Part Number: AM5728
Other Parts Discussed in Thread: DRA752, TMP102
U-Boot SPL 2017.01-g856bf87 (Aug 20 2020 - 16:05:07)
DRA752-GP ES2.0
Trying to boot from MMC2_2
reading u-boot.img
reading u-boot.img
U-Boot 2017.01-g856bf87 (Aug 20 2020 - 16:05:07 +0800)
CPU : DRA752-GP ES2.0
Board: Tronlong am57xx_evm boards
I2C: ready
DRAM: 1 GiB
WARNING: Caches not enabled
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
SCSI: SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
Found 0 device(s).
Net: <ethaddr> not set. Validating first E-fuse MAC
cpsw
Hit <SPACE> key to stop autoboot in 1s
Card did not respond to voltage select!
** Bad device mmc 0 **
There is no valid bmp file at the given address
Trying to boot Linux from eMMC ...
switch to partitions #0, OK
mmc1(part 0) is current device
SD/MMC found on device 1
6394368 bytes read in 556 ms (11 MiB/s)
160698 bytes read in 28 ms (5.5 MiB/s)
## Flattened Device Tree blob at 88000000
Booting using the fdt blob at 0x88000000
Loading Device Tree to 8ffd5000, end 8ffff3b9 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.19.94-gbe5389fd85 (root@qihua-virtual-machine) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11)) #2 SMP Tue Sep 13 15:12:58 CST 2022
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: TL5728-EasyEVM
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[ 0.000000] OF: reserved mem: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 80 MiB at 0x00000000bac00000
[ 0.000000] OMAP4: Map 0x00000000bfd00000 to (ptrval) for dram barrier
[ 0.000000] DRA752 ES2.0
[ 0.000000] random: get_random_bytes called from start_kernel+0xb4/0x460 with crng_init=0
[ 0.000000] percpu: Embedded 15 pages/cpu s32012 r8192 d21236 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 210240
[ 0.000000] Kernel command line: console=ttyO2,115200n8 omapdrm.displays=0,1 root=PARTUUID=9c1fae8a-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 575904K/847872K available (10240K kernel code, 321K rwdata, 2676K rodata, 2048K init, 273K bss, 26208K reserved, 245760K cma-reserved, 176128K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (12256 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (2048 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 322 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 274 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: GICv2 detected, but range too small and irqchip.gicv2_force_probe not set
[ 0.000000] ti_dt_clocks_register: missing clkctrl nodes, please update your dts.
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000018] Switching to timer-based delay loop, resolution 162ns
[ 0.000356] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000366] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000849] Console: colour dummy device 80x30
[ 0.000868] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
[ 0.000876] This ensures that you still see kernel messages. Please
[ 0.000883] update your kernel commandline.
[ 0.000914] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000928] pid_max: default: 32768 minimum: 301
[ 0.001049] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001063] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001612] CPU: Testing write buffer coherency: ok
[ 0.001648] CPU0: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
[ 0.001852] /cpus/cpu@0 missing clock-frequency property
[ 0.001869] /cpus/cpu@1 missing clock-frequency property
[ 0.001881] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002334] Setting up static identity map for 0x80200000 - 0x80200060
[ 0.002437] rcu: Hierarchical SRCU implementation.
[ 0.002786] EFI services will not be available.
[ 0.002917] smp: Bringing up secondary CPUs ...
[ 0.003515] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.003522] CPU1: Spectre v2: using ICIALLU workaround
[ 0.003637] smp: Brought up 1 node, 2 CPUs
[ 0.003648] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[ 0.003657] CPU: All CPU(s) started in HYP mode.
[ 0.003665] CPU: Virtualization extensions available.
[ 0.004150] devtmpfs: initialized
[ 0.028812] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.028985] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.029001] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.032966] pinctrl core: initialized pinctrl subsystem
[ 0.033459] DMI not present or invalid.
[ 0.033757] NET: Registered protocol family 16
[ 0.034821] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.035681] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.048137] omap_hwmod: mcasp3: no dt node
[ 0.048147] ------------[ cut here ]------------
[ 0.048169] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.26+0x1bc/0x4d4
[ 0.048178] omap_hwmod: mcasp3: doesn't have mpu register target base
[ 0.048186] Modules linked in:
[ 0.048200] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.19.94-gbe5389fd85 #2
[ 0.048210] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 0.048217] Backtrace:
[ 0.048235] [<c020bbd8>] (dump_backtrace) from [<c020bea8>] (show_stack+0x18/0x1c)
[ 0.048247] r7:00000009 r6:60000013 r5:00000000 r4:c124cedc
