下面是打印信息
[host] Application Start Completed
Dev_pollOpen: Couldn't open /dev/syslinkipc_MultiProc: No such file or directory
Please ensure that SysLink's device driver module (syslink.ko) is installed
MultiProc driver close: : Bad file descriptor
[host] 0: SYSTEM: System Common Init in progress !!!
[host] 1: SYSTEM: IPC init in progress !!!
Dev_pollOpen: Couldn't open /dev/syslinkipc_SharedRegion: No such file or direct
ory
SharedRegion driver open: : No such file or directory
SharedRegion driver close: : Bad file descriptor
ory
Dev_pollOpen: Couldn't open /dev/syslinkipc_Osal: No such file or directory
OsalDrv driver open: /dev/syslinkipc_Osal: No such file or directory
OsalDrv driver close: /dev/syslinkipc_Osal: Bad file descriptor
Dev_pollOpen: Couldn't open /dev/syslinkipc_GateMP: No such file or directory
Dev_pollOpen: Couldn't open /dev/syslinkipc_MessageQ: No such file or directory
MessageQ driver close: : Bad file descriptor
root@dm814x-evm:~# mkdosfs 3.0.12 (29 Oct 2011)
unable to get drive geometry, using default 255/63
/dev/sbulla has 255 heads and 63 sectors per track,
logical sector size is 512,
using 0xf8 media descriptor, with 1024 sectors;
file system has 2 12-bit FATs and 4 sectors per cluster.
FAT size is 1 sector, and provides 247 clusters.
There is 1 reserved sector.
Root directory contains 512 slots and uses 32 sectors.
Volume ID is 2fb1feeb, no volume label.
g_file_storage gadget: No serial-number string provided!
g_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010
g_file_storage gadget: Number of LUNs=1
g_file_storage gadget-lun0: ro=0, nofua=0, file: /dev/sbulla
Simple mixer control 'PGA',0
Capabilities: cvolume cswitch penum
Capture channels: Front Left - Front Right
Limits: Capture 0 - 119
Front Left: Capture 80 [67%] [40.00dB] [on]
Front Right: Capture 80 [67%] [40.00dB] [on]
queue id:0
ApproDrvInit: 7
Creat queue id:131076
queue id:131076
ApproDrvInit: 3
queue id:131076
queue id:0
TimeOut occure in boot_proc.
Program exit.
Program exit.
各位咋回事呀,没动任何东西,按理说 应该能直接能用浏览器去访问相机看图像呀,谢谢
