TDA4VM: yolov5m 在EVM上精度损失
Part Number: TDA4VM
Hi,TIer,
在部署 pretrained model yolov5m6_640_ti_lite_44p1_62p9.onnx(link 如下(1)) 到 TDA4 EVM (8bits 量化)时,基于coco dataset val2017做了精度测试,conf 0.001,nms 0.65,EVM上AP[0.5:0.95]结果0.284,与TI发布页(link 如下(2))中浮点模型的精度0.441相差很大,TIDL 尝试了16bits 量化,EVM上结果为0.311,精度损失依然很大。
(1) https://github.com/TexasInstruments/edgeai-yolov5/blob/master/pretrained_models/models/detection/coco/edgeai-yolov5/yolov5m6_640_ti_lite_44p1_62p9.onnx.link
(2) https://github.com/TexasInstruments/edgeai-yolov5
请问:
1. TI 基于此pretrained yolov5m model是否有做过TDA4 EVM上的精度测试,结果如何?
2. 麻烦帮忙check 下import的配置,是否有待改进的参数?或者针对这个模型,TI的推荐配置?
(1) 测试使用 TI_DEVICE_a72_test_dl_algo_host_rt.out,处理val2017
(2) import configuration file
    modelType = 2
    numParamBits = 8
    numFeatureBits = 8
    #quantizationStyle = 3
    quantizationStyle = 2
    inputNetFile = "../../test/testvecs/models/public/onnx/yolov5m6_640_ti_lite_44p1_62p9.onnx"
    outputNetFile = "../../test/testvecs/config/tidl_models/onnx/tidl_net_yolov5m6_640_ti_lite_44p1_62p9.bin"
    outputParamsFile = "../../test/testvecs/config/tidl_models/onnx/tidl_io_yolov5m6_640_ti_lite_44p1_62p9_"
    inDataNorm = 1
    inMean = 0 0 0
    inScale = 0.003921568627 0.003921568627 0.003921568627
    inDataFormat = 1
    inWidth = 640
    inHeight = 640
    inNumChannels = 3
    numFrames = 1
    inData = "../../test/testvecs/config/detection_list.txt"
    perfSimConfig = ../../test/testvecs/config/import/device_config.cfg
    inElementType = 0
    metaArchType = 4
    metaLayersNamesList = "../../test/testvecs/config/import/public/onnx/yolov5m6_640_ti_lite_metaarch.prototxt"
    postProcType = 2
    foldPreBnConv2D = 0
    #calibrationOption = 7
(3) prototxt file:相对于发布配置,只修改了 confidence_threshold: 0.001
(4) infer configuration file
    inFileFormat = 2
    numFrames = 5000
    netBinFile = "testvecs/config/tidl_models/onnx/tidl_net_yolov5m6_640_ti_lite_44p1_62p9.bin"
    ioConfigFile = "testvecs/config/tidl_models/onnx/tidl_io_yolov5m6_640_ti_lite_44p1_62p9_1.bin"
    inData = testvecs/config/name_list_acc.txt
    outData = testvecs/output/tidl_yolov5m6_640_ti_lite_44p1_62p9_od.bin
    inResizeMode = 0
    debugTraceLevel = 0
    writeTraceLevel = 0
    postProcType = 2
Thanks
Regards