[ 0.048262] [<c020be90>] (show_stack) from [<c09e8d44>] (dump_stack+0x98/0xac)
[ 0.048275] [<c09e8cac>] (dump_stack) from [<c022dca0>] (__warn+0x104/0x11c)
[ 0.048287] r7:00000009 r6:c0db142c r5:00000000 r4:ef07bddc
[ 0.048298] [<c022db9c>] (__warn) from [<c022dd04>] (warn_slowpath_fmt+0x4c/0x68)
[ 0.048309] r8:00000000 r7:c1210cc4 r6:6198b9f2 r5:c0db1b20 r4:c1204c48
[ 0.048323] [<c022dcbc>] (warn_slowpath_fmt) from [<c100d070>] (_init.constprop.26+0x1bc/0x4d4)
[ 0.048331] r3:c0db3934 r2:c0db1b20
[ 0.048341] r6:c1204c48 r5:00000000 r4:c1210c8c
[ 0.048355] [<c100ceb4>] (_init.constprop.26) from [<c100d4b8>] (__omap_hwmod_setup_all+0x48/0x134)
[ 0.048366] r10:00000003 r9:c1204c48 r8:ffffe000 r7:00000000 r6:c100d470 r5:c120a448
[ 0.048373] r4:c1210c8c
[ 0.048388] [<c100d470>] (__omap_hwmod_setup_all) from [<c02025fc>] (do_one_initcall+0x5c/0x1a0)
[ 0.048397] r5:c12505c0 r4:c12505c0
[ 0.048412] [<c02025a0>] (do_one_initcall) from [<c1000ff8>] (kernel_init_freeable+0x1d4/0x26c)
[ 0.048423] r9:c1000620 r8:000000da r7:c1050824 r6:c1064800 r5:c12505c0 r4:c12505c0
[ 0.048438] [<c1000e24>] (kernel_init_freeable) from [<c09fe3e0>] (kernel_init+0x10/0x118)
[ 0.048448] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c09fe3d0
[ 0.048455] r4:00000000
[ 0.048467] [<c09fe3d0>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
[ 0.048475] Exception stack(0xef07bfb0 to 0xef07bff8)
[ 0.048485] bfa0: 00000000 00000000 00000000 00000000
[ 0.048495] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.048505] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 0.048514] r5:c09fe3d0 r4:00000000
[ 0.048525] ---[ end trace 6cf6c81409687e58 ]---
[ 0.049379] omap_hwmod: mcasp4: no dt node
[ 0.049387] ------------[ cut here ]------------
[ 0.049400] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.26+0x1bc/0x4d4
[ 0.049407] omap_hwmod: mcasp4: doesn't have mpu register target base
[ 0.049414] Modules linked in:
[ 0.049426] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.94-gbe5389fd85 #2
[ 0.049434] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 0.049440] Backtrace:
[ 0.049453] [<c020bbd8>] (dump_backtrace) from [<c020bea8>] (show_stack+0x18/0x1c)
[ 0.049464] r7:00000009 r6:60000013 r5:00000000 r4:c124cedc
[ 0.049475] [<c020be90>] (show_stack) from [<c09e8d44>] (dump_stack+0x98/0xac)
[ 0.049486] [<c09e8cac>] (dump_stack) from [<c022dca0>] (__warn+0x104/0x11c)
[ 0.049496] r7:00000009 r6:c0db142c r5:00000000 r4:ef07bddc
[ 0.049507] [<c022db9c>] (__warn) from [<c022dd04>] (warn_slowpath_fmt+0x4c/0x68)
[ 0.049517] r8:00000000 r7:c1210c48 r6:6198b9f2 r5:c0db1b20 r4:c1204c48
[ 0.049530] [<c022dcbc>] (warn_slowpath_fmt) from [<c100d070>] (_init.constprop.26+0x1bc/0x4d4)
[ 0.049538] r3:c0db3900 r2:c0db1b20
[ 0.049547] r6:c1204c48 r5:00000000 r4:c1210c10
[ 0.049561] [<c100ceb4>] (_init.constprop.26) from [<c100d4b8>] (__omap_hwmod_setup_all+0x48/0x134)
[ 0.049572] r10:00000003 r9:c1204c48 r8:ffffe000 r7:00000000 r6:c100d470 r5:c120a448
[ 0.049579] r4:c1210c10
[ 0.049592] [<c100d470>] (__omap_hwmod_setup_all) from [<c02025fc>] (do_one_initcall+0x5c/0x1a0)
[ 0.049601] r5:c12505c0 r4:c12505c0
[ 0.049614] [<c02025a0>] (do_one_initcall) from [<c1000ff8>] (kernel_init_freeable+0x1d4/0x26c)
[ 0.049625] r9:c1000620 r8:000000da r7:c1050824 r6:c1064800 r5:c12505c0 r4:c12505c0
[ 0.049639] [<c1000e24>] (kernel_init_freeable) from [<c09fe3e0>] (kernel_init+0x10/0x118)
[ 0.049649] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c09fe3d0
[ 0.049656] r4:00000000
[ 0.049668] [<c09fe3d0>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
[ 0.049676] Exception stack(0xef07bfb0 to 0xef07bff8)
[ 0.049685] bfa0: 00000000 00000000 00000000 00000000
[ 0.049695] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.049704] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 0.049713] r5:c09fe3d0 r4:00000000
[ 0.049721] ---[ end trace 6cf6c81409687e59 ]---
[ 0.050584] omap_hwmod: mcasp5: no dt node
[ 0.050593] ------------[ cut here ]------------
[ 0.050607] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.26+0x1bc/0x4d4
[ 0.050615] omap_hwmod: mcasp5: doesn't have mpu register target base
[ 0.050621] Modules linked in:
[ 0.050633] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.94-gbe5389fd85 #2
[ 0.050641] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 0.050648] Backtrace:
[ 0.050661] [<c020bbd8>] (dump_backtrace) from [<c020bea8>] (show_stack+0x18/0x1c)
[ 0.050672] r7:00000009 r6:60000013 r5:00000000 r4:c124cedc
[ 0.050683] [<c020be90>] (show_stack) from [<c09e8d44>] (dump_stack+0x98/0xac)
[ 0.050694] [<c09e8cac>] (dump_stack) from [<c022dca0>] (__warn+0x104/0x11c)
[ 0.050704] r7:00000009 r6:c0db142c r5:00000000 r4:ef07bddc
[ 0.050715] [<c022db9c>] (__warn) from [<c022dd04>] (warn_slowpath_fmt+0x4c/0x68)
[ 0.050726] r8:00000000 r7:c1210bcc r6:6198b9f2 r5:c0db1b20 r4:c1204c48
[ 0.050739] [<c022dcbc>] (warn_slowpath_fmt) from [<c100d070>] (_init.constprop.26+0x1bc/0x4d4)
[ 0.050747] r3:c0db38cc r2:c0db1b20
[ 0.050756] r6:c1204c48 r5:00000000 r4:c1210b94
[ 0.050770] [<c100ceb4>] (_init.constprop.26) from [<c100d4b8>] (__omap_hwmod_setup_all+0x48/0x134)
