Part Number: J7200XSOMXEVM
背景: SDK:ti-processor-sdk-rtos-j7200-evm-08_02_00_05
已经将以太网固件(ethfw)编译成功(SDK代码无修改)并在开发板中运行(在开发板/sys/kernel/debug/remoteproc/remoteproc1/trace0路径下有我添加的打印信息)。
问题: 根据官网( software-dl.ti.com/.../index.html )中Running the Demo章节 DRA821以太网固件(ethfw),网线接到PC1(port3)和PC2(port2)后,RJ45指示灯均不亮。登陆开发板ifconfig信息如下,请问现在应该如何排查问题?
[14:05:33][20220701_14:05:33] [14:05:40] [14:05:40]U-Boot SPL 2021.01-g44a87e3ab8 (Mar 24 2022 - 08:53:12 +0000) [14:05:40]Model: Texas Instruments K3 J7200 SoC [14:05:40]Board: J7200X-PM2-SOM rev E6 [14:05:40]SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam') [14:05:40]Trying to boot from MMC2 [14:05:40]Starting ATF on ARM64 core... [14:05:40] [14:05:40]NOTICE: BL31: v2.5(release):08.01.00.006-dirty [14:05:40]NOTICE: BL31: Built : 08:20:28, Mar 24 2022 [14:05:40] [14:05:40]U-Boot SPL 2021.01-g44a87e3ab8 (Mar 24 2022 - 08:21:51 +0000) [14:05:40]Model: Texas Instruments K3 J7200 SoC [14:05:40]Board: J7200X-PM2-SOM rev E6 [14:05:40]SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam') [14:05:40]Detected: J7X-BASE-CPB rev E3 [14:05:41]Detected: J7X-VSC8514-ETH rev E2 [14:05:41]Trying to boot from MMC2 [14:05:41]am654_sdhci sdhci@4fb0000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 [14:05:41] [14:05:41] [14:05:41]U-Boot 2021.01-g44a87e3ab8 (Mar 24 2022 - 08:21:51 +0000) [14:05:41] [14:05:41]SoC: J7200 SR1.0 [14:05:41]Model: Texas Instruments K3 J7200 SoC [14:05:41]Board: J7200X-PM2-SOM rev E6 [14:05:41]DRAM: 4 GiB [14:05:41]Flash: 0 Bytes [14:05:41]MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1 [14:05:41]Loading Environment from MMC... OK [14:05:41]In: serial@2800000 [14:05:41]Out: serial@2800000 [14:05:41]Err: serial@2800000 [14:05:41]am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000 [14:05:41]Detected: J7X-BASE-CPB rev E3 [14:05:41]Detected: J7X-VSC8514-ETH rev E2 [14:05:41]Net: eth0: ethernet@46000000port@1 [14:05:43]Hit any key to stop autoboot: 0 [14:05:44]switch to partitions #0, OK [14:05:44]mmc1 is current device [14:05:44]SD/MMC found on device 1 [14:05:44]Failed to load 'boot.scr' [14:05:44]0 bytes read in 1 ms (0 Bytes/s) [14:05:44]Loaded env from uEnv.txt [14:05:44]Importing environment from mmc1 ... [14:05:44]19276288 bytes read in 204 ms (90.1 MiB/s) [14:05:44]46143 bytes read in 4 ms (11 MiB/s) [14:05:44]## Flattened Device Tree blob at 88000000 [14:05:44] Booting using the fdt blob at 0x88000000 [14:05:44] Loading Device Tree to 000000008fef1000, end 000000008fffffff ... OK [14:05:44] [14:05:44]Starting kernel ... [14:05:44] [14:05:44][ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [14:05:44][ 0.000000] Linux version 5.10.100-g7a7a3af903 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Thu Mar 24 08:25:59 UTC 2022 [14:05:44][ 0.000000] Machine model: Texas Instruments K3 J7200 SoC [14:05:44][ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [14:05:44][ 0.000000] printk: bootconsole [ns16550a0] enabled [14:05:44][ 0.000000] efi: UEFI not found. [14:05:44][ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [14:05:44][ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool [14:05:44][ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [14:05:44][ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool [14:05:44][ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [14:05:44][ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool [14:05:44][ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [14:05:44][ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool [14:05:44][ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [14:05:44][ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool [14:05:44][ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB [14:05:44][ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool [14:05:44][ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB [14:05:44][ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool [14:05:44][ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB [14:05:44][ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool [14:05:45][ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 2 MiB [14:05:45][ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@a5000000, compatible id shared-dma-pool [14:05:45][ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5200000, size 30 MiB [14:05:45][ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@a5200000, compatible id shared-dma-pool [14:05:45][ 0.000000] Zone ranges: [14:05:45][ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [14:05:45][ 0.000000] DMA32 empty [14:05:45][ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff] [14:05:45][ 0.000000] Movable zone start for each node [14:05:45][ 0.000000] Early memory node ranges [14:05:45][ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [14:05:45][ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a47fffff] [14:05:45][ 0.000000] node 0: [mem 0x00000000a4800000-0x00000000a4ffffff] [14:05:45][ 0.000000] node 0: [mem 0x00000000a5000000-0x00000000a6ffffff] [14:05:45][ 0.000000] node 0: [mem 0x00000000a7000000-0x00000000ffffffff] [14:05:45][ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff] [14:05:45][ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff] [14:05:45][ 0.000000] cma: Reserved 512 MiB at 0x00000000e0000000 [14:05:45][ 0.000000] psci: probing for conduit method from DT. [14:05:45][ 0.000000] psci: PSCIv1.1 detected in firmware. [14:05:45][ 0.000000] psci: Using standard PSCI v0.2 function IDs [14:05:45][ 0.000000] psci: Trusted OS migration not required [14:05:45][ 0.000000] psci: SMC Calling Convention v1.2 [14:05:45][ 0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072 [14:05:45][ 0.000000] Detected PIPT I-cache on CPU0 [14:05:45][ 0.000000] CPU features: detected: GIC system register CPU interface [14:05:45][ 0.000000] CPU features: detected: EL2 vector hardening [14:05:45][ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [14:05:45][ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 65472 [14:05:45][ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:1m(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:1m(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs) root=PARTUUID=d9117e3b-02 rw rootfstype=ext4 rootwait [14:05:45][ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear) [14:05:45][ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear) [14:05:45][ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [14:05:45][ 0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB) [14:05:45][ 