task.defaultStackSize = 16*1024; +Task.enableIdleTask = true; +Task.checkStackFlag = true; + +/* Idle.addFunc('&appIdleLoop'); */ + +Hwi.checkStackFlag = false; + +/* malloc heap size */ +Memory.defaultHeapSize = 768*1024; + +/* set input Hz to all timers */ +var DMTimer = xdc.useModule('ti.sysbios.timers.dmtimer.Timer'); +for (var i=0; i < DMTimer.numTimerDevices; i++) { + DMTimer.intFreqs[i].lo = 19200000; + DMTimer.intFreqs[i].hi = 0; +} + +Load.swiEnabled = true; +Load.hwiEnabled = true; +Load.taskEnabled = true; +Load.updateInIdle = true; +Load.windowInMs = 500; +Load.postUpdate = '&Utils_prfLoadUpdate'; + +/* Set the proxy for System module. + * This enables print statements at runtime in the application + */ +var SysMin = xdc.module('xdc.runtime.SysMin'); +SysMin.bufSize = 0x80000; + +System.SupportProxy = SysMin; + +var Core = xdc.useModule('ti.sysbios.family.arm.v7r.keystone3.Core'); +Core.id = 0; + +var Cache = xdc.useModule('ti.sysbios.family.arm.v7r.Cache'); +Cache.enableCache = true; + +var Hwi = xdc.useModule('ti.sysbios.family.arm.v7r.keystone3.Hwi'); +Hwi.vimBaseAddress = 0x40F80000; + +/* DMTimer #x - in general, address is 0x024x0000 where x is timer # */ +var Timer = xdc.useModule('ti.sysbios.timers.dmtimer.Timer'); +Timer.checkFrequency = false; + +var Clock = xdc.useModule('ti.sysbios.knl.Clock'); +Clock.timerId = 1; + +var Reset = xdc.useModule("xdc.runtime.Reset"); +Reset.fxns[Reset.fxns.length++] = "&ipcCopyVecs2Exc"; + +/* + * Initialize MPU and enable it + * + * Note: MPU must be enabled and properly configured for caching to work. + */ +xdc.loadCapsule("r5_mpu.xs"); + + diff --git a/mcuss_demos/profiling/cddIpc/soc/j721e/mcu1_0/ipcCopyVecs2Exc.asm b/mcuss_demos/profiling/cddIpc/soc/j721e/mcu1_0/ipcCopyVecs2Exc.asm new file mode 100644 index 0000000..d740900 --- /dev/null +++ b/mcuss_demos/profiling/cddIpc/soc/j721e/mcu1_0/ipcCopyVecs2Exc.asm @@ -0,0 +1,59 @@ +; +; Copyright (c) 2020, Texas Instruments Incorporated +; All rights reserved. +; +; Redistribution and use in source and binary forms, with or without +; modification, are permitted provided that the following conditions +; are met: +; +; * Redistributions of source code must retain the above copyright +; notice, this list of conditions and the following disclaimer. +; +; * Redistributions in binary form must reproduce the above copyright +; notice, this list of conditions and the following disclaimer in the +; documentation and/or other materials provided with the distribution. +; +; * Neither the name of Texas Instruments Incorporated nor the names of +; its contributors may be used to endorse or promote products derived +; from this software without specific prior written permission. +; +; THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" +; AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, +; THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR +; PURPOSE ARE DISCLAIMED.IN NO EVENT SHALL THE COPYRIGHT OWNER OR +; CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, +; EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, +; PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; +; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, +; WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR +; OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, +; EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. +; +; +; ======== ipcCopyVecs2Exc.asm ======== +; Copies sysbios defined vector to Exception Handler area +; + .text + .sect ".ipcCopyVecsToExc" +;============================================================================== +; void ipcCopyVecs2Exc( void ) +;============================================================================== + .global ti_sysbios_family_arm_v7r_keystone3_Hwi_vectors + + .global ipcCopyVecs2Exc +ipcCopyVecs2Exc: + .asmfunc + movw r0, ti_sysbios_family_arm_v7r_keystone3_Hwi_vectors + movt r0, ti_sysbios_family_arm_v7r_keystone3_Hwi_vectors + mov r1, #0 ; Exeception Handler address + mov r2, #64 ; 64 bytes +loop: + ldr r3, [r0], #4 + str r3, [r1], #4 + subs r2, r2, #4 + bgt loop +exit: + bx lr + .endasmfunc + + .end diff --git a/mcuss_demos/profiling/cddIpc/soc/j721e/mcu1_0/linker_r5_sysbios.lds b/mcuss_demos/profiling/cddIpc/soc/j721e/mcu1_0/linker_r5_sysbios.lds new file mode 100755 index 0000000..a686d55 --- /dev/null +++ b/mcuss_demos/profiling/cddIpc/soc/j721e/mcu1_0/linker_r5_sysbios.lds @@ -0,0 +1,198 @@ +/*----------------------------------------------------------------------------*/ +/* File: k3m4_r5f_linker.cmd */ +/* Description: */ +/* Link command file for j721e M4 MCU 0 view */ +/* TI ARM Compiler version 15.12.3 LTS or later */ +/* */ +/* Platform: QT */ +/* (c) Texas Instruments 2017, All rights reserved. */ +/*----------------------------------------------------------------------------*/ +/* History: *' +/* Aug 26th, 2016 Original version ..........................Loc Truong */ +/* Aug 01th, 2017 new TCM mem map ..........................Loc Truong */ +/* Nov 07th, 2017 Changes for R5F Init Code..................Vivek Dhande */ +/*----------------------------------------------------------------------------*/ +/* Linker Settings */ +/* Standard linker options */ +--retain="*(.bootCode)" +--retain="*(.startupCode)" +--retain="*(.startupData)" +--retain="*(.ipcCopyVecsToExc)" +--fill_value=0 +/*----------------------------------------------------------------------------*/ +/* Memory Map */ + +--define FILL_PATTERN=0xFEAA55EF +--define FILL_LENGTH=0x100 + +/* 1 MB of MCU Domain MSRAM is split as shown below */ +/* Size used F0000 Number of slices 4 */ +/* Rounding Offset */ +/*SBL? Start 41C00000 245760 0 */ +/* End 41C3C000 */ +/*MCU 10 Start 41C3C100 245760 100 */ +/* End 41C78100 */ +/*MCU 11 Start 41C78200 245760 100 */ +/* End 41CB4200 */ + +MEMORY +{ + /* R5F_TCMA [ size 32.00 KB ] */ + R5F_TCMA ( X ) : ORIGIN = 0x00000000 , LENGTH = 0x00008000 + /* R5F_TCMB0_VECS [ size 256 B ] */ + R5F_TCMB0_VECS ( RWIX ) : ORIGIN = 0x41010000 , LENGTH = 0x00000100 + /* R5F_TCMB0 [ size 31.75 KB ] */ + R5F_TCMB0 ( RWIX ) : ORIGIN = 0x41010100 , LENGTH = 0x00007F00 + /* DDR for MCU1_0 for Linux IPC [ size 1024.00 KB ] */ + DDR_MCU1_0_IPC ( RWIX ) : ORIGIN = 0xA0000000 , LENGTH = 0x00100000 + /* DDR for MCU1_0 for Linux resource table [ size 1024 B ] */ + DDR_MCU1_0_RESOURCE_TABLE ( RWIX ) : ORIGIN = 0xA0100000 , LENGTH = 0x00000400 + /* DDR for MCU1_0 for code/data [ size 15.00 MB ] */ + DDR_MCU1_0 ( RWIX ) : ORIGIN = 0xA0100400 , LENGTH = 0x00EFFC00 + /* Memory for IPC Vring's.MUST be non-cached or cache-coherent [ size 32.00 MB ] */ + IPC_VRING_MEM : ORIGIN = 0xB0000000 , LENGTH = 0x02000000 + /* Memory for remote core logging [ size 256.00 KB ] */ + APP_LOG_MEM : ORIGIN = 0xB2000000 , LENGTH = 0x00040000 + /* Memory for TI OpenVX shared memory.MUST be non-cached or cache-coherent [ size 63.62 MB ] */ + TIOVX_OBJ_DESC_MEM : ORIGIN = 0xB2040000 , LENGTH = 0x03FA0000 + /* Memory for shared memory buffers in DDR [ size 512.00 MB ] */ + DDR_SHARED_MEM : ORIGIN = 0xB8000000 , LENGTH = 0x20000000 + /* DDR for MCU1_0 for local heap [ size 8.00 MB ] */ + DDR_MCU1_0_LOCAL_HEAP ( RWIX ) : ORIGIN = 0xE0000000 , LENGTH = 0x00800000 + +} + +/*----------------------------------------------------------------------------*/ +/* Section Configuration */ + +SECTIONS +{ + .vecs : { + *(.vecs) + } palign(8) > R5F_TCMB0_VECS + .vecs : { + __VECS_ENTRY_POINT = .; + } palign(8) > R5F_TCMB0_VECS + xdc.meta (COPY): { *(xdc.meta) } > R5F_TCMB0 + .init_text : { + boot.*(.text) + *(.text:ti_sysbios_family_arm_MPU_*) + *(.text:ti_sysbios_family_arm_v7r_Cache_*) + } > R5F_TCMB0 + .text:xdc_runtime_Startup_reset__I : {} palign(8) > R5F_TCMB0 + .bootCode : {} palign(8) > R5F_TCMB0 + .startupCode : {} palign(8) > R5F_TCMB0 + .startupData : {} palign(8) > R5F_TCMB0, type = NOINIT + .ipcCopyVecsToExc : {} palign(8) > R5F_TCMB0 + + .text : {} palign(8) > DDR_MCU1_0 + .const : {} palign(8) > DDR_MCU1_0 + .cinit : {} palign(8) > DDR_MCU1_0 + .pinit : {} palign(8) > DDR_MCU1_0 + + /* For NDK packet memory, we need to map this sections before .bss*/ + .bss:NDK_MMBUFFER (NOLOAD) {} ALIGN (128) > DDR_MCU1_0 + .bss:NDK_PACKETMEM (NOLOAD) {} ALIGN (128) > DDR_MCU1_0 + + .bss : {} align(4) > DDR_MCU1_0 + .far : {} align(4) > DDR_MCU1_0 + .data : {} palign(128) > DDR_MCU1_0 + .data_buffer: {} palign(128) > DDR_MCU1_0 + .sysmem : {} > DDR_MCU1_0 + .stack : {} align(4) > DDR_MCU1_0 (HIGH) fill=FILL_PATTERN + + .bss.devgroup* : {} align(4) > DDR_MCU1_0 + .const.devgroup*: {} align(4) > DDR_MCU1_0 + .data_user : {} align(4) > DDR_MCU1_0 + .boardcfg_data : {} align(4) > DDR_MCU1_0 + /* USB or any other LLD buffer for benchmarking */ + .benchmark_buffer (NOLOAD) {} ALIGN (8) > DDR_MCU1_0 + + /* Additional sections settings */ + McalTextSection : fill=FILL_PATTERN, align=4, load > DDR_MCU1_0 + { + .=align(4); + __linker_cdd_ipc_text_start = .; + .+= FILL_LENGTH; + *(CDD_IPC_TEXT_SECTION) + *(CDD_IPC_ISR_TEXT_SECTION) + .=align(4); + .+= FILL_LENGTH; + __linker_cdd_ipc_text_end = .; + + } + McalConstSection : fill=FILL_PATTERN, align=4, load > DDR_MCU1_0 + { + .