DM365 的板子把PHY 修改成 LAN8710A 启动后出现如下错误
你好!
估计是哪里的问题?
OK
Starting kernel ...
[ 0.280000] 1:01 not found
[ 0.280000] 1:02 not found
[ 0.280000] 1:03 not found
[ 0.290000] 1:04 not found
[ 0.290000] 1:05 not found
[ 0.290000] 1:06 not found
[ 0.290000] 1:07 not found
[ 0.300000] 1:08 not found
[ 0.300000] 1:09 not found
[ 0.300000] 1:0a not found
[ 0.300000] 1:0b not found
[ 0.310000] 1:0c not found
[ 0.310000] 1:0d not found
[ 0.310000] 1:0e not found
[ 0.320000] 1:0f not found
[ 0.320000] 1:10 not found
[ 0.320000] 1:11 not found
[ 0.320000] 1:12 not found
[ 0.330000] 1:13 not found
[ 0.330000] 1:14 not found
[ 0.330000] 1:15 not found
[ 0.340000] 1:16 not found
[ 0.340000] 1:17 not found
[ 0.340000] 1:18 not found
[ 0.340000] 1:19 not found
[ 0.350000] 1:1a not found
[ 0.350000] 1:1b not found
[ 0.350000] 1:1c not found
[ 0.350000] 1:1d not found
[ 0.360000] 1:1e not found
[ 0.360000] 1:1f not found
INIT: version 2.86 booting
mknod: /dev/spidev0.0: File exists
Creat queue id:0
queue id:0
FileMngThread created
Creat queue id:32769
queue id:32769
AlramThread created
Share memory init success
IPNC_DM365_3.1.0 (root@ubuntu) (gcc version 4.2.0 (MontaVista 4
Creat queue id:65538
queue id:65538
Setting up networking ...rm: unable to remove `/etc/network/run': Read-only file system
queue id:32769
queue id:65538
Creat queue id:98307
queue id:98307
----------->>ProFileThread wait for......5s-------------------
log status
Starting portmap daemon: log status
net_search_gateway:eth0, 1A8C0, 0, 1
CPU is DM368
DEMOCFG Value : 0
Videocodecmode : 0
Videocodecres : 0
IPNC BUILD VERSION: DM368 IPNC REF DESIGN VERSION 3.10.00.08
./av_server.out DM368 NTSC TI2A AEWB 720P H264 4000000 VBR AUTO MENUOFF &
Check_device_version : DEVICE VER = 0 !!
portmapgio44 , input hight this meaning that is daylinght, output daylinght status
start_daemon
----------->>use connect trace fun = PollingThread, line = 870
ApproDrvInit: 7
Creat queue id:131076
queue id:131076
log success
log status
log status
Starting mounting local filesystems: log status
ApproDrvInit: 9
queue id:131076
ApproDrvInit: 8
queue id:131076
AVSERVER UI: Initializing.
ApproDrvInit: 2
queue id:131076
ApproDrvInit: 6
queue id:131076
ApproDrvInit: 10
queue id:131076
mount none on /dev/shm type tmpfs (rw,size=5M)
none on /var/run type tmpfs (rw)
none on /tmp type tmpfs (rw,sync)
log success
log status
Starting hotplug subsystem:
CLK Hz,
ARM Hz = 297000000
DDR Hz = 270000000
VPSS Hz = 270000000
IMCOP Hz = 270000000
DRV LDC: GetConfig 0004 0x0
[OSA_FILE ] Reading file [/mnt/nand/IMG_Paramset.bin] ... ERROR
IMAGE TUNE: Paramset File is not available..... Setting DEFAULT parameter
usb
SYSTEM.MSTPRI0 value changed to 00440011
CONFIGURING AVSERVER FOR DM368 .....
queue id:65538
OV9712drv: fun = DRV_imgsOpen In
--------------check mux value------------------
mux_0, value = 0x0
mux_1, value = 0x430000
mux_2, value = 0x1980
mux_3, value = 0x735affff
mux_4, value = 0x30c000
: --->>>>>trace set pin mux3 = 0x615affff
: --->>>>>trace set pin mux4 = 0xc000
IMGS_H_PAD = 8, IMGS_V_PAD = 6
dataW = 1280, dataH = 736
sensorDataWidth = 1280, sensorDataHeight = 736
validStartX = 2, validStartY = 2
validWidth = 1272, validHeight = 730
fps= 30, t_frame = 33356572.000000, t_row = 40285.714844, t_pclk = 23.809525
cols = 1692, rows = 828, master_clk = 24000000,pll_clk = 84000000, f_pclk = 42000000
pll_pre_div = 2, pll_mul = 7 pll_div = 2
Ov9712: sensorMode = 4, width = 1280, height = 736, addr=0x60
----chipId =9711-----
ov9712: chipId = 0x9711
9712open: step3, check Image Id, status = 0
TI Setting Applied
pipe, open, row = 0, col = 0
queue id:131076
FR : 0 users registered from exsiting face album
Initializing...