0.000000] Memory: 3441792K/4194304K available (10880K kernel code, 1288K rwdata, 4352K rodata, 1856K init, 751K bss, 228224K reserved, 524288K cma-reserved) [14:05:45][ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [14:05:45][ 0.000000] rcu: Preemptible hierarchical RCU implementation. [14:05:45][ 0.000000] rcu: RCU event tracing is enabled. [14:05:45][ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [14:05:45][ 0.000000] Trampoline variant of Tasks RCU enabled. [14:05:45][ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [14:05:45][ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [14:05:45][ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [14:05:45][ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [14:05:45][ 0.000000] GICv3: 960 SPIs implemented [14:05:45][ 0.000000] GICv3: 0 Extended SPIs implemented [14:05:45][ 0.000000] GICv3: Distributor has no Range Selector support [14:05:45][ 0.000000] GICv3: 16 PPIs implemented [14:05:45][ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [14:05:45][ 0.000000] ITS [mem 0x01820000-0x0182ffff] [14:05:45][ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [14:05:45][ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0) [14:05:45][ 0.000000] ITS: using cache flushing for cmd queue [14:05:45][ 0.000000] GICv3: using LPI property table @0x00000008800b0000 [14:05:45][ 0.000000] GIC: using cache flushing for LPI property table [14:05:45][ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000 [14:05:45][ 0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4c4 with crng_init=0 [14:05:45][ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [14:05:45][ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [14:05:45][ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [14:05:45][ 0.008296] Console: colour dummy device 80x25 [14:05:45][ 0.012855] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [14:05:45][ 0.023526] pid_max: default: 32768 minimum: 301 [14:05:45][ 0.028274] LSM: Security Framework initializing [14:05:45][ 0.033025] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear) [14:05:45][ 0.040601] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear) [14:05:45][ 0.050156] rcu: Hierarchical SRCU implementation. [14:05:45][ 0.055330] Platform MSI: msi-controller@1820000 domain created [14:05:45][ 0.061511] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [14:05:45][ 0.070800] EFI services will not be available. [14:05:45][ 0.075645] smp: Bringing up secondary CPUs ... [14:05:45][ 0.081042] Detected PIPT I-cache on CPU1 [14:05:45][ 0.081070] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [14:05:45][ 0.081083] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000 [14:05:45][ 0.081125] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [14:05:45][ 0.081213] smp: Brought up 1 node, 2 CPUs [14:05:45][ 0.110575] SMP: Total of 2 processors activated. [14:05:45][ 0.115383] CPU features: detected: 32-bit EL0 Support [14:05:45][ 0.120642] CPU features: detected: CRC32 instructions [14:05:45][ 0.134210] CPU: All CPU(s) started at EL2 [14:05:45][ 0.138417] alternatives: patching kernel code [14:05:45][ 0.143567] devtmpfs: initialized [14:05:45][ 0.149893] KASLR disabled due to lack of seed [14:05:45][ 0.154625] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [14:05:45][ 0.164598] futex hash table entries: 512 (order: -1, 32768 bytes, linear) [14:05:45][ 0.172464] pinctrl core: initialized pinctrl subsystem [14:05:45][ 0.178115] DMI not present or invalid. [14:05:45][ 0.182416] NET: Registered protocol family 16 [14:05:45][ 0.190475] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations [14:05:45][ 0.197856] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [14:05:45][ 0.205911] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [14:05:45][ 0.214280] thermal_sys: Registered thermal governor 'step_wise' [14:05:45][ 0.214284] thermal_sys: Registered thermal governor 'power_allocator' [14:05:45][ 0.220671] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [14:05:45][ 0.234337] ASID allocator initialised with 65536 entries [14:05:45][ 0.251301] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages [14:05:45][ 0.258161] HugeTLB registered 512 MiB page size, pre-allocated 0 pages [14:05:45][ 0.264920] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [14:05:45][ 0.274449] cryptd: max_cpu_qlen set to 1000 [14:05:45][ 0.281891] k3-chipinfo 43000014.chipid: Family:J7200 rev:SR1.0 JTAGID[0x0bb6d02f] Detected [14:05:45][ 0.290768] vsys_3v3: supplied by evm_12v0 [14:05:45][ 0.295261] vsys_5v0: supplied by evm_12v0 [14:05:45][ 0.300060] iommu: Default domain type: Translated [14:05:45][ 0.305233] SCSI subsystem initialized [14:05:45][ 0.309423] mc: Linux media interface: v0.10 [14:05:45][ 0.313817] videodev: Linux video capture interface: v2.00 [14:05:45][ 0.319463] pps_core: LinuxPPS API ver. 1 registered [14:05:45][ 0.324536] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [14:05:45][ 0.333877] PTP clock support registered [14:05:45][ 0.337898] EDAC MC: Ver: 3.0.0 [14:05:45][ 0.341846] FPGA manager framework [14:05:45][ 0.345375] Advanced Linux Sound Architecture Driver Initialized. [14:05:45][ 0.352142] clocksource: Switched to clocksource arch_sys_counter [14:05:45][ 0.358618] VFS: Disk quotas dquot_6.6.0 [14:05:45][ 0.362695] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes) [14:05:45][ 0.372989] NET: Registered protocol family 2 [14:05:45][ 0.377764] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear) [14:05:45][ 0.386639] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear) [14:05:45][ 0.395500] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear) [14:05:45][ 0.403716] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear) [14:05:45][ 0.411687] TCP: Hash tables configured (established 32768 bind 32768) [14:05:45][ 0.418532] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear) [14:05:45][ 0.425438] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear) [14:05:45][ 0.432862] NET: Registered protocol family 1 [14:05:45][ 0.437776] RPC: Registered named UNIX socket transport module. [14:05:45][ 0.443852] RPC: Registered udp transport module. [14:05:45][ 0.448677] RPC: Registered tcp transport module. [14:05:45][ 0.453484] RPC: Registered tcp NFSv4.1 backchannel transport module. [14:05:45][ 0.460069] PCI: CLS 0 bytes, default 64 [14:05:45][ 0.464454] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [14:05:45][ 0.476322] Initialise system trusted keyrings [14:05:45][ 