[ 0.050781] r10:00000003 r9:c1204c48 r8:ffffe000 r7:00000000 r6:c100d470 r5:c120a448
[ 0.050788] r4:c1210b94
[ 0.050801] [<c100d470>] (__omap_hwmod_setup_all) from [<c02025fc>] (do_one_initcall+0x5c/0x1a0)
[ 0.050810] r5:c12505c0 r4:c12505c0
[ 0.050823] [<c02025a0>] (do_one_initcall) from [<c1000ff8>] (kernel_init_freeable+0x1d4/0x26c)
[ 0.050834] r9:c1000620 r8:000000da r7:c1050824 r6:c1064800 r5:c12505c0 r4:c12505c0
[ 0.050847] [<c1000e24>] (kernel_init_freeable) from [<c09fe3e0>] (kernel_init+0x10/0x118)
[ 0.050858] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c09fe3d0
[ 0.050865] r4:00000000
[ 0.050877] [<c09fe3d0>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
[ 0.050885] Exception stack(0xef07bfb0 to 0xef07bff8)
[ 0.050894] bfa0: 00000000 00000000 00000000 00000000
[ 0.050903] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.050913] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 0.050921] r5:c09fe3d0 r4:00000000
[ 0.050929] ---[ end trace 6cf6c81409687e5a ]---
[ 0.051775] omap_hwmod: mcasp6: no dt node
[ 0.051783] ------------[ cut here ]------------
[ 0.051796] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.26+0x1bc/0x4d4
[ 0.051803] omap_hwmod: mcasp6: doesn't have mpu register target base
[ 0.051810] Modules linked in:
[ 0.051822] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.94-gbe5389fd85 #2
[ 0.051829] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 0.051836] Backtrace:
[ 0.051849] [<c020bbd8>] (dump_backtrace) from [<c020bea8>] (show_stack+0x18/0x1c)
[ 0.051859] r7:00000009 r6:60000013 r5:00000000 r4:c124cedc
[ 0.051871] [<c020be90>] (show_stack) from [<c09e8d44>] (dump_stack+0x98/0xac)
[ 0.051882] [<c09e8cac>] (dump_stack) from [<c022dca0>] (__warn+0x104/0x11c)
[ 0.051892] r7:00000009 r6:c0db142c r5:00000000 r4:ef07bddc
[ 0.051902] [<c022db9c>] (__warn) from [<c022dd04>] (warn_slowpath_fmt+0x4c/0x68)
[ 0.051913] r8:00000000 r7:c1210b50 r6:6198b9f2 r5:c0db1b20 r4:c1204c48
[ 0.051925] [<c022dcbc>] (warn_slowpath_fmt) from [<c100d070>] (_init.constprop.26+0x1bc/0x4d4)
[ 0.051934] r3:c0db3898 r2:c0db1b20
[ 0.051943] r6:c1204c48 r5:00000000 r4:c1210b18
[ 0.051956] [<c100ceb4>] (_init.constprop.26) from [<c100d4b8>] (__omap_hwmod_setup_all+0x48/0x134)
[ 0.051967] r10:00000003 r9:c1204c48 r8:ffffe000 r7:00000000 r6:c100d470 r5:c120a448
[ 0.051974] r4:c1210b18
[ 0.051987] [<c100d470>] (__omap_hwmod_setup_all) from [<c02025fc>] (do_one_initcall+0x5c/0x1a0)
[ 0.051995] r5:c12505c0 r4:c12505c0
[ 0.052009] [<c02025a0>] (do_one_initcall) from [<c1000ff8>] (kernel_init_freeable+0x1d4/0x26c)
[ 0.052020] r9:c1000620 r8:000000da r7:c1050824 r6:c1064800 r5:c12505c0 r4:c12505c0
[ 0.052033] [<c1000e24>] (kernel_init_freeable) from [<c09fe3e0>] (kernel_init+0x10/0x118)
[ 0.052044] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c09fe3d0
[ 0.052051] r4:00000000
[ 0.052062] [<c09fe3d0>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
[ 0.052070] Exception stack(0xef07bfb0 to 0xef07bff8)
[ 0.052079] bfa0: 00000000 00000000 00000000 00000000
[ 0.052089] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.052098] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 0.052107] r5:c09fe3d0 r4:00000000
[ 0.052114] ---[ end trace 6cf6c81409687e5b ]---
[ 0.052963] omap_hwmod: mcasp7: no dt node
[ 0.052970] ------------[ cut here ]------------
[ 0.052983] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.26+0x1bc/0x4d4
[ 0.052991] omap_hwmod: mcasp7: doesn't have mpu register target base
[ 0.052997] Modules linked in:
[ 0.053009] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.94-gbe5389fd85 #2
[ 0.053016] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 0.053023] Backtrace:
[ 0.053035] [<c020bbd8>] (dump_backtrace) from [<c020bea8>] (show_stack+0x18/0x1c)
[ 0.053045] r7:00000009 r6:60000013 r5:00000000 r4:c124cedc
[ 0.053056] [<c020be90>] (show_stack) from [<c09e8d44>] (dump_stack+0x98/0xac)
[ 0.053067] [<c09e8cac>] (dump_stack) from [<c022dca0>] (__warn+0x104/0x11c)
[ 0.053076] r7:00000009 r6:c0db142c r5:00000000 r4:ef07bddc
[ 0.053087] [<c022db9c>] (__warn) from [<c022dd04>] (warn_slowpath_fmt+0x4c/0x68)
[ 0.053097] r8:00000000 r7:c1210ad4 r6:6198b9f2 r5:c0db1b20 r4:c1204c48
[ 0.053110] [<c022dcbc>] (warn_slowpath_fmt) from [<c100d070>] (_init.constprop.26+0x1bc/0x4d4)
[ 0.053118] r3:c0db3864 r2:c0db1b20
[ 0.053127] r6:c1204c48 r5:00000000 r4:c1210a9c
[ 0.053141] [<c100ceb4>] (_init.constprop.26) from [<c100d4b8>] (__omap_hwmod_setup_all+0x48/0x134)
[ 0.053151] r10:00000003 r9:c1204c48 r8:ffffe000 r7:00000000 r6:c100d470 r5:c120a448
[ 0.053159] r4:c1210a9c
[ 0.053172] [<c100d470>] (__omap_hwmod_setup_all) from [<c02025fc>] (do_one_initcall+0x5c/0x1a0)
[ 0.053180] r5:c12505c0 r4:c12505c0
[ 0.053193] [<c02025a0>] (do_one_initcall) from [<c1000ff8>] (kernel_init_freeable+0x1d4/0x26c)
[ 0.053204] r9:c1000620 r8:000000da r7:c1050824 r6:c1064800 r5:c12505c0 r4:c12505c0
[ 0.053217] [<c1000e24>] (kernel_init_freeable) from [<c09fe3e0>] (kernel_init+0x10/0x118)
[ 0.053228] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c09fe3d0
[ 0.053235] r4:00000000
