DSP -k -mw 反馈信息比较
hi:
大家好!
问题描述:
下面两个反馈信息,分别是优化前后的。优化前的 II = 33.优化后的II = 10 。按照我的理解
应该是优化后 II = 10 的效率明显要比II = 33的要好很多吧,为什么测试时间却是II = 33时间少。
II =10反而耗时更多。难道耗时在于数据存储,而不在于计算?如何解释?谢谢!
Bef Optimization:
;*   SOFTWARE PIPELINE INFORMATION
;*      Loop source line                 : 166
;*      Loop opening brace source line   : 167
;*      Loop closing brace source line   : 186
;*      Known Minimum Trip Count         : 1
;*      Known Max Trip Count Factor      : 1
;*      Loop Carried Dependency Bound(^) : 32
;*      Unpartitioned Resource Bound     : 9
;*      Partitioned Resource Bound(*)    : 11
;*      Resource Partition:
;*                                A-side   B-side
;*      .L units                     3        5
;*      .S units                     5        7
;*      .D units                     3        5
;*      .M units                     4        6
;*      .X cross paths               8       10
;*      .T address paths             2        4
;*      Long read paths              0        0
;*      Long write paths             0        0
;*      Logical  ops (.LS)           0        0     (.L or .S unit)
;*      Addition ops (.LSD)          7       16     (.L or .S or .D unit)
;*      Bound(.L .S .LS)             4        6
;*      Bound(.L .S .D .LS .LSD)     6       11*
;*      Searching for software pipeline schedule at ...
;*         ii = 32 Did not find schedule
;*         ii = 33 Schedule found with 1 iterations in parallel
Aft optimization:
;*      Loop Carried Dependency Bound(^) : 5
;*      Partitioned Resource Bound(*)    : 10
;*                                A-side   B-side
;*      .L units                     5        3
;*      .S units                     6        5
;*      .D units                     5        3
;*      .M units                     3        7
;*      .X cross paths               7       10*
;*      Addition ops (.LSD)         10       13     (.L or .S or .D unit)
;*      Bound(.L .S .LS)             6        4
;*      Bound(.L .S .D .LS .LSD)     9        8
;*         ii = 10 Schedule found with 5 iterations in parallel
Best Regards!