0.481005] workingset: timestamp_bits=46 max_order=16 bucket_order=0 [14:05:45][ 0.489515] squashfs: version 4.0 (2009/01/31) Phillip Lougher [14:05:45][ 0.495871] NFS: Registering the id_resolver key type [14:05:45][ 0.501082] Key type id_resolver registered [14:05:45][ 0.505361] Key type id_legacy registered [14:05:46][ 0.509497] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [14:05:46][ 0.516348] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [14:05:46][ 0.524018] 9p: Installing v9fs 9p2000 file system support [14:05:46][ 0.550004] Key type asymmetric registered [14:05:46][ 0.554203] Asymmetric key parser 'x509' registered [14:05:46][ 0.559214] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [14:05:46][ 0.566776] io scheduler mq-deadline registered [14:05:46][ 0.571402] io scheduler kyber registered [14:05:46][ 0.576617] pinctrl-single 4301c000.pinctrl: 94 pins, size 376 [14:05:46][ 0.582831] pinctrl-single 11c000.pinctrl: 173 pins, size 692 [14:05:46][ 0.591098] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [14:05:46][ 0.597406] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [14:05:46][ 0.605484] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [14:05:46][ 0.619767] brd: module loaded [14:05:46][ 0.627464] loop: module loaded [14:05:46][ 0.631106] megasas: 07.714.04.00-rc1 [14:05:46][ 0.636629] tun: Universal TUN/TAP device driver, 1.6 [14:05:46][ 0.642096] igbvf: Intel(R) Gigabit Virtual Function Network Driver [14:05:46][ 0.648514] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [14:05:46][ 0.654595] sky2: driver version 1.30 [14:05:46][ 0.658930] VFIO - User Level meta-driver version: 0.3 [14:05:46][ 0.664701] i2c /dev entries driver [14:05:46][ 0.668805] sdhci: Secure Digital Host Controller Interface driver [14:05:46][ 0.675143] sdhci: Copyright(c) Pierre Ossman [14:05:46][ 0.679958] sdhci-pltfm: SDHCI platform and OF driver helper [14:05:46][ 0.686256] ledtrig-cpu: registered to indicate activity on CPUs [14:05:46][ 0.692616] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [14:05:46][ 0.699850] optee: probing for conduit method. [14:05:46][ 0.704414] optee: revision 3.12 (3d47a131) [14:05:46][ 0.704752] optee: initialized driver [14:05:46][ 0.714190] NET: Registered protocol family 17 [14:05:46][ 0.718826] 9pnet: Installing 9P2000 support [14:05:46][ 0.723230] Key type dns_resolver registered [14:05:46][ 0.727700] Loading compiled-in X.509 certificates [14:05:46][ 0.737573] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [14:05:46][ 0.743963] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [14:05:46][ 0.751928] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam') [14:05:46][ 0.777387] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz [14:05:46][ 0.783700] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz [14:05:46][ 0.790001] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz [14:05:46][ 0.796492] pca953x 3-0021: supply vcc not found, using dummy regulator [14:05:46][ 0.803339] pca953x 3-0021: using no AI [14:05:46][ 0.828714] pca953x 3-0020: supply vcc not found, using dummy regulator [14:05:46][ 0.835558] pca953x 3-0020: using no AI [14:05:46][ 0.840193] pca953x 3-0022: supply vcc not found, using dummy regulator [14:05:46][ 0.847017] pca953x 3-0022: using AI [14:05:46][ 0.851106] random: fast init done [14:05:46][ 0.854872] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz [14:05:46][ 0.861286] pca953x 4-0020: supply vcc not found, using dummy regulator [14:05:46][ 0.868148] pca953x 4-0020: using no AI [14:05:46][ 0.892537] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz [14:05:46][ 0.898786] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz [14:05:46][ 0.904992] omap_i2c 2030000.i2c: bus 6 rev0.12 at 100 kHz [14:05:46][ 0.911200] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz [14:05:46][ 0.917405] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz [14:05:46][ 0.923605] omap_i2c 2060000.i2c: bus 9 rev0.12 at 100 kHz [14:05:46][ 0.929828] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created [14:05:46][ 0.939840] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created [14:05:46][ 0.948670] ti-sci-intr bus@100000:bus@30000000:interrupt-controller1: Interrupt Router 213 domain created [14:05:46][ 0.958709] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 209 created [14:05:46][ 0.968614] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [14:05:46][ 0.976300] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000 [14:05:46][ 0.984604] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000 [14:05:46][ 0.992890] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [14:05:47][ 2.012429] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00 [14:05:47][ 2.018869] pci_bus 0000:00: root bus resource [bus 00-0f] [14:05:47][ 2.024477] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x18001000-0x18010fff]) [14:05:47][ 2.034168] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff] [14:05:47][ 2.041227] pci 0000:00:00.0: [104c:b00f] type 01 class 0x060400 [14:05:47][ 2.047467] pci 0000:00:00.0: supports D1 [14:05:47][ 2.051565] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [14:05:47][ 2.057456] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit] [14:05:47][ 2.064483] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs) [14:05:47][ 2.075290] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [14:05:47][ 2.084246] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01 [14:05:47][ 2.091022] pci 0000:00:00.0: BAR 7: assigned [mem 0x18400000-0x193fffff 64bit] [14:05:47][ 2.098500] pci 0000:00:00.0: PCI bridge to [bus 01] [14:05:47][ 2.103833] pcieport 0000:00:00.0: PME: Signaling with IRQ 36 [14:05:47][ 2.110930] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,32] sci-dev-id:235 [14:05:47][ 2.120845] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [14:05:47][ 2.127610] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64 [14:05:47][ 2.137287] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[120,200] sci-dev-id:211 [14:05:47][ 2.147466] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [14:05:47][ 2.154231] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64 [14:05:47][ 2.162270] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250 [14:05:47][ 2.171867] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 22, base_baud = 3000000) is a 8250 [14:05:47][ 2.180626] printk: console [ttyS2] enabled [14:05:47][ 2.180626] printk: console [ttyS2] enabled [14:05:47][ 2.189067] printk: bootconsole [ns16550a0] disabled [14:05:47][ 2.189067] printk: bootconsole [ns16550a0] disabled [14:05:47][ 2.199746] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 23, base_baud = 3000000) is a 8250 [14:05:47][ 2.376153] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 20000 [14:05:47][ 2.409574] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [14:05:47][ 2.417905] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000 [14:05:47][ 2.433284] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0 [14:05:47][ 2.442581] mmc0: CQHCI version 5.10 [14:05:47][ 2.450264] vdd_mmc1: supplied by vsys_3v3 [14:05:47][ 2.455248] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc8900 [14:05:47][ 2.462164] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc8900 [14:05:47][ 2.469338] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [14:05:47][ 2.479289] ti-udma 31150000.dma-controller: Channels: 50 (tchan: 25, rchan: 25, gp-rflow: 8) [14:05:47][ 2.486795] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit [14:05:47][ 2.497869] spi-nor spi0.0: s28hs512t (65536 Kbytes) [14:05:47][ 2.502852] 7 cmdlinepart partitions found on MTD device 47040000.spi.0 [14:05:48][ 2.509454] Creating 7 MTD partitions on "47040000.spi.0": [14:05:48][ 2.514928] 0x000000000000-0x000000100000 : "ospi.tiboot3" [14:05:48][ 2.521114] 0x000000100000-0x000000300000 : "ospi.tispl" [14:05:48][ 2.527137] 0x000000300000-0x000000700000 : "ospi.u-boot" [14:05:48][ 2.533206] 0x000000700000-0x000000740000 : "ospi.env" [14:05:48][ 2.538979] 0x000000740000-0x000000780000 : "ospi.env.backup" [14:05:48][ 2.545436] 0x000000800000-0x000003fc0000 : "ospi.rootfs" [14:05:48][ 2.551491] 0x000003fc0000-0x000004000000 : "ospi.phypattern" [14:05:48][ 2.582918] mmc0: Command Queue Engine enabled [14:05:48][ 2.587386] mmc0: new HS400 MMC card at address 0001 [14:05:48][ 2.592749] mmcblk0: mmc0:0001 S0J56X 14.8 GiB [14:05:48][ 2.597480] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB [14:05:48][ 2.603601] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB [14:05:48][ 2.609646] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0) [14:05:48][ 2.618109] mmcblk0: p1 p2 p3 [14:05:48][ 2.728161] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 20000 [14:05:48][ 2.758797] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [14:05:48][ 2.767127] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000 [14:05:48][ 2.780668] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [14:05:48][ 2.787705] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [14:05:48][ 2.794947] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [14:05:48][ 2.801390] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0 [14:05:48][ 2.811767] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present! [14:05:48][ 2.812051] mmc1: CQHCI version 5.10 [14:05:48][ 2.823060] ALSA device list: [14:05:48][ 2.826043] No soundcards found. [14:05:48][ 2.864163] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit [14:05:48][ 2.872079] Waiting for root device PARTUUID=d9117e3b-02... [14:05:48][ 2.924198] mmc1: new ultra high speed SDR104 SDHC card at address aaaa [14:05:48][ 2.931336] mmcblk1: mmc1:aaaa SC16G 14.8 GiB [14:05:48][ 2.940932] mmcblk1: p1 p2 [14:05:48][ 3.237285] EXT4-fs (mmcblk1p2): 1 orphan inode deleted [14:05:48][ 3.242539] EXT4-fs (mmcblk1p2): recovery complete [14:05:48][ 3.262091] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [14:05:48][ 3.270218] VFS: Mounted root (ext4 filesystem) on device 179:98. [14:05:48][ 3.281204] devtmpfs: mounted [14:05:48][ 3.285378] Freeing unused kernel memory: 1856K [14:05:48][ 3.289971] Run /sbin/init as init process [14:05:48][ 3.408600] systemd[1]: System time before build time, advancing clock. [14:05:48][ 3.455135] NET: Registered protocol family 10 [14:05:48][ 3.460267] Segment Routing with IPv6 [14:05:48][ 3.480058] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid) [14:05:49][ 3.501950] systemd[1]: Detected architecture arm64. [14:05:49] [14:05:49]Welcome to Arago 2021.09! [14:05:49] [14:05:49][ 3.541001] systemd[1]: Set hostname to <j7200-evm>. [14:05:49][ 3.747546] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly. [14:05:49][ 3.838453] random: systemd: uninitialized urandom read (16 bytes read) [14:05:49][ 3.845196] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling. [14:05:49][ 3.857538] systemd[1]: (This warning is only shown for the first unit using IP firewalling.) [14:05:49][ 3.868016] systemd[1]: Created slice system-getty.slice. [14:05:49][ OK ] Created slice system-getty.slice. [14:05:49][ 3.888274] random: systemd: uninitialized urandom read (16 bytes read) [14:05:49][ 3.895849] systemd[1]: Created slice system-serial\x2dgetty.slice. [14:05:49][ OK ] Created slice system-serial\x2dgetty.slice. [14:05:49][ 3.916269] random: systemd: uninitialized urandom read (16 bytes read) [14:05:49][ 3.923829] systemd[1]: Created slice system-syslog\x2dng.slice. [14:05:49][ OK ] Created slice system-syslog\x2dng.slice. [14:05:49][ 3.945257] systemd[1]: Created slice User and Session Slice. [14:05:49][ OK ] Created slice User and Session Slice. [14:05:49][ 3.968450] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [14:05:49][ OK ] Started Dispatch Password …ts to Console Directory Watch. [14:05:49][ 3.992408] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [14:05:49][ OK ] Started Forward Password R…uests to Wall Directory Watch. [14:05:49][ 4.016360] systemd[1]: Reached target Paths. [14:05:49][ OK ] Reached target Paths. [14:05:49][ 4.032284] systemd[1]: Reached target Remote File Systems. [14:05:49][ OK ] Reached target Remote File Systems. [14:05:49][ 4.052270] systemd[1]: Reached target Slices. [14:05:49][ OK ] Reached target Slices. [14:05:49][ 4.068284] systemd[1]: Reached target Swap. [14:05:49][ OK ] Reached target Swap. [14:05:49][ 4.090823] systemd[1]: Listening on RPCbind Server Activation Socket. [14:05:49][ OK ] Listening on RPCbind Server Activation Socket. [14:05:49][ 4.112295] systemd[1]: Reached target RPC Port Mapper. [14:05:49][ OK ] Reached target RPC Port Mapper. [14:05:49][ 4.139538] systemd[1]: Listening on Process Core Dump Socket. [14:05:49][ OK ] Listening on Process Core Dump Socket. [14:05:49][ 4.160457] systemd[1]: Listening on initctl Compatibility Named Pipe. [14:05:49][ OK ] Listening on initctl Compatibility Named Pipe. [14:05:49][ 4.192689] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. [14:05:49][ 4.201125] systemd[1]: Listening on