C6722连接不上仿真器
C6722连接XDS510Plus后FREE RUNING,点击“停止”后芯片和仿真器断开,但是用XDS560PLUS不存在这个问题,另外一块芯片连接正常。
提示错误如下:
Trouble Halting Target CPU:
Error 0x00000020/-2072
Error during: Execution,
Cannot halt the processor
Trouble Halting Target CPU: Error 0x00000020/-2072 Error during: Execution, Cannot halt the processor
Failed to remove the debug state from the target before disconnecting. There may still be breakpoint opcodes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging.