IPNC AUTO_IRIS = 0
Initializing...
Initializing...
Initializing...
Initializing...
OV9712drv: fun = DRV_imgsEnable In
...done initializing
Play this stream using the URL:
rtsp://192.168.1.168:8556/PSIA/Streaming/channels/2?videoCodecType=H.264
(We use port 8303 for optional RTSP-over-HTTP tunneling.)
rtsp://192.168.1.168:8555/PSIA/Streaming/channels/0?videoCodecType=MJPEG
(We use port 8302 for optional RTSP-over-HTTP tunneling.)
rtsp://192.168.1.168:8553/PSIA/Streaming/channels/1?videoCodecType=MPEG4
(We use port 8300 for optional RTSP-over-HTTP tunneling.)
rtsp://192.168.1.168:8554/PSIA/Streaming/channels/1?videoCodecType=MPEG4
(We use port 8301 for optional RTSP-over-HTTP tunneling.)
rtsp://192.168.1.168:8557/PSIA/Streaming/channels/2?videoCodecType=H.264
(We use port 8304 for optional RTSP-over-HTTP tunneling.)
OV9712drv: fun = DRV_imgsSetEshutter In
TI AWB PRODUCTION VERSION 1.0.0
usb [success]
input
input [success]
done.
Simple mixer control 'PGA',0
Capabilities: cvolume
Capture channels: Mono
Limits: Capture 0 - 3
Mono: Capture 2 [67%]
Simple mixer control 'Mono DAC',0
Capabilities: pvolume pvolume-joined
Playback channels: Mono
Limits: Playback 0 - 63
Mono: Playback 47 [75%]
sycOnvif Profile 1
SystemInit success
Schedule manager init success
Starting internet superserver: inetd.
mkdosfs 3.0.6 (04 Oct 2009)
unable to get drive geometry, using default 255/63
/dev/sbulla has 255 heads and 63 sectors per track,
logical sector size is 512,
using 0xf8 media descriptor, with 1024 sectors;
file system has 2 12-bit FATs and 4 sectors per cluster.
FAT size is 1 sector, and provides 247 clusters.
Root directory contains 512 slots.
Volume ID is 3945e71f, no volume label.
queue id:0
umount: /mnt/mmc: not mounted
dns=192.168.1.1
net_search_gateway:eth0, 0, FE01A8C0, 3
dns=192.168.1.1
ERROR: Module g_file_storage does not exist in /proc/modules
[ 21.240000] Unable to handle kernel NULL pointer dereference at virtual address 00000004
[ 21.240000] pgd = c0f44000
[ 21.240000] [00000004] *pgd=82035031, *pte=00000000, *ppte=00000000
[ 21.240000] Internal error: Oops: 17 [#1]
[ 21.240000] Modules linked in: sbull iscsi_tcp libiscsi scsi_transport_iscsi usbmon musb_hdrc usbcore davinci_mmc mmc_block mmc_core sha1 md5 des deflate crc32c libcrc32c crc_ccitt ppp_deflate ppp_generic netconsole slhc tun loop
[ 21.240000] CPU: 0
[ 21.240000] pc : [<c015d488>] lr : [<c015f5dc>] Not tainted
[ 21.240000] sp : c2205cc8 ip : c2205ce8 fp : c2205ce4
[ 21.240000] r10: c2205eb0 r9 : c2204000 r8 : 00000000
[ 21.240000] r7 : 00000001 r6 : c2205dac r5 : 00000000 r4 : c2204000
[ 21.240000] r3 : c03b1284 r2 : c2205dac r1 : 00000001 r0 : 00000000
[ 21.240000] Flags: Nzcv IRQs off FIQs on Mode SVC_32 Segment user
[ 21.240000] Control: 5317F
[ 21.240000] Table: 80F44000 DAC: 00000015
[ 21.240000] Process system_server (pid: 282, stack limit = 0xc2204258)
[ 21.240000] Stack: (0xc2205cc8 to 0xc2206000)
[ 21.240000] 5cc0: c03b1280 c03b1280 c2205dac c2205dac c2205da4 c2205ce8
[ 21.240000] 5ce0: c015f5dc c015d47c c2205d14 c2205cf8 c2205d14 c2205d00 c00a8af0 c00a8a5c
[ 21.240000] 5d00: ffffffea ffffffea c2205d3c c2205d18 c00c95fc c00a8a98 00000000 c0fc4ab8
[ 21.240000] 5d20: 00000000 c03438e8 c034395c c2205f08 c2205d74 c2205d40 c009e7a4 c009e6a0
[ 21.240000] 5d40: c2205d74 c2205d50 c00a9798 c0113aac c03437b0 c2205f08 c03438e8 c2204000