[ 0.053246] [<c09fe3d0>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
[ 0.053254] Exception stack(0xef07bfb0 to 0xef07bff8)
[ 0.053263] bfa0: 00000000 00000000 00000000 00000000
[ 0.053273] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.053282] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 0.053290] r5:c09fe3d0 r4:00000000
[ 0.053298] ---[ end trace 6cf6c81409687e5c ]---
[ 0.054152] omap_hwmod: mcasp8: no dt node
[ 0.054159] ------------[ cut here ]------------
[ 0.054173] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.26+0x1bc/0x4d4
[ 0.054180] omap_hwmod: mcasp8: doesn't have mpu register target base
[ 0.054186] Modules linked in:
[ 0.054197] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.94-gbe5389fd85 #2
[ 0.054205] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 0.054211] Backtrace:
[ 0.054224] [<c020bbd8>] (dump_backtrace) from [<c020bea8>] (show_stack+0x18/0x1c)
[ 0.054234] r7:00000009 r6:60000013 r5:00000000 r4:c124cedc
[ 0.054245] [<c020be90>] (show_stack) from [<c09e8d44>] (dump_stack+0x98/0xac)
[ 0.054256] [<c09e8cac>] (dump_stack) from [<c022dca0>] (__warn+0x104/0x11c)
[ 0.054266] r7:00000009 r6:c0db142c r5:00000000 r4:ef07bddc
[ 0.054277] [<c022db9c>] (__warn) from [<c022dd04>] (warn_slowpath_fmt+0x4c/0x68)
[ 0.054287] r8:00000000 r7:c1210a58 r6:6198b9f2 r5:c0db1b20 r4:c1204c48
[ 0.054300] [<c022dcbc>] (warn_slowpath_fmt) from [<c100d070>] (_init.constprop.26+0x1bc/0x4d4)
[ 0.054309] r3:c0db3828 r2:c0db1b20
[ 0.054317] r6:c1204c48 r5:00000000 r4:c1210a20
[ 0.054331] [<c100ceb4>] (_init.constprop.26) from [<c100d4b8>] (__omap_hwmod_setup_all+0x48/0x134)
[ 0.054342] r10:00000003 r9:c1204c48 r8:ffffe000 r7:00000000 r6:c100d470 r5:c120a448
[ 0.054349] r4:c1210a20
[ 0.054362] [<c100d470>] (__omap_hwmod_setup_all) from [<c02025fc>] (do_one_initcall+0x5c/0x1a0)
[ 0.054370] r5:c12505c0 r4:c12505c0
[ 0.054384] [<c02025a0>] (do_one_initcall) from [<c1000ff8>] (kernel_init_freeable+0x1d4/0x26c)
[ 0.054395] r9:c1000620 r8:000000da r7:c1050824 r6:c1064800 r5:c12505c0 r4:c12505c0
[ 0.054408] [<c1000e24>] (kernel_init_freeable) from [<c09fe3e0>] (kernel_init+0x10/0x118)
[ 0.054418] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c09fe3d0
[ 0.054425] r4:00000000
[ 0.054437] [<c09fe3d0>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
[ 0.054445] Exception stack(0xef07bfb0 to 0xef07bff8)
[ 0.054454] bfa0: 00000000 00000000 00000000 00000000
[ 0.054464] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.054473] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 0.054481] r5:c09fe3d0 r4:00000000
[ 0.054489] ---[ end trace 6cf6c81409687e5d ]---
[ 0.056107] omap_hwmod: dma_system: no dt node
[ 0.056115] ------------[ cut here ]------------
[ 0.056128] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.26+0x1bc/0x4d4
[ 0.056136] omap_hwmod: dma_system: doesn't have mpu register target base
[ 0.056142] Modules linked in:
[ 0.056154] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.94-gbe5389fd85 #2
[ 0.056161] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 0.056167] Backtrace:
[ 0.056180] [<c020bbd8>] (dump_backtrace) from [<c020bea8>] (show_stack+0x18/0x1c)
[ 0.056190] r7:00000009 r6:60000013 r5:00000000 r4:c124cedc
[ 0.056201] [<c020be90>] (show_stack) from [<c09e8d44>] (dump_stack+0x98/0xac)
[ 0.056212] [<c09e8cac>] (dump_stack) from [<c022dca0>] (__warn+0x104/0x11c)
[ 0.056221] r7:00000009 r6:c0db142c r5:00000000 r4:ef07bddc
[ 0.056232] [<c022db9c>] (__warn) from [<c022dd04>] (warn_slowpath_fmt+0x4c/0x68)
[ 0.056242] r8:00000000 r7:c121274c r6:6198b9f2 r5:c0db1b20 r4:c1204c48
[ 0.056255] [<c022dcbc>] (warn_slowpath_fmt) from [<c100d070>] (_init.constprop.26+0x1bc/0x4d4)
[ 0.056263] r3:c0db1eac r2:c0db1b20
[ 0.056272] r6:c1204c48 r5:00000000 r4:c1212714
[ 0.056286] [<c100ceb4>] (_init.constprop.26) from [<c100d4b8>] (__omap_hwmod_setup_all+0x48/0x134)
[ 0.056297] r10:00000003 r9:c1204c48 r8:ffffe000 r7:00000000 r6:c100d470 r5:c120a448
[ 0.056304] r4:c1212714
[ 0.056318] [<c100d470>] (__omap_hwmod_setup_all) from [<c02025fc>] (do_one_initcall+0x5c/0x1a0)
[ 0.056326] r5:c12505c0 r4:c12505c0
[ 0.056340] [<c02025a0>] (do_one_initcall) from [<c1000ff8>] (kernel_init_freeable+0x1d4/0x26c)
[ 0.056351] r9:c1000620 r8:000000da r7:c1050824 r6:c1064800 r5:c12505c0 r4:c12505c0
[ 0.056364] [<c1000e24>] (kernel_init_freeable) from [<c09fe3e0>] (kernel_init+0x10/0x118)
[ 0.056375] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c09fe3d0
[ 0.056382] r4:00000000
[ 0.056393] [<c09fe3d0>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
[ 0.056401] Exception stack(0xef07bfb0 to 0xef07bff8)
[ 0.056410] bfa0: 00000000 00000000 00000000 00000000
[ 0.056420] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.056429] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 0.056438] r5:c09fe3d0 r4:00000000
[ 0.056445] ---[ end trace 6cf6c81409687e5e ]---
[ 0.071100] omap_hwmod: hdq1w: no dt node
[ 0.071109] ------------[ cut here ]------------
[ 0.071123] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.26+0x1bc/0x4d4
[ 0.071131] omap_hwmod: hdq1w: doesn't have mpu register target base
