Part Number: TMS320C6748
配置文件代码:
var Defaults = xdc.useModule('xdc.runtime.Defaults');
var Diags = xdc.useModule('xdc.runtime.Diags');
var Error = xdc.useModule('xdc.runtime.Error');
var Log = xdc.useModule('xdc.runtime.Log');
var LoggerBuf = xdc.useModule('xdc.runtime.LoggerBuf');
var Main = xdc.useModule('xdc.runtime.Main');
var Memory = xdc.useModule('xdc.runtime.Memory')
var SysMin = xdc.useModule('xdc.runtime.SysMin');
var System = xdc.useModule('xdc.runtime.System');
var Text = xdc.useModule('xdc.runtime.Text');
var BIOS = xdc.useModule('ti.sysbios.BIOS');
var Clock = xdc.useModule('ti.sysbios.knl.Clock');
var Swi = xdc.useModule('ti.sysbios.knl.Swi');
var Task = xdc.useModule('ti.sysbios.knl.Task');
var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore');
var Hwi = xdc.useModule('ti.sysbios.hal.Hwi');
var LoggerRunMode = xdc.useModule('ti.uia.loggers.LoggerRunMode');
var LoggingSetup = xdc.useModule('ti.uia.sysbios.LoggingSetup');
* Minimize exit handler array in System. The System module includes
* an array of functions that are registered with System_atexit() to be
* called by System_exit().
System.maxAtexitHandlers = 4;
* The BIOS module will create the default heap for the system.
* Specify the size of this default heap.
BIOS.heapSize = 0x1000;
* Build a custom SYS/BIOS library from sources.
BIOS.libType = BIOS.LibType_Custom;
/* System stack size (used by ISRs and Swis) */
Program.stack = 0x2000;
/* Circular buffer size for System_printf() */
SysMin.bufSize = 0x200;
* Create and install logger for the whole system
var loggerBufParams = new LoggerBuf.Params();
loggerBufParams.numEntries = 16;
var logger0 = LoggerBuf.create(loggerBufParams);
Defaults.common$.logger = logger0;
Main.common$.diags_INFO = Diags.ALWAYS_ON;
System.SupportProxy = SysMin;
LoggingSetup.sysbiosSwiLogging = true;
LoggingSetup.sysbiosSemaphoreLogging = true;
LoggingSetup.loggerType = LoggingSetup.LoggerType_JTAGRUNMODE;
var task0Params = new Task.Params();
task0Params.instance.name = "task0";
Program.global.task0 = Task.create("&fun_task0", task0Params);
var task1Params = new Task.Params();
task1Params.instance.name = "task1";
Program.global.task1 = Task.create("&fun_task1", task1Params);
main文件代码:
#include <xdc/std.h>
#include <xdc/runtime/System.h>
#include <ti/sysbios/BIOS.h>
#include <xdc/runtime/Log.h>
#include <ti/sysbios/knl/Task.h>
* ======== main ========
void fun_task0(void);
void fun_task1(void);
Void main()
System_printf("hello world\n");
BIOS_start();
Int count = 0;
while(count<10)
Log_info1("Task0 is doing %d\n",count);
Task_yield();
count++;
BIOS_exit(0);
Int count = 0;
while(count<10)
Log_info1("Task1 is doing %d\n",count);
Task_yield();
count++;
BIOS_exit(0);
运行结果:
System_printf有结果,Log在printf窗口没有结果输出
请问有没有修改建议?
