Other Parts Discussed in Thread: PCM3168A
Arago 2021.09 j7-evm ttyS2
j7-evm login: root
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~# /opt/vision_apps# dmesg | grep rpmsg
-sh: /opt/vision_apps#: No such file or directory
root@j7-evm:~# cd /opt/vision_apps
root@j7-evm:/opt/vision_apps# dmesg | grep rpmsg
[ 11.637265] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 12.079137] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 12.097202] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
[ 12.097357] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
[ 12.131007] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 12.146006] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
root@j7-evm:/opt/vision_apps# [ 140.469551] Initializing XFRM netlink socket
[ 141.920365] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update you.
[ 141.923246] Bridge firewalling registered
[ 142.527194] process 'docker/tmp/qemu-check185105001/check' started with executable stack
root@j7-evm:/opt/vision_apps# source ./vision_apps_init.sh
root@j7-evm:/opt/vision_apps# APP_LOG: ERROR: Unable to map memory @ 0xb2000000 of size 262144 byte!