[ 0.071138] Modules linked in:
[ 0.071151] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.94-gbe5389fd85 #2
[ 0.071158] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 0.071165] Backtrace:
[ 0.071179] [<c020bbd8>] (dump_backtrace) from [<c020bea8>] (show_stack+0x18/0x1c)
[ 0.071190] r7:00000009 r6:60000013 r5:00000000 r4:c124cedc
[ 0.071201] [<c020be90>] (show_stack) from [<c09e8d44>] (dump_stack+0x98/0xac)
[ 0.071212] [<c09e8cac>] (dump_stack) from [<c022dca0>] (__warn+0x104/0x11c)
[ 0.071222] r7:00000009 r6:c0db142c r5:00000000 r4:ef07bddc
[ 0.071234] [<c022db9c>] (__warn) from [<c022dd04>] (warn_slowpath_fmt+0x4c/0x68)
[ 0.071245] r8:00000000 r7:c12119e0 r6:6198b9f2 r5:c0db1b20 r4:c1204c48
[ 0.071259] [<c022dcbc>] (warn_slowpath_fmt) from [<c100d070>] (_init.constprop.26+0x1bc/0x4d4)
[ 0.071267] r3:c0db3b20 r2:c0db1b20
[ 0.071276] r6:c1204c48 r5:00000000 r4:c12119a8
[ 0.071290] [<c100ceb4>] (_init.constprop.26) from [<c100d4b8>] (__omap_hwmod_setup_all+0x48/0x134)
[ 0.071302] r10:00000003 r9:c1204c48 r8:ffffe000 r7:00000000 r6:c100d470 r5:c120a448
[ 0.071309] r4:c12119a8
[ 0.071322] [<c100d470>] (__omap_hwmod_setup_all) from [<c02025fc>] (do_one_initcall+0x5c/0x1a0)
[ 0.071331] r5:c12505c0 r4:c12505c0
[ 0.071345] [<c02025a0>] (do_one_initcall) from [<c1000ff8>] (kernel_init_freeable+0x1d4/0x26c)
[ 0.071356] r9:c1000620 r8:000000da r7:c1050824 r6:c1064800 r5:c12505c0 r4:c12505c0
[ 0.071369] [<c1000e24>] (kernel_init_freeable) from [<c09fe3e0>] (kernel_init+0x10/0x118)
[ 0.071381] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c09fe3d0
[ 0.071389] r4:00000000
[ 0.071400] [<c09fe3d0>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
[ 0.071409] Exception stack(0xef07bfb0 to 0xef07bff8)
[ 0.071418] bfa0: 00000000 00000000 00000000 00000000
[ 0.071428] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.071437] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 0.071446] r5:c09fe3d0 r4:00000000
[ 0.071454] ---[ end trace 6cf6c81409687e5f ]---
[ 0.098339] omap_hwmod: smartreflex_core: no dt node
[ 0.098348] ------------[ cut here ]------------
[ 0.098362] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.26+0x1bc/0x4d4
[ 0.098371] omap_hwmod: smartreflex_core: doesn't have mpu register target base
[ 0.098378] Modules linked in:
[ 0.098390] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.94-gbe5389fd85 #2
[ 0.098398] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 0.098405] Backtrace:
[ 0.098419] [<c020bbd8>] (dump_backtrace) from [<c020bea8>] (show_stack+0x18/0x1c)
[ 0.098430] r7:00000009 r6:60000013 r5:00000000 r4:c124cedc
[ 0.098442] [<c020be90>] (show_stack) from [<c09e8d44>] (dump_stack+0x98/0xac)
[ 0.098453] [<c09e8cac>] (dump_stack) from [<c022dca0>] (__warn+0x104/0x11c)
[ 0.098464] r7:00000009 r6:c0db142c r5:00000000 r4:ef07bddc
[ 0.098475] [<c022db9c>] (__warn) from [<c022dd04>] (warn_slowpath_fmt+0x4c/0x68)
[ 0.098486] r8:00000000 r7:c120fee8 r6:6198b9f2 r5:c0db1b20 r4:c1204c48
[ 0.098499] [<c022dcbc>] (warn_slowpath_fmt) from [<c100d070>] (_init.constprop.26+0x1bc/0x4d4)
[ 0.098508] r3:c0db3660 r2:c0db1b20
[ 0.098516] r6:c1204c48 r5:00000000 r4:c120feb0
[ 0.098530] [<c100ceb4>] (_init.constprop.26) from [<c100d4b8>] (__omap_hwmod_setup_all+0x48/0x134)
[ 0.098541] r10:00000003 r9:c1204c48 r8:ffffe000 r7:00000000 r6:c100d470 r5:c120a448
[ 0.098549] r4:c120feb0
[ 0.098562] [<c100d470>] (__omap_hwmod_setup_all) from [<c02025fc>] (do_one_initcall+0x5c/0x1a0)
[ 0.098570] r5:c12505c0 r4:c12505c0
[ 0.098584] [<c02025a0>] (do_one_initcall) from [<c1000ff8>] (kernel_init_freeable+0x1d4/0x26c)
[ 0.098595] r9:c1000620 r8:000000da r7:c1050824 r6:c1064800 r5:c12505c0 r4:c12505c0
[ 0.098609] [<c1000e24>] (kernel_init_freeable) from [<c09fe3e0>] (kernel_init+0x10/0x118)
[ 0.098619] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c09fe3d0
[ 0.098626] r4:00000000
[ 0.098637] [<c09fe3d0>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
[ 0.098646] Exception stack(0xef07bfb0 to 0xef07bff8)
[ 0.098655] bfa0: 00000000 00000000 00000000 00000000
[ 0.098664] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.098674] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 0.098682] r5:c09fe3d0 r4:00000000
[ 0.098690] ---[ end trace 6cf6c81409687e60 ]---
[ 0.099533] omap_hwmod: smartreflex_mpu: no dt node
[ 0.099541] ------------[ cut here ]------------
[ 0.099554] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.26+0x1bc/0x4d4
[ 0.099562] omap_hwmod: smartreflex_mpu: doesn't have mpu register target base
[ 0.099569] Modules linked in:
[ 0.099580] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.94-gbe5389fd85 #2
[ 0.099587] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 0.099594] Backtrace:
[ 0.099608] [<c020bbd8>] (dump_backtrace) from [<c020bea8>] (show_stack+0x18/0x1c)
[ 0.099619] r7:00000009 r6:60000013 r5:00000000 r4:c124cedc
[ 0.099630] [<c020be90>] (show_stack) from [<c09e8d44>] (dump_stack+0x98/0xac)
[ 0.099640] [<c09e8cac>] (dump_stack) from [<c022dca0>] (__warn+0x104/0x11c)
[ 0.099651] r7:00000009 r6:c0db142c r5:00000000 r4:ef07bddc