Journal Socket (/dev/log). [14:05:49][ OK ] Listening on Journal Socket (/dev/log). [14:05:49][ 4.224618] systemd[1]: Listening on Journal Socket. [14:05:49][ OK ] Listening on Journal Socket. [14:05:49][ 4.240683] systemd[1]: Listening on Network Service Netlink Socket. [14:05:49][ OK ] Listening on Network Service Netlink Socket. [14:05:49][ 4.264612] systemd[1]: Listening on udev Control Socket. [14:05:49][ OK ] Listening on udev Control Socket. [14:05:49][ 4.284482] systemd[1]: Listening on udev Kernel Socket. [14:05:49][ OK ] Listening on udev Kernel Socket. [14:05:49][ 4.308094] systemd[1]: Mounting Huge Pages File System... [14:05:49] Mounting Huge Pages File System... [14:05:49][ 4.327688] systemd[1]: Mounting POSIX Message Queue File System... [14:05:49] Mounting POSIX Message Queue File System... [14:05:49][ 4.351880] systemd[1]: Mounting Kernel Debug File System... [14:05:49] Mounting Kernel Debug File System... [14:05:49][ 4.374246] systemd[1]: Mounting Temporary Directory (/tmp)... [14:05:49] Mounting Temporary Directory (/tmp)... [14:05:49][ 4.395728] systemd[1]: Starting Create list of static device nodes for the current kernel... [14:05:49] Starting Create list of st…odes for the current kernel... [14:05:49][ 4.423989] systemd[1]: Starting RPC Bind... [14:05:49] Starting RPC Bind... [14:05:49][ 4.440360] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [14:05:49][ 4.453770] systemd[1]: Starting Journal Service... [14:05:49] Starting Journal Service... [14:05:49][ 4.473957] systemd[1]: Starting Load Kernel Modules... [14:05:49] Starting Load Kernel Modules... [14:05:49][ 4.495822] systemd[1]: Starting Remount Root and Kernel File Systems... [14:05:50] Starting Remount Root and Kernel File Systems... [14:05:50][ 4.509493] cryptodev: loading out-of-tree module taints kernel. [14:05:50][ 4.525382] systemd[1]: Starting udev Coldplug all Devices... [14:05:50][ 4.529901] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null) [14:05:50][ 4.538436] cryptodev: driver 1.10 loaded. [14:05:50] Starting udev Coldplug all Devices... [14:05:50][ 4.555606] systemd[1]: Started RPC Bind. [14:05:50][ OK ] Started RPC Bind. [14:05:50][ 4.572694] systemd[1]: Started Journal Service. [14:05:50][ OK ] Started Journal Service. [14:05:50][ OK ] Mounted Huge Pages File System. [14:05:50][ OK ] Mounted POSIX Message Queue File System. [14:05:50][ OK ] Mounted Kernel Debug File System. [14:05:50][ OK ] Mounted Temporary Directory (/tmp). [14:05:50][ OK ] Started Create list of sta… nodes for the current kernel. [14:05:50][ OK ] Started Load Kernel Modules. [14:05:50][ OK ] Started Remount Root and Kernel File Systems. [14:05:50] Mounting Kernel Configuration File System... [14:05:50] Starting Flush Journal to Persistent Storage... [14:05:50][ 4.756435] systemd-journald[156]: Received client request to flush runtime journal. [14:05:50] Starting Apply Kernel Variables... [14:05:50] Starting Create Static Device Nodes in /dev... [14:05:50][ OK ] Mounted Kernel Configuration File System. [14:05:50][ OK ] Started Flush Journal to Persistent Storage. [14:05:50][ OK ] Started Apply Kernel Variables. [14:05:50][ OK ] Started Create Static Device Nodes in /dev. [14:05:50][ OK ] Reached target Local File Systems (Pre). [14:05:50] Mounting /media/ram... [14:05:50] Mounting /var/volatile... [14:05:50] Starting udev Kernel Device Manager... [14:05:50][ OK ] Started udev Coldplug all Devices. [14:05:50][ OK ] Mounted /media/ram. [14:05:50][ OK ] Mounted /var/volatile. [14:05:50] Starting udev Wait for Complete Device Initialization... [14:05:50] Starting Load/Save Random Seed... [14:05:50][ OK ] Reached target Local File Systems. [14:05:50] Starting Create Volatile Files and Directories... [14:05:50][ OK ] Started udev Kernel Device Manager. [14:05:50][ OK ] Started Create Volatile Files and Directories. [14:05:50] Starting Network Time Synchronization... [14:05:50] Starting Update UTMP about System Boot/Shutdown... [14:05:50][ OK ] Started Update UTMP about System Boot/Shutdown. [14:05:50][ OK ] Started Network Time Synchronization. [14:05:50][ OK ] Reached target System Time Set. [14:05:50][ OK ] Reached target System Time Synchronized. [14:05:51][ 5.673930] ti-udma 285c0000.dma-controller: chan1: is running! [14:05:51][ 5.727230] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [14:05:51][ 5.922062] platform 41000000.r5f: configured R5F for IPC-only mode [14:05:51][ 5.983146] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000 [14:05:51][ 6.137636] remoteproc remoteproc0: 41000000.r5f is available [14:05:51][ 6.244250] remoteproc remoteproc0: attaching to 41000000.r5f [14:05:51][ 6.387216] platform 41000000.r5f: R5F core initialized in IPC-only mode [14:05:51][ 6.474777] remoteproc0#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000 [14:05:51][ 6.484220] virtio_rpmsg_bus virtio0: rpmsg host is online [14:05:51][ 6.490349] remoteproc0#vdev0buffer: registered virtio0 (type 7) [14:05:51][ 6.495389] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd [14:05:52][ 6.504223] remoteproc remoteproc0: remote processor 41000000.r5f is now attached [14:05:52][ 6.507628] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe [14:05:52][ 6.536853] platform 5c00000.r5f: configured R5F for remoteproc mode [14:05:52][ 6.584242] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000 [14:05:52][ 6.736825] remoteproc remoteproc1: 5c00000.r5f is available [14:05:52][ 6.745945] platform 5d00000.r5f: configured R5F for remoteproc mode [14:05:52][ 6.760856] remoteproc remoteproc1: powering up 5c00000.r5f [14:05:52][ 6.766479] remoteproc remoteproc1: Booting fw image j7200-main-r5f0_0-fw, size 634196 [14:05:52][ 6.779546] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000 [14:05:52][ 6.787685] remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000 [14:05:52][ 6.797338] virtio_rpmsg_bus virtio1: rpmsg host is online [14:05:52][ 6.803597] remoteproc1#vdev0buffer: registered virtio1 (type 7) [14:05:52][ 6.809821] remoteproc remoteproc1: remote processor 5c00000.r5f is now up [14:05:52][ 6.912070] virtio_rpmsg_bus virtio1: creating channel ti.ethfw.notifyservice addr 0x1e [14:05:52][ 6.921956] virtio_rpmsg_bus virtio1: creating channel rpmsg-kdrv addr 0x1a [14:05:52][ 6.934995] virtio_rpmsg_bus virtio1: creating channel rpmsg-kdrv addr 0x1a [14:05:52][ 6.947515] virtio_rpmsg_bus virtio1: channel rpmsg-kdrv:ffffffff:1a already exist [14:05:52][ 6.960615] remoteproc remoteproc2: 5d00000.r5f is available [14:05:52][ 