IPC 例程build问题求教
编译出现如下问题  请问是什么原因?   我在工程属性里设置了include option   包含了CCS5\pdk_C6678_1_0_0_9_beta2\packages
Description Resource Path Location Type
#10010 errors encountered during linking; "IPC_example_on_6678.out" not IPC_example_on_6678    C/C++ Problem
<a href="file:/D:/CCS5/ccsv5/tools/compiler/dmed/HTML/10234.html">#10234-D</a>  unresolved symbols remain IPC_example_on_6678    C/C++ Problem
cannot find file "C:\Program Files\Texas IPC_example_on_6678    C/C++ Problem
unresolved symbol CSL_chipReadReg, first referenced in ./ipc_interrupt.obj IPC_example_on_6678    C/C++ Problem
unresolved symbol CSL_intcGlobalEnable, first referenced in ./ipc_interrupt.obj IPC_example_on_6678    C/C++ Problem
unresolved symbol CSL_intcGlobalNmiEnable, first referenced in ./ipc_interrupt.obj IPC_example_on_6678    C/C++ Problem
unresolved symbol CSL_intcHwControl, first referenced in ./ipc_interrupt.obj IPC_example_on_6678    C/C++ Problem
unresolved symbol CSL_intcInit, first referenced in ./ipc_interrupt.obj IPC_example_on_6678    C/C++ Problem
unresolved symbol CSL_intcOpen, first referenced in ./ipc_interrupt.obj IPC_example_on_6678    C/C++ Problem
unresolved symbol CSL_intcPlugEventHandler, first referenced in ./ipc_interrupt.obj IPC_example_on_6678    C/C++ Problem
