TI DM365 IP摄像机全套方案(包括源代码,原理图和PCB图,可用于IP摄像机的直接生产)
详细说明:TI DM365 IP摄像机全套方案,包括源代码,原理图和PCB图,可用于IP摄像机的直接生产,也可用于重要参考.
网址:http://www.61ic.com/Download/DaVinci/Code/201110/64162.html  文件有44M,传不上来,直接贴网址
文件列表
Private_IPNC_DM365_0.7.0\Application\bin\cramfsImage_ipnc_dm365_0.7.0
........................\...........\src\dvsdk_2_10_00_16_patch.tgz
........................\...........\...\ipnc_app_dm365_priv_0.7.0.tgz
........................\Docs\AVServer_UserGuide_IPNC_DM365_0.7.0.pdf
........................\....\Design_Document_IPNC_DM365_0.7.0.pdf
........................\....\Diagnostic_Guide_IPNC_DM365_0.7.0.pdf
........................\....\Getting_Started_Guide_IPNC_DM365_0.7.0.pdf
........................\....\Hardware_Test_Report_IPNC_DM365_0.7.0.pdf
........................\....\Product_Datasheet_IPNC_DM365_0.7.0.pdf
........................\....\Release_Notes_IPNC_DM365_0.7.0.pdf
........................\....\Users_Guide_IPNC_DM365_0.7.0.pdf
........................\Hardware\365IPC_TOTAL_BOM_0307.xls
........................\........\Gerber_IPNC_DM365.rar
........................\........\Schematic_IPNC_DM365.zip
........................\readme.txt
........................\Utils\bin\diagnostic_ipnc_dm36x_0.2.0.bin
........................\.....\...\gel_ ipnc_dm36x_0.2.0.gel
........................\.....\...\nandwriter_ipnc_dm36x_0.2.0.out
........................\.....\...\ubl_ipnc_dm36x_297_0.2.0.bin
........................\.....\src\diagnostic_ipnc_dm36x_0.2.0.zip
........................\.....\...\flash_utils_ipnc_dm36x_0.2.0.zip
........................\Application\bin