6.960877] virtio_rpmsg_bus virtio1: rpmsg_create_channel failed [14:05:52][ 6.978464] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15 [14:05:52][ 6.985815] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15 [14:05:52][ 7.000256] virtio_rpmsg_bus virtio1: channel rpmsg_chrdev:ffffffff:15 already exist [14:05:52][ 7.011820] virtio_rpmsg_bus virtio1: rpmsg_create_channel failed [14:05:52][ 7.018078] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uart_id: 3 [14:05:52][ 7.037705] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0) 26/Jun/2022 SHA: [14:05:52][ 7.052869] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF uart_id: 3 [14:05:52][ 7.068937] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0) 26/Jun/2022 SHA: [14:05:52][ 7.084368] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: rpmsg attach_ext - rx_mtu:1522 features:0000000B tx_mtu[0]:2024 flow_idx:84 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:1d:92:c1 mac-only:0 [14:05:52][ 7.112479] remoteproc remoteproc2: powering up 5d00000.r5f [14:05:52][ 7.118068] remoteproc remoteproc2: Booting fw image j7200-main-r5f0_1-fw, size 2809848 [14:05:52][ 7.132382] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: virt_cpsw_nuss mac loaded [14:05:52][ 7.140341] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: rdev_features:0000000B rdev_mtu:1522 flow_id:84 tx_psil_dst_id:4A00 mac_only:0 [14:05:52][ 7.154172] remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000 [14:05:52][ 7.159773] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1 [14:05:52][ 7.166235] virtio_rpmsg_bus virtio2: rpmsg host is online [14:05:52][ 7.180997] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:85 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:1d:92:c2 mac-only:1 [14:05:52][ 7.188844] remoteproc2#vdev0buffer: registered virtio2 (type 7) [14:05:52][ 7.213599] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac loaded [14:05:52][ 7.216469] remoteproc remoteproc2: remote processor 5d00000.r5f is now up [14:05:52][ 7.221564] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rdev_features:00000007 rdev_mtu:1522 flow_id:85 tx_psil_dst_id:4A01 mac_only:1 [14:05:52][ 7.252204] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c2 [14:05:53][ 7.520194] random: crng init done [14:05:53][ 7.523618] random: 7 urandom warning(s) missed due to ratelimiting [14:05:53][ OK ] Started Load/Save Random Seed. [14:05:53][ 8.266288] usbcore: registered new interface driver usbfs [14:05:53][ 8.283810] omap_rng 40910000.rng: Random Number Generator ver. 241b34c [14:05:53][ 8.306192] usbcore: registered new interface driver hub [14:05:53][ 8.316632] usbcore: registered new device driver usb [14:05:53][ OK ] Created slice system-systemd\x2dfsck.slice. [14:05:54][ OK ] Found device /dev/mmcblk0p2. [14:05:54] Starting File System Check on /dev/mmcblk0p2... [14:05:54][ OK ] Found device /dev/mmcblk0p3. [14:05:54] Starting File System Check on /dev/mmcblk0p3... [14:05:54][ OK ] Found device /dev/mmcblk0p1. [14:05:54] Starting File System Check on /dev/mmcblk0p1... [14:05:54][ OK ] Found device /dev/mmcblk1p1. [14:05:54] Starting File System Check on /dev/mmcblk1p1... [14:05:54][ OK ] Started udev Wait for Complete Device Initialization. [14:05:54][ OK ] Started Hardware RNG Entropy Gatherer Daemon. [14:05:54][ OK ] Reached target System Initialization. [14:05:54][ OK ] Started Daily rotation of log files. [14:05:54][ OK ] Started Daily Cleanup of Temporary Directories. [14:05:54][ OK ] Reached target Timers. [14:05:54][ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [14:05:54][ OK ] Listening on D-Bus System Message Bus Socket. [14:05:54] Starting Docker Socket for the API. [14:05:54][ OK ] Listening on dropbear.socket. [14:05:54] Starting Reboot and dump vmcore via kexec... [14:05:54][ OK ] Started File System Check on /dev/mmcblk0p2. [14:05:54][ OK ] Listening on Docker Socket for the API. [14:05:54][ OK ] Reached target Sockets. [14:05:54][ OK ] Reached target Basic System. [14:05:54] Mounting /run/media/mmcblk0p2... [14:05:54][ OK ] Started Job spooling tools. [14:05:54][ OK ] Started Periodic Command Scheduler. [14:05:54][ OK ] Started D-Bus System Message Bus. [14:05:54] Starting Ethernet Bridge Filtering Tables... [14:05:54] Starting Print notice about GPLv3 packages... [14:05:54] Starting IPv6 Packet Filtering Framework... [14:05:54] Starting IPv4 Packet Filtering Framework... [14:05:54][ OK ] Started irqbalance daemon. [14:05:54] Starting Telephony service... [14:05:54] Starting System Logger Daemon "default" instance... [14:05:54] Starting Login Service... [14:05:54][ OK ] Started TEE Supplicant. [14:05:54] Starting telnetd.service... [14:05:54][ OK ] Started Reboot and dump vmcore via kexec. [14:05:54][ OK ] Mounted /run/media/mmcblk0p2. [14:05:54][ OK ] Started IPv4 Packet Filtering Framework. [14:05:54][ OK ] Started IPv6 Packet Filtering Framework. [14:05:54][ OK ] Reached target Network (Pre). [14:05:54] Starting Network Service... [14:05:54][ OK ] Started Telephony service. [14:05:54][ OK ] Started Ethernet Bridge Filtering Tables. [14:05:54][ OK ] Started File System Check on /dev/mmcblk0p1. [14:05:54] Mounting /run/media/mmcblk0p1... [14:05:54][ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch. [14:05:54][ OK ] Started telnetd.service. [14:05:54] Starting syslog.service... [14:05:54][ 9.180505] Bluetooth: Core ver 2.22 [14:05:54][ 9.186127] NET: Registered protocol family 31 [14:05:54][ 9.195017] Bluetooth: HCI device and connection manager initialized [14:05:54][ 9.206661] Bluetooth: HCI socket layer initialized [14:05:54][ 9.217297] Bluetooth: L2CAP socket layer initialized [14:05:54][ 9.227667] Bluetooth: SCO socket layer initialized [14:05:54][ OK ] Mounted /run/media/mmcblk0p1. [14:05:54][ OK ] Started Network Service. [14:05:54] Starting Wait for Network to be Configured... [14:05:54] Starting Network Name Resolution... [14:05:54][ OK ] Started System Logger Daemon "default" instance. [14:05:54][ 9.412357] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac started [14:05:55][ 9.437987] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: virt_cpsw_nuss mac started [14:05:55][ OK ] Started syslog.service. [14:05:55][ OK ] Started File System Check on /dev/mmcblk1p1. [14:05:55] Mounting /run/media/mmcblk1p1... [14:05:55][ OK ] Mounted /run/media/mmcblk1p1. [14:05:55][ OK ] Started File System Check on /dev/mmcblk0p3. [14:05:55] Mounting /run/media/mmcblk0p3... [14:05:55][ OK ] Started Login