[ 0.099662] [<c022db9c>] (__warn) from [<c022dd04>] (warn_slowpath_fmt+0x4c/0x68)
[ 0.099673] r8:00000000 r7:c120fe74 r6:6198b9f2 r5:c0db1b20 r4:c1204c48
[ 0.099686] [<c022dcbc>] (warn_slowpath_fmt) from [<c100d070>] (_init.constprop.26+0x1bc/0x4d4)
[ 0.099694] r3:c0db3650 r2:c0db1b20
[ 0.099703] r6:c1204c48 r5:00000000 r4:c120fe3c
[ 0.099717] [<c100ceb4>] (_init.constprop.26) from [<c100d4b8>] (__omap_hwmod_setup_all+0x48/0x134)
[ 0.099728] r10:00000003 r9:c1204c48 r8:ffffe000 r7:00000000 r6:c100d470 r5:c120a448
[ 0.099735] r4:c120fe3c
[ 0.099748] [<c100d470>] (__omap_hwmod_setup_all) from [<c02025fc>] (do_one_initcall+0x5c/0x1a0)
[ 0.099757] r5:c12505c0 r4:c12505c0
[ 0.099770] [<c02025a0>] (do_one_initcall) from [<c1000ff8>] (kernel_init_freeable+0x1d4/0x26c)
[ 0.099781] r9:c1000620 r8:000000da r7:c1050824 r6:c1064800 r5:c12505c0 r4:c12505c0
[ 0.099794] [<c1000e24>] (kernel_init_freeable) from [<c09fe3e0>] (kernel_init+0x10/0x118)
[ 0.099805] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c09fe3d0
[ 0.099812] r4:00000000
[ 0.099823] [<c09fe3d0>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
[ 0.099831] Exception stack(0xef07bfb0 to 0xef07bff8)
[ 0.099840] bfa0: 00000000 00000000 00000000 00000000
[ 0.099850] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.099860] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 0.099869] r5:c09fe3d0 r4:00000000
[ 0.099876] ---[ end trace 6cf6c81409687e61 ]---
[ 0.128552] omap_hwmod: vip2: no dt node
[ 0.128561] ------------[ cut here ]------------
[ 0.128577] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.26+0x1bc/0x4d4
[ 0.128585] omap_hwmod: vip2: doesn't have mpu register target base
[ 0.128593] Modules linked in:
[ 0.128605] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.94-gbe5389fd85 #2
[ 0.128614] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 0.128621] Backtrace:
[ 0.128635] [<c020bbd8>] (dump_backtrace) from [<c020bea8>] (show_stack+0x18/0x1c)
[ 0.128646] r7:00000009 r6:60000013 r5:00000000 r4:c124cedc
[ 0.128657] [<c020be90>] (show_stack) from [<c09e8d44>] (dump_stack+0x98/0xac)
[ 0.128669] [<c09e8cac>] (dump_stack) from [<c022dca0>] (__warn+0x104/0x11c)
[ 0.128679] r7:00000009 r6:c0db142c r5:00000000 r4:ef07bddc
[ 0.128690] [<c022db9c>] (__warn) from [<c022dd04>] (warn_slowpath_fmt+0x4c/0x68)
[ 0.128701] r8:00000000 r7:c1212e7c r6:6198b9f2 r5:c0db1b20 r4:c1204c48
[ 0.128714] [<c022dcbc>] (warn_slowpath_fmt) from [<c100d070>] (_init.constprop.26+0x1bc/0x4d4)
[ 0.128723] r3:c0db3da4 r2:c0db1b20
[ 0.128732] r6:c1204c48 r5:00000000 r4:c1212e44
[ 0.128746] [<c100ceb4>] (_init.constprop.26) from [<c100d4b8>] (__omap_hwmod_setup_all+0x48/0x134)
[ 0.128757] r10:00000003 r9:c1204c48 r8:ffffe000 r7:00000000 r6:c100d470 r5:c120a448
[ 0.128764] r4:c1212e44
[ 0.128778] [<c100d470>] (__omap_hwmod_setup_all) from [<c02025fc>] (do_one_initcall+0x5c/0x1a0)
[ 0.128787] r5:c12505c0 r4:c12505c0
[ 0.128801] [<c02025a0>] (do_one_initcall) from [<c1000ff8>] (kernel_init_freeable+0x1d4/0x26c)
[ 0.128812] r9:c1000620 r8:000000da r7:c1050824 r6:c1064800 r5:c12505c0 r4:c12505c0
[ 0.128826] [<c1000e24>] (kernel_init_freeable) from [<c09fe3e0>] (kernel_init+0x10/0x118)
[ 0.128836] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c09fe3d0
[ 0.128843] r4:00000000
[ 0.128855] [<c09fe3d0>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
[ 0.128863] Exception stack(0xef07bfb0 to 0xef07bff8)
[ 0.128872] bfa0: 00000000 00000000 00000000 00000000
[ 0.128881] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.128891] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 0.128899] r5:c09fe3d0 r4:00000000
[ 0.128907] ---[ end trace 6cf6c81409687e62 ]---
[ 0.217452] cpuidle: using governor ladder
[ 0.217488] cpuidle: using governor menu
[ 0.223991] OMAP GPIO hardware version 0.1
[ 0.228347] OF: /ocp/serial@4806c000: could not get #interrupt-cells for /ocp/l4@4a000000/cm_core_aon@5000/clocks/atl_clkin2_ck
[ 0.228598] OF: /ocp/serial@48020000: could not get #interrupt-cells for /ocp/l4@4a000000/cm_core_aon@5000/clocks/atl_clkin1_ck
[ 0.228862] OF: /ocp/serial@4806e000: could not get #interrupt-cells for /ocp/l4@4ae00000/prm@6000/clocks/abe_sys_clk_div@120
[ 0.229113] OF: /ocp/serial@48066000: could not get #interrupt-cells for /ocp/l4@4a000000/cm_core@8000/clocks/dpll_per_m2_ck@150
[ 0.229368] OF: /ocp/serial@48068000: could not get #interrupt-cells for /ocp/l4@4a000000/cm_core_aon@5000/clocks/usb_dpll_hs_clk_div
[ 0.229622] OF: /ocp/serial@48420000: could not get #interrupt-cells for /ocp/l4@4a000000/scm@2000/pinmux@1400/i2c2_pins_default
[ 0.229876] OF: /ocp/serial@48422000: could not get #interrupt-cells for /ocp/l4@4a000000/scm@2000/pinmux@1400/i2c3_pins_default
[ 0.230157] OF: /ocp/serial@48424000: could not get #interrupt-cells for /ocp/l4@4a000000/scm@2000/pinmux@1400/i2c5_pins_default
[ 0.249060] No ATAGs?
[ 0.249156] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.249172] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.249204] omap_device: omap_dma_system: build failed (-22)
[ 0.249214] omap2_system_dma_init_dev: Can't build omap_device for omap_dma_system:dma_system.