=align(4); + __linker_cdd_ipc_const_start = .; + .+= FILL_LENGTH; + *(CDD_IPC_CONST_32_SECTION) + *(CDD_IPC_CONFIG_SECTION) + .=align(4); + .+= FILL_LENGTH; + __linker_cdd_ipc_const_end = .; + } + + McalInitSection : fill=FILL_PATTERN, align=4, load > DDR_MCU1_0 + { + .=align(4); + __linker_cdd_ipc_init_start = .; + .+= FILL_LENGTH; + *(CDD_IPC_DATA_INIT_UNSPECIFIED_SECTION) + *(CDD_IPC_DATA_INIT_32_SECTION) + *(CDD_IPC_DATA_INIT_8_SECTION) + .=align(4); + .+= FILL_LENGTH; + __linker_cdd_ipc_init_end = .; + } + McalNoInitSection : fill=FILL_PATTERN, align=4, load > DDR_MCU1_0, type = NOINIT + { + __linker_cdd_ipc_no_init_start = .; + .+= FILL_LENGTH; + *(CDD_IPC_DATA_NO_INIT_UNSPECIFIED_SECTION) + *(CDD_IPC_DATA_NO_INIT_8_SECTION) + .=align(4); + .+= FILL_LENGTH; + __linker_cdd_ipc_no_init_end = .; + + } + /* Example Utility specifics */ + VariablesAlignedNoInitSection : align=8, load > DDR_MCU1_0, type = NOINIT + { + .=align(8); + __linker_cdd_ipc_no_init_align_8b_start = .; + .+= FILL_LENGTH; + *(CDD_IPC_DATA_NO_INIT_8_ALIGN_8B_SECTION) + .=align(8); + .+= FILL_LENGTH; + __linker_cdd_ipc_no_init_align_8b_end = .; + } + /* Example Utility specifics */ + UtilityNoInitSection : align=4, load > DDR_MCU1_0, type = NOINIT + { + .=align(4); + __linker_utility_no_init_start = .; + .+= FILL_LENGTH; + *(EG_TEST_RESULT_32_SECTION) + .=align(4); + .+= FILL_LENGTH; + __linker_utility_no_init_end = .; + } + SciClientBoardCfgSection : align=128, load > DDR_MCU1_0, type = NOINIT + { + .=align(128); + __linker_boardcfg_data_start = .; + .+= FILL_LENGTH; + *(.boardcfg_data) + .=align(128); + .+= FILL_LENGTH; + __linker_boardcfg_data_end = .; + } + +} /* end of SECTIONS */ + +/*----------------------------------------------------------------------------*/ +/* Misc linker settings */ + + +/*-------------------------------- END ---------------------------------------*/ |
MCU2_1 的修改如下:
diff --git a/apps/basic_demos/app_tirtos/common/app_cfg.h b/apps/basic_demos/app_tirtos/common/app_cfg.h index aa02bcc..8b667ea 100755 --- a/apps/basic_demos/app_tirtos/common/app_cfg.h +++ b/apps/basic_demos/app_tirtos/common/app_cfg.h @@ -70,7 +70,9 @@ #define ENABLE_PRINTF_REDIRECT
#define ENABLE_IPC_MPU1_0 -//#define ENABLE_IPC_MCU1_0 +#ifdef CPU_mcu2_1 +#define ENABLE_IPC_MCU1_0 +#endif //#define ENABLE_IPC_MCU1_1 #define ENABLE_IPC_MCU2_0 #define ENABLE_IPC_MCU2_1 diff --git a/apps/basic_demos/app_tirtos/common/app_cfg_mcu2_1.h b/apps/basic_demos/app_tirtos/common/app_cfg_mcu2_1.h index 02c0bc2..c48eae1 100755 --- a/apps/basic_demos/app_tirtos/common/app_cfg_mcu2_1.h +++ b/apps/basic_demos/app_tirtos/common/app_cfg_mcu2_1.h @@ -74,5 +74,5 @@ #define ENABLE_VHWA_DMPAC #define ENABLE_VHWA_CODEC