Service. [14:05:55][ 9.745296] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL) [14:05:55][ OK ] Mounted /run/media/mmcblk0p3. [14:05:55][ 9.829890] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down [14:05:55][ OK ] Started Network Name Resolution. [14:05:55][ OK ] Reached target Network. [14:05:55][ OK ] Reached target Host and Network Name Lookups. [14:05:55] Starting Avahi mDNS/DNS-SD Stack... [14:05:55] Starting Enable and configure wl18xx bluetooth stack... [14:05:55][ OK ] Started NFS status monitor for NFSv2/3 locking.. [14:05:55] Starting Simple Network Ma…ent Protocol (SNMP) Daemon.... [14:05:55] Starting Permit User Sessions... [14:05:55][ OK ] Started Vsftpd ftp daemon. [14:05:55][ OK ] Started Permit User Sessions. [14:05:55][ OK ] Started Getty on tty1. [14:05:55][ OK ] Started Serial Getty on ttyS2. [14:05:55][ OK ] Started Serial Getty on ttyS3. [14:05:55][ OK ] Reached target Login Prompts. [14:05:55] Starting Synchronize System and HW clocks... [14:05:55][ OK ] Started Enable and configure wl18xx bluetooth stack. [14:05:55][FAILED] Failed to start Synchronize System and HW clocks. [14:05:55]See 'systemctl status sync-clocks.service' for details. [14:05:55][ OK ] Started Avahi mDNS/DNS-SD Stack. [14:05:56][ OK ] Started Simple Network Man…ement Protocol (SNMP) Daemon.. [14:05:58] Starting Cleanup of Temporary Directories... [14:05:58][ OK ] Started Cleanup of Temporary Directories. [14:05:59]*************************************************************** [14:05:59]*************************************************************** [14:05:59]NOTICE: This file system contains the following GPLv3 packages: [14:05:59] autoconf [14:05:59] bash-dev [14:05:59] bash [14:05:59] bc [14:05:59] binutils [14:05:59] cifs-utils [14:05:59] coreutils-stdbuf [14:05:59] coreutils [14:05:59] cpio [14:05:59] cpp-symlinks [14:05:59] cpp [14:05:59] dosfstools [14:05:59] elfutils [14:05:59] g++-symlinks [14:05:59] g++ [14:05:59] gawk [14:05:59] gcc-symlinks [14:05:59] gcc [14:05:59] gdb [14:05:59] gdbserver [14:05:59] gettext [14:05:59] gstreamer1.0-libav-dev [14:05:59] gstreamer1.0-libav [14:05:59] gzip [14:05:59] less [14:05:59] libasm1 [14:05:59] libbfd [14:05:59] libdw1 [14:05:59] libelf1 [14:05:59] libgdbm-compat4 [14:05:59] libgdbm-dev [14:05:59] libgdbm6 [14:05:59] libgettextlib [14:05:59] libgettextsrc [14:05:59] libgmp-dev [14:05:59] libgmp10 [14:05:59] libgmpxx4 [14:05:59] libidn2-0 [14:05:59] libidn2-dev [14:05:59] libmpc3 [14:05:59] libmpfr6 [14:05:59] libreadline-dev [14:05:59] libreadline8 [14:05:59] libunistring-dev [14:05:59] libunistring2 [14:05:59] m4-dev [14:05:59] m4 [14:05:59] make [14:05:59] nettle-dev [14:05:59] nettle [14:05:59] parted [14:05:59] python3-rfc3987 [14:05:59] python3-strict-rfc3339 [14:05:59] tar [14:05:59] which [14:05:59] zeromq [14:05:59] [14:05:59]If you do not wish to distribute GPLv3 components please remove [14:05:59]the above packages prior to distribution. This can be done using [14:05:59]the opkg remove command. i.e.: [14:05:59] opkg remove <package> [14:05:59]Where <package> is the name printed in the list above [14:05:59] [14:05:59]NOTE: If the package is a dependency of another package you [14:05:59] will be notified of the dependent packages. You should [14:05:59] use the --force-removal-of-dependent-packages option to [14:05:59] also remove the dependent packages as well [14:05:59]*************************************************************** [14:05:59]*************************************************************** [14:06:05][ OK ] Started Print notice about GPLv3 packages. [14:06:07][ OK ] Created slice system-systemd\x2dcoredump.slice. [14:06:07][ OK ] Started Process Core Dump (PID 929/UID 0). [14:06:07][ OK ] Started Process Core Dump (PID 931/UID 0). [14:06:07][ OK ] Started Process Core Dump (PID 933/UID 0). [14:06:07][ OK ] Started Process Core Dump (PID 932/UID 0). [14:06:07][ OK ] Started Process Core Dump (PID 930/UID 0). [14:06:07][ OK ] Stopped Login Service. [14:06:07] Starting Login Service... [14:06:07][ OK ] Stopped Network Time Synchronization. [14:06:07] Starting Network Time Synchronization... [14:06:07][ OK ] Stopped udev Kernel Device Manager. [14:06:07] Starting udev Kernel Device Manager... [14:06:07][ OK ] Stopped Network Name Resolution. [14:06:07] Starting Network Name Resolution... [14:06:07][ OK ] Started Login Service. [14:06:07][ OK ] Started udev Kernel Device Manager. [14:06:08][ OK ] Started Network Time Synchronization. [14:06:08][ OK ] Stopped Network Service. [14:06:08] Starting Network Service... [14:06:08][ OK ] Started Network Name Resolution. [14:06:08][ OK ] Started Network Service. [14:06:12] [14:06:12] _____ _____ _ _ [14:06:12]| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ [14:06:12]| | _| .'| . | . | | __| _| . | | | -_| _| _| [14:06:12]|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| [14:06:12] |___| |___| [14:06:12] [14:06:12]Arago Project http://arago-project.org j7200-evm ttyS2 [14:06:12] [14:06:12]Arago 2021.09 j7200-evm ttyS2 [14:06:12] [14:06:14]j7200-evm login: root [14:06:18]root@j7200-evm:~# ifconfig [14:06:18]eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 metric 1 [14:06:18] ether f4:84:4c:f8:68:70 txqueuelen 1000 (Ethernet) [14:06:18] RX packets 0 bytes 0 (0.0 B) [14:06:18] RX errors 0 dropped 0 overruns 0 frame 0 [14:06:18] TX packets 0 bytes 0 (0.0 B) [14:06:18] TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 [14:06:18] [14:06:18]eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 metric 1 [14:06:18] inet6 fe80::72ff:76ff:fe1d:92c1 prefixlen 64 scopeid 0x20<link> [14:06:18] ether 70:ff:76:1d:92:c1 txqueuelen 1000 (Ethernet) [14:06:18] RX packets 0 bytes 0 (0.0 B) [14:06:18] RX errors 0 dropped 0 overruns 0 frame 0 [14:06:18] TX packets 23 bytes 3697 (3.6 KiB) [14:06:18] TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 [14:06:18] [14:06:18]eth2: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 metric 1 [14:06:18] inet6 fe80::72ff:76ff:fe1d:92c2 prefixlen 64 scopeid 0x20<link> [14:06:18] ether 70:ff:76:1d:92:c2 txqueuelen 1000 (Ethernet) [14:06:18] RX packets 0 bytes 0 (0.0 B) [14:06:18] RX errors 0 dropped 0 overruns 0 frame 0 [14:06:18] TX packets 24 bytes 3827 (3.7 KiB) [14:06:18] TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 [14:06:18] [14:06:18]lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 metric 1 [14:06:18] inet 127.0.0.1 netmask 255.0.0.0 [14:06:18] inet6 ::1 prefixlen 128 scopeid 0x10<host> [14:06:18] loop txqueuelen 