Part Number: TDA2EXEVM
你好:
按照ProcessSDKRadar_User Guide.pdf的build and run来配置windows下gmake的编译环境。path添加如下
Rules.make已按照下图修改
在cmd中使用gmake编译,以下为结果:
C:\Users\dinglei>cd \PROCESSOR_SDK_RADAR_03_08_00_00\vision_sdk\build
C:\PROCESSOR_SDK_RADAR_03_08_00_00\vision_sdk\build>gmake -s depend
C:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: ipc_PATH does not exist! ()
/cygdrive/c/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/windows/xdctools_3_32_01_22_core/bin/mkdir: cannot create directory `C:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/links_fw/include/config': File exists
/cygdrive/c/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/windows/xdctools_3_32_01_22_core/bin/mkdir: cannot create directory `C:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/links_fw/include/config/apps': File exists
/cygdrive/c/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/windows/xdctools_3_32_01_22_core/bin/mkdir: cannot create directory `C:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/links_fw/include/config/apps/tda2xx_evm_bios_radar': File exists
# makeconfig: Config is [ tda2xx_evm_bios_radar ]
# makeconfig: Output file is @ C:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/links_fw/include/config/apps/tda2xx_evm_bios_radar/system_cfg.h
# makeconfig: Input file is @ C:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/tda2xx_evm_bios_radar/cfg.mk
# makeconfig: Generating header ...
# makeconfig: Generating alg plugin config ...
# makeconfig: Generating usecase config ...
# makeconfig: Generating footer ...
# makeconfig: Done !!!
# CPUs that are NOT required but included in config [ tda2xx_evm_bios_radar ],
# CPUs that are required but not included in config [ tda2xx_evm_bios_radar ],
# Edit C:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/apps/configs/tda2xx_evm_bios_radar/cfg.mk to include or exclude CPUs in an application
# Compiling tda2xx-evm:a15_0:release:edma3lld_drv: src/edma3_drv_init.c
process_begin: CreateProcess(NULL, C:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/cg_tools/windows/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc -MD -MF C:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_bios_radar/obj/edma3lld_drv/tda2xx-evm/a15/release/.deps/edma3_drv_init.P -D_NDK_EXTERN_CONFIG -D_INCLUDE_NIMU_CODE -DMSGLEVEL=3 -D_INCLUDE_IPv6_CODE -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -ffunction-sections -fdata-sections -DSYSBIOS -DCGT_GCC -DCPU_IDLE_ENABLED -O2 -s -DNDEBUG -Werror -Dxdc_target_types__=gnu/targets/arm/std.h -Dxdc_target_name__=A15F -Dxdc_bld__profile_release -Dxdc_bld__vers_1_0_4_9_3 -DBIOS_BUILD -Dfar= -D__DYNAMIC_REENT__ -DTDA2XX_BUILD -DTDA2XX_FAMILY_BUILD -DPLATFORM_EVM_SI -DVPS_VIP_BUILD -DVPS_DSS_BUILD -IC:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/os_tools/bios_6_46_06_00/packages/gnu/targets/arm/libs/install-native/arm-none-eabi/include -IC:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/cg_tools/windows/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -I. -I../../../.. -Isrc -IC:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/networking/ndk_2_24_02_31/packages -IC:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/networking/nsp_gmacsw_4_16_01_01/packages -IC:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/open_compute/opencl_rtos_am57xx_01_01_10_00/packages -I/packages -IC:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/links_fw/include/config/apps/tda2xx_evm_bios_radar -o C:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_bios_radar/obj/edma3lld_drv/tda2xx-evm/a15/release/edma3_drv_init.oa15fg src/edma3_drv_init.c, ...) failed.
make (e=2): 系统找不到指定的文件。
gmake[4]: *** [C:/PROCESSOR_SDK_RADAR_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_bios_radar/obj/edma3lld_drv/tda2xx-evm/a15/release/edma3_drv_init.oa15fg] Error 2
gmake[3]: *** [a15_0] Error 2
gmake[2]: *** [edma3lld] Error 2
gmake[1]: *** [edma3lld] Error 2
gmake: *** [depend] Error 2
这个是哪边配置有问题?