[ 21.240000] 5d60: 00000000 00000003 c2205dc4 c2205d78 c00a0f80 c00a9770 00000101 00000015
[ 21.240000] 5d80: 60000013 c03b1280 c2205dac c2204000 00000000 c2205eb0 c2205e6c c2205da8
[ 21.240000] 5da0: c0163934 c015f4d4 c2205f08 00000001 00000001 00000001 c2205e3c c2205dc8
[ 21.240000] 5dc0: c00a1238 c00ae778 c0442838 c03342a0 c29d3660 c03437b0 c0334220 00000101
[ 21.240000] 5de0: 00000001 00000000 00000020 00000000 c023b93c 00000000 c005234c c030f764
[ 21.240000] 5e00: c008cb78 00000204 c2205e24 c2205e18 00000000 00000000 00000020 00000000
[ 21.240000] 5e20: c023b93c 00000000 c2205f08 363137b0 00000038 c0285e08 c2205e9c c2205e48
[ 21.240000] 5e40: c2205e6c c2205e50 00000016 43a23d7c 60000013 000089f0 c03b1000 c2205eb0
[ 21.240000] 5e60: c2205e8c c2205e70 c01cff9c c0163804 c2205e8c c2205eb0 000089f0 43a23d5c
[ 21.240000] 5e80: c2205f04 c2205e90 c01d1418 c01cfc0c c2205eec c2205ea0 c0118484 c011772c
[ 21.240000] 5ea0: 0000000a ffffffff ffffffff 00000000 30687465 00000000 00000000 00000000
[ 21.240000] 5ec0: 43a23d88 00000000 00000000 00000000 00000119 c2205f3c c0fc4a90 c0f66f40
[ 21.240000] 5ee0: 000089f0 43a23d5c 00000004 c0f66f40 c2204000 00000000 c2205f24 c2205f08
[ 21.240000] 5f00: c01c37ac c01d0ed8 c2205f64 c0f66f40 43a23d5c 000089f0 c2205f44 c2205f28
[ 21.240000] 5f20: c00a3c1c c01c35bc 00000002 c0f66f40 00000004 43a23d5c c2205f74 c2205f48
[ 21.240000] 5f40: c00a3f40 c00a3bf4 c2746ba0 00000004 000442b8 00000000 43a23d5c 000089f0
[ 21.240000] 5f60: c0f66f40 c2204000 c2205fa4 c2205f78 c00a3fcc c00a3c8c c2205fa4 00000001
[ 21.240000] 5f80: c01c48ec 00000000 00000001 43a23d5c 00000036 c0033f88 00000000 c2205fa8
[ 21.240000] 5fa0: c0033de0 c00a3f78 00000000 00000001 00000004 000089f0 43a23d5c 43a23d88
[ 21.240000] 5fc0: 00000000 00000001 43a23d5c 00000036 00000000 00000000 4009685c ffffffff
[ 21.240000] 5fe0: 00000004 43a23d58 0001c588 4016b27c 60000010 00000004 00000000 00000000
[ 21.240000] Backtrace:
[ 21.240000] Function entered at [<c015d46c>] from [<c015f5dc>]
[ 21.240000] r7 = C2205DAC r6 = C2205DAC r5 = C03B1280 r4 = C03B1280
[ 21.240000] Function entered at [<c015f4c4>] from [<c0163934>]
[ 21.240000] Function entered at [<c01637f4>] from [<c01cff9c>]
[ 21.240000] r6 = C2205EB0 r5 = C03B1000 r4 = 000089F0
[ 21.240000] Function entered at [<c01cfbfc>] from [<c01d1418>]
[ 21.240000] r6 = 43A23D5C r5 = 000089F0 r4 = C2205EB0
[ 21.240000] Function entered at [<c01d0ec8>] from [<c01c37ac>]
[ 21.240000] Function entered at [<c01c35ac>] from [<c00a3c1c>]
[ 21.240000] r6 = 000089F0 r5 = 43A23D5C r4 = C0F66F40
[ 21.240000] Function entered at [<c00a3be4>] from [<c00a3f40>]
[ 21.240000] r6 = 43A23D5C r5 = 00000004 r4 = C0F66F40
[ 21.240000] Function entered at [<c00a3c7c>] from [<c00a3fcc>]
[ 21.240000] r9 = C2204000 r8 = C0F66F40 r6 = 000089F0 r5 = 43A23D5C
[ 21.240000] r4 = 00000000
[ 21.240000] Function entered at [<c00a3f68>] from [<c0033de0>]
[ 21.240000] r8 = C0033F88 r7 = 00000036 r6 = 43A23D5C r5 = 00000001
[ 21.240000] Code: e3cd4d7f e3c4403f e1a05000 e1a07001 (e5906004)
[ 21.240000] insmod: g_file_storage.ko: No such file or directory
ApproDrvInit: 3
queue id:131076
queue id:0
queue id:32769
[01/Jan/2000:00:00:22 +0000] boa: server version Boa/0.94.13
[01/Jan/2000:00:00:22 +0000] boa: server built May 28 2013 at 10:59:14.
[01/Jan/2000:00:00:22 +0000] boa: starting server pid=700, port 80
queue id:0
UDPString=uuid:Upnp-TVEmulator-1_0-00_0024869451</UDN>