- +#define ENABLE_CDD_IPC_REMOTE #endif /* APP_CFG_MCU2_1_H_ */ diff --git a/apps/basic_demos/app_tirtos/common/app_init.c b/apps/basic_demos/app_tirtos/common/app_init.c index cff1ffa..46bc52a 100755 --- a/apps/basic_demos/app_tirtos/common/app_init.c +++ b/apps/basic_demos/app_tirtos/common/app_init.c @@ -494,7 +494,8 @@ int32_t appInit() if((host_os_type == APP_HOST_TYPE_LINUX) || (host_os_type == APP_HOST_TYPE_QNX)) { /* dont sync with MPU1 running linux/qnx since that is taken care by the kernel */ - if(ipc_init_prm.enabled_cpu_id_list[i]!=APP_IPC_CPU_MPU1_0) + if((ipc_init_prm.enabled_cpu_id_list[i]!=APP_IPC_CPU_MPU1_0) + &&(ipc_init_prm.enabled_cpu_id_list[i]!=APP_IPC_CPU_MCU1_0)) { sync_cpu_id_list[num_sync_cpus] = ipc_init_prm.enabled_cpu_id_list[i]; num_sync_cpus++; diff --git a/apps/basic_demos/app_tirtos/common/app_run.c b/apps/basic_demos/app_tirtos/common/app_run.c index 9b0c9e1..89e9bab 100755 --- a/apps/basic_demos/app_tirtos/common/app_run.c +++ b/apps/basic_demos/app_tirtos/common/app_run.c @@ -270,6 +270,130 @@ void appMenuMain()
#endif
+#if defined(ENABLE_CDD_IPC_REMOTE) +#include <ti/drv/ipc/ipc.h> + +#define APP_IPC_ECHO_TEST_MAX_TASK_NAME (12u) +#define APP_IPC_ECHO_TEST_TASK_STACKSIZE (64*1024) +/* this should be >= RPMessage_getObjMemRequired() */ +#define IPC_RPMESSAGE_OBJ_SIZE (256) +#define MSGSIZE 512 + +#define RPMSG_DATA_SIZE (256*MSGSIZE + IPC_RPMESSAGE_OBJ_SIZE) + +#define SERVICE "ti.ipc4.cdd-ipc" + +static char g_rpmsg_responder_task_name[APP_IPC_ECHO_TEST_MAX_TASK_NAME]; +static uint8_t g_rspBuf[RPMSG_DATA_SIZE] __attribute__ ((aligned (128))); + +/* + * This "Task" waits for a "ping" message from any processor + * then replies with a "pong" message. + */ +static void cddipc_responderFxn(UArg arg0, UArg arg1) +{ + RPMessage_Handle handle; + RPMessage_Params params; + uint32_t myEndPt = 0; + uint32_t remoteEndPt; + uint32_t remoteProcId; + uint16_t len; + int32_t n; + int32_t status = 0; + void *buf; + uint32_t bufSize = RPMSG_DATA_SIZE; + char str[MSGSIZE]; + + buf = g_rspBuf; + RPMessageParams_init(¶ms); + params.requestedEndpt = 61; + params.buf = buf; + params.bufSize = bufSize; + + handle = RPMessage_create(¶ms, &myEndPt); + if(!handle) + { + status = -1; + appLogPrintf("CDDIPC: respTask: failed to create PRMessage\n"); + } + + if (status == 0) + { + status = RPMessage_announce(IPC_MCU1_0, myEndPt, SERVICE); + if(status != 0) + { + status = -1; + appLogPrintf("CDDIPC: respTask: announce to remote core\n"); + } + } + + if (status == 0) + { + while(1) + { + /*we are expecting a "ping n" msg from cddipc host*/ + status = RPMessage_recv(handle, (void*)str, &len, &remoteEndPt, &remoteProcId, + IPC_RPMESSAGE_TIMEOUT_FOREVER); + if(status != IPC_SOK) + { + appLogPrintf("CDDIPC: respTask: failed with code %d\n", status); + break; + } + else + { + /* NULL terminated string */ + str[len] = '\0'; + appLogPrintf("CDDIPC: respTask: received %s from remote %d (EP %d)\n", + str, remoteProcId, remoteEndPt); + } + + status = sscanf(str, "ping %d", &n); + if(status == 1) + { + len = snprintf(str, MSGSIZE-1, "pong %d", n); + } + + status = RPMessage_send(handle, remoteProcId, remoteEndPt, myEndPt, str, len); + if (status != IPC_SOK) + { + appLogPrintf("CDDIPC: respTask: RPMessage_send " + " failed, status %d procId %d\n", status, remoteProcId); + break; + } + else + { + appLogPrintf("CDDIPC: respTask: sent %s to remote %d\n", + str, remoteProcId); + } + } + } + + /* Delete the RPMesg object now */ + //RPMessage_delete(&handle); +} + +static void appCddIpcResponder() +{ + Task_Params params; + Task_Handle rx_task; + + /* Respond to messages coming in to endPt ENDPT1 */ + Task_Params_init(¶ms); + params.priority = 3; + params.stackSize = APP_IPC_ECHO_TEST_TASK_STACKSIZE; + params.arg0 = 0; + params.instance->name = &g_rpmsg_responder_task_name[0]; + + strncpy(g_rpmsg_responder_task_name, "CDD_IPC_RX", APP_IPC_ECHO_TEST_MAX_TASK_NAME); + g_rpmsg_responder_task_name[APP_IPC_ECHO_TEST_MAX_TASK_NAME-1] = 0; + + rx_task = Task_create(cddipc_responderFxn, ¶ms, NULL); + if(rx_task==NULL) + { + appLogPrintf("CDDIPC: ERROR: Failed to create CDDIPC-RX task !!!\n"); + } +} +#endif
void appRun() { @@ -278,6 +402,9 @@ void appRun() #if defined(ENABLE_IPC_ECHO_TEST) && defined(ENABLE_IPC) appIpcEchoTestStart(); #endif + #if defined(ENABLE_CDD_IPC_REMOTE) + appCddIpcResponder(); + #endif #if defined(ENABLE_TIOVX_HOST) appMenuMain(); #endif diff --git a/apps/basic_demos/app_tirtos/common/concerto.mak b/apps/basic_demos/app_tirtos/common/concerto.mak index 19cd082..6330414 100755 --- a/apps/basic_demos/app_tirtos/common/concerto.mak +++ b/apps/basic_demos/app_tirtos/common/concerto.mak @@ -179,6 +179,7 @@ CSOURCES := $(call all-c-files)
DEFS+=APP_CFG_FILE=\"app_cfg_$(CPU_ID).h\" DEFS+=CPU_$(CPU_ID) +DEFS+=SOC_J721E
ifeq ($(BUILD_APP_TIRTOS_QNX),yes) IDIRS+=$(VISION_APPS_PATH)/apps/basic_demos/app_tirtos/tirtos_qnx diff --git a/utils/ipc/src/app_ipc_sysbios_echo_test.c b/utils/ipc/src/app_ipc_sysbios_echo_test.c index a9af4c7..22af6fe 100755 --- a/utils/ipc/src/app_ipc_sysbios_echo_test.c +++ b/utils/ipc/src/app_ipc_sysbios_echo_test.c @@ -457,7 +457,7 @@ int32_t appIpcEchoTestStart(void) { for(cpu_id = 0; cpu_id < numProc; cpu_id++) { - if((cpu_id != appIpcGetSelfCpuId()) && appIpcIsCpuEnabled(cpu_id)) + if((cpu_id != appIpcGetSelfCpuId()) && appIpcIsCpuEnabled(cpu_id) && (cpu_id != APP_IPC_CPU_MCU1_0)) { uint32_t ipc_lld_cpu_id = g_app_to_ipc_cpu_id[cpu_id]; |
以下是基于上述修改的测试日志:
MCU1_0 日志(从 MCU_UART0,请在 Linux 中禁用 MCU_UART0 以捕获这些日志):
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2021.06.10 13:29:47 =~=~=~=~=~=~=~=~=~=~=~= ....PASSED
IPC Profile App:
IPC Profile App: IPC Profile Application - STARTS !!!
IPC Profile App: CDD IPC MCAL Version Info
IPC Profile App: ---------------------
IPC Profile App: Vendor ID : 44
IPC Profile App: Module ID : 255
IPC Profile App: SW Major Version : 1
IPC Profile App: SW Minor Version : 3
IPC Profile App: SW Patch Version : 2
IPC Profile App: Received ti.ipc4.cdd-ipc as ctrl MSG from MCU 2 1
IPC Profile App:
IPC Profile App: Starting Profiling for MCU 2 1
IPC Profile App: sent ping 0 MSG to comm[2]
IPC Profile App: Received pong 0 MSG from comm[2]
IPC Profile App: sent ping 1 MSG to comm[2]
IPC Profile App: Received pong 1 MSG from comm[2]
IPC Profile App: |
MCU2_1 日志(从 MAIN_UART0):
