求解load 在CMD文件中定义数据段时的具体含义,数据段定义时用不用load对代码执行周期数的影响?
求解load 在CMD文件中定义数据段时的具体含义?
做复数浮点FFT变换时,4K,8K,16K,32k,64k时,都可以load到DDR3中,但是存在以下问题:在定义DDR3段时,用不用load语句,指令运行周期数差别比较大,请大神分析原因。
以64k的复数浮点FFT为例,
定义DDR3段的时候采用.DDR3:load>>DDR3 采用load指令时指令周期数CYCLES:3096024
定义DDR3段的时候采用.DDR3:>>DDR3没有采用load指令时指令周期数CYCLES:54106352
相差数十倍,求原因。
测试结果如下:
 数据存放在DDR3中 定义DDR3段的时候采用.DDR3:load>>DDR3 采用load指令
FFT点数                         运行时间                运行指令周期数数
N = 8   radix = 2  TIME: 0.215000 us  CYCLES:215
N = 16   radix = 4  TIME: 0.243000 us  CYCLES:243
N = 32   radix = 2  TIME: 0.401000 us  CYCLES:401
N = 64   radix = 4  TIME: 0.617000 us  CYCLES:617
N = 128  radix = 2  TIME: 1.207000 us  CYCLES:1207
N = 256  radix = 4  TIME: 2.168000 us  CYCLES:2168
N = 512  radix = 2  TIME: 4.793000 us  CYCLES:4793
N = 1024  radix = 4  TIME: 9.256000 us  CYCLES:9256
N = 2048  radix = 2  TIME: 21.034000 us  CYCLES:21034
N = 4096  radix = 4  TIME: 51.208000 us  CYCLES:51208
N = 8192  radix = 2  TIME: 266.581000 us  CYCLES:266581
N = 16384  radix = 4  TIME: 539.959000 us  CYCLES:539959
N = 32768  radix = 2  TIME: 1512.223000 us  CYCLES:1512223
N = 65536  radix = 4  TIME: 3096.024000 us  CYCLES:3096024
数据存放在DDR3中 定义DDR3段的时候采用.DDR3:>>DDR3没有采用load指令
FFT点数                         运行时间                运行指令周期数数
N = 8   radix = 2  TIME: 1.603000 us  CYCLES:1603
N = 16   radix = 4  TIME: 3.136000 us  CYCLES:3136
N = 32   radix = 2  TIME: 9.645000 us  CYCLES:9645
N = 64   radix = 4  TIME: 19.355000 us  CYCLES:19355
N = 128  radix = 2  TIME: 52.260000 us  CYCLES:52260
N = 256  radix = 4  TIME: 104.660000 us  CYCLES:104660
N = 512  radix = 2  TIME: 260.284000 us  CYCLES:260284
N = 1024  radix = 4  TIME: 480.613000 us  CYCLES:480613
N = 2048  radix = 2  TIME: 1040.438000 us  CYCLES:1040438
N = 4096  radix = 4  TIME: 2064.545000 us  CYCLES:2064545
N = 8192  radix = 2  TIME: 4781.424000 us  CYCLES:4781424
N = 16384  radix = 4  TIME: 10776.016000 us  CYCLES:10776016
N = 32768  radix = 2  TIME: 25084.586000 us  CYCLES:25084586
N = 65536  radix = 4  TIME: 54106.352000 us  CYCLES:54106352