[ 0.260463] edma 43300000.edma: memcpy is disabled
[ 0.263769] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.267893] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.268058] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.268280] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.268510] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.268873] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 0.269028] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 0.269278] iommu: Adding device 58820000.ipu to group 1
[ 0.269355] iommu: Adding device 55020000.ipu to group 2
[ 0.269465] iommu: Adding device 40800000.dsp to group 0
[ 0.269690] iommu: Adding device 41000000.dsp to group 3
[ 0.270940] SCSI subsystem initialized
[ 0.271103] usbcore: registered new interface driver usbfs
[ 0.271151] usbcore: registered new interface driver hub
[ 0.271211] usbcore: registered new device driver usb
[ 0.272047] palmas 0-0058: Irq flag is 0x00000008
[ 0.302874] palmas 0-0058: Muxing GPIO 2b, PWM 0, LED 0
[ 0.305023] SMPS12: supplied by regulator-dummy
[ 0.306594] SMPS3: supplied by regulator-dummy
[ 0.306926] smps3: Bringing 1500000uV into 1350000-1350000uV
[ 0.308882] SMPS45: supplied by regulator-dummy
[ 0.309227] smps45: Bringing 1170000uV into 1060000-1060000uV
[ 0.311278] SMPS6: supplied by regulator-dummy
[ 0.312830] SMPS7: supplied by regulator-dummy
[ 0.314302] random: fast init done
[ 0.314559] SMPS8: supplied by regulator-dummy
[ 0.315720] SMPS9: supplied by regulator-dummy
[ 0.316362] LDO1: supplied by regulator-dummy
[ 0.324418] LDO2: supplied by regulator-dummy
[ 0.334295] LDO3: supplied by regulator-dummy
[ 0.344306] LDO4: supplied by regulator-dummy
[ 0.354329] LDO5: supplied by regulator-dummy
[ 0.354969] LDO6: supplied by regulator-dummy
[ 0.355609] LDO7: supplied by regulator-dummy
[ 0.356244] LDO8: supplied by regulator-dummy
[ 0.356896] LDO9: supplied by regulator-dummy
[ 0.364350] LDOLN: supplied by regulator-dummy
[ 0.374372] LDOUSB: supplied by regulator-dummy
[ 0.386574] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.387148] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz
[ 0.387379] media: Linux media interface: v0.10
[ 0.387418] videodev: Linux video capture interface: v2.00
[ 0.387489] pps_core: LinuxPPS API ver. 1 registered
[ 0.387498] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.387518] PTP clock support registered
[ 0.387547] EDAC MC: Ver: 3.0.0
[ 0.388265] omap-mailbox 4883c000.mailbox: omap mailbox rev 0x400
[ 0.388503] omap-mailbox 4883e000.mailbox: omap mailbox rev 0x400
[ 0.388731] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.388953] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.389299] Advanced Linux Sound Architecture Driver Initialized.
[ 0.390060] clocksource: Switched to clocksource arch_sys_counter
[ 0.397591] NET: Registered protocol family 2
[ 0.398120] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.398149] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.398212] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.398338] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.398408] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.398442] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.398568] NET: Registered protocol family 1
[ 0.398934] RPC: Registered named UNIX socket transport module.
[ 0.398944] RPC: Registered udp transport module.
[ 0.398953] RPC: Registered tcp transport module.
[ 0.398960] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.399935] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 0.400151] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.401102] Initialise system trusted keyrings
[ 0.401224] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.405946] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.406388] NFS: Registering the id_resolver key type
[ 0.406410] Key type id_resolver registered
[ 0.406419] Key type id_legacy registered
[ 0.406458] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.408067] Key type asymmetric registered
[ 0.408079] Asymmetric key parser 'x509' registered
[ 0.408125] bounce: pool size: 64 pages
[ 0.408157] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.408168] io scheduler noop registered
[ 0.408177] io scheduler deadline registered
[ 0.408269] io scheduler cfq registered (default)
[ 0.408279] io scheduler mq-deadline registered
[ 0.408288] io scheduler kyber registered
[ 0.411159] phy phy-4a084000.phy.0: Linked as a consumer to regulator.22
[ 0.411426] phy phy-4a085000.phy.1: Linked as a consumer to regulator.22
[ 0.413603] pinctrl-single 4a003400.pinmux: 282 pins, size 1128
[ 0.417669] dra7-pcie 51000000.pcie: Linked as a consumer to phy-4a094000.pciephy.3
[ 0.417856] dra7-pcie 51000000.pcie: WA for Errata i870 not applied
[ 0.417939] dra7-pcie 51000000.pcie: host bridge /ocp/axi@0/pcie@51000000 ranges:
[ 0.417955] dra7-pcie 51000000.pcie: No bus range found for /ocp/axi@0/pcie@51000000, using [bus 00-ff]
[ 0.417990] dra7-pcie 51000000.pcie: IO 0x20003000..0x20012fff -> 0x00000000
[ 0.418020] dra7-pcie 51000000.pcie: MEM 0x20013000..0x2fffffff -> 0x20013000
[ 1.418299] dra7-pcie 51000000.pcie: Phy link never came up
[ 1.418429] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[ 1.418443] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.418455] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 1.418466] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[ 1.425119] PCI: bus0: Fast back to back transfers disabled
[ 1.431318] PCI: bus1: Fast back to back transfers enabled
[ 1.431359] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff 64bit]
[ 1.431379] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 1.431687] pcieport 0000:00:00.0: Signaling PME with IRQ 195
[ 1.431814] pcieport 0000:00:00.0: AER enabled with IRQ 195
[ 1.432948] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 1.433020] pwm-backlight backlight: Linked as a consumer to regulator.0
[ 1.435695] vdd_3v3: supplied by regen1
[ 1.435923] aic_dvdd_fixed: supplied by vdd_3v3
[ 1.435981] vtt_fixed: supplied by smps3
[ 1.480348] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 1.483024] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 45, base_baud = 3000000) is a 8250
[ 1.483305] OF: /ocp/serial@4806c000: could not get #interrupt-cells for /ocp/l4@4a000000/cm_core_aon@5000/clocks/atl_clkin2_ck