1000 (Local Loopback) [14:06:18] RX packets 82 bytes 6220 (6.0 KiB) [14:06:18] RX errors 0 dropped 0 overruns 0 frame 0 [14:06:18] TX packets 82 bytes 6220 (6.0 KiB) [14:06:18] TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 [14:06:18] [14:06:37]root@j7200-evm:~# cat /sys/kernel/debug/remoteproc/remoteproc1/trace0 [14:06:37] [14:06:37]TTTTTTTTTTTTTTTTTTTTTTTTTTTTTT2 [14:06:37] [14:06:37]======================================================= [14:06:37] CPSW Ethernet Firmware [14:06:37]======================================================= [14:06:37]ETHFW: Shared multicasts (software fanout): [14:06:37] 01:00:5e:00:00:01 [14:06:37] 01:00:5e:00:00:fb [14:06:37] 01:00:5e:00:00:fc [14:06:37] 33:33:00:00:00:01 [14:06:37] 33:33:ff:1d:92:c2 [14:06:37] 01:80:c2:00:00:00 [14:06:37] 01:80:c2:00:00:03 [14:06:37]ETHFW: Reserved multicasts: [14:06:37] 01:80:c2:00:00:0e [14:06:37] 01:1b:19:00:00:00 [14:06:37]EnetMcm: CPSW_5G on MAIN NAVSS [14:06:37] [14:06:37]ETHFW Version : 0.02.00 [14:06:38]ETHFW Build Date: Jun 26, 2022 [14:06:38]ETHFW Build Time: 23:29:01 [14:06:38]ETHFW Commit SHA: [14:06:38] [14:06:38]Starting lwIP, local interface IP is 192.168.1.200 [14:06:38]Host MAC address: 70:ff:76:1d:92:c3 [14:06:38][LWIPIF_LWIP] Enet LLD netif initialized successfully [14:06:38][LWIPIF_LWIP_IC] Interface started successfully [14:06:38][LWIPIF_LWIP_IC] NETIF INIT SUCCESS [14:06:38][LWIPIF_LWIP_IC] Interface started successfully [14:06:38][LWIPIF_LWIP_IC] NETIF INIT SUCCESS [14:06:38]Added interface 'br4', IP is 192.168.1.200 [14:06:38]EthFw: TimeSync PTP enabled [14:06:38]Rx Flow for Software Inter-VLAN Routing is up [14:06:38]CpswProxyServer: Virtual port configuration: [14:06:38] mpu_1_0 <-> Switch port 0: mpu_1_0_ethswitch-device-0 [14:06:38] mcu_2_1 <-> Switch port 1: mcu_2_1_ethswitch-device-1 [14:06:38] mpu_1_0 <-> MAC port 1: mpu_1_0_ethmac-device-1 [14:06:38] mcu_2_1 <-> MAC port 4: mcu_2_1_ethmac-device-4 [14:06:38]CpswProxyServer: initialization completed (core: mcu2_0) [14:06:38]REMOTE_SERVICE: Init ... !!! [14:06:38]REMOTE_SERVICE: Init ... Done !!! [14:06:38]Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:5 [14:06:38]Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:5 [14:06:38]Function:CpswProxyServer_attachExtHandlerCb,HostId:4,CpswType:5 [14:06:38]Function:CpswProxyServer_ioctlHandlerCb,HostId:4,Handle:a2a596e8,CoreKey:38acb976, Cmd:1010401,InArgsLen:0, OutArgsLen:4 [14:06:38]Function:CpswProxyServer_ioctlHandlerCb,HostId:4,Handle:a2a596e8,CoreKey:38acb976, Cmd:1010201,InArgsLen:24, OutArgsLen:4 [14:06:38]Function:CpswProxyServer_registerMacHandlerCb,HostId:4,Handle:a2a596e8,CoreKey:38acb976, MacAddress:70:ff:76:1d:92:c4, FlowIdx:91, FlowIdxOffset:7 [14:06:38]Cpsw_ioctlInternal: CPSW: Registered MAC address. ALE entry:8, Policer Entry:3 [14:06:38]Function:CpswProxyServer_registerRemoteTimerHandlerCb,HostId:4,Handle:a2a596e8,CoreKey:38acb976, Name:mcu_2_1_ethswitch-device-1, Timer:1, PushNum:2 [14:06:38]Function:CpswProxyServer_attachExtHandlerCb,HostId:4,CpswType:5 [14:06:38]Function:CpswProxyServer_ioctlHandlerCb,HostId:4,Handle:a2a596e8,CoreKey:38acb976, Cmd:1010401,InArgsLen:0, OutArgsLen:4 [14:06:38]Function:CpswProxyServer_ioctlHandlerCb,HostId:4,Handle:a2a596e8,CoreKey:38acb976, Cmd:1010201,InArgsLen:24, OutArgsLen:4 [14:06:38]Function:CpswProxyServer_registerMacHandlerCb,HostId:4,Handle:a2a596e8,CoreKey:38acb976, MacAddress:70:ff:76:1d:92:c5, FlowIdx:92, FlowIdxOffset:8 [14:06:38]Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c2, FlowIdx:85, FlowIdxOffset:1 [14:06:38]Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6,mode:disable [14:06:38]Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6,mode:disable [14:06:38]Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1, FlowIdx:84, FlowIdxOffset:0 [14:06:38]Cpsw_ioctlInternal: CPSW: Registered MAC address. ALE entry:11, Policer Entry:6 [14:06:38]Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:1, vlanId:0, FlowIdx:84, FlowIdOffset:0 [14:06:38]Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:1:0:5e:0:0:1, vlanId:0, FlowIdx:84, FlowIdOffset:0 [14:06:38]Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:33:33:ff:1d:92:c1, vlanId:0, FlowIdx:84, FlowIdOffset:0 [14:06:38]Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6,mode:disable [14:06:38]Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6,mode:disable [14:06:38]Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6,mode:disable [14:06:38]Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:0, vlanId:0, FlowIdx:84, FlowIdOffset:0 [14:06:38]Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:3, vlanId:0, FlowIdx:84, FlowIdOffset:0 [14:06:38]Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:e, vlanId:0, FlowIdx:84, FlowIdOffset:0 [14:06:38]CpswProxyServer_isRsvdMcast: Reserved mcast cannot be added to filter [14:06:38]Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6,mode:disable [14:06:38]Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:fb, vlanId:0, FlowIdx:84, FlowIdOffset:0 [14:06:38]Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6,mode:disable [14:06:38]Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6,mode:disable [14:06:38]Function:CpswProxyServer_filterDelMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:e, vlanId:0, FlowIdx:84, FlowIdOffset:0 [14:06:38]CpswProxyServer_isRsvdMcast: Reserved mcast cannot be added to filter [14:06:38]Function:CpswProxyServer_filterDelMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:0, vlanId:0, FlowIdx:84, FlowIdOffset:0 [14:06:38]Function:CpswProxyServer_filterDelMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:3, vlanId:0, FlowIdx:84, FlowIdOffset:0 [14:06:38]Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6,mode:disable [14:06:38]Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6,mode:disable [14:06:38]Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6,mode:disable [14:06:38]Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:33:33:0:1:0:3, vlanId:0, FlowIdx:84, FlowIdOffset:0 [14:06:38]Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6,mode:disable [14:06:38]Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:0, vlanId:0, FlowIdx:84, FlowIdOffset:0 [14:06:38]Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:3, vlanId:0, FlowIdx:84, FlowIdOffset:0 [14:06:38]Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:e, vlanId:0, FlowIdx:84, FlowIdOffset:0 [14:06:38]CpswProxyServer_isRsvdMcast: Reserved mcast cannot be added to filter
