Part Number: TDA4VM
Can csitx set deskew? My current process is csitx -> 9295 -> 9296, but if the csitx lane speed setting exceeds 500Mbps, the data cannot be received normally
请看下面英文e2e论坛工程师的回复。
I think it does support, but we have not tested/validated it.
But typically, at such low lane speed, it should not require deskew calibration. Can you please check if the issue is really due to deskew?
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1130354/tda4vm-can-csitx-set-deskew