[ 1.483841] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 46, base_baud = 3000000) is a 8250
[ 1.484107] OF: /ocp/serial@48020000: could not get #interrupt-cells for /ocp/l4@4a000000/cm_core_aon@5000/clocks/atl_clkin1_ck
[ 1.484614] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 47, base_baud = 3000000) is a 8250
[ 5.231444] console [ttyS2] enabled
[ 5.235231] OF: /ocp/serial@4806e000: could not get #interrupt-cells for /ocp/l4@4ae00000/prm@6000/clocks/abe_sys_clk_div@120
[ 5.247129] 4806e000.serial: ttyS3 at MMIO 0x4806e000 (irq = 48, base_baud = 3000000) is a 8250
[ 5.256161] OF: /ocp/serial@48066000: could not get #interrupt-cells for /ocp/l4@4a000000/cm_core@8000/clocks/dpll_per_m2_ck@150
[ 5.268313] 48066000.serial: ttyS4 at MMIO 0x48066000 (irq = 49, base_baud = 3000000) is a 8250
[ 5.277346] OF: /ocp/serial@48068000: could not get #interrupt-cells for /ocp/l4@4a000000/cm_core_aon@5000/clocks/usb_dpll_hs_clk_div
[ 5.289936] 48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 50, base_baud = 3000000) is a 8250
[ 5.298965] OF: /ocp/serial@48420000: could not get #interrupt-cells for /ocp/l4@4a000000/scm@2000/pinmux@1400/i2c2_pins_default
[ 5.311133] 48420000.serial: ttyS6 at MMIO 0x48420000 (irq = 51, base_baud = 3000000) is a 8250
[ 5.320152] OF: /ocp/serial@48422000: could not get #interrupt-cells for /ocp/l4@4a000000/scm@2000/pinmux@1400/i2c3_pins_default
[ 5.332313] 48422000.serial: ttyS7 at MMIO 0x48422000 (irq = 52, base_baud = 3000000) is a 8250
[ 5.341324] OF: /ocp/serial@48424000: could not get #interrupt-cells for /ocp/l4@4a000000/scm@2000/pinmux@1400/i2c5_pins_default
[ 5.353492] 48424000.serial: ttyS8 at MMIO 0x48424000 (irq = 53, base_baud = 3000000) is a 8250
[ 5.363032] 4ae2b000.serial: ttyS9 at MMIO 0x4ae2b000 (irq = 54, base_baud = 3000000) is a 8250
[ 5.373797] omap_rng 48090000.rng: Random Number Generator ver. 20
[ 5.374261] random: crng init done
[ 5.384021] omapdss_dss 58000000.dss: Linked as a consumer to regulator.21
[ 5.391155] omapdss_dss 58000000.dss: Dropping the link to regulator.21
[ 5.406696] brd: module loaded
[ 5.415755] loop: module loaded
[ 5.447299] ti-qspi 4b300000.qspi: No Rx DMA available, trying mmap mode
[ 5.455288] libphy: Fixed MDIO Bus: probed
[ 5.462189] dwc3 48890000.usb: Failed to get clk 'ref': -2
[ 5.470374] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 5.475907] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 5.483869] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010
[ 5.493359] xhci-hcd xhci-hcd.0.auto: irq 197, io mem 0x48890000
[ 5.500214] hub 1-0:1.0: USB hub found
[ 5.504018] hub 1-0:1.0: 1 port detected
[ 5.508277] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 5.513820] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 5.521534] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 5.528188] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 5.536900] hub 2-0:1.0: USB hub found
[ 5.540718] hub 2-0:1.0: 1 port detected
[ 5.545067] usbcore: registered new interface driver usb-storage
[ 5.580314] rtc-ds1307: probe of 3-006f failed with error -121
[ 5.586212] i2c /dev entries driver
[ 5.591809] tmp102 0-0048: error reading config register
[ 5.597230] tmp102: probe of 0-0048 failed with error -121
[ 5.603770] cpu cpu0: "syscon" is missing, cannot use OPPv2 table.
[ 5.611136] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
[ 5.619964] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 5.624851] omap_hsmmc 4809c000.mmc: RX DMA channel request failed
[ 5.631777] omap_hsmmc 480b4000.mmc: RX DMA channel request failed
[ 5.639531] ledtrig-cpu: registered to indicate activity on CPUs
[ 5.648653] NET: Registered protocol family 10
[ 5.653882] Segment Routing with IPv6
[ 5.657621] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 5.664054] NET: Registered protocol family 17
[ 5.668713] Key type dns_resolver registered
[ 5.673163] Registering SWP/SWPB emulation handler
[ 5.677978] omap_voltage_late_init: Voltage driver support not added
[ 5.684374] Power Management for TI OMAP4+ devices.
[ 5.689971] Loading compiled-in X.509 certificates
[ 5.710785] dmm 4e000000.dmm: failed to initialize work-around for i878
[ 5.718916] dmm 4e000000.dmm: initialized all PAT entries
[ 5.725931] omap_i2c 48072000.i2c: bus 1 rev0.12 at 100 kHz
[ 5.732388] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
[ 5.738477] omapdss_dss 58000000.dss: Linked as a consumer to regulator.21
[ 5.745603] omapdss_dss 58000000.dss: Dropping the link to regulator.21
[ 5.753352] omapdss_dss 58000000.dss: Linked as a consumer to regulator.21
[ 5.760441] omapdss_dss 58000000.dss: Dropping the link to regulator.21
[ 5.768207] hctosys: unable to open rtc device (rtc0)
[ 5.774115] ALSA device list:
[ 5.777097] No soundcards found.
[ 5.781194] Waiting for root device PARTUUID=9c1fae8a-02...
[ 5.900077] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 6.136292] hub 1-1:1.0: USB hub found
[ 6.140137] hub 1-1:1.0: 4 ports detected
[ 6.201292] omapdss_dss 58000000.dss: Linked as a consumer to regulator.21
[ 6.208374] omapdss_dss 58000000.dss: Dropping the link to regulator.21
[ 6.230124] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[ 6.280275] hub 2-1:1.0: USB hub found
[ 6.284100] hub 2-1:1.0: 4 ports detected
[ 6.291385] omapdss_dss 58000000.dss: Linked as a consumer to regulator.21
[ 6.298444] omapdss_dss 58000000.dss: Dropping the link to regulator.21
[ 6.520075] usb 1-1.1: new high-speed USB device number 3 using xhci-hcd
[ 6.714909] omapdss_dss 58000000.dss: Linked as a consumer to regulator.21
[ 6.722174] omapdss_dss 58000000.dss: Dropping the link to regulator.21
[ 6.820074] usb 1-1.2: new high-speed USB device number 4 using xhci-hcd
[ 7.002918] omapdss_dss 58000000.dss: Linked as a consumer to regulator.21
[ 7.009983] omapdss_dss 58000000.dss: Dropping the link to regulator.21
[ 7.110077] usb 1-1.3: new high-speed USB device number 5 using xhci-hcd
[ 7.290923] omapdss_dss 58000000.dss: Linked as a consumer to regulator.21
[ 7.297977] omapdss_dss 58000000.dss: Dropping the link to regulator.21
[ 7.400078] usb 1-1.4: new high-speed USB device number 6 using xhci-hcd
[ 7.578919] omapdss_dss 58000000.dss: Linked as a consumer to regulator.21
[ 7.586000] omapdss_dss 58000000.dss: Dropping the link to regulator.21
[ 36.330089] aic_dvdd_fixed: disabling
[ 36.333774] vmmcwl_fixed: disabling
[ 36.337299] pbias_mmc_omap5: disabling
这里好像是emmc未识别到,导致文件系统无法加载,请问应该如何解决,换成4.9的版本内核没有问